Forum Index : Microcontroller and PC projects : Is it possible to save VGA screen (content) to a file
| Page 1 of 2 |
| Peter63 Senior Member Joined: 28/07/2017 Location: SwedenPosts: 205 |
Hello Is it possible to save VGA screen (content) to a file? using: Pico2 PicoMiteVGA MMBasic USB RP2350A Edition V6.00.01R10 /Peter63 |
BLIT READ #b, x, y, w, h to read the screen but then how to save. sure it's in the manual SAVE IMAGE file$ [,x, y, w, h] or SAVE COMPRESSED IMAGE file$ [,x, y, w, h] Save the current image on the video output or LCD panel as a BMP file. Any LCD panel must be capable of being read, for example, a ILI9341 based panel or a VIRTUAL_M or VIRTUAL_C panel. 'file$' is the name of the file. If an extension is not specified “.BMP” will be added to the file name. The image is saved as a true colour 24-bit image. ‘x’, ‘y’, ‘w’ and ‘h’ are optional and are the coordinates (‘x’ and ‘y’ are the top left coordinate) and dimensions (width and height) of the area to be saved. If not specified the whole screen will be saved. SAVE COMPRESSED IMAGE will work the same except that RLE compression will be used to reduce the file size.. Edited 2025-01-05 03:24 by stanleyella |
I'am using MODE 2 (320x240), VGA screen ![]() tested Blit read 1,0,42,319,198 then Error: Not enough Heap memory tested Save compressed image "pic1.bmp",0,42,319,198 crash , black screen , have to reboot Pico2 /Peter63 |
Tested Save compressed image "pic2.bmp" it works jippi Why didn't it work with, Save compressed image "pic2.bmp",0,42,319,198 i only want to save a part of the screen /Peter63 |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1769 |
save image "pic3.bmp" would work. Regards Michael too late ... ![]() Edited 2025-01-05 03:55 by twofingers ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Tested again and it works with: Save image "pic1.bmp",0,42,319,198 This saved the part of the screen i wanted /Peter63 |
@Peter Congratulations! But that's not always true. Be careful: sometimes the RLE overhead is extremely high. Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
I was quoting the manual |
@Stan That was directed at Peter and not a criticism of you! I was surprised myself that the compression is so ineffective. Regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
I never used it but knew it's one of mmb's comprehensive commands somewhere in the comprehensive manual. I've read sci-fi novels with less pages |
I just looked at the MicroMite manual today. Just over 70 pages. Picomite triples that. An amazing evolution! ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
I'm using the latest manual and it covers the 2350 as well... a bit.. but not moaning. I would like to put in some words about pico 2 and resolution and cpu speed and is it automatic and other stuff but don't want to upset anyone. cos it's too late anyway :) |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9115 |
Only wondering.... I wonder if it's possible to create an integer array then point its address at the start of the frame buffer? It might then be possible to save the array (i.e. the frame buffer) to a file as a numeric array and possibly even load it straight back into the screen by pointing an empty array then filling it from the file. This would be completely non-standard and incompatible with everything but it would get rid of (or at least reduce) buffering issues that might fill up heap memory. just a muse.... Mick Zilog Inside! nascom.info for Nascom & Gemini |
| EDNEDN Guru Joined: 18/02/2023 Location: United StatesPosts: 306 |
I wonder if it's possible to create an integer array then point its address at the start of the frame buffer? It might then be possible to save the array (i.e. the frame buffer) to a file as a numeric array and possibly even load it straight back into the screen by pointing.... Yes. And the other thing it would allow you to do is directly index into the array to update screen values. I do like the idea. And it would be almost trivial to implement. But it would be such a hack. Probably everybody reading this is cringing... |
Including me.... :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
you could read the screen area using pixel it says in the manual that pixel sets a pixel x,y,colour but I've used if pixel(lander_x,lander_y+39)>0 and pixel(lander_x+3,lander_y+39)=>0 and pixel(lander_x+23,lander_y+39)>0 and pixel(lander_x+27,lander_y+39)>0 then end so this should work to store screen area to array i(c) but it doesn't say pixel will read a pixel in the manual for y=y1 to y2 for x=x1 to x2 i(c)=pixel x,y inc c next x next y Edited 2025-01-05 08:54 by stanleyella |
But if you create a blank array of the correct size then change it's address so that it points to the frame buffer instead of the variables area then instantly the whole screen is in the array. True, you are left with the original blank array still taking up space in the variables area. That might prevent it from working, but if it was only during the time needed to save the array it could then have it's original address poked back in, it could then be destroyed. Remember, I'm not a programmer and I'm probably missing something that's obvious. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6100 |
Mick, I am sure you can read the address of an array. But I expect you cannot change (write) it. But why would you, you can peek and poke every location on screen if you know the screen start address mm.info() Volhout PicomiteVGA PETSCII ROBOTS |
well my lunar lander don't work as pixel has changed so can't find read pixel if it exists The manual says PIXEL( x, y) Returns the colour of a pixel on the video output or LCD display. 'x' is the horizontal coordinate and 'y' is the vertical coordinate of the pixel. but also says PIXEL x, y [,c] Set a pixel on a video output or an attached LCD panel to a colour. 'x' is the horizontal coordinate and 'y' is the vertical coordinate of the pixel. 'c' is a 24 bit number specifying the colour. 'c' is optional and if omitted the current foreground colour will be used. All parameters can be expressed as arrays and the software will plot the number of pixels as determined by the dimensions of the smallest array. 'x' and 'y' must both be arrays or both be single variables /constants otherwise an error will be generated. 'c' can be either an array or a single variable or constant. edit it was old lander. this works if wanted to be added to vga games 'lunar lander vga 640x480 OPTION EXPLICIT OPTION BASE 1 option autorun on 'landscape data dim integer lx(43)=(0,5,9,13,3,18,25,30,48,53,57,47,32,11,5,9,57,89,108,149,170,220,262,300,320,400,447,493,510,545,572,600,638,605,590,577,560,513,495,470,457,500,639) dim integer ly(43)=(9,17,15,25,40,70,100,130,130,160,193,253,298,346,420,430,430,400,370,457,450,400,440,466,424,400,460,460,452,403,373,320,240,210,190,170,130,120,137,110,60,26,9) dim integer l,o,fno,fnc,spnum,k,spc dim lander_x,lander_y,last_lander_x,last_lander_y,gravity,inertia,antigravity,fuel lander_x=260:lander_y=10:gravity=0.0001:inertia=0:fuel=100 ' mode 1 cls ' sprites 'set up lander sprites text 170,180,"d a g s f" 'keys for l=1 to 6 sprite WRITE l,l*80,200 'draw all sprites NEXT ' text 210,120,"Press any key to start" do:loop until inkey$<> "" ' FRAMEBUFFER CREATE F FRAMEBUFFER WRITE f cls RGB(black) Line GRAPH lx(),ly()'draw landscape ' text 0,470,"FUEL" spnum=1 '-------------------------------------- do if fuel>0 then text 48,470,str$(fuel)," " k = asc(inkey$) if k then 'key presses spc=20 'set counts until no flame select case k Case 100 'd up spnum=2 gravity=gravity-.005 inc fuel,-.8 Case 115 's left spnum=5 inertia=inertia-0.005 inc fuel,-.4 Case 102 'f right spnum=6 inertia=inertia+0.005 inc fuel,-.4 case 103 'g up/right spnum=4 inertia=inertia+0.005 gravity=gravity-.005 inc fuel,-1.2 case 97 'a up/left spnum=3 inertia=inertia-0.005 gravity=gravity-.005 inc fuel,-1.2 end select endif end if ' last_lander_x=lander_x:last_lander_y=lander_y lander_y=lander_y+gravity lander_x=lander_x+inertia gravity=gravity+.00015 ' 'has lander landed, check 2 pixels under each foot all lit if pixel(lander_x,lander_y+40)=rgb(white) then if pixel(lander_x+3,lander_y+40)=rgb(white) then if pixel(lander_x+23,lander_y+40)=rgb(white) then if pixel(lander_x+27,lander_y+40)=rgb(white) then text 240,150, "Landed": framebuffer COPY f,N:end'-------- end if end if end if end if ' 'has lander hit landscape, check pixels around it, any lit crashed o=pixel(lander_x,lander_y)+pixel(lander_x,lander_y+10)+pixel(lander_x,lander_y+20)+pixel(lander_x,lander_y+30)+pixel(lander_x,lander_y+40)+pixel(lander_x+29,lander_y) o=o+pixel(lander_x+29,lander_y+10)+pixel(lander_x+29,lander_y+20)+pixel(lander_x+29,lander_y+30)+pixel(lander_x+29,lander_y+40)+pixel(lander_x+7,lander_y) o=o+pixel(lander_x+14,lander_y)+pixel(lander_x+21,lander_y)+pixel(lander_x+7,lander_y+39)+pixel(lander_x+14,lander_y+39)+pixel(lander_x+21,lander_y+39) if o>0 then explode:end'-------- ' inc spc,-1:if spc<1 then spnum=1 'no flame if no nav key pressed inc fnc: if fnc=10 then fnc=0:fno=not fno 'which lander for animation if spc>0 box last_lander_x,last_lander_y,30,39,,0,0 'erase lander if fno=0 then sprite WRITE 1,lander_x,lander_y 'draw noflame lander else sprite WRITE spnum,lander_x,lander_y 'draw flame lander if nav key pressed end if ' framebuffer COPY f,N pause 10 loop end ' sub sprites ship sprite READ 1,86,88,28,39'no flame ' ship triangle 96,114,100,126,104,114,1'flame straight sprite READ 2,86,88,28,39 ' ship triangle 96,114,100,126,104,114,1'flame straight triangle 107,107,113,110,107,112,1'right thrust sprite READ 3,86,88,28,39 ' ship triangle 96,114,100,126,104,114,1'flame straight triangle 92,107,86,110,92,113,1'left thrust sprite READ 4,86,88,28,39 ' ship triangle 107,107,113,110,107,112,1'right thrust sprite READ 5,86,88,28,39 ' ship triangle 92,107,86,110,92,113,1'left thrust sprite READ 6,86,88,28,39 cls end sub ' sub ship'draw ship cls circle 100,98,8 box 92,106,16,8 line 92,114,88,126 line 107,114,111,126 line 86,126,90,126 line 109,126,113,126 end sub ' sub explode for o=1 to 24 circle lander_x+15,lander_y+20,o,1,1,rgb(white) framebuffer COPY f,N pause 20 next for o=1 to 24 circle lander_x+15,lander_y+20,o,1,1,rgb(black) framebuffer COPY f,N pause 20 next end sub Edited 2025-01-05 10:17 by stanleyella |
| Page 1 of 2 |
