Local Time 06:37 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Copying code from other programs with inbuilt editor?
DigitalDreams
Posted: 12:59pm 24 Jan 2026
I often find myself wanting to copy or move sections of code from one program to another while using the built in editor. Is there a way of doing this as exiting clears the paste buffer ?. Maybe a way of inserting another .bas file at the cursor position ?
Would save me having to use a PC via the sd card saves, not feasible when travelling.
Thanks in advance...
Posted: 01:59pm 24 Jan 2026
Working from a PC, I use autosave append for this
twofingers
Posted: 02:43pm 24 Jan 2026
I use the HDMI version of the FileManager for this (old F8=Cut, old F9=Merge).
Michael
Martin H.
Posted: 04:35pm 24 Jan 2026
This is how I do it.
Transfer the source files to the PC via xmodem, then edit them in Notepad++ and copy them back to the Pico via xmodem. You can then store frequently used routines (subs/fonts/functions) on the PC and simply add them to the source code.
For minor changes, testing and error corrections, I use the built-in editor.
Martin
Edited 2026-01-25 02:39 by Martin H.
'no comment
DigitalDreams
Posted: 04:58pm 24 Jan 2026
Think I'll have to say again NO PC, only using the inbuilt file manager and editor... there must be a way. LCD Picomite 6.01 on a Pico2 btw...
A command such as 'INSERT' would be great for this, or preserving the copy  buffer on exiting the editor so the section could be pasted into another .bas
twofingers
Posted: 05:36pm 24 Jan 2026
  DigitalDreams said  Think I'll have to say again NO PC, only using the inbuilt file manager and editor...
Where did you say it for the first time?
DigitalDreams
Posted: 05:49pm 24 Jan 2026
  twofingers said  Where did you say it for the first time?
"while using the built in editor", "would save me having to use a PC"
stanleyella
Posted: 05:52pm 24 Jan 2026
I'm not an inbuilt editor user but can't the lcd sdcard reader be used?
Posted: 08:46pm 24 Jan 2026
Until someone comes up with a better way, here is a convoluted method that may (eventually) do what you want.
1) Save your current program (the one you want to add a block of code to) to A: or B:
2) Load and edit the program that has the routine you want from A: or B:
3) Delete everything except the routine you want and save it with a new name to A: or B:
4) Write a short program to open that file and append each of its lines to the target program.
4) Edit that program (the one in step 1, if I have confused you) and move that new block of code from the end to where it is needed.
That should keep you out of mischief for a while. ;)
Option 2 (the one you don't want)
Always take a laptop/notebook computer when travelling.
Posted: 09:27pm 24 Jan 2026
The Picomite has no OS or windows-type clipboard. You can list a second program to the console  while editing one, but you can't copy from it as it's merely being listed from flash or SD card - it's not in the editor. You can only have one program there.
disco4now
Posted: 10:56pm 24 Jan 2026
An extension of Phils idea.
Use the REM command to create some directives that a third program understands.
e.g.
--- In the target file
REM SOURCE A:/file1.bas
REM INSERT FILE          'insert whole file here
REM INSERT AA            'insert section bounded by REM AA ... REM AA
REM INSERT BB etc
--- In the source file
REM AA
code to insert
REM AA
REM BB
other code
REM BB
1. Added the required directives and save the file.
2. Load the source file and mark the sections and save if not already done.
3. Run your third program , a utility that understands the above syntax that will modify your file as specified and reload it.
F4 H7FotSF4xGT
Posted: 08:04am 25 Jan 2026
Use include for the section you need to add
DigitalDreams
Posted: 08:29am 25 Jan 2026
  Volhout said  Use include for the section you need to add
Include ??
Posted: 09:01am 25 Jan 2026
No idea. Does the Picomite support INCLUDE now? I don't think so. That's only on the CMM2, I think, as that runs a pre-processor.
There is no way to insert text midway through a file unless it is records in a random access file.
Phil's idea will work fine, but as he points out you have to append the text then move it into position.
I like the idea of creating directives but I think it might rapidly get clunky for a program of any size, with a read_line-test_line-write_line for every line in the program. Maybe Volhout was suggesting using the word INCLUDE rather than INSERT? That would make sense.
IanT
Posted: 09:24am 25 Jan 2026
No, all too complicated for me. I'll stick to using a PC.
IanT
Posted: 09:36am 25 Jan 2026
Me too. :)  Unfortunately I can't think of any other way on a self-contained LCD display system.
The Picomite isn't a computer and, amazing though it is, asking it to do things like cut and paste between separate files via a clipboard is probably asking a bit much of it.
Arne
Posted: 10:04am 25 Jan 2026
I often use the built in editor.
Best for me would be following:
Marking with F4 :
F5 generates then a „Clipboard-file“ on the active drive (instead of storing data in RAM).
Advantage: Big data amount could be transferred, permanent storage, transferable to other programs
Disadvantage: Slower, more flash write cycles
Maybe implementation with „OPTION CLIPBOARD…“ selectable.
Arne
Posted: 10:51am 25 Jan 2026
Never tried it. But...
I always use MMEdit.
Posted: 02:27pm 25 Jan 2026
  Volhout said  Never tried it [#include]. But...
I tried it, it didn't work, and I posted a question about it quoting that CMM2 LOAD text from the Picomite manual. Peter explained that it did only work with CMM2 LOAD, which (as the manual says), strips out comments and white space.
Posted: 02:32pm 25 Jan 2026
Watch this space
