Local Time 04:25 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to order PCB - standard Pico2 HDMI
homa
Posted: 04:15pm 08 Dec 2024
Hi Peter and guys,
I am currently trying to order the "standard" board from you.
https://www.thebackshed.com/forum/ViewTopic.php?TID=17301&P=4#228678
The How-to-order-PCB.txt says the following:
Please refer to
https://prodocs.easyeda.com/en/pcb/order-order-pcb/index.html
On the website of easyeda.com I first try to import the ZIP as a project, but that doesn't work, neither in the easy nor in the pro version? The ZIP contains "only" Gerber files.
On which page do I have to upload them to order assembled boards?
I would appreciate a brief explanation and help so that I don't make any mistakes when ordering, thank you.
Matthias
Posted: 04:27pm 08 Dec 2024
Order from jlcpcb not easyeda
twofingers
Posted: 05:13pm 08 Dec 2024
Hi Matthias,
are you looking for this:
https://geoffg.net/Custom_PCBs.html
Michael
PS:
I also need a board. In case you want to order more than one.
The lone and ...
homa
Posted: 05:16pm 08 Dec 2024
thx.
I got it out and ordered it. Now it's time to wait ...
@PilotPirx: Have a look at your PM about the CMM2 housing and possibly this one ...
@Michael: When the order arrives, I'll get back to you.
twofingers
Posted: 05:22pm 08 Dec 2024
That was quick!
The lone and ...
homa
Posted: 06:04pm 08 Dec 2024
Hello Peter,
do you have a suitable dxf file? https://www.thebackshed.com/forum/ViewTopic.php?TID=17301&P=3#227926
Then I can use it to feed my little CNC (cheese milling machine ;-).
  twofingers said  That was quick!
hopefully without errors
Matthias
twofingers
Posted: 06:18pm 08 Dec 2024
  homa said  hopefully without errors
Matthias
I'm confident.
  Quote  cheese milling machine
I'm still waiting for the intended use for my cheese milling machine (Genmitsu 3018-PROVer V2). It's been sitting unused for 3 years. I think it makes too much dirt in living spaces.
Michael
Regarding the front panel: isn't it easier to 3D print it? I imagine it would smell pretty bad to laser it.
Edited 2024-12-09 04:22 by twofingers
The lone and ...
Posted: 06:55pm 08 Dec 2024
Front and rear panels can be made as PCBs. It works really well, and you can have any colour that's available as solder mask. :)  I use 1.6mm board but take the copper off for a couple of mm right round the edges. That reduces the thickness slightly and helps prevent the solder mask from chipping when the board is cut up.
disco4now
Posted: 12:44am 09 Dec 2024
  [ said  QUOTE=matherp
All the design files are now available on github
This includes a dxf file for matching end-plates for the MULTICOMP MCRM2015S or HAMMOND RM2015S box.
F4 H7FotSF4xGT
twofingers
Posted: 09:11am 09 Dec 2024
I got it!
Thank you Gerry!
Kind Regards
MIchael
The lone and ...
homa
Posted: 06:01pm 09 Dec 2024
Hi Michael,
can you load the dxf file? And if so, with which program? Unfortunately I get an error message that something in the file is wrong ...
Matthias
Fixed, the download was wrong. I have to download it as “raw”, save target as only puts garbage in the file :-(
Edited 2024-12-10 04:07 by homa
twofingers
Posted: 06:24pm 09 Dec 2024
  homa said  Hi Michael,
can you load the dxf file? And if so, with which program? ...
Fusion 360. But you found already a solution. Great!
Michael
The lone and ...
homa
Posted: 05:27pm 23 Dec 2024
Front housing and cnc with plastic are not compatible, I prefer to stick to milling wood with my modest skills.
Now I have to find someone with a laser ...
The order and completion of the project are completed so far.
Matthias
@Michael (twofingers): Noch Interesse an einem kompletten Bausatz (Board, rp2350, Gehäuse)? Dann schreibe eine PN. Löten und die Fronten musst du selber machen oder ich finde die Tage noch jemanden mit Laser.
Still interested in a complete kit (board, rp2350, housing)? Then write me a PN. You'll have to do the soldering and the fronts yourself or I'll find someone with a laser in the next few days.
Posted: 05:50pm 23 Dec 2024
  Quote  Front housing and cnc with plastic are not compatible,
It can work OK. You need a 2mm single flute bit and turn it quite slowly
twofingers
Posted: 06:00pm 23 Dec 2024
Hi Matthias,
I am very happy about the offer!
You got a PM.
Kind regards
Michael
The lone and ...
Frank N. Furter
Posted: 09:09am 24 Dec 2024
@homa:
Hi Matthias,
Do you perhaps still have a kit left?
Kind regards and Merry Christmas (to all)
Frank
Martin H.
Posted: 11:43am 24 Dec 2024
Matthias
if you actually have one left, please let me know
Martin
PS: Maybe it would be enough if I printed the front panel
'no comment
Posted: 01:01pm 24 Dec 2024
If you print the front panel, laminate it and cut it out neatly it can often cover slightly oversize holes in the plastic. I've done this before and it worked ok. For this sort of case you really need to stick the print down then trim it so about 0.5mm of plastic shows top anb bottom and about 1mm at each end. Any reasonable double sided tape is fine.
homa
Posted: 01:06pm 24 Dec 2024
Hi Frank and Martin,
I won't know myself until next week after the holidays.
I'll get back to you on Monday. I'm sorry that I can't be more specific yet.
Happy and blessed holidays to all!
Matthias
Martin H.
Posted: 01:35pm 24 Dec 2024
  Mixtel90 said  If you print the front panel, laminate it and cut it out neatly it can often cover slightly oversize holes in the plastic. I've done this before and it worked ok. For this sort of case you really need to stick the print down then trim it so about 0.5mm of plastic shows top anb bottom and about 1mm at each end. Any reasonable double sided tape is fine.
Yes, there are various good options for creating the front panels.
I was thinking of 3d printing instead of milling and drilling. You can also get a label by changing the filament for the last 2 layers.
Happy christmas holidays
Martin
(Pensioners from 2025)
T-shirt, my daughter gave me as a present
Edited 2024-12-24 23:44 by Martin H.
'no comment
