Local Time 08:39 05 Nov 2026 Privacy Policy
Forum Index : Windmills : servo motors
     Page 1 of 3
97fishmt
Posted: 01:20am 19 Apr 2010
Hello all- new guy here.
Anyone using a permanent magnet ac servo motor for an
alternator here? I'm the guy that let that secret out
on Field Lines years ago. They don't like me much, they
are trying to sell a product. I found you guys down under!
97fishmt
Posted: 02:11am 19 Apr 2010
Something like this.
This is a 6kw motor. 6000watts. 200volts @ 30amps. 16volts @200rpm and 30 amps is just the starting point. You don't want to go over the name plate rating but really it will do 5 times as much with the right prop.Edited by 97fishmt 2010-05-06
97fishmt
Posted: 02:14am 19 Apr 2010
Or this
You can see this one needs a big prop for the 150 rpm cut in.
So a small package for about a 400 watt machine. But still
probably an 8' prop. I have had this one up with an 8' prop
and it did very well in light winds on a test stand. I saw
10 amps easy into the battery. The prop needed better balancing
so I haven't played with it since.
Edited by 97fishmt 2010-05-07
97fishmt
Posted: 02:17am 19 Apr 2010
To get this.
This is a 9kw motor and I have seen over 100amps out of it at 15volts.Edited by 97fishmt 2010-05-06
Posted: 03:55am 19 Apr 2010
Hi 97fishmt.
Yes I did use a servo motor once, it worked very well from memory.
But if its in good condition, its worth a lot of money as a servo motor! You could sell that and get the funds to build a couple of axial flux turbines.
Downwind
Posted: 04:02am 19 Apr 2010
Just out of interest what is a motor like that actually worth to buy?
Pete.
Ps. if you are nice to use here we wont throw stones at you.
Sometimes it just works
VK4AYQ
Posted: 06:04am 19 Apr 2010
Welcome 97fishmt
Looks impressive I haven't seen any of these in Australia though, what does it weigh what does it cost and what will it produce???
We are free radicals here I think so you should fit in well.
All the best
Bob
Foolin Around
GWatPE
Posted: 12:23pm 19 Apr 2010
I have a couple of these, Pacific Scientific Brand. These use SaCo cast magnets on the inner rotor. Mine are 4pole, with 16 curved magnets, arranged with a twist, and have nil cogging. These are low inertia, with the smallish rotor dia, and low rotor mass.
Mine have short shafts, and tachsyn encoding as a motor. These were quite expensive new.
You need the larger frame size units with low inductance windings for best use as a windmill. Mine were designed for 300VDC and 4000RPM. They worked well with gearing on a solar car pre wheel motors. They are used a lot in the automotive, robotics machine assembly lines, instead of people to make cars etc.
I would be wary of hanging a large windmill rotor directly off the shaft.
Gordon.
become more energy aware
97fishmt
Posted: 04:08pm 19 Apr 2010
  Gizmo said   Hi 97fishmt.
I remember Glenn, I told you to give it a try.
So you tore that robot apart and checked it out.
Seemed like you were happy but I never herd if you
made a mill out of it or the other one.
Nice to see you guys doing so much 1/2 way around the
world. Glad I found ya!
97fishmt
Posted: 04:13pm 19 Apr 2010
Hey Pete look on ebay at the servo motors.
I just can't resist when they go for $30
so I have about a dozen now.
New they can be $10k
97fishmt
Posted: 04:26pm 19 Apr 2010
Hi Bob
They are out there.
I bought my first one from Boeing airplane company.
New old stock from there surplus store for $200.
Took a gamble on it because everything was in German.
I was able to make out 144 volt 65 amp 3 phase y @2000
rpm. Weighs about 100 lbs.
So for an alternator I see the 65 amps at a slower speed
like 200 rpm and 14.5 volts. Works perfect for a wind
turbine.
97fishmt
Posted: 04:45pm 19 Apr 2010
Hi Gordon
I have bought about a dozen off ebey in the last
5 years or so. I look for the 200 volt machines
with winding resistance less than an ohm and the
most amperage I can find.
20 or 30 amp units go for $30 if no one is looking.
Doesn't seem that way anymore though.
I do have some 360 volt and 400 volt ones but the rpm
is around 1500. The 200 volt ones work perfectly for
12 volt direct drive if you find one with 2000 rpm or
less depending on what size rotor you are planning on.
The shafts on all mine are 1 3/8" plenty big enough for
a 10' rotor with very nice bearings.
I have been running a 9kw siemens for around 10 years now
it just keeps pumping out power to the batteries.
I plan on going to a higher voltage soon, 24 volt or 48 volt.
I may have to start looking for other motors, I have seen some
600 volt ones. I'm just trying out what I can find for cheep
and have been doing it for over 20 years.
Posted: 10:17pm 19 Apr 2010
Yeah it did work well. It was just too simple, it worked, so I moved onto something else. I only had one windmill tower.
I still have the motors, 3 of them, and when I get the space for a couple of towers I'll put them up with a set of the PVC or Aluminium extruded blades.
vasi
Posted: 12:07am 20 Apr 2010
  97fishmt said   Hello all- new guy here.
Hi,
This one?
Is just a short presentation, no pictures.
VasiEdited by vasi 2010-04-21
Elvish name: Mablung Miriel
Beyound Arduino Lang
97fishmt
Posted: 03:11am 20 Apr 2010
Yes that's the one. I'm better at typing now and communicating
I hope. I guess I just wanted to share to the world. So that
one is this one.
birdhouse
Posted: 01:51am 21 Apr 2010
fish-
i'm on the servo motor kick for my first mill. getting really close to being done. i found a fanuc motor on ebay. seems to do well on my ghetto bench tests. i guess time will tell!
birdhouse
i pee more than once before flushing, and don't have to flush at all up at the ranch!
97fishmt
Posted: 01:58am 21 Apr 2010
Hey birdhouse
I remember when you got that one.
It will work awesome.
Post a picture soon, Please..
birdhouse
Posted: 02:38am 21 Apr 2010
fish-
thanks for the encouraging words! i hope it works awesome! hits 24 volts at 240 rpm. 8.5 ft. dia. just got a layer of fiber glass on the blades the other day. lately, i've been trucking away at it for sure! hoping to have it up by june 19th!
here's a few photos... nothing recent... hope this link works!
pics
birdhouse
97fishmt
Posted: 02:46am 21 Apr 2010
I can't get into that one.
Maybe some other time huh?
Thanks let us know how it works!
birdhouse
Posted: 02:55am 21 Apr 2010
yea, it's facebook...
i'm putting this thing up at my ranch where i can't keep track of it, so i'm really worried about getting the furling down right. my solution is to mount the thing off the front of my truck and use the speedo to dial in the furling. it just so happens i've got dual 1.25" reese type hitches on the front. i'll take video of that for sure! getting excited for that experiment!
birdhouse
     Page 1 of 3
