Local Time 10:46 05 Nov 2026 Privacy Policy
Forum Index : Windmills : New Farm mill ready to go ~1KW.
     Page 1 of 4
KarlJ
Posted: 09:06am 13 Jan 2010
Lashed out and bought a Phillm dual after I saw the excellent blade mounting solution, been umming and arring for 6 months now (thanks Phill for putting up with me and the endless questions)
Here's some pics, I know there was some discussion over the colours people wanted from Phill, so all the bits that weren't painted, I allowed the kids to choose, looks pretty smart!
Have 2 sets of stators set aside, hoping for the two 100S (one in star and one in delta) to be good for over 1KW at 500rpm
and the two 80S wired as 7x2C (one star and one delta)
Twisted the poles on all of them and varnished them too, even painted the stator support rings!
Here's some pics for people to drool over, should be up in a month or so -waiting on the solar guy and sparkie, trench for the power and tower to go in -sorry no pics of that yet but 7m monopole tilting!
Weighs in at a hefty 43KG all up
Bugger photo doesn't do justice to the purple, looks blue in the pic!
Edited by KarlJ 2010-01-14
fillm
Posted: 12:43pm 13 Jan 2010
Hi Karl,
That tail is one of a kind , the girls did a top job .
Looks like the Aluminium blades are also painted .
Hopefully all the services go in soon and we can start to see some good results
KarlJ
Posted: 12:49pm 13 Jan 2010
Yep, blades (and tail) in aluminium etch primer, then flat white basecoat, then gloss white topcoat, should keep them in good nick for a few years yet!
Plenty of doses of loctite, bearings to the masthead, F&P shaft to the F&P bearings, hub centre to blade mount handfull of 3/8" nylocks for the blade bolts and a handful of washers.
Looks again like a move to Perth is on the cards, wife flying over next Friday for job interview with BHP, thats two in as many months!
one of a kind! Couldn't let anyone down!
Perry
Posted: 09:44pm 13 Jan 2010
Congrats Karl. Looks like a fun set up. Nice paint too.
Perry
JimBo911
Posted: 01:30am 14 Jan 2010
Super Sweet
KarlJ
Posted: 03:32am 14 Jan 2010
Unfortunately short of the paint job the
goes to Phill, the tooling side of things and the accuracy required to get smooth running and thus longevity are beyond my equipment at this time.
the next "lucky customer" gets the one with the tail mounted with bearings for even smoother furling.
I did read an interesting article that said wind turbines should be at least 5 times the height of any obstacles within 300' --a really big ask!
Tower is only 7m high, perhaps a stretch is possible later on with guy wires added up top.
This beggs the next question.....
I have 100M of cable 16mm2 cross sectional area
do I go 45m from the house and run double cable (16mm2)
in which case i will loose approx 3% in the cable
or do I go 90m from the house and run single cable.
in which case I will loose 9% (at 1000W)
My thoughts are...
Volt drop almost doesn't matter as turbine will happily make more than the 55V required for charging and thus should gain some efficiency by being allowed to run 4-5V higher than the batts/inverter end of things.
90-100W lost at the top end is almost irrelevant as the low end gain from being further away from obstacles and allowing the turbine to run in smooth air means that it will make more power more of the time and at lower current the losses will be linearly less.
I'm heading up there on Sunday to start digging the trenches...
VK4AYQ
Posted: 04:18am 19 Jan 2010
Hi Karl
Losses are a fact of life so as long as the loss dosent exceed the gain all is good to get the last 10% of efficiency can cost 90 % of the project.
All the best
Bob
Foolin Around
KarlJ
Posted: 09:27am 20 Jan 2010
Progress update
Backhoe digging the trench and us backfilling
Hole Inspector Sophie
Hole completed
View back to House
Wind turbine after balancing and final assembly
temporarily mounted on a beam in the garage.
Now for the special part -I spent some time getting the stators exactly set up so that one stator pole is in-between the other stator, result.......
with the door open and a few windows open behind it.....
The windmill would sustain about 100rpm IN THE SHED!!!!!
(no load but nonetheless pretty bloody happy with that)
Lastly, dropped in to see Haydn from Eastcoast green energy in Stratford -(he's the guy doing my tower and puts up a turbine or two a week!!)
and showed him the mill
Here's a quick narrative...
-Chinese mills furl but dont like coming back into the wind how did you deal with furling?
-Adjustable offset Response -Brilliant
How do you deal with blade angles-
-Adjustable Response -Brilliant
The tail should be allowed to sit 10deg in the oppposite direction from furling side did you account for that
Yep, adjustable - Response -Brilliant
How about tip runout what are you doing for that
ahh mate thats adjustable too
what do you think of these blades.......
WOW- nice
Whats with the exposed stator, laquered 3 coats, shell be fine
Whats the kicker on the tail?
holds it into the wind better for turbulent sites
Whats with the fridge and capacitors?
Halves the cutin rpm?......say what...how?
long story but I've got some really smart mates, can be done for the chinese mills too.
Geez -is there anything you didn't think of?
So how many of these puppies can you supply, how much?
If you get 1000KW/HR/year out of this puppy, she's worth
at least double that!
K.So whats the verdict?
Hadyn, well mate I flog the chinese turbine caus the other stuff doesnt work or costs the earth so in comparison, looking at the construction here..
Chinese = turd, SOMA = turd, Whispers =turd that needs a howling gale to make anything!
this = gold, but needs sliprings to be saleable
Needless to say I was bloody happy with that!
and then we started talking OZ AXFX and eyes really lit up.
Edited by KarlJ 2010-01-21
HeadsUp
Posted: 01:22pm 20 Jan 2010
noise shouldnt be an issue that far from the house
whats the rule for cable depth in your state ?
happy daze is a home made anything making your own power
VK4AYQ
Posted: 01:35pm 20 Jan 2010
Top Marks for the whole lot Karl.
Cant wait to see the output when you get it logging.
All the best
Bob
Foolin Around
Perry
Posted: 02:37pm 20 Jan 2010
Looks great but for putting up a turbine or two a week your tower installer doesn't seem to know the first thing about turbines. Maybe he just does towers and has never seen a turbine. With the exception of the caps the rest is all turbine 101 stuff. You should direct him to this site and scold him for concentrating on Chinese turbines.
Perry
Edited by Perry 2010-01-22
JimBo911
Posted: 09:13pm 20 Jan 2010
Karl your all most there. You will be pleasently surprised how efficient those blades are.
neil0mac
Posted: 09:38pm 20 Jan 2010
You didn't use one of those u-beaut mercury thingys? (Mentioned somewhere in these forums.)
KarlJ
Posted: 09:53pm 20 Jan 2010
Perry..
this guy is the most experienced person I have actually met
having installed most of whats there on the market, the reason for the preference to the CHinese mills is the same as the bloke with the EXmork turbine that makes twice the power of its twice as expensive american turbine.
The Chinese stuff-although not without its problems is still good value, even if you have to spend the same amount as the turbine itself making it right, then its still cheaper than the american alternative or our local SOMA turbines, once they are up and running smoothly-other than the furling not being right, the do work!
Small wind turbines I have seen in the wild, whilst travelling the countryside, only 5 -not like there are lots of guys who have put up lots of turbines
hence I respect his opinion more than a salesman from an online "store"
I plan on going to visit a 20KW chine mill he put in a month or so ago for a look see.
VK4AYQ
Posted: 10:57pm 20 Jan 2010
Hi Karl
I noticed a slip ring assembly on ebay for about $40 plus postage might be worth a look.
Allm the best
Bob
Foolin Around
KarlJ
Posted: 04:25am 21 Jan 2010
OK scored some batteries today 8x 80 AH SLAs
all virginal but a few months old paid $600.
Again amazingly enough the guy had an F&P windmmill in the backyard!!!, he had seen peak output of 600W using the 7phase into 48V -pretty good I reckon!
Question should I parallel the 2 x 48V strings or parallel each 12V battery, then series the 4 batts? like the pic
KarlJ
Posted: 11:33am 21 Jan 2010
Bugger, made up links between all the batts pretty much as shown, (exception of the three blue lines in the middle as couldnt be bothered) then downloaded the instructions which say to leave a min 12mm airgap between the cells..
ah more flattening and drilling....
GWatPE
Posted: 01:32pm 21 Jan 2010
Hi Karl,
the links appear quite thin. Are you planning on connecting a power inverter to this, or only a GTI.
10mm copper would be good. Some, flatten 1/2" copper pipe and drill some holes each end.
thicker is better than thin.
Gordon.
become more energy aware
Downwind
Posted: 02:01pm 21 Jan 2010
Karl your work looks very neat and tidy but as Gorden said it looks light in the wiring.
The last place you want to introduce any resistance is at the battery bank.
Pete.
Sometimes it just works
KarlJ
Posted: 10:11pm 21 Jan 2010
This was my schematic only... with powerpoint,
Buss bars here
     Page 1 of 4
