Local Time 13:55 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Machine code for SetPin 2,din
     Page 1 of 3
rogersan
Posted: 07:53pm 26 Apr 2015
To get the DHT11 software to work for the DHT22 I want to move the
SetPin 2,din into the start of CFunction dht11conv
Could someone give me the machine code for SetPin 2,din so I can add it into the CFunction.
twofingers
Posted: 12:45am 27 Apr 2015
AFAIK can you get the whole Micromite code from Geoff.
Michael
The lone and ...
rogersan
Posted: 07:23am 28 Apr 2015
Hi Michael
Sorry I do not understand your reply, what is AFAIKT? Would Geoff give me the listing of his Basic Interpreter so I can find the machine code for SetPin 2,din.
To get the machine code to SetPin 2,din, I need to set bit 0 of portaA data direction register, Do I have to download an assembler or C just to get this code? It used to be possible to get this from the manual of a microprocessor where each instruction was described and the machine code given.
Posted: 07:54am 28 Apr 2015
  Quote  so I can find the machine code for SetPin 2,din
rogersan
It isn't as easy as that, SETPIN does more than just set the appropriate bit in the data direction register. I wrote the DHT11 Cfunction in response to a request to support that specific sensor. The DHT22 is already fully supported by the Micromite MKII firmware so there was no need to cover that as well.
I don't have a DHT22 to test with so can't amend/test the Cfunction for the DHT22
If you want to do it yourself the C code is attached to my original listing and full details of how to write/compile Cfunctions is given on G8JCF's website
Posted: 08:05am 28 Apr 2015
  rogersan said   . . . what is AFAIKT?
As Far As I Know (no 'T')Edited by WhiteWizzard 2015-04-29
twofingers
Posted: 08:42am 28 Apr 2015
Thanks WW!
@Roger
AFAIK you will find the Micromite source (for personal use) here.
Also valuable for any Micromite user:
http://geoffg.net/micromite.html
Michael
The lone and ...
rogersan
Posted: 09:33am 28 Apr 2015
The DHT22 function in Micromite V 4.6 does not work at low temperatures, I will have to send my Micromite back to a Silicon Chip to reprogram it to V 4.6B, or buy a programmer.
I also found the the DHT11 read program would only work once, you cannot place it in a loop as you get an error message the second time it Is called.
Using SetPin(2)=1 if pin 2 is an defined already an input will give an error message. You can SetPin(2)=1 before you make pin 2 into an input or an output, but not if it defined as an input. This is strange you are just writing to the portaA output register, so it should not matter whether it is an output or input.
To allow the DHT11 read routine to be called more than once, I do this.
Initialise
SetPin(2)=0 'pin 2 will be forced low when it is set to be an output
Pin 2,din
In the DHT11 routine to pulse pin 2 low
Pin 2,dout 'force pin 2 low
Pause 1. ' for 1 millisec
Pin 2,din. 'Pin 2 high again
Unfortunately the time it takes for Pin 2,din and the call to th CFunction to read the DHT11 takes so long that the CFunction misses the first low going pulse from the DHT22. So I would like to put the Pin 2,din at the start of the CFunction. This means the low pulse from the Micromite is terminated in the CFunction so that it should not miss the reply from the DHT22.
So what do I need to add to the start of the CFunction to do this?
Posted: 10:13am 28 Apr 2015
@rogersan
Just to clarify something:
You quote: 'Pin 2,dout' & 'Pin 2,din' but my understanding when using 'din' and 'dout' is that it is used with 'SetPin(x), ...'.
To configure a pin as a digital input you use SETPIN(x),DIN (or SETPIN x,DIN)
To configure a pin as a digital output you use SETPIN(x),DOUT (or SETPIN x,DOUT)
Then to switch a digital output as high or low you use:
PIN(x)=1 (to set high)
PIN(x=0 (to set low)
Not sure if this will help you resolve things . . . .
WWEdited by WhiteWizzard 2015-04-29
rogersan
Posted: 10:21am 28 Apr 2015
You are right, I wrote the message without the code in front of me.
My options at the moment to reliably read a DHT22 is to have my Micromite II reprogrammed as V4.6B.
Or
Learn how to write a CFunction
BobD
Posted: 10:27am 28 Apr 2015
You should consider getting a programmer. They are cheap. Updates to the firmware will occur occasionally. It could cost you more to get others to do the work for you. That said, if you indicate approximately where you are then you may find someone able to help you.
rogersan
Posted: 09:36pm 29 Apr 2015
To learn how to write CFunctions for the Micromite II, is the 74 page MMbasic Mark II CFunctions Manual the one to use?
rogersan
Posted: 06:10pm 30 Apr 2015
To set the data direction of portaA bit 0 TO AN INPUT can be done by writing Ox0001 to the register TRISASET, however I need the address of the TRISASET register for the C program.
Can anyone give me the address of the TRISASET register for the PIC32MX170F256-50i/SP?
Posted: 09:28pm 30 Apr 2015
Would not the Microchip datasheet for the PIC32 chip not give you that information?
I have never needed to delve into Cfunctions - yet - so I don't know if that info is in the manual or not.
rogersan
Posted: 09:47pm 30 Apr 2015
Reading the fine print on the Datasheet there is an offset of 8 between the address of TRISA and TRISASET
so the address of TRISA is BF886010 in hexadecimal
and the address of TRISASET is BF886018
So for the CFunction I will try
#define portad *(volatile unsigned int *)Oxbf886018 //portasetdir
Portad=1; //pin 2 now an input
G8JCF
Posted: 11:26pm 30 Apr 2015
I think that perhaps plib.h may be what you need
Peter
The only Konstant is Change
rogersan
Posted: 04:04pm 01 May 2015
The C Make File plib.h is very impressive for the range of functions it makes available. It is certainly worth using for complex projects written in C.
rogersan
Posted: 07:44pm 02 May 2015
Trying to download the X32 compiler from Microchip.
The MAC address of my PC is required, I got this but the download page keep saying it is invalid, The MAC STARTS with E0 but this is not accepted.
Any suggestions?
G8JCF
Posted: 10:19pm 02 May 2015
Hi @rogersan
I've never heard of anyone having a problem like the one you've described, when I downloaded XC32 for Windows after I had installed MPLAB/X I can't recall MCHP asking for my MAC address.
Has anybody else experienced what @rogersan is going through ?
Peter
rogersan
Posted: 01:31am 03 May 2015
I found that the MAC address would only be accepted if you take out the dashes. You can then run a .bat file. This still does not download XC32 which you have to do separately.
I tried MPLAB V3.3 to create a CFunction but this does not have an "Additional Options" box in Project Options, so you cannot enter -fPIC -mono -abicals which is critically important.
G8JCF
Posted: 04:43am 03 May 2015
Hi, this might help people make sure their MPLab/X + XC32 installation and configuration is correct
2015-05-03_144234_MPLabCheckout.zip
Peter
PS, @RogerSan I've sent you an email directly about this.Edited by G8JCF 2015-05-04
     Page 1 of 3
