Local Time 11:26 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ARMmite b11, Selectable USB/UART Console
     Page 1 of 3
Posted: 07:52am 09 Mar 2015
Please find attached a revised hex file for the STM32F407VG.
This now supports connecting the console via UART or USB.
To use USB you need to download and install the STM Serial Port Driver
To install the new firmware over a previous release you MUST use the option "Target/Erase chip" to clear the flash memory completely. Then load the new firmware:
2015-03-09_193433_ARMmiteb11.zip
Plug a micro-USB cable into the port next to the Audio output and connect to your computer. When you restart the microcontroller you should then get the usual messages about installing a USB driver. Help Windows as required to get the STM driver loaded and once that is successful open a terminal window and connect to the relevant virtual comm port. Press "enter" and you should get the command prompt displayed.
You can then swap between using a USB connected console or a normal UART as follows:
Use OPTION CONSOLE USB, or OPTION CONSOLE UART. This setting is stored in flash memory for subsequent restarts and power cycles. Once the processor is restarted, the appropriate driver will then be used.
Another new OPTION is "OPTION VCC n.nnn"
If you measure accurately the supply voltage to the microprocessor, then using this option will calibrate both the ADCs and the DACs correctly. The option is stored in flash memory for subsequent restarts and power cycles.
The Discovery board has a diode between the 3.3V regulator and the chip supply which drops the voltage, "OPTION VCC 2.92" works for my board. You can then confirm the setting by using "print pin(0)" which should then report 1.2V.
Valid values are 1.8V to 3.6V - the allowable range for the chip.
OPTION PIN has now been implemented
CPU RESTART has now been implemented.
I'd appreciate feedback on who, if anybody, has got a STM32 up and runningEdited by matherp 2015-03-10
atmega8
Posted: 10:41am 09 Mar 2015
Peter, Peter....
Chapeau for your great Job!
It is extreemly impressive to me, what you and the other guys working on this port are doing.
Also that Geoff has programmed and documented an MMBASIC Interpreter that can be ported to another Platform, awesome..
I will try to pick up a board on ebay for testing and debugging.
Next Step would be a PCB for the new Platform and debugging ( if necessary) and enhancing with geoffs Feature rich MMBasic, and my be more;-)
Thank you,
Dietmar
viscomjim
Posted: 11:55am 09 Mar 2015
Damn it, now I have to get one of these....
Great work!!!!!
plasma
Posted: 12:16pm 09 Mar 2015
Hi Peter ,
works here on win 7 /64 bit.
now the serial part is easy as arduino
Zonker
Posted: 01:54pm 09 Mar 2015
Will get one ordered this weekend.. (payday)..
viscomjim
Posted: 06:28am 10 Mar 2015
Is this the recommended board we can use. If so, damn, its cheap.Edited by viscomjim 2015-03-11
Posted: 07:36am 10 Mar 2015
Yes, that one.
dmasz
Posted: 12:05pm 10 Mar 2015
Hi Peter,
I successfully flashed Discovery board with new ARmite
and i am using console port via micro USB with VCP drivers and teraterm.
I noticed that in terminal there is one character delay while typing.
in other words last pressed character shows after pressing another key and so on.
is it wrong config of teraterm or bug in ARMite firmware?
br
Dan
boss
Posted: 01:23pm 10 Mar 2015
Has anyone ST-Link running on Win 8.1? Damn, I upgraded all my comps to 8.1 and I'm able to upgrade FW via ST-link, but nothing else. So the communication basically works, but nothing else.
Any suggestion will be appreciated.
Bo
boss
Posted: 01:29pm 10 Mar 2015
I apologize for misplaced pictures, I sent the pictures from my iPhone and did't realize they are upside down.
For today it is enough,
Bo
Zonker
Posted: 02:12pm 10 Mar 2015
OK... Discovery Board ordered from above link...
Bizzie
Posted: 06:30pm 10 Mar 2015
I have purchased a STM32F4 Discovery I have it working using a USB/serial adapter.
I have downloaded and installed the "STM Serial Port Driver " (win 8.1) all went has normal. I have a serial bus device called STM32 STlink in device manager.
Now the embarrassing bit I can not remember how to find what com port it is connected to!
An update!
A reboot of my system resulted in a windows update (yet another worry with 8.1!).
I now have a device driver tree that looks like this :-
Properties page shows :-
A search for the driver says it is up to date. As usual solution does not make any difference.
Latest Update :-
Will not include a screen dump. I uninstalled the drivers and then manually installed them by pointing the driver update to the folder C:\Program Files (x86)\STMicroelectronics
All seems OK BUT I have no communication with the STM32 from either terra term via ST-LINK (comm5) or the STM32 ST-LINK Utility AND if I pull the plug on the USB console I can not see the STM32 from TT via the USART.
So I can go no further with out some ideas.
Edited by Bizzie 2015-03-12
Rob White
aargee
Posted: 09:00pm 10 Mar 2015
Matherp,
Working at this end. Seems blindingly fast.
Just running a simple flash the leds program on the ST board, while the program is running it won't respond to CTL C?
The editor closes with a CTRL C allright.
- Rob.
aargee
Posted: 09:06pm 10 Mar 2015
  Bizzie said   I have purchased a STM32F4 Discovery I have it working using a USB/serial adapter.
An update!
Latest Update :-
You do have two USB cables connected? the Mini-USB is for power and the Micro-USB (near the audio socket) is for serial comms.
(I'll get this editing right eventually!!)Edited by aargee 2015-03-12
Bizzie
Posted: 09:22pm 10 Mar 2015
Yes,
It is very interesting that connecting the "power USB", the one with the red led's either side shows a usb connection in my system tray!
Connecting the other USB (near audio conn.) makes a sound on the PC, this is also the case when I press the black reset button on the STM32.
Rob White
Posted: 09:26pm 10 Mar 2015
  Quote  Just running a simple flash the leds program on the ST board, while the program is running it won't respond to CTL C?
Revised b12 hex file attached. I forgot I changed the uart routines to support ctr-C and hadn't done the same to the USB drivers
2015-03-11_090902_ARMmiteb12.zip
Edited by matherp 2015-03-12
Bizzie
Posted: 11:54pm 10 Mar 2015
I think I have progressed!!? - Have regained connection with the STM32, switched off and went to dinner.
I now can not erase the STM32's memory :-
I tried both a complete erase and by sector, note error during sector erases.
Just tried loading STM32B10.hex after another unsuccessful clear memory. I now have Ver. B10 running fine so will play with that for a while and try Ver. B11 later.Edited by Bizzie 2015-03-12
Rob White
Posted: 12:17am 11 Mar 2015
  Quote  I tried both a complete erase and by sector, note error during sector erases.
Try "Target/Setting/Mode/Connect under reset" when programming.
Bizzie
Posted: 12:32am 11 Mar 2015
That is the mode I have been using. If I try any other mode the STM32 ST-utility says it can not connect to use "Connect under reset".
Matherp, it seems the memory command has not been implemented, is that correct? It causes a lockup of my system I have to use the reset button to regain control.
Rob White
Posted: 12:42am 11 Mar 2015
You can also try putting a jumper between BOOT0 and VDD.
Just tested and "memory" works fine on both B10 and B12 using the hex files on the web and programming with ST-LINK so I assume you are not getting the chip properly erased. It must be fully erased before programming as the options are stored in sector 11 and they are different in the different versions.
     Page 1 of 3
