Local Time 10:44 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Humidity Calculation
palcal
Posted: 04:16am 28 Nov 2025
Does any one have a formula for Humidity calculaton from wet and dry bulb temperatures.
My outdoor sensor doesn't last long, the humidity here varies from over 80% early morning dropping to 65% to 70% during the day. At the moment it is 31 Deg. C and78% humidity, very uncomfortable for some but I'm used to it.
I want to use a wet and dry bulb which should last indefinately. I'm thinking of topping up the wet bulb tank with a feed from my garden watering system
  I tried a couple of formulas I found online but they weren't very accurate when compared to a psychrometric chart.
Edited 2025-11-28 14:16 by palcal
Posted: 06:56am 28 Nov 2025
Try here
https://www.thebackshed.com/forum/ViewTopic.php?TID=15917&PID=203964#203964#203964
Good luck finding the BOM website that I reference!
Edit: have you tried the HDC3022?
https://www.thebackshed.com/forum/ViewTopic.php?TID=17688&PID=234524#234524#234468
You should be able to dry it out once a week or whatever.
Edited 2025-11-28 17:03 by TassyJim
Pluto
Posted: 07:50am 28 Nov 2025
Link to a few older posts about Humidity Measurements.
  Quote  https://www.thebackshed.com/forum/ViewTopic.php?TID=17688&PID=234062#234062#234062
Pluto
zeitfest
Posted: 08:22am 28 Nov 2025
Maybe just use a lookup table - kludgy but effective..
data
zeitfest
Posted: 09:26am 28 Nov 2025
A formula
Edited 2025-11-28 19:28 by zeitfest
Posted: 11:37am 28 Nov 2025
Hi Pascal,
Picomite Code for Pascal
I seem to have shown you a demo program before.
Time flies
palcal
Posted: 07:40pm 28 Nov 2025
Thanks for the answers.
@Voltout  I vaguely remembered asking before and did a search but missed it, my memory is not what it used to be. Thanks, that's a big help.
@TassyJim..I did try a HDC3022 with bad results, I was in a hurry to get the weather station up and running again so used another HTU21. I will have another look at the HDC3022 today. From a quick look at your code it seems like you have to turn the heater on manually, I was thinking of doing it once per week with an interrupt somehow.
Posted: 08:06pm 28 Nov 2025
  palcal said  I will have another look at the HDC3022 today. From a quick look at your code it seems like you have to turn the heater on manually, I was thinking of doing it once per week with an interrupt somehow.
In your high humidity I would run the heater whenever the humidity has been over 95% for more than 1 day. Or something similar, it is a long time since I have lived in the deep north.
palcal
Posted: 08:44pm 28 Nov 2025
Jim,   I am using the code for HDC3022 as posted but my sensor is reading -45 Deg and 0%, so I can't really do any more with it exept order another one. I'm comming down your way in January for a bit of relief from this weather, I have a granddaughter who lives in Hobart.
Just had a look, I paid $30 with postage for this one, too expensive to play with.
Edited 2025-11-29 08:24 by palcal
Posted: 02:47am 29 Nov 2025
If you want to post it to me, I can have a look at the HDC3022. Having a working unit to compare things with does make life easier.
palcal
Posted: 07:32am 29 Nov 2025
Thanks for that Jim, PM me with details.
Paul.
palcal
Posted: 12:09am 30 Nov 2025
I cobbled together a rough wet/dry bulb setup and Voltout's code seems to work well.
palcal
Posted: 12:54am 30 Nov 2025
Can anyone point me to Psychrometric Tables, in table form not a graph, in Celcius. All I can find are tables in Fahrenheit. I asked AI and got all sorts of rubbish.
Posted: 02:42am 30 Nov 2025
Here is one I found . Only goes up to 40°C so you may have to extrapolate when it gets hot.
relative-humidity-table.zip
Posted: 02:50am 30 Nov 2025
This is one I found in '23
Using the formula I used back then, it would be easy enough to produce a table to cover your temperature range.
I will give it a go later when I have finished my 'real' jobs for the day.
palcal
Posted: 03:03am 30 Nov 2025
Thanks Jim, that's ok for now.
Posted: 04:06am 30 Nov 2025
Had a break from the shovel
rh1.pdf
3 different formula giving slightly different results
Was 45 degrees high enough?
palcal
Posted: 06:04am 30 Nov 2025
That's great Jim, it's just to test the readings I'm getting from Voltouts code. So far it looks good, been running all afternoon displayin RH at 1 minute intervals and seems accurate. Now to make up the hardware for the sensors, and the water to keep it topped up.
palcal
Posted: 08:06pm 30 Nov 2025
I got my HDC3033 working at last. I had it connected to a PicoW, when I gave up on it I connected a couple of DS18b20's to it and they didn't work either. I then connected the DS18B20 to a Pico2040 and they worked ok.
I just connected my DS3022 to a Micromite and it works. Maybe a dud PicoW although it worked with a HTU21D. Just one of those things.
Posted: 09:30pm 30 Nov 2025
That's good news.
It will be interesting to compare it with the wet and dry bulb method in your high humidity.
