Local Time 22:26 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multi line ELSE IF
DigitalDreams
Posted: 08:49pm 29 Jun 2025
Slightly confusing and adding a further endif on the end makes no difference or error !?....
If ~~~~~~ Then
Elseif ~~~~~~~ Then
Endif
Elseif ~~~~~~~~ Then
Endif
Endif
Do I have something wrong here ?
vhofst
Posted: 09:07pm 29 Jun 2025
Hello.
It depends on what you want to do in the code.
If ~~~~~~ Then
 if ~~~~~~~ Then
 Endif
ELSEIF ~~~~~~~~ Then
Endif
Edited 2025-06-30 07:10 by vhofst
Posted: 09:42pm 29 Jun 2025
If you use the CODE button your indentation is preserved.
e.g.
If ~~~~~~ Then
 Elseif ~~~~~~~ Then
   Endif
   Endif
Endif
It's still a screwy piece of code though. :)
It could equally be:
If ~~~~~~ Then
 Elseif ~~~~~~~ Then
   Endif
Endif
Endif  'this line is superfluous but won't flag an error because the first example will parse it!
Edited 2025-06-30 07:45 by Mixtel90
Posted: 09:50pm 29 Jun 2025
  Latest manual, p216 said  In a multiline IF statement you can make additional tests using the ELSE IF command.
This is best explained by using an example (the temperatures are all in ºC):
IF Temp < 0 THEN
   PRINT “Freezing”
  ELSE IF Temp < 20 THEN
   PRINT “Cold”
  ELSE IF Temp < 35 THEN
   PRINT “Warm”
  ELSE
   PRINT “Hot”
ENDIF
The ELSE IF uses the same tests as an ordinary IF (ie, <, <=, etc) but that test will only be made if the preceding test was false. So, for example, you will only get the message Warm if Temp < 0 failed, and Temp < 20 failed but Temp < 35 was true. The final ELSE will catch the case where all the tests were false.
The last condition is just ELSE and there is only 1 ENDIF
SELECT CASE can do a similar thing.
Edited 2025-06-30 08:07 by phil99
DigitalDreams
Posted: 10:11pm 29 Jun 2025
IF Temp < 0 THEN
   PRINT “Freezing”
   PRINT “Cold”
   PRINT “Warm”
  ELSE
   PRINT “Hot”
ENDIF
Thanks, that looks more like it. Can't use select case though as each elseif is followed by a complicated set of comparisons on several variables.
Posted: 10:14pm 29 Jun 2025
The extra endifs will totally screw up the logic. What happens depends on any other if..endif structures.
To expand on Phils example
 TEMP = 22
 IF x = 0 THEN ' change to x = 1 and uncomment the extra endif
   IF TEMP < 0 THEN
     PRINT "Freezing"
   ELSEIF TEMP < 20 THEN
     PRINT "Cold"
     'endif
   ELSEIF TEMP < 35 THEN
     PRINT "Warm"
   ELSE
     PRINT "Hot"
   ENDIF
 ENDIF
 TEMP = 22
   IF TEMP < 0 THEN
     PRINT "Freezing"
     PRINT "Cold"
   ENDIF
   PRINT "Warm"
 ELSE
   PRINT "Hot"
 ENDIF
ENDIF
x=0 and the inner code runs but it will find the superfluous endif
You may not receive any error but the code will not run as expected.
PhenixRising
Posted: 05:35am 30 Jun 2025
  DigitalDreams said  Can't use select case though as each elseif is followed by a complicated set of comparisons on several variables.
Select Case can evaluate. What can't it handle?
Posted: 06:42am 30 Jun 2025
If you are doing a lot of complex comparisons then your program is probably overcomplicated. Go back and think it out again. Such constructs are rarely needed min my experience! Also, each comparison slows down your program as the two variables have to be looked up and retrieved in order to compare them.
You may be able to simplify it by using a couple of FUNCTION blocks that are called several times to get rid of repeated comparisons.
Don't try to escape from an IF tree using ENDIF. That should only appear once, as the last statement. It *might* work but it equally well might not. In any case it will be confusing to both you and the interpreter!
SELECT/CASE is often much faster than a comparison tree as non-true values are skipped quickly. If arranged so that the most frequent true values come first then they can be very fast. Remember that the CASE values can be more than simple values, they can be ranges as well so CASE X<43 and CASE X = 22 TO 30 are valid commands.
If a piece of code doesn't look "clean" then it probably isn't and you'll probably have a hell of a time trying to figure out what you did if you have to come back to it later for any reason. :)
Edited 2025-06-30 16:47 by Mixtel90
twofingers
Posted: 08:24am 30 Jun 2025
  Mixtel90 said  SELECT/CASE is often much faster than a comparison tree as non-true values are skipped quickly. ...
Have you tested it? It contradicts my experience; I thought so too until recently. Why not do a little comparison test?
  Mixtel90 said  If a piece of code doesn't look "clean" then it probably isn't
I agree 100%.
Michael
Posted: 08:45am 30 Jun 2025
I'll test later today if I have time (I have cooker repairs to look at first :( ). I'm certain that IF will beat SELECT on any simple comparisons as it's much more fundamental, however I'm pretty sure that things like window comparisons, which would require multiple, stacked IF statements, are faster in SELECT. Also, be careful when testing comparisons against absolute values vs variables. They are much faster when there is no variable to look up.
DigitalDreams
Posted: 09:32am 30 Jun 2025
Thanks guys, my code looks much tidier now. It's been decades since I used ELSEIF.
In my own past testing 'Select Case' was faster but not suitable in my situ.
Posted: 09:46am 30 Jun 2025
The fastest I've found so far has been SELECT CASE used with TO to select ranges of values. It can be very fast indeed
Also
CASE <40
is a lot faster than
CASE X < 40
as this causes a second variable lookup. Something to watch out for in CASE statements. I know, I've done it. :)
I don't know if MMBasic does it, but compilers sometimes optimize SELECT trees, something not always possible with IF statements.
DigitalDreams
Posted: 10:08am 30 Jun 2025
Oh to have MMBasic compile to machine code !
PhenixRising
Posted: 10:40am 30 Jun 2025
The single best thing about MMBasic is that it's an interpreter.
If we have portions that require a boost, we have C-function option.
I have traditionally been a speed freak but in so many cases, the code is only waiting faster.
Posted: 11:53am 30 Jun 2025
  Quote  I have traditionally been a speed freak but in so many cases, the code is only waiting faster.
This is very true. It's easy to get hung up on the program execution speed.
You don't gain in program development speed when using a compiler. It's much slower, especially if using MMBasic's built-in editor. Program errors, editing cursor is on the line where the error occurred. Nothing else that I know of does that.
If you want fast IO operations there's always a PIO to play with. :)
twofingers
Posted: 12:36pm 30 Jun 2025
A small select-if benchmark (RP2350A Edition V6.00.02RC14/HDMI):
Dim integer a,b,c,MAX_LOOPS=10000
Print "'IF'loop "
c=1
Timer =0
a=1
b=1
If a<b Then
 Inc c
ElseIf a>b Then
 Inc c
Else
 Inc c
EndIf
Loop While c<MAX_LOOPS
Print Timer
Print
Print "'Select Case' with 'a' variable"
c=1
Timer =0
a=1
b=1
Select Case a
 Case a<b
   Inc c
 Case a>b
   Inc c
 Case Else
   Inc c
End Select
Print Timer
Print
Print "'Select Case' without 'a' variable"
c=1
Timer =0
a=1
b=1
Select Case a
 Case <b
   Inc c
 Case >b
   Inc c
 Case Else
   Inc c
End Select
Print Timer
Print
Print "'IF' again"
c=1
Timer =0
a=1
b=1
If a<b Then
 Inc c
ElseIf a>b Then
 Inc c
Else
 Inc c
EndIf
Print Timer
Result:
'IF'loop
437.357
434.884
415.708
'IF' again
437.197
With a larger number of comparisons, if/then is even significantly worse!
Generally, I would prefer select/case for clarity.
Edited 2025-06-30 23:00 by twofingers
Posted: 01:11pm 30 Jun 2025
If speed is what you are after and most of the ranges have a span that follows some pattern it may be possible to replace SELECT CASE with a lookup table in the form of an array.
This:-
IF Temp < 0 THEN
  PRINT “Freezing”
  PRINT “Cold”
 ELSE IF Temp < 25 THEN
  PRINT “Cool”
 ELSE IF Temp < 30 THEN
  PRINT “Mild”
  PRINT “warm”
 ELSE IF Temp < 40 THEN
  PRINT “Very warm”
 ELSE IF Temp < 45 THEN
  PRINT “Hot”
 ELSE
  PRINT “Too Hot”
ENDIF
Becomes this:-
Dim Temp, range%, Heat$(7)=("Freezing","Cold","Cool","Mild","warm","Very warm","Hot","To Hot")
'main
t=timer
For Temp = -5 To 55
 range% = Temp \ 5 - 3
 If range% > 7 Then range% = 7
 If Temp < 20 Then range% = 1
 If Temp < 0 Then range% = 0
 Print Temp, Heat$(range%)
Next
Print timer-t;" mS"
End
31.294 mS
If the Print in the loop is commented out:-
8.824 mS
Edited 2025-06-30 23:24 by phil99
stanleyella
Posted: 02:01pm 30 Jun 2025
I don't use logic like
if x<5 and x>10 then
I use
if x<5 then if x>10 then
in first case it does 2 tests. in the second if first test not true it skips second test
Posted: 02:31pm 30 Jun 2025
SELECT x
CASE 5 TO 10
'do something
END SELECT
also does a single variable lookup but combines two comparisons.
I'm not a great fan of convoluted IF trees, where one IF loop is conditional on another IF loop. There are often much more readable ways to do it. Certainly, indentation is critical when you use lots of IF-THEN-ELSE-ENDIF statements as they quickly get confusing otherwise. Lose that indentation and you may as well give up on ever understanding the program.
PhenixRising
Posted: 06:39pm 30 Jun 2025
Loops:
It has been a while and I'm not at my desk to verify but I seem to remember finding for-next loops to be faster than do-loops:
For i = 1 to [ridiculously big number]
   if condition = true then
       i = [ridiculously big number]
   end if
Next
Could be wrong.
