Local Time 06:56 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Converting a single precision float to double in Basic
Posted: 11:35am 20 Jun 2024
In another thread a reading from a sensor was returning a single precision floating point number.
This post shows how to convert this to a standard MMBasic double with a bit of of simple bit-twiddling.
Option explicit
Option default none
Dim w%,s$,c%,d%,e%,o%,a!,i!
Input "Enter a single precision FP number as hex and the expected answer";s$,i!
If Left$(s$,2)<>"&H" Then s$="&H"+s$
Poke word Peek(varaddr w%),Val(s$) 'store the single precision floating point
c%=(w% And &H80000000)<<32 'get the sign bit
d%=(w% And &h7FFFFF)<<29 'get the mantissa
e%=(((w% And &H7f800000)>>23)-127+1023)<<52 'get the exponent and convert
o%=(c% Or d% Or e%)
Poke integer Peek(varaddr a!),o% 'put the answer into a double
Print "Double precision", a!
CaptainBoing
Posted: 11:42am 20 Jun 2024
hero! is it any wonder we love him so!
seriously, great work!
Fill yer boots Stan!
h
Edited 2024-06-20 21:44 by CaptainBoing
Posted: 06:00pm 20 Jun 2024
In case it isn't clear, the algorithm is as follows:
Move the sign bit (bit31) from the float to the sign bit (bit63) in the double
Move the mantissa (bits0-22) from the float to bits29-51 in the double
The only remotely complex piece is the handling of the exponent
Bits23-30 are the exponent in the float (coded 0-255) and we have to subtract 127 to get the actual exponent -127 to 128
Bits52-62 are the exponent in the double (coded 0-2047) so we have to add 1023 to the actual float exponent to get the coded double exponent
hence given a integer variable in memory w% holding the 32-bit float:
o%=(c% Or d% Or e%)
will create an integer o% in memory holding the 64-bit double
Then this can be copied into a floating point variable a! using
Edited 2024-06-21 04:04 by matherp
stanleyella
Posted: 08:32pm 20 Jun 2024
er.. still don't understand, like logs when I was 15 or tables of pi, trig was hard to.
nice of @matherp to post the conversion code and explain the idea.
what's with using peek and poke? it's like picaxe but seems to have become normal in mmb but where's it say why? noticed mmb is getting more complicated? hate to be a new user.
Posted: 09:17pm 20 Jun 2024
PEEK and POKE are powerful and very useful in MMBasic. Peter is using them to copy just part of one number into a new one. It's no use simply copying the number as he is converting the original format into a different one.
Posted: 09:28pm 20 Jun 2024
Stan,
The internal encodings of single & double (IEEE) floating point numbers are fairly similar but need some adjusting to convert from single to double.  Peter's code does the magic needed.  It's a bit ugly looking but hey MMBasic was never designed to do it - and you can just grab the code :)
zeitfest
Posted: 12:05am 21 Jun 2024
There is a function CDBL in standard Basic for it,
see CDBL in this ref
Edited 2024-06-21 10:06 by zeitfest
Posted: 05:11am 21 Jun 2024
Peter,
Thanks for the explanation. I was mistaken about the exponent.
Posted: 07:57am 21 Jun 2024
  zeitfest said  There is a function CDBL in standard Basic for it,
So something like (untested!)
Option explicit
Option default none
function CDBL(s$)
local w%,c%,d%,e%,o%,a!
o%=(c% Or d% Or e%)
CDBL=a!
end function
but you pass in the 4 hex bytes of the single-precision number as a string
Posted: 08:05am 21 Jun 2024
"Standard BASIC"? What a strange concept. :) There ain't never been no such thing. The original BASIC (Dartmouth) had a single floating point precision for everything:
  Quote  All arithmetic was done in floating point. In the GE-225 and GE-235, this meant a precision of about 30 bits (roughly ten digits) with an base 2 exponent range of -256 to +255.
Since then all the BASICs have been non-standard. :)
Dartmouth BASIC commands
CaptainBoing
Posted: 08:26am 21 Jun 2024
function CDBL(s$)
end function
A candidate for inclusion on FotS
h
Edited 2024-06-21 18:39 by CaptainBoing
Posted: 08:39am 21 Jun 2024
function CDBL(s$) tested and gives same results as Peter's original post.
stanleyella
Posted: 05:33pm 21 Jun 2024
basic in the 80's, many manufacturers basic, for pic picaxe,gcbasic,mmbasic ,
converting code is difficult imho.
Posted: 05:53pm 21 Jun 2024
Converting between BASICs becomes more difficult the further away you move from Dartmouth BASIC. That defined the fundamental commands that are common to just about all of them (if you exclude the Tiny BASICs, which are specialised to run on low memory systems).
Posted: 05:59pm 21 Jun 2024
  phil99 said  function CDBL(s$) tested and gives same results as Peter's original post.
Thanks!
CaptainBoing
Posted: 07:55pm 21 Jun 2024
I never had a problem converting between dialects or even languages (within reason)... machine level stuff like PEEKs and POKEs, embedded machine code and calls into the firmware are really the only thing that gets in the way. If the "donor" code sticks to the basics (ha ha) then I consider it to be an enjoyable canter.
When I was a much younger programmer in simpler times (early-middle 80s), one of my favourite things was to hand-compile. Get a program working right in Basic, then convert it line by line to assembler optimizing along the way. The other day, I was looking at some met radar processing stuff I did 38 years ago and the tell-tale was jump destinations like L270, L390 etc. Floating point stuff and everything. You ended up with the same prog but very much faster plus things you couldn't do easily in the supplied Basic
h
PhenixRising
Posted: 08:22pm 21 Jun 2024
h
This is the kinda stuff I like to read about
stanleyella
Posted: 08:53pm 21 Jun 2024
siclair basic and bbc basic, very different yet one was used in schools and the other home,cost.
disco4now
Posted: 12:20am 22 Jun 2024
  Quote  A candidate for inclusion on FotS
I have already added to page for it. Mostly just points to this thread at the moment. I also have a need to go the other way, sending the value in a double precision float to a CAN bus controlled power supply  which expects 4 bytes coded as a single precision float.
Gerry
FotS Page
P.S.
Any potential FotS authors just send me a PM and I will create an account. Include your email if its not already in your TBS member details as FotS  will automatically send the password.
Edited 2024-06-22 10:46 by disco4now
F4 H7FotSF4xGT
CaptainBoing
Posted: 06:04am 22 Jun 2024
It would be a shame to "lose" info like this - good work
