Local Time 15:35 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : HP Tablet thing that has an unhappy battery....
Posted: 05:23am 23 Dec 2024
This is not good......
At least it was easy to get apart - the battery had pretty much popped most of the clips holding it together!
This unit WILL NOT power-up now, with the battery removed.
Could it be possible that they design a tablet, such that WITHOUT the battery being present, it won't boot?
Hmmmmmmm......
Posted: 05:43am 23 Dec 2024
No boot without battery seems common, might be able to get around that.
The battery would have been flat back in 2015.
Cheers Aaron
Off The Grid
Posted: 06:21am 23 Dec 2024
Owwww - very interesting!
I could look for a replacement battery - it WAS working OK before I removed the battery, which is pretty amazing really, considering the massive physical distortion going on.
Posted: 06:27am 23 Dec 2024
Genuine battery is about NZ$60 plus about NZ$20 in freight, so about NZ$80 or so.
Not sure if it is worth it.
Maybe I will, maybe I won't.....
Posted: 06:57am 23 Dec 2024
I guess you could try several 18650 cells in parallel to see if it runs ok with them instead. If so they would need to be externally mounted.
If you don't have any of them simulate a battery with a power supply set to 4.35V, perhaps with a dummy load to absorb any charging current if it needs it own PSU plugged in for the first boot.
Posted: 07:00am 23 Dec 2024
A big capacitor for a battery then run it from external supply.
The poota probably thinks the battery is flat and is waiting for some charge in it before turning on.
Posted: 07:28am 23 Dec 2024
Certainly worth a try, though as the cap will start with 0V it may assume its a failed battery and refuse to charge at all.
Maybe a little DC to DC converter set to 4V connected between the power socket and the capacitor may fool it.
Posted: 08:01am 23 Dec 2024
Excellent ideas, thanks chums!
Posted: 09:13am 23 Dec 2024
try removing the cell(s), but retain the electronics PCB (the BMS). connect an 18650 up to the BMS and see what happens.
is it an HP X360? i have a number of HP Stream 11 G3 machines that use 2 cells in the base - underneath the keyboard. i have run these with the battery (including BMS) unplugged without issue. the machine i am typing this on in fact has no battery installed and the charger plug permanently taped in place. i've also experimented with powering the machines with 2 banks of 3x paralleled 18650 cells; with the stream 11 you can replace the cells without the BMS getting unhappy.
rob   :-)
Edited 2024-12-23 19:14 by robert.rozee
Posted: 11:12pm 23 Dec 2024
HP have cryptic part numbers on their machines, that DON'T match what the bloody thing is actually referred to.
Product: P6M73PA#ABG
The keyboard is removable, turning it into a tablet, or you can put the keyboard on to turn it into a netbook kind of idea.
A search of Mr. Google reveals that this thing is a "HP Pavilion x2 - 10-n103tu" - why the hell the product code and the product name don't match, is beyond me, but HP are notorious for for this kind of thing.
The label on the unit mentions that "10-n103tu" is the "M/M", but most people would try(just like me) to find it using the PRODUCT CODE.  Nowhere on the product spec label or the machine itself, does it even MENTION it is a "Pavilion X2" - you only find that out, after searching the product code.  WHY, HP, WHY?!!!?!?!!
Starting to rant now, so I'll stop.
It's a quite low-spec thing, so I don't know if it's worth fixing it or not.
I suppose it would work fine with something like Puppy Linux on it and a simple terminal software, it could still be useful I guess.  It is small and light, so maybe....
ville56
Posted: 05:17am 24 Dec 2024
a search on Amazon here with "DO02XL" reveals a replacement battery for € 29,12- . Maybe that is also available in NZ. For this price it should be worth it.
just saw, shipping is € 14,88 ... so maybe not worth it ...
Edited 2024-12-24 15:19 by ville56
73 de OE1HGA, Gerald
Posted: 06:35am 24 Dec 2024
LOL!!!
I think I will get the replacement.
A hundred bucks or so, is not THAT much to bring it back to life.
Posted: 07:20am 24 Dec 2024
Ebay has them for $65AU posted
Posted: 07:44am 24 Dec 2024
I will check.
Are they GENUINE though?
Merry Christmas!
Posted: 03:10am 26 Dec 2024
I've decided to just order a genuine battery - the genuine HP one.
They are not prohibitively expensive.
But look what I found on a sticker on the INSIDE of the back of the lid:
This is on the INSIDE of the case!
Why the bloody hell couldn't HP put that information on the OUTSIDE of the damn thing!?!??!
But as I say, HP are notorious for this, and I can't figure out their logic.
I've censored the ID and SN, but I probably didn't need to - it'd be invalid(expired) by now anyway....
Posted: 04:57am 26 Dec 2024
The new battery might have the same (perhaps a year or 2 later) manufacture date as the one you are replacing, sort of depends how long that model was used for, this is normal for phone batteries as they keep changing models and design's, and no longer make that model of battery.
Don't know if the seller will tell you the date on the new battery?
It may take some time to charge because they are usually flat, not enough charge to boot up, at least this is how its been foe phone batteries, computers have a bit bigger power supply.
Cheers Aaron
Off The Grid
Posted: 05:02am 26 Dec 2024
Good to know - I will leave the charger on it, and monitor it.
ville56
Posted: 06:20am 26 Dec 2024
as this is a Li-Ion battery I wouldn't charge a FLAT one again. Flat means for me the voltage across the battery terminals is much less than about 2.7 volts. If things turn out good, only the capacity is lowered, if going bad the battery may gas out and the package pops or it may even burn. I've just killed 2 16850 cells by deep discharge. They charge, get a bit warmer than normal but have only half their capacity. I will dispose them off, just to make sure they will not do any harm... i'm not anxious, but the Li-Ions are unpredictable beasts if offended once.
Just as a word of warning
Posted: 08:17am 26 Dec 2024
Li-Ion 18650 cells do behave a little different compared to pouch cells, having charged and used a few thousand of them I learned a thing or two, cylindrical cells are packed very tight compared to pouch cells that will expand easily if there is any problem, good to check the voltage before installing the battery, depends how long its been sitting on the shelf.
There certainly don't like been left completely flat or reversed.
Hopefully they send a good battery.
Cheers Aaron
Off The Grid
Posted: 07:21am 27 Dec 2024
I have no idea as to the date of the replacement.
As it is a genuine HP replacement, I expect to find a sticker on it saying when it was made.  I'll keep the forums updated, once I receive the battery.
