Forum Index : Microcontroller and PC projects : uM2(+): ILI9341 enhanced driver, backpack
| Page 1 of 2 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11893 |
Please view the video to see what is now possible. This loadable driver adds significant functionality to that supported by the in-built firmware and takes just 8k of memory. It is faster: CLS takes 186msec using the in-built driver on a MX170 at 40MHz. The new driver takes 93msec It is more colourful: The in-built driver uses RGB565 (65k colours), the new driver uses RGB666 (262k colours) It supports transparent text and bitmaps: use 1 for the background colour and only the pixels forming the character or bitmap will be changed on the screen, the background will be left intact. It supports reading the graphic memory: This allows rectangular areas of the screen to be saved to an array in Basic and then re-stored at a later date. It supports outputting images from SD card on the MM2: It allows an area for writing to be set up on the display and then a byte sequence of R0,G0,B0,R1,G1,B1....Rn,Gn,Bn can be used to write full colour information to the display. It supports writing, reading and restoring triangles to/from the display: triangles are the basis of much of advanced computer graphics. The new facilities allow things like gauge or clock pointers and hands to be written as multiple triangles with the option of overlaying the display background. A demo program for the Micromite (MX170) is attached. This should work on Geoff's LCD backpack as well as many other boards. Note all three SPI pins must be connected (MOSI, MISO and CLK) as well as user selectable CS, Reset and D/C (may be labelled CD, A0). The demo optionally uses the SDcard to load a background image using the Micromite MX170 SD card driver The driver will normally be saved to the library using LIBRARY SAVE and will be automatically loaded on restart. The Zip file includes both Micromite (MX170) and Micromite+ (MX470) versions of the drivers. These should work on all versions of the Micromite running 5.2 or above (28,44,64,100-pin). Also included are the picture files and a test/demo program for the Micromite+ as well as the C source. 2016-07-11_113754_ili9341.zip Option explicit
option default NONE ' ' Demo of functionality of ILI9341 enhanced functionality driver for Micromite MX170 ' const SD_CS_PIN = 23 'set to 0 for demo if SDcard not connected ' connect other SD card pins in parallel with ILI9341 display i.e. SPI 1 ' ' Codes for use of the ILI9341 driver ' const writebuffer=5 ' writes colour data saved in a string into a region previously defined ' The zero position of the string contains its length and the subsequent bytes the RGB intensities ' e.g. 6,R1,G1,B1,R2,G2,B2 ' this routine can be called repeatedly to fill the defined region ' The string length must be divisible by 3 const saverectangle=6 ' reads the contents of a rectangle off the screen, 3 bytes per pixel (R,G,B) ' the parameters are: ' address of a buffer to receive the data ' x,y coordinates of top left, width, height ' byte position in the buffer to start writing const restorerectangle=7 ' writes the contents of a buffer to the screen, 3 bytes per pixel (R,G,B) ' the parameters are: ' address of a buffer to provide the data ' x,y coordinates of top left, width, height ' byte position in the buffer to start reading const defineregion=8 ' defines a region that can be written into specified as x,y coordinates of top left, width, height ' the parameters are: ' code to indicate the region will be used for writing (1) or reading (0) ' x,y coordinates of top left, width, height const writetriangle=9 ' ' routine to write a single filled triangle to the screen ' the parameters are: ' dummy parameter - set to zero ' colour of the triangle to be written ' arrays of the x1,y1, x2,y2, x3,y3 coordinates of the triangle const triangles=128 ' + number of triangles ' routine to save current screen data for a triangle and replace it with a user supplied colour and/or replace the screen data with information previously stored. ' the parameters are: ' Number of triangles to be processed ' a buffer big enough to hold the RGB data for all the triangles to be stored (3 bytes per pixel) ' array of the colours of the triangles to be written (use -1 to restore from the buffer) ' arrays of the x1,y1, x2,y2, x3,y3 coordinates of the triangles ' returns the number of byte used in the buffer: divide by 8 and add 1 to get the required number of integers ' ' ' Codes for use of the SD card driver ' see http://www.thebackshed.com/forum/forum_posts.asp?TID=8648 for more details ' const mount=0 const fileopen=1 const readfile=2 const writefile=3 const opendir=4 const readdir=5 ' const buffersize=5000 dim integer buff(buffersize),i,j,maxd if MM.vres>mm.hres then maxd=mm.vres else maxd=mm.hres endif if SD_CS_PIN then DisplayPicture("tiger2.ppm",0,0) else cls rgb(GRAY) for i=5 to sqr(mm.hres^2 + mm.Vres^2)/2 step 5 'cover the screen in circles circle mm.hres\2,mm.vres\2,i next i endif i=ILI9341_MX170(saverectangle, buff(), 95, 80, 130, 80, 0) 'save the central screen area to a buffer for j=0 to 10 'flash transparent text overlayed on the background text mm.hres\2,mm.vres\2-28,"ILI9341",CM,,2,rgb(red),1 text mm.hres\2,mm.vres\2,"Enhanced",CM,,2,rgb(red),1 text mm.hres\2,mm.vres\2+28,"Driver",CM,,2,rgb(red),1 pause 500 i=ILI9341_MX170(restorerectangle, buff(), 95, 80, 130, 80, 0) 'restore the central screen area to a buffer pause 500 next j ' ' rotate a pointer over the background ' const Y_top = 0 'Y coordinate of top of the area swept by the pointer on the screen const X_left = 0 'X coordinate of left of the iarea swept by the pointer on the screen const Y_point = mm.vres\2 'Y coodinate of the centre of the pointer relative to the top const X_point = mm.hres\2 'X coodinate of the centre of the pointer relative to the left ' ' Now we define the pointer as the X,Y coordinates of a number of triangles with the rotation point at 0,0 ' It is simplest to define this in the 12-oclock position which means the Y-coordinates at the top of the pointer will be negative ' The order of data elements in the array is: ' t1x1,t1y1,t1x2,t1y2,t1x3,t1y3, t2x1,t2y1,t2x2,t2y2,t2x3,t2y3,...tntx1,tnty1,tntx2,tnty2,tntx3,tnty3 ' dim integer nt=2 'Number of triangles used to define the pointer dim integer ptr(5,nt-1)=(-4,100,-4,-100,4,100,-4,-100,4,-100,4,100) DIM INTEGER pcolour=rgb(green) 'define the colour of the pointer dim integer xx0(nt*2-1),yy0(nt*2-1),xx1(nt*2-1),yy1(nt*2-1),xx2(nt*2-1),yy2(nt*2-1),tcol(nt*2-1) dim integer first=1 'marker to control alternate processing on first time through the loop for j=0 to 360*10 step 3 drawpointer(j) pause 100 next j end Sub drawpointer(angle as float) Local integer i for i=0 to nt-1 rotatetriangle(i,pcolour,angle,X_point+X_left,Y_point+Y_top,ptr(0,i),ptr(1,i),ptr(2,i),ptr(3,i),ptr(4,i),ptr(5,i)) 'rotate the pointer into the drawing array next i if first then 'store the background and write the pointer i=ILI9341_MX170(triangles or nt, buff() , tcol(nt), xx0(nt), yy0(nt), xx1(nt), yy1(nt), xx2(nt), yy2(nt)) first=0 else 'replace the background over the last pointer, store the background for the new pointer and write itand write the pointer i=ILI9341_MX170(triangles or nt*2, buff() , tcol(), xx0(), yy0(), xx1(), yy1(), xx2(), yy2()) endif End Sub ' sub rotatetriangle(n as integer, col as integer, angle as float, x as integer, y as integer, x0 as integer, y0 as integer, x1 as integer, y1 as integer, x2 as integer, y2 as integer) local float sine=sin(rad(angle)),cosine=cos(rad(angle)) local integer x0a,y0a,x1a,y1a,x2a,y2a x0a= x0*cosine - y0 * sine + x y0a= y0*cosine + x0 * sine + y x1a= x1*cosine - y1 * sine + x y1a= y1*cosine + x1 * sine + y x2a= x2*cosine - y2 * sine + x y2a= y2*cosine + x2 * sine + y xx0(n)=xx0(n+nt) yy0(n)=yy0(n+nt) xx1(n)=xx1(n+nt) yy1(n)=yy1(n+nt) xx2(n)=xx2(n+nt) yy2(n)=yy2(n+nt) xx0(n+nt)=x0a yy0(n+nt)=y0a xx1(n+nt)=x1a yy1(n+nt)=y1a xx2(n+nt)=x2a yy2(n+nt)=y2a tcol(n)=-1 tcol(n+nt)=col end sub '*************************************************************************************************** ' ' Display a picture from the SD card ' Code should work on any of the MM2 supported displays ILI9341, ST7735, ILI9163 ' Picture must be in binary .PPM format ' ' Parameters are: ' PIC$ = filename of the picture to be displayed ' StartX% = X coordinate of the top left of the picture ' StartY% = Y coordinate of the top left of the picture ' ' Note: the routine checks that the picture is not too big for the screen and reports an error if it is ' Sub DisplayPicture(PIC$, StartX%, StartY%) LOCAL Buffer$,addbuffer$ length 3 LOCAL Result%=-1 LOCAL NumBytes%,a%,i% if(SDcard(mount,SD_CS_PIN)) THEN : Print "Unable to mount Disk" : END : ENDIF IF(SDcard(fileopen,PIC$)) then : print "Unable to open file" : END : ENDIF 'Read the first 128 bytes Buffer$=STRING$(128," ") IF(SDcard(readfile,buffer$,0,len(buffer$),NumBytes%)) THEN : PRINT "Unable to read file" : END : ENDIF a%=instr(buffer$,chr$(10)) ' look for the first CR if left$(buffer$,a%-1)="P6" then buffer$=right$(buffer$,len(buffer$)-a%) a%=instr(buffer$,chr$(10)) ' look for the second CR buffer$=right$(buffer$,len(buffer$)-a%) a%=instr(buffer$,chr$(32)) ' look for the space between dimensions local width%=val(left$(buffer$,a%-1)) buffer$=right$(buffer$,len(buffer$)-a%) a%=instr(buffer$,chr$(10)) ' look for the third CR LOCAL height%=val(left$(buffer$,a%-1)) buffer$=right$(buffer$,len(buffer$)-a%) a%=instr(buffer$,chr$(10)) ' look for the fourth CR buffer$=right$(buffer$,len(buffer$)-a%) a%=len(buffer$) mod 3 addBuffer$=STRING$(3-a%," ") ' we need to make sure we have a number of bytes divisible by three in the buffer Result%=SDcard(readfile,addbuffer$,-1,len(addbuffer$),NumBytes%) buffer$=buffer$+addbuffer$ if (StartX%+width%>MM.HRES) OR (StartY%+height%>MM.VRES) then print "Picture too big", width%," x",height% else i%=ILI9341_MX170(defineregion, 1, StartX%, StartY%, width%, height%) i%=ILI9341_MX170(writeregion,Buffer$) Buffer$=STRING$(255,chr$(0)) do Result%=SDcard(readfile,buffer$,-1,255,NumBytes%) if numbytes%<>0 then i%=ILI9341_MX170(writeregion,Buffer$) loop while NumBytes%<>0 endif else Print "Invalid File Format" endif end sub CFunction SDcard ' SPI 1 version 0000062F 'rcv_spi 240300FF 3C02BF80 AC435820 3C03BF80 8C625810 30420080 1040FFFD 3C02BF80 8C425820 03E00008 304200FF 'xmit_spi 308400FF 3C02BF80 AC445820 3C03BF80 8C625810 30420080 1040FFFD 3C02BF80 8C425820 03E00008 304200FF 'mem_set 10C00006 00801021 00862021 A0450000 24420001 5444FFFE A0450000 03E00008 00000000 'mem_cmp 2407FFFF 24C6FFFF 10C70008 00001021 80830000 80A20000 00621023 14400003 24840001 1000FFF7 24A50001 03E00008 00000000 'mystrlen 80830000 10600006 00001021 24420001 00821821 80630000 5460FFFD 24420001 03E00008 00000000 'MtoC 00801021 80870000 10E0000A 00802821 24830001 00873821 10600004 00000000 90660000 A0A60000 24A50001 1467FFFA 24630001 03E00008 A0A00000 'send_cmd 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 309100FF 7C111420 04410009 00A09021 24040077 00002821 0411FFF4 00000000 2C430002 10600034 8FBF001C 3231007F 3C109D00 8E030090 8E02001C 80640030 0040F809 24050006 0411FFA3 00000000 8E030090 8E02001C 80640030 0040F809 24050005 0411FF9C 00000000 02202021 0411FFA4 00000000 00122602 0411FFA1 00000000 7E443C00 0411FF9E 00000000 7E443A00 0411FF9B 00000000 324400FF 0411FF98 00000000 24020040 12220006 24040095 3A310048 24020001 24030087 00402021 0071200A 0411FF8E 00000000 2410000A 0411FF80 00000000 7C021C20 04610004 2610FFFF 321000FF 1600FFF9 00000000 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020 'disk_readp 27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809021 00C09821 00E0A021 3C029D00 8C42008C 8C4300FC 30630008 00051240 24040051 0043280A 0411FFA6 00000000 14400024 24100001 34109C40 241100FF 0411FF5B 00000000 14510005 2610FFFF 1600FFFB 00000000 1000001A 24100001 240300FE 14430017 24100001 00138823 26310202 12600006 02348823 0411FF4C 00000000 2673FFFF 1660FFFC 00000000 02548021 0411FF46 00000000 A2420000 26520001 1650FFFB 00000000 0411FF40 00000000 2631FFFF 1620FFFC 00000000 00008021 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FF34 00000000 02001021 8FBF0024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0028 'clust2sect 24A5FFFE 8C830008 2463FFFE 00A3182B 10600005 00001021 90830002 8C820014 70A32002 00821021 03E00008 00000000 'dir_rewind 27BDFFE8 AFBF0014 AFB00010 00A08021 A4A00000 8CA50008 24030001 10A30015 24020001 8C830008 00A3182B 50600012 8FBF0014 54A00008 AE05000C 90830000 24020003 54620008 AE00000C 8C850010 10A00005 AE05000C 0411FFDD 00000000 10000003 AE020010 8C820010 AE020010 00001021 8FBF0014 8FB00010 03E00008 27BD0018 'create_name 27BDFFE0 AFBF001C AFB10018 AFB00014 00A08021 8C910004 02202021 24050020 2406000B 0411FF09 00000000 8E080000 00002021 00001821 24070008 2409002F 2406002E 240A0008 01031021 90420000 24630001 2C450021 14A00018 306300FF 50490017 01031821 10460003 0087282B 14A00008 2445FF9F 54EA0011 01031821 5446000F 01031821 01402021 1000FFEE 2407000B 30A500FF 2CA5001A 10A00003 02242821 2442FFE0 304200FF A0A20000 24840001 1000FFE4 308400FF 01031821 AE030000 2C420021 A222000B 00001021 8FBF001C 8FB10018 8FB00014 03E00008 27BD0020 'get_clust 90840000 24020003 14820006 00001821 90A30015 00031A00 90A20014 00621825 00031C00 90A2001B 00021200 90A4001A 00441025 03E00008 00621025 'get_fat 27BDFFE0 AFBF001C 2CA20002 1440001B 24030001 8C820008 00A2102B 10400018 00601021 000519C2 8C82000C 30A6007F 27A40010 00622821 00063080 24070004 0411FF31 00000000 1440000C 24030001 93A30013 00031E00 93A20012 00021400 00621825 93A20010 00621825 93A20011 00021200 00621825 7C63D800 00601021 8FBF001C 03E00008 27BD0020 'dir_next 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00808821 00A08021 94B20000 26520001 3252FFFF 12400028 24020003 8CA30010 50600026 8FBF001C 3242000F 54400021 A6120000 24630001 ACA30010 8CA5000C 14A00007 00121902 94830004 0243182B 14600017 24020003 10000018 8FBF001C 90820002 2442FFFF 00621024 54400011 A6120000 0411FFBA 00000000 00402821 2C430002 1460000C 24020001 8E230008 00A3182B 10600008 24020003 AE05000C 02202021 0411FF39 00000000 AE020010 A6120000 00001021 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020 'dir_find 27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00809821 00A08821 00C09021 0411FF31 00000000 14400021 00408021 96260000 30C6000F 02402021 8E250010 00063140 24070020 0411FED2 00000000 0002802B 16000017 02001021 92420000 50400013 24100003 9242000B 30420008 14400008 02602021 02402021 8E250004 2406000B 0411FE55 00000000 10400008 02602021 02202821 0411FF9F 00000000 1040FFE3 00408021 10000002 02001021 02001021 8FBF0024 8FB30020 8FB2001C 8FB10018 8FB00014 03E00008 27BD0028 'follow_path 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00809021 00A08021 AFA7002C 80E20000 24030020 14430006 00C08821 24E70001 AFA7002C 80E20000 5043FFFD 24E70001 2403002F 54430004 AE000008 24E70001 AFA7002C AE000008 8FA2002C 90420000 2C420020 10400008 02002021 02402021 02002821 0411FEE7 00000000 1000001B A2200000 02002021 27A5002C 0411FF02 00000000 14400015 02402021 02002821 02203021 0411FFA0 00000000 14400010 8FBF001C 8E030004 9063000B 5460000D 8FB20018 9222000B 30420010 10400006 02402021 02202821 0411FF28 00000000 1000FFE8 AE020008 24020003 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020 'pf_lseek 27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00808021 1080004F 24020005 90830001 30630001 1060004B 24020004 8C82001C 0045902B 00B2100A 00409021 8C830018 AC800018 12400043 00001021 90910002 10600012 00118A40 2463FFFF 2642FFFF 0051001B 022001F4 00001012 0071001B 022001F4 00002012 0044102B 54400008 8E050020 00111023 00431824 AE030018 02439023 10000003 8E050024 8E050020 AE050024 0232102B 10400018 00119823 02519023 02002021 0411FEFC 00000000 00402821 2C420002 54400006 A2000001 8E020008 00A2102B 54400004 AE050024 A2000001 1000001B 24020001 8E020018 00511021 AE020018 02531021 00511821 0223182B 5460FFEB 00409021 8E020018 00529021 AE120018 02002021 0411FE6E 00000000 54400004 92040002 A2000001 10000008 24020001 2484FFFF 8E030018 00031A42 00831824 00431021 AE020028 00001021 8FBF0024 8FB30020 8FB2001C 8FB10018 8FB00014 03E00008 27BD0028 'pf_read 27BDFFD0 AFBF002C AFB60028 AFB50024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00808021 00A0A821 00E09821 ACE00000 1080004A 24020005 90830001 30630001 10600046 24020004 8C92001C 8C820018 02429023 0246102B 00C2900A 1240003F 00001021 00A0A021 24160200 8E020018 304301FF 5460001F 8E060018 00021A42 92110002 2631FFFF 00718824 323100FF 1620000E 02002021 54400003 8E050024 10000003 8E020020 0411FEA3 00000000 2C430002 50600004 AE020024 A2000001 10000026 24020001 02002021 8E050024 0411FE24 00000000 14400004 00518821 A2000001 1000001D 24020001 AE110028 8E060018 30C601FF 02C61023 0052882B 0251100A 00408821 00002021 0295200B 8E050028 00403821 0411FDC9 00000000 50400004 8E020018 A2000001 1000000B 24020001 00511021 AE020018 02519023 8E620000 00511021 12400003 AE620000 1000FFC6 0291A021 00001021 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0030 'disk_initialize 27BDFFD0 AFBF002C AFB30028 AFB20024 AFB10020 AFB0001C 2403003B 3C02BF80 AC435830 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 2410000A 0411FD11 00000000 2610FFFF 321000FF 1600FFFB 24040040 00002821 0411FD4F 00000000 24030001 14430061 3C029D00 24040048 240501AA 0411FD48 00000000 24030001 14430037 240400E9 27B00010 27B10014 0411FCFC 00000000 A2020000 26100001 1611FFFB 93A30012 24020001 1462004E 00008021 93A30013 240200AA 1462004B 3C029D00 10000008 24112710 0040F809 24040064 2631FFFF 16200005 240400E9 1000003F 00008021 3C109D00 240400E9 3C054000 0411FD28 00000000 5440FFF3 8E020004 12200038 00008021 2404007A 00002821 0411FD20 00000000 14400033 3C029D00 24110004 0411FCD6 00000000 27A40010 00901821 26100001 1611FFFA A0620000 93B00010 32100040 2402000C 24030004 0070100A 10000023 00408021 00002821 0411FD0C 00000000 2C420002 24030002 24100001 0062800B 240300E9 24130041 0062980B 24112710 10000006 3C129D00 0040F809 24040064 2631FFFF 52200011 00008021 02602021 00002821 0411FCF9 00000000 5440FFF6 8E420004 52200009 00008021 24040050 24050200 0411FCF1 00000000 10000003 0002800B 10000002 3C029D00 3C029D00 8C43008C AC7000FC 8C430090 8C42001C 80640030 0040F809 24050006 0411FC9E 00000000 12000003 24030002 3C02BF80 AC435830 2E020001 8FBF002C 8FB30028 8FB20024 8FB10020 8FB0001C 03E00008 27BD0030 'disk_writep 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 10800014 00808021 30A5FFFF 10A00052 00009021 97828010 1040004F 00858821 92040000 26100001 0411FC8C 00000000 97828010 2442FFFF 3042FFFF 12110045 A7828010 5440FFF7 92040000 10000042 00009021 10A00016 97908010 3C029D00 8C42008C 8C4300FC 30630008 00051240 24040058 0043280A 0411FCB2 00000000 14400035 24120001 240400FF 0411FC73 00000000 240400FE 0411FC70 00000000 24020200 A7828010 1000002B 00009021 26100002 12000008 2610FFFF 2411FFFF 00002021 0411FC65 00000000 2610FFFF 1611FFFC 00002021 0411FC55 00000000 3042001F 24030005 14430010 24120001 10000005 241207D0 0040F809 240403E8 10000003 2652FFFF 241100FF 3C109D00 0411FC47 00000000 50510004 2E520001 5640FFF5 8E020004 24120001 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FC3A 00000000 10000003 02401021 00009021 02401021 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020 'pf_write 27BDFFD0 AFBF002C AFB60028 AFB50024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00808021 00C09021 00E09821 ACE00000 1080007B 24020005 90830001 30640001 10800077 24020004 14C00010 30630040 5060000A 92020001 00002021 00002821 0411FF84 00000000 50400004 92020001 A2000001 1000006A 24020001 304200BF A2020001 10000066 00001021 54600006 8E03001C 8E030018 2402FE00 00621024 AE020018 8E03001C 8E020018 00621023 0052182B 14600005 00000000 00A0A021 24150200 10000005 2416FFBF 1440FFFB 00409021 10000053 8FBF002C 8E020018 304301FF 54600029 8E110018 00021A42 92110002 2631FFFF 00718824 323100FF 1620000E 02002021 54400003 8E050024 10000003 8E020020 0411FD32 00000000 2C430002 50600004 AE020024 A2000001 1000003B 24020001 02002021 8E050024 0411FCB3 00000000 14400004 00512821 A2000001 10000032 24020001 AE050028 00002021 0411FF43 00000000 50400004 92020001 A2000001 10000029 24020001 34420040 A2020001 8E110018 323101FF 02B18823 0232102B 0242880A 02802021 02202821 0411FF33 00000000 50400004 8E020018 A2000001 10000019 24020001 00511021 AE020018 8E620000 00511021 AE620000 8E020018 304201FF 5440000D 02519023 00002021 00002821 0411FF21 00000000 50400004 92020001 A2000001 10000007 24020001 00561024 A2020001 02519023 1640FFB1 0291A021 00001021 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0030 'check_fs 27BDFFE0 AFBF001C AFB10018 AFB00014 00808021 00A08821 240601FE 24070002 0411FC20 00000000 14400028 24030003 92040001 00042200 92020000 00822025 7C042620 2402AA55 14820020 24030002 02002021 02202821 24060036 24070002 0411FC10 00000000 1440000A 02002021 92040001 00042200 92020000 00822025 7C042620 24024146 10820010 00001821 02002021 02202821 24060052 24070002 0411FC00 00000000 14400008 24030001 92030001 00031A00 92020000 00621825 7C031E20 38634146 0003182B 00601021 8FBF001C 8FB10018 8FB00014 03E00008 27BD0020 'pf_mount 27BDFFB8 AFBF0044 AFB10040 AFB0003C 00808021 0411FE3B 00000000 30420001 14400087 24030002 27A40010 00002821 0411FFBA 00000000 24030001 1443001A 00008821 27A40010 00002821 240601BE 24070010 0411FBDA 00000000 14400078 24030001 93A20014 10400075 24030006 93B1001B 00118E00 93A2001A 00021400 02228825 93A20018 02228825 93A20019 00021200 02228825 27A40010 02202821 0411FF9E 00000000 24040003 10440064 24030001 14400062 24030006 27A40010 02202821 2406000D 24070024 0411FBBC 00000000 1440005A 24030001 93A2001A 00021200 93A30019 00431025 1440000C 93A30013 93A3002A 00031E00 93A20029 00021400 00621025 93A30027 00431025 93A30028 00031A00 00431025 93A30013 70431002 93A60012 00063200 93A30011 00C33025 02268821 AE11000C 93A50010 A2050002 93A40015 00042200 93A30014 00832025 A6040004 93A30017 00031A00 93A70016 00671825 1460000B 00042102 93A70026 00073E00 93A30025 00031C00 00E31825 93A70023 00671825 93A70024 00073A00 00671825 00661823 00621823 00641823 0065001B 00A001F4 00003012 24C50002 AE050008 24C6F00A 3407EFFF 00C7302B 2CA70FF7 24030002 0066380B 3403FFF7 00A3282B 10A0001F 24030003 10E00017 24030006 24030003 14E3000D A2070000 93A50032 00052E00 93A30031 00031C00 00A32825 93A3002F 00A32825 93A30030 00031A00 00A31825 10000003 AE030010 00511821 AE030010 02248821 02221021 AE020014 A2000001 00001821 00601021 8FBF0044 8FB10040 8FB0003C 03E00008 27BD0048 1000FFE6 A2030000 'pf_open 27BDFFA0 AFBF005C AFB10058 AFB00054 00808821 00A03821 10800025 24100005 A0800001 27A20024 AFA20014 27A50010 27A60030 0411FC99 00000000 1440001C 00408021 93A20030 10400018 93A2003B 30420010 54400016 24100003 02202021 27A50030 0411FBED 00000000 AE220020 93A3004F 00031E00 93A2004E 00021400 00621025 93A3004C 00431025 93A3004D 00031A00 00431025 AE22001C AE200018 24020001 10000002 A2220001 24100003 02001021 8FBF005C 8FB10058 8FB00054 03E00008 27BD0060 'pf_opendir 27BDFFB0 AFBF004C AFB10048 AFB00044 00808021 00A08821 00C03821 10800018 24020005 27A20010 ACA20004 27A6001C 0411FC68 00000000 14400012 8FBF004C 93A2001C 1040000B 02002021 93A30027 30630010 1060000A 24020003 02002021 27A5001C 0411FBBB 00000000 AE220008 02002021 02202821 0411FB5C 00000000 8FBF004C 8FB10048 8FB00044 03E00008 27BD0050 'get_fileinfo 8C830010 10600036 24C20009 90A30000 24040020 1064000E 00A02021 244A0008 24090005 240800E5 10000003 240B0020 106B0007 24840001 00693826 0107180A A0430000 24420001 544AFFF9 90830001 90A40008 24030020 1083000A 2403002E A0430000 90A30008 24040020 1464001E 24420001 10000004 90A3000B A0430000 24420001 90A3000B A0C30008 90A4001F 00042600 90A3001E 00031C00 00831825 90A4001C 00641825 90A4001D 00042200 00641825 ACC30000 90A30019 00031A00 90A40018 00641825 A4C30004 90A30017 00031A00 90A40016 00641825 A4C30006 03E00008 A0400000 A0430000 90A30009 24040020 1064FFE3 24420001 A0430000 90A3000A 1464FFDD 24420001 1000FFDE 90A3000B 'dir_read 27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809821 00A08021 00C08821 24020003 241200E5 10000019 2414002E 30C6000F 02202021 00063140 24070020 0411FAA9 00000000 0002102B 54400016 AE000010 92230000 50600012 24020003 10720005 9224000B 10740003 30840008 1080000E 8FBF0024 02602021 02002821 0411FB7A 00000000 54400007 AE000010 8E050010 54A0FFE6 96060000 10400003 8FBF0024 AE000010 8FBF0024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0028 'pf_readdir 27BDFFB0 AFBF004C AFB20048 AFB10044 AFB00040 00808821 00A08021 00C09021 1080001B 24020005 27A20010 14C00005 ACA20004 0411FACF 00000000 10000015 8FBF004C 27A6001C 0411FFB9 00000000 24030003 10430004 02002021 1440000D 8FBF004C 02002021 27A5001C 02403021 0411FF6A 00000000 02202021 02002821 0411FB48 00000000 38430003 0003100A 8FBF004C 8FB20048 8FB10044 8FB00040 03E00008 27BD0050 'main 27BDFFB8 AFBF0044 AFBE0040 AFB7003C AFB60038 AFB50034 AFB40030 AFB3002C AFB20028 AFB10024 AFB00020 00808821 00A0A021 00C0A821 00E0B021 3C02BF80 34038060 AC435800 24030C00 AC435840 24030002 AC435830 3C039D00 8C72008C 26530050 26570078 8C445830 AE440044 8C455800 8C64008C AC850048 8C445840 8C62008C AC44004C 8E220000 144000C0 00008021 3C02BF81 8C44F220 7C84D800 3C030661 3463A053 1083000B 24020050 3C02BF81 8C43F220 7C63D800 3C020660 3442A053 00621026 24030050 2404000C 0082180B 00601021 3C039D00 8C630088 00431021 8C430000 24020065 10620084 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040014 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030014 24050003 00A4180B 00602021 24050008 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040014 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030014 24050003 00A4180B 00602021 24050064 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040029 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030029 2405000E 00A4180B 00602021 24050002 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040029 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030029 2405000E 00A4180B 00602021 24050064 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 2404000E 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 2403000E 24050019 00A4180B 00602021 24050008 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 2404000E 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 2403000E 24050019 00A4180B 00602021 24050064 0040F809 00003021 3C02BF81 8C43FA84 24040001 7C831804 AC43FA84 3C02BF81 8C43FB04 24040003 7C831804 AC43FB04 3C02BF80 34038060 AC435800 24030C00 AC435840 3C109D00 8E020090 92830000 A0430030 8E030090 8E020010 80640030 24050008 0040F809 00003021 8E030090 8E02001C 80640030 0040F809 24050006 8E02008C AC4000F8 02602021 0411FD8C 00000000 00408021 8E230000 24020001 1462000B 24020002 82820000 02821021 A0400001 02602021 26850001 0411FE18 00000000 00408021 8E230000 24020002 5462001E 8E230000 8EA50000 04A00004 02602021 0411FAF7 00000000 00408021 56000016 8E230000 8EC60000 28C20100 10400009 02602021 26850001 27A70010 0411FB4A 00000000 00408021 8FA20010 10000006 A2820000 02802821 27A70010 0411FB42 00000000 00408021 8FA30010 8FA20058 AC430000 8E230000 24020003 54620067 8E230000 8EA20000 04410005 3C029D00 8C42008C 8C4200F8 AEA20000 3C029D00 8C42008C 8C4400F8 8EC30000 00831821 AC4300F8 8EBE0000 2410FE00 03D08024 02602021 02002821 0411FAC9 00000000 8EC60000 28C20100 02821021 AFA20018 8EA20000 10500040 3C029D00 8C42003C 0040F809 24040200 0040A821 02602021 00402821 24060200 27A70010 0411FB16 00000000 02602021 02002821 0411FAB4 00000000 1440002A 00408021 33DE01FF 8EC40000 03C42021 2C820201 14400003 00008021 2490FE00 24040200 03C4102A 10400008 8FA20018 02BEF021 02A42021 90430000 A3C30000 27DE0001 17C4FFFC 24420001 02602021 02A02821 8FA60010 27A70010 0411FC4D 00000000 1200000A 02602021 8EC50000 00B02823 8FA20018 00452821 02003021 27A70010 0411FC43 00000000 02602021 00002821 00003021 27A70010 0411FC3D 00000000 00408021 3C029D00 8C420044 0040F809 02A02021 1000000E 8E230000 02602021 8FA50018 27A70010 0411FC31 00000000 02602021 00002821 00003021 27A70010 0411FC2B 00000000 00408021 8E230000 24020004 5462000B 8E230000 02802021 0411F888 00000000 02602021 02E02821 00403021 0411FDB4 00000000 00408021 8E230000 24020005 1462003E 3C029D00 265200A0 02602021 02E02821 02403021 0411FE47 00000000 92440008 24030016 14830007 00408021 02602021 02E02821 02403021 0411FE3E 00000000 00408021 56000029 82430009 8FA20010 02421021 80420009 50400024 82430009 92420008 30420010 54400006 2402003C 24110001 02911821 00001021 1000000C 2405000C A2820001 24020044 A2820002 24020069 A2820003 24020072 A2820004 2402003E A2820005 1000FFF2 24110006 02422021 90840009 A0640000 24420001 1445FFFB 24630001 2402000C AFA20010 26440009 0411F83E 00000000 2631FFFF 02228821 A2910000 82430009 2402FFFF 0043800A 3C029D00 8C43008C 8C640044 3C02BF80 AC445830 8C640048 AC445800 8C63004C AC435840 00101FC3 02001021 8FBF0044 8FBE0040 8FB7003C 8FB60038 8FB50034 8FB40030 8FB3002C 8FB20028 8FB10024 8FB00020 03E00008 27BD0048 End CFunction |
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
Do you have this driver for the 64-pin MM+ as well? http://rittle.org -------------- |
Should have read it better http://rittle.org -------------- |
Wow, picture-in-picture graphics with a PIC170 MM2 and $10 serial ILI9341 full colour screen. Getting really serious here Peter, congratulations. Greg |
@matherp Please can you confirm that this runs on an 'unmodified' BackPack (in terms of hardware) i.e. no extra PIC pins (or TFT pins) need to be 'connected'from Geoff's published version. I am about to order some BackPack PCBs as available on Geoff's website (Construction Pack), but would prefer to 'modify' the design if a 'hack' is indeed needed. From what I see it is fine - but want to be 100% certain. Thanks for any confirmation . . . .
WW |
I haven't got one to test but as far as I can see it has all the connections needed. Of course the backpack doesn't connect to the SD pins so they would need to be patch wired to also use the MX170 SD card driver. If you were to do another version having these also plug in like on this board for the 64-pin would be an improvement from my perspective |
jman![]() Guru Joined: 12/06/2011 Location: New ZealandPosts: 711 |
Peter this is fantastic and very much appreciated Regards Jman |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1773 |
@Peter THAT'S FANTASTIC! ![]() ![]() Congratulations!
Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Thanks for the kind words. Unfortunately there was finger trouble in the zip file and in the listing above due to various cut and paste errors when I was adding the comments const writebuffer=5
should have been const writeregion=5
I also used the 5.1 version of the SDcard drivers which have a different calling sequence. Both of these faults are corrected in the attached zip. Finally I managed to omit the Basic MM2 driver completely
2016-07-12_172905_ILI9341.zip The files included are as follows: ILI9341enhanced.c: C source of the driver ILI9341MM2.bas: the loadable driver for the MM2 ILI9341MM2test.bas: the test/demo program for the MM2 including the 5.2 version of the SD card driver ILI9341MMplus.bas: the loadable driver for the MM+ ILI9341MMplustest.bas: the test/demo program for the MM+ tiger2.bmp: 320x240 image for use with the MM+ test program tiger2.ppm: 320x240 image for use with the MM2 test program |
Thanks a lot! ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
| astro1 Regular Member Joined: 26/06/2016 Location: AustraliaPosts: 53 |
Anyone seen this come up on a BackBack 28 pin MM, using the code from 12/07? > RUN CPU exception #5 at address 0x9D01B764 Processor restarted ILI9341 driver loaded Code runs OK in "demo" mode, SD_CS_PIN = 0. Seems to be having problems at line 70 SDCard... Thanks. Edit *** patched in the original SP1_version.bas code and it gets past line 70. It partial loads the picture and runs through the rest of the demo. |
The issue was an uninitialised bit of flash memory in Micromites that hadn't previously been used for SDcards. New version tested on 28-pin freshly programmed with 5.2 attached Option explicit
option default NONE ' ' Demo of functionality of ILI9341 enhanced functionality driver for Micromite MX170 ' const SD_CS_PIN = 10 'set to 0 for demo if SDcard not connected ' connect other SD card pins in parallel with ILI9341 display i.e. SPI 1 ' ' Codes for use of the ILI9341 driver ' const writeregion=5 ' writes colour data saved in a string into a region previously defined ' The zero position of the string contains its length and the subsequent bytes the RGB intensities ' e.g. 6,R1,G1,B1,R2,G2,B2 ' this routine can be called repeatedly to fill the defined region ' The string length must be divisible by 3 const saverectangle=6 ' reads the contents of a rectangle off the screen, 3 bytes per pixel (R,G,B) ' the parameters are: ' address of a buffer to receive the data ' x,y coordinates of top left, width, height ' byte position in the buffer to start writing const restorerectangle=7 ' writes the contents of a buffer to the screen, 3 bytes per pixel (R,G,B) ' the parameters are: ' address of a buffer to provide the data ' x,y coordinates of top left, width, height ' byte position in the buffer to start reading const defineregion=8 ' defines a region that can be written into specified as x,y coordinates of top left, width, height ' the parameters are: ' code to indicate the region will be used for writing (1) or reading (0) ' x,y coordinates of top left, width, height const writetriangle=9 ' ' routine to write a single filled triangle to the screen ' the parameters are: ' dummy parameter - set to zero ' colour of the triangle to be written ' arrays of the x1,y1, x2,y2, x3,y3 coordinates of the triangle const triangles=128 ' + number of triangles ' routine to save current screen data for a triangle and replace it with a user supplied colour and/or replace the screen data with information previously stored. ' the parameters are: ' Number of triangles to be processed ' a buffer big enough to hold the RGB data for all the triangles to be stored (3 bytes per pixel) ' array of the colours of the triangles to be written (use -1 to restore from the buffer) ' arrays of the x1,y1, x2,y2, x3,y3 coordinates of the triangles ' returns the number of byte used in the buffer: divide by 8 and add 1 to get the required number of integers ' ' ' Codes for use of the SD card driver ' see http://www.thebackshed.com/forum/forum_posts.asp?TID=8648 for more details ' const mount=0 const fileopen=1 const readfile=2 const writefile=3 const opendir=4 const readdir=5 ' const buffersize=5000 dim integer buff(buffersize),i,j,maxd if MM.vres>mm.hres then maxd=mm.vres else maxd=mm.hres endif if SD_CS_PIN then SDcard mount,SD_CS_PIN 'this line should really appear in MM.STARTUP DisplayPicture("tiger2.ppm",0,0) else cls rgb(GRAY) for i=5 to sqr(mm.hres^2 + mm.Vres^2)/2 step 5 'cover the screen in circles circle mm.hres\2,mm.vres\2,i next i endif i=ILI9341_MX170(saverectangle, buff(), 95, 80, 130, 80, 0) 'save the central screen area to a buffer for j=0 to 10 'flash transparent text overlayed on the background text mm.hres\2,mm.vres\2-28,"ILI9341",CM,,2,rgb(red),1 text mm.hres\2,mm.vres\2,"Enhanced",CM,,2,rgb(red),1 text mm.hres\2,mm.vres\2+28,"Driver",CM,,2,rgb(red),1 pause 500 i=ILI9341_MX170(restorerectangle, buff(), 95, 80, 130, 80, 0) 'restore the central screen area to a buffer pause 500 next j ' ' rotate a pointer over the background ' const Y_top = 0 'Y coordinate of top of the area swept by the pointer on the screen const X_left = 0 'X coordinate of left of the iarea swept by the pointer on the screen const Y_point = mm.vres\2 'Y coodinate of the centre of the pointer relative to the top const X_point = mm.hres\2 'X coodinate of the centre of the pointer relative to the left ' ' Now we define the pointer as the X,Y coordinates of a number of triangles with the rotation point at 0,0 ' It is simplest to define this in the 12-oclock position which means the Y-coordinates at the top of the pointer will be negative ' The order of data elements in the array is: ' t1x1,t1y1,t1x2,t1y2,t1x3,t1y3, t2x1,t2y1,t2x2,t2y2,t2x3,t2y3,...tntx1,tnty1,tntx2,tnty2,tntx3,tnty3 ' dim integer nt=2 'Number of triangles used to define the pointer dim integer ptr(5,nt-1)=(-4,100,-4,-100,4,100,-4,-100,4,-100,4,100) DIM INTEGER pcolour=rgb(green) 'define the colour of the pointer dim integer xx0(nt*2-1),yy0(nt*2-1),xx1(nt*2-1),yy1(nt*2-1),xx2(nt*2-1),yy2(nt*2-1),tcol(nt*2-1) dim integer first=1 'marker to control alternate processing on first time through the loop for j=0 to 360*10 step 3 drawpointer(j) pause 100 next j end Sub drawpointer(angle as float) Local integer i for i=0 to nt-1 rotatetriangle(i,pcolour,angle,X_point+X_left,Y_point+Y_top,ptr(0,i),ptr(1,i),ptr(2,i),ptr(3,i),ptr(4,i),ptr(5,i)) 'rotate the pointer into the drawing array next i if first then 'store the background and write the pointer i=ILI9341_MX170(triangles or nt, buff() , tcol(nt), xx0(nt), yy0(nt), xx1(nt), yy1(nt), xx2(nt), yy2(nt)) first=0 else 'replace the background over the last pointer, store the background for the new pointer and write itand write the pointer i=ILI9341_MX170(triangles or nt*2, buff() , tcol(), xx0(), yy0(), xx1(), yy1(), xx2(), yy2()) endif End Sub ' sub rotatetriangle(n as integer, col as integer, angle as float, x as integer, y as integer, x0 as integer, y0 as integer, x1 as integer, y1 as integer, x2 as integer, y2 as integer) local float sine=sin(rad(angle)),cosine=cos(rad(angle)) local integer x0a,y0a,x1a,y1a,x2a,y2a x0a= x0*cosine - y0 * sine + x y0a= y0*cosine + x0 * sine + y x1a= x1*cosine - y1 * sine + x y1a= y1*cosine + x1 * sine + y x2a= x2*cosine - y2 * sine + x y2a= y2*cosine + x2 * sine + y xx0(n)=xx0(n+nt) yy0(n)=yy0(n+nt) xx1(n)=xx1(n+nt) yy1(n)=yy1(n+nt) xx2(n)=xx2(n+nt) yy2(n)=yy2(n+nt) xx0(n+nt)=x0a yy0(n+nt)=y0a xx1(n+nt)=x1a yy1(n+nt)=y1a xx2(n+nt)=x2a yy2(n+nt)=y2a tcol(n)=-1 tcol(n+nt)=col end sub '*************************************************************************************************** ' ' Display a picture from the SD card ' Code should work on any of the MM2 supported displays ILI9341, ST7735, ILI9163 ' Picture must be in binary .PPM format ' ' Parameters are: ' PIC$ = filename of the picture to be displayed ' StartX% = X coordinate of the top left of the picture ' StartY% = Y coordinate of the top left of the picture ' ' Note: the routine checks that the picture is not too big for the screen and reports an error if it is ' Sub DisplayPicture(PIC$, StartX%, StartY%) LOCAL Buffer$,addbuffer$ length 3 LOCAL Result%=-1 LOCAL NumBytes%,a%,i% local integer buff(511) SDcard fileopen,PIC$ 'Read the first 128 bytes Buffer$=STRING$(128," ") SDcard readfile,buffer$,0,len(buffer$),NumBytes% a%=instr(buffer$,chr$(10)) ' look for the first CR if left$(buffer$,a%-1)="P6" then buffer$=right$(buffer$,len(buffer$)-a%) a%=instr(buffer$,chr$(10)) ' look for the second CR buffer$=right$(buffer$,len(buffer$)-a%) a%=instr(buffer$,chr$(32)) ' look for the space between dimensions local width%=val(left$(buffer$,a%-1)) buffer$=right$(buffer$,len(buffer$)-a%) a%=instr(buffer$,chr$(10)) ' look for the third CR LOCAL height%=val(left$(buffer$,a%-1)) buffer$=right$(buffer$,len(buffer$)-a%) a%=instr(buffer$,chr$(10)) ' look for the fourth CR buffer$=right$(buffer$,len(buffer$)-a%) a%=len(buffer$) mod 3 addBuffer$=STRING$(3-a%," ") ' we need to make sure we have a number of bytes divisible by three in the buffer SDcard readfile,addbuffer$,-1,len(addbuffer$),NumBytes% buffer$=buffer$+addbuffer$ if (StartX%+width%>MM.HRES) OR (StartY%+height%>MM.VRES) then print "Picture too big", width%," x",height% else i%=ILI9341_MX170(defineregion, 1, StartX%, StartY%, width%, height%) i%=ILI9341_MX170(writeregion,Buffer$) Buffer$=STRING$(255,chr$(0)) do SDcard readfile,buff(),-1,4095,NumBytes% if numbytes%<>0 then i%=ILI9341_MX170(writeregion,Buff(),numbytes%) loop while NumBytes%<>0 endif else Print "Invalid File Format" endif end sub Csub SDcard ' SPI 1 version 00000669 'rcv_spi 240300FF 3C02BF80 AC435820 3C03BF80 8C625810 30420080 1040FFFD 3C02BF80 8C425820 03E00008 304200FF 'xmit_spi 308400FF 3C02BF80 AC445820 3C03BF80 8C625810 30420080 1040FFFD 3C02BF80 8C425820 03E00008 304200FF 'mem_set 10C00006 00801021 00862021 A0450000 24420001 5444FFFE A0450000 03E00008 00000000 'mem_cmp 2407FFFF 24C6FFFF 10C70008 00001021 80830000 80A20000 00621023 14400003 24840001 1000FFF7 24A50001 03E00008 00000000 'mystrlen 80830000 10600006 00001021 24420001 00821821 80630000 5460FFFD 24420001 03E00008 00000000 'send_cmd 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 309100FF 7C111420 04410009 00A09021 24040077 00002821 0411FFF4 00000000 2C430002 10600034 8FBF001C 3231007F 3C109D00 8E030090 8E02001C 80640030 0040F809 24050006 0411FFB2 00000000 8E030090 8E02001C 80640030 0040F809 24050005 0411FFAB 00000000 02202021 0411FFB3 00000000 00122602 0411FFB0 00000000 7E443C00 0411FFAD 00000000 7E443A00 0411FFAA 00000000 324400FF 0411FFA7 00000000 24020040 12220006 24040095 3A310048 24020001 24030087 00402021 0071200A 0411FF9D 00000000 2410000A 0411FF8F 00000000 7C021C20 04610004 2610FFFF 321000FF 1600FFF9 00000000 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020 'disk_readp 27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809021 00C09821 00E0A021 3C029D00 8C42008C 8C4300FC 30630008 00051240 24040051 0043280A 0411FFA6 00000000 14400024 24100001 34109C40 241100FF 0411FF6A 00000000 14510005 2610FFFF 1600FFFB 00000000 1000001A 24100001 240300FE 14430017 24100001 00138823 26310202 12600006 02348823 0411FF5B 00000000 2673FFFF 1660FFFC 00000000 02548021 0411FF55 00000000 A2420000 26520001 1650FFFB 00000000 0411FF4F 00000000 2631FFFF 1620FFFC 00000000 00008021 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FF43 00000000 02001021 8FBF0024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0028 'clust2sect 24A5FFFE 8C830008 2463FFFE 00A3182B 10600005 00001021 90830002 8C820014 70A32002 00821021 03E00008 00000000 'dir_rewind 27BDFFE8 AFBF0014 AFB00010 00A08021 A4A00000 8CA50008 24030001 10A30015 24020001 8C830008 00A3182B 50600012 8FBF0014 54A00008 AE05000C 90830000 24020003 54620008 AE00000C 8C850010 10A00005 AE05000C 0411FFDD 00000000 10000003 AE020010 8C820010 AE020010 00001021 8FBF0014 8FB00010 03E00008 27BD0018 'create_name 27BDFFE0 AFBF001C AFB10018 AFB00014 00A08021 8C910004 02202021 24050020 2406000B 0411FF18 00000000 8E080000 00002021 00001821 24070008 2409002F 2406002E 240A0008 01031021 90420000 24630001 2C450021 14A00018 306300FF 50490017 01031821 10460003 0087282B 14A00008 2445FF9F 54EA0011 01031821 5446000F 01031821 01402021 1000FFEE 2407000B 30A500FF 2CA5001A 10A00003 02242821 2442FFE0 304200FF A0A20000 24840001 1000FFE4 308400FF 01031821 AE030000 2C420021 A222000B 00001021 8FBF001C 8FB10018 8FB00014 03E00008 27BD0020 'get_clust 90840000 24020003 14820006 00001821 90A30015 00031A00 90A20014 00621825 00031C00 90A2001B 00021200 90A4001A 00441025 03E00008 00621025 'get_fat 27BDFFE0 AFBF001C 2CA20002 1440001B 24030001 8C820008 00A2102B 10400018 00601021 000519C2 8C82000C 30A6007F 27A40010 00622821 00063080 24070004 0411FF31 00000000 1440000C 24030001 93A30013 00031E00 93A20012 00021400 00621825 93A20010 00621825 93A20011 00021200 00621825 7C63D800 00601021 8FBF001C 03E00008 27BD0020 'dir_next 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00808821 00A08021 94B20000 26520001 3252FFFF 12400028 24020003 8CA30010 50600026 8FBF001C 3242000F 54400021 A6120000 24630001 ACA30010 8CA5000C 14A00007 00121902 94830004 0243182B 14600017 24020003 10000018 8FBF001C 90820002 2442FFFF 00621024 54400011 A6120000 0411FFBA 00000000 00402821 2C430002 1460000C 24020001 8E230008 00A3182B 10600008 24020003 AE05000C 02202021 0411FF39 00000000 AE020010 A6120000 00001021 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020 'dir_find 27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00809821 00A08821 00C09021 0411FF31 00000000 14400021 00408021 96260000 30C6000F 02402021 8E250010 00063140 24070020 0411FED2 00000000 0002802B 16000017 02001021 92420000 50400013 24100003 9242000B 30420008 14400008 02602021 02402021 8E250004 2406000B 0411FE64 00000000 10400008 02602021 02202821 0411FF9F 00000000 1040FFE3 00408021 10000002 02001021 02001021 8FBF0024 8FB30020 8FB2001C 8FB10018 8FB00014 03E00008 27BD0028 'follow_path 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00809021 00A08021 AFA7002C 80E20000 24030020 14430006 00C08821 24E70001 AFA7002C 80E20000 5043FFFD 24E70001 2403002F 54430004 AE000008 24E70001 AFA7002C AE000008 8FA2002C 90420000 2C420020 10400008 02002021 02402021 02002821 0411FEE7 00000000 1000001B A2200000 02002021 27A5002C 0411FF02 00000000 14400015 02402021 02002821 02203021 0411FFA0 00000000 14400010 8FBF001C 8E030004 9063000B 5460000D 8FB20018 9222000B 30420010 10400006 02402021 02202821 0411FF28 00000000 1000FFE8 AE020008 24020003 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020 'pf_lseek 27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00808021 1080004F 24020005 90830001 30630001 1060004B 24020004 8C82001C 0045902B 00B2100A 00409021 8C830018 AC800018 12400043 00001021 90910002 10600012 00118A40 2463FFFF 2642FFFF 0051001B 022001F4 00001012 0071001B 022001F4 00002012 0044102B 54400008 8E050020 00111023 00431824 AE030018 02439023 10000003 8E050024 8E050020 AE050024 0232102B 10400018 00119823 02519023 02002021 0411FEFC 00000000 00402821 2C420002 54400006 A2000001 8E020008 00A2102B 54400004 AE050024 A2000001 1000001B 24020001 8E020018 00511021 AE020018 02531021 00511821 0223182B 5460FFEB 00409021 8E020018 00529021 AE120018 02002021 0411FE6E 00000000 54400004 92040002 A2000001 10000008 24020001 2484FFFF 8E030018 00031A42 00831824 00431021 AE020028 00001021 8FBF0024 8FB30020 8FB2001C 8FB10018 8FB00014 03E00008 27BD0028 'pf_read 27BDFFD0 AFBF002C AFB60028 AFB50024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00808021 00A0A821 00E09821 ACE00000 1080004A 24020005 90830001 30630001 10600046 24020004 8C92001C 8C820018 02429023 0246102B 00C2900A 1240003F 00001021 00A0A021 24160200 8E020018 304301FF 5460001F 8E060018 00021A42 92110002 2631FFFF 00718824 323100FF 1620000E 02002021 54400003 8E050024 10000003 8E020020 0411FEA3 00000000 2C430002 50600004 AE020024 A2000001 10000026 24020001 02002021 8E050024 0411FE24 00000000 14400004 00518821 A2000001 1000001D 24020001 AE110028 8E060018 30C601FF 02C61023 0052882B 0251100A 00408821 00002021 0295200B 8E050028 00403821 0411FDC9 00000000 50400004 8E020018 A2000001 1000000B 24020001 00511021 AE020018 02519023 8E620000 00511021 12400003 AE620000 1000FFC6 0291A021 00001021 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0030 'disk_initialize 27BDFFD0 AFBF002C AFB30028 AFB20024 AFB10020 AFB0001C 2403003B 3C02BF80 AC435830 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 2410000A 0411FD20 00000000 2610FFFF 321000FF 1600FFFB 24040040 00002821 0411FD4F 00000000 24030001 14430061 3C029D00 24040048 240501AA 0411FD48 00000000 24030001 14430037 240400E9 27B00010 27B10014 0411FD0B 00000000 A2020000 26100001 1611FFFB 93A30012 24020001 1462004E 00008021 93A30013 240200AA 1462004B 3C029D00 10000008 24112710 0040F809 24040064 2631FFFF 16200005 240400E9 1000003F 00008021 3C109D00 240400E9 3C054000 0411FD28 00000000 5440FFF3 8E020004 12200038 00008021 2404007A 00002821 0411FD20 00000000 14400033 3C029D00 24110004 0411FCE5 00000000 27A40010 00901821 26100001 1611FFFA A0620000 93B00010 32100040 2402000C 24030004 0070100A 10000023 00408021 00002821 0411FD0C 00000000 2C420002 24030002 24100001 0062800B 240300E9 24130041 0062980B 24112710 10000006 3C129D00 0040F809 24040064 2631FFFF 52200011 00008021 02602021 00002821 0411FCF9 00000000 5440FFF6 8E420004 52200009 00008021 24040050 24050200 0411FCF1 00000000 10000003 0002800B 10000002 3C029D00 3C029D00 8C43008C AC7000FC 8C430090 8C42001C 80640030 0040F809 24050006 0411FCAD 00000000 12000002 3C02BF80 AC405830 2E020001 8FBF002C 8FB30028 8FB20024 8FB10020 8FB0001C 03E00008 27BD0030 'disk_writep 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 10800014 00808021 30A5FFFF 10A00052 00009021 97828010 1040004F 00858821 92040000 26100001 0411FC9C 00000000 97828010 2442FFFF 3042FFFF 12110045 A7828010 5440FFF7 92040000 10000042 00009021 10A00016 97908010 3C029D00 8C42008C 8C4300FC 30630008 00051240 24040058 0043280A 0411FCB3 00000000 14400035 24120001 240400FF 0411FC83 00000000 240400FE 0411FC80 00000000 24020200 A7828010 1000002B 00009021 26100002 12000008 2610FFFF 2411FFFF 00002021 0411FC75 00000000 2610FFFF 1611FFFC 00002021 0411FC65 00000000 3042001F 24030005 14430010 24120001 10000005 241207D0 0040F809 240403E8 10000003 2652FFFF 241100FF 3C109D00 0411FC57 00000000 50510004 2E520001 5640FFF5 8E020004 24120001 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FC4A 00000000 10000003 02401021 00009021 02401021 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020 'pf_write 27BDFFD0 AFBF002C AFB60028 AFB50024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00808021 00C09021 00E09821 ACE00000 1080007B 24020005 90830001 30640001 10800077 24020004 14C00010 30630040 5060000A 92020001 00002021 00002821 0411FF84 00000000 50400004 92020001 A2000001 1000006A 24020001 304200BF A2020001 10000066 00001021 54600006 8E03001C 8E030018 2402FE00 00621024 AE020018 8E03001C 8E020018 00621023 0052182B 14600005 00000000 00A0A021 24150200 10000005 2416FFBF 1440FFFB 00409021 10000053 8FBF002C 8E020018 304301FF 54600029 8E110018 00021A42 92110002 2631FFFF 00718824 323100FF 1620000E 02002021 54400003 8E050024 10000003 8E020020 0411FD33 00000000 2C430002 50600004 AE020024 A2000001 1000003B 24020001 02002021 8E050024 0411FCB4 00000000 14400004 00512821 A2000001 10000032 24020001 AE050028 00002021 0411FF43 00000000 50400004 92020001 A2000001 10000029 24020001 34420040 A2020001 8E110018 323101FF 02B18823 0232102B 0242880A 02802021 02202821 0411FF33 00000000 50400004 8E020018 A2000001 10000019 24020001 00511021 AE020018 8E620000 00511021 AE620000 8E020018 304201FF 5440000D 02519023 00002021 00002821 0411FF21 00000000 50400004 92020001 A2000001 10000007 24020001 00561024 A2020001 02519023 1640FFB1 0291A021 00001021 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0030 'check_fs 27BDFFE0 AFBF001C AFB10018 AFB00014 00808021 00A08821 240601FE 24070002 0411FC21 00000000 14400028 24030003 92040001 00042200 92020000 00822025 7C042620 2402AA55 14820020 24030002 02002021 02202821 24060036 24070002 0411FC11 00000000 1440000A 02002021 92040001 00042200 92020000 00822025 7C042620 24024146 10820010 00001821 02002021 02202821 24060052 24070002 0411FC01 00000000 14400008 24030001 92030001 00031A00 92020000 00621825 7C031E20 38634146 0003182B 00601021 8FBF001C 8FB10018 8FB00014 03E00008 27BD0020 'pf_mount 27BDFFB8 AFBF0044 AFB10040 AFB0003C 00808021 0411FE3C 00000000 30420001 14400087 24030002 27A40010 00002821 0411FFBA 00000000 24030001 1443001A 00008821 27A40010 00002821 240601BE 24070010 0411FBDB 00000000 14400078 24030001 93A20014 10400075 24030006 93B1001B 00118E00 93A2001A 00021400 02228825 93A20018 02228825 93A20019 00021200 02228825 27A40010 02202821 0411FF9E 00000000 24040003 10440064 24030001 14400062 24030006 27A40010 02202821 2406000D 24070024 0411FBBD 00000000 1440005A 24030001 93A2001A 00021200 93A30019 00431025 1440000C 93A30013 93A3002A 00031E00 93A20029 00021400 00621025 93A30027 00431025 93A30028 00031A00 00431025 93A30013 70431002 93A60012 00063200 93A30011 00C33025 02268821 AE11000C 93A50010 A2050002 93A40015 00042200 93A30014 00832025 A6040004 93A30017 00031A00 93A70016 00671825 1460000B 00042102 93A70026 00073E00 93A30025 00031C00 00E31825 93A70023 00671825 93A70024 00073A00 00671825 00661823 00621823 00641823 0065001B 00A001F4 00003012 24C50002 AE050008 24C6F00A 3407EFFF 00C7302B 2CA70FF7 24030002 0066380B 3403FFF7 00A3282B 10A0001F 24030003 10E00017 24030006 24030003 14E3000D A2070000 93A50032 00052E00 93A30031 00031C00 00A32825 93A3002F 00A32825 93A30030 00031A00 00A31825 10000003 AE030010 00511821 AE030010 02248821 02221021 AE020014 A2000001 00001821 00601021 8FBF0044 8FB10040 8FB0003C 03E00008 27BD0048 1000FFE6 A2030000 'pf_open 27BDFFA0 AFBF005C AFB10058 AFB00054 00808821 00A03821 10800025 24100005 A0800001 27A20024 AFA20014 27A50010 27A60030 0411FC9A 00000000 1440001C 00408021 93A20030 10400018 93A2003B 30420010 54400016 24100003 02202021 27A50030 0411FBEE 00000000 AE220020 93A3004F 00031E00 93A2004E 00021400 00621025 93A3004C 00431025 93A3004D 00031A00 00431025 AE22001C AE200018 24020001 10000002 A2220001 24100003 02001021 8FBF005C 8FB10058 8FB00054 03E00008 27BD0060 'pf_opendir 27BDFFB0 AFBF004C AFB10048 AFB00044 00808021 00A08821 00C03821 10800018 24020005 27A20010 ACA20004 27A6001C 0411FC69 00000000 14400012 8FBF004C 93A2001C 1040000B 02002021 93A30027 30630010 1060000A 24020003 02002021 27A5001C 0411FBBC 00000000 AE220008 02002021 02202821 0411FB5D 00000000 8FBF004C 8FB10048 8FB00044 03E00008 27BD0050 'get_fileinfo 8C830010 10600036 24C20009 90A30000 24040020 1064000E 00A02021 244A0008 24090005 240800E5 10000003 240B0020 106B0007 24840001 00693826 0107180A A0430000 24420001 544AFFF9 90830001 90A40008 24030020 1083000A 2403002E A0430000 90A30008 24040020 1464001E 24420001 10000004 90A3000B A0430000 24420001 90A3000B A0C30008 90A4001F 00042600 90A3001E 00031C00 00831825 90A4001C 00641825 90A4001D 00042200 00641825 ACC30000 90A30019 00031A00 90A40018 00641825 A4C30004 90A30017 00031A00 90A40016 00641825 A4C30006 03E00008 A0400000 A0430000 90A30009 24040020 1064FFE3 24420001 A0430000 90A3000A 1464FFDD 24420001 1000FFDE 90A3000B 'dir_read 27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809821 00A08021 00C08821 24020003 241200E5 10000019 2414002E 30C6000F 02202021 00063140 24070020 0411FAAA 00000000 0002102B 54400016 AE000010 92230000 50600012 24020003 10720005 9224000B 10740003 30840008 1080000E 8FBF0024 02602021 02002821 0411FB7B 00000000 54400007 AE000010 8E050010 54A0FFE6 96060000 10400003 8FBF0024 AE000010 8FBF0024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0028 'pf_readdir 27BDFFB0 AFBF004C AFB20048 AFB10044 AFB00040 00808821 00A08021 00C09021 1080001B 24020005 27A20010 14C00005 ACA20004 0411FAD0 00000000 10000015 8FBF004C 27A6001C 0411FFB9 00000000 24030003 10430004 02002021 1440000D 8FBF004C 02002021 27A5001C 02403021 0411FF6A 00000000 02202021 02002821 0411FB49 00000000 38430003 0003100A 8FBF004C 8FB20048 8FB10044 8FB00040 03E00008 27BD0050 'getFPC 27BDFFF8 AFBF0004 00852023 03E42021 ACC40000 8FBF0004 03E00008 27BD0008 'errstring 27BDFFD8 AFBF0024 AFB10020 AFB0001C 00808021 00002021 3C059D00 24A518C8 27A60010 0411FFEE 00000000 12000031 24020001 16020006 24020002 8FA20010 3C119D00 2631249C 1000000F 02228821 16020006 24020003 8FA20010 3C119D00 263124AC 10000010 02228821 16020007 24020004 8FA20010 3C119D00 263124B8 10000011 02228821 24020004 16020007 24020005 8FA20010 3C119D00 263124C4 10000010 02228821 24020005 16020007 24020006 8FA20010 3C119D00 263124D4 10000008 02228821 24020006 16020006 3C029D00 8FA20010 3C119D00 263124E4 02228821 3C029D00 8C4200BC 0040F809 02202021 8FBF0024 8FB10020 8FB0001C 03E00008 27BD0028 'main 27BDFFA8 AFBF0054 AFBE0050 AFB7004C AFB60048 AFB50044 AFB40040 AFB3003C AFB20038 AFB10034 AFB00030 00808021 00A08821 00C0A821 00E09821 3C02BF80 8C455830 3C039D00 8C64008C AC850044 8C455800 8C64008C AC850048 8C455840 8C64008C AC85004C 34048260 AC445800 24040C00 AC445840 AC405830 8C72008C 26540050 8E060000 24020001 10C20006 26570078 24020006 10C20003 24020007 14C20006 24020004 82250000 04A10007 00001021 1000000F 03A52821 14C2001C 24020007 1000FFF9 82250000 27A40010 00821821 02222021 90840000 A0640000 24420001 00A2182A 1060FFF9 27A40010 03A52821 24020006 14C20005 A0A00011 3C029D00 8C4200C4 0040F809 00000000 8E060000 24020001 10C2000B 3C02BF81 24020006 10C20008 3C02BF81 24020007 10C20005 3C02BF81 24020004 54C200BF 8E030000 3C02BF81 8C44F220 7C84D800 3C030661 3463A053 1083000B 24020050 3C02BF81 8C43F220 7C63D800 3C020660 3442A053 00621026 24030050 2404000C 0082180B 00601021 3C039D00 8C630088 00431021 8C430000 24020065 10620084 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040014 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030014 24050003 00A4180B 00602021 24050008 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040014 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030014 24050003 00A4180B 00602021 24050064 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040029 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030029 2405000E 00A4180B 00602021 24050002 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040029 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030029 2405000E 00A4180B 00602021 24050064 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 2404000E 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 2403000E 24050019 00A4180B 00602021 24050008 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 2404000E 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 2403000E 24050019 00A4180B 00602021 24050064 0040F809 00003021 3C02BF81 8C43FA84 24160001 7EC31804 AC43FA84 3C02BF81 8C43FB04 24040003 7C831804 AC43FB04 3C02BF80 34038260 AC435800 24030C00 AC435840 3C029D00 8C42008C AC4000F8 02802021 0411FD24 00000000 00402021 0411FEBB 00000000 8E020000 54560009 8E030000 02802021 27A50011 0411FDB2 00000000 00402021 0411FEB1 00000000 8E030000 24020002 54620022 8E030000 8EA50000 04A00006 02802021 0411FA90 00000000 00402021 0411FEA5 00000000 8E660000 28C20100 1040000B 02802021 26250001 27A70020 0411FAE3 00000000 00402021 0411FE9A 00000000 8FA20020 10000008 A2220000 02202821 27A70020 0411FAD9 00000000 00402021 0411FE90 00000000 8FA30020 8FA20068 AC430000 8E030000 24020003 54620077 8E030000 8EA20000 04410005 3C029D00 8C42008C 8C4200F8 AEA20000 3C029D00 8C42008C 8C4400F8 8E630000 00831821 AC4300F8 8EBE0000 2416FE00 03D6B024 02802021 02C02821 0411FA5E 00000000 00402021 0411FE73 00000000 8E660000 28C20100 02221021 AFA20028 8EA20000 10560048 33DE01FF 3C029D00 8C420040 0040F809 24040200 0040A821 02802021 00402821 24060200 27A70020 0411FAA7 00000000 00402021 0411FE5E 00000000 02802021 02C02821 0411FA42 00000000 00402021 0411FE57 00000000 8E640000 03C42021 2C820201 14400003 0000B021 2496FE00 24040200 03C4102A 10400008 8FA20028 02BEF021 02A42021 90430000 A3C30000 27DE0001 17C4FFFC 24420001 02802021 02A02821 8FA60020 27A70020 0411FBDA 00000000 00402021 0411FE3D 00000000 12C0000D 02802021 8E650000 00B62823 8FA20028 00452821 02C03021 27A70020 0411FBCD 00000000 00402021 0411FE30 00000000 02802021 00002821 00003021 27A70020 0411FBC4 00000000 00402021 0411FE27 00000000 10000013 8E030000 02802021 8FA50028 27A70020 0411FBBA 00000000 00402021 0411FE1D 00000000 02802021 00002821 00003021 27A70020 0411FBB1 00000000 00402021 0411FE14 00000000 8E030000 24020004 5462000A 8E030000 02802021 02E02821 27A60010 0411FD3B 00000000 00402021 0411FE08 00000000 8E030000 24020005 5462003C 8E030000 265200A0 02802021 02E02821 02403021 0411FDCC 00000000 00402021 0411FDFB 00000000 92430008 24020016 5462000A 82420009 02802021 02E02821 02403021 0411FDC0 00000000 00402021 0411FDEF 00000000 82420009 50400023 A2200000 92420008 30420010 54400006 2402003C 24130001 02331821 00001021 1000000C 2405000C A2220001 24020044 A2220002 24020069 A2220003 24020072 A2220004 2402003E A2220005 1000FFF2 24130006 02422021 90840009 A0640000 24420001 1445FFFB 24630001 2402000C AFA20020 26440009 0411F7D2 00000000 2673FFFF 02629821 A2330000 8E030000 24020006 5462003E 8E030000 3C029D00 8C420040 0040F809 3404C800 0040B021 02802021 27A50011 0411FCBB 00000000 00402021 0411FDBA 00000000 02802021 00002821 0411F99E 00000000 00402021 0411FDB3 00000000 02C09021 0000A821 24130001 02802021 02402821 24060080 27A70020 0411F9F0 00000000 00402021 0411FDA7 00000000 8FA30020 1860000E 00001021 02421821 80630000 54600006 24420001 52600004 24420001 AFA20020 00009821 24420001 8FA30020 0043202A 5480FFF5 02421821 24020080 14620003 02A3A821 1000FFE3 26520080 02D5A821 A2A00000 A2A00001 3C029D00 8C4200B8 02C02021 0040F809 00002821 8E030000 24020007 5462004D 8E020000 02802021 27A50011 0411FC80 00000000 00402021 0411FD7F 00000000 02802021 00002821 0411F963 00000000 00402021 0411FD78 00000000 3C129D00 8E420040 0040F809 24040100 00409821 8E5500C0 24120001 3C169D00 2417000D 1000001C 241E000A 1452FFFF 02602021 8EC200C8 0040F809 02A02821 0040A821 02602021 0411F769 00000000 02621821 A0770000 A07E0001 02802021 02602821 24460002 27A70020 0411FAF5 00000000 00402021 0411FD58 00000000 82A20000 14400005 00000000 82A20001 50400005 A2600000 82A20000 1440FFE3 00000000 A2600000 A2600001 02802021 02602821 24060002 27A70020 0411FAE1 00000000 00402021 0411FD44 00000000 02802021 00002821 00003021 27A70020 0411FAD8 00000000 00402021 0411FD3B 00000000 8E020000 14400023 3C029D00 8C430090 92240000 A0640030 82240000 8C430088 00041080 00431021 8C430000 24020065 1062000D 3C109D00 8E030090 8E020010 80640030 24050008 0040F809 00003021 8E030090 8E020010 80640030 24050065 0040F809 00003021 3C109D00 8E030090 8E02001C 80640030 0040F809 2405FFFD 8E030090 8E02001C 80640030 0040F809 24050006 3C029D00 8C43008C 8C640044 3C02BF80 AC445830 8C640048 AC445800 8C63004C AC435840 8FBF0054 8FBE0050 8FB7004C 8FB60048 8FB50044 8FB40040 8FB3003C 8FB20038 8FB10034 8FB00030 03E00008 27BD0058 '.rodata 'err1 6B736944 72724520 0A0D726F 00000000 'err2 20746F4E 64616552 000A0D79 'err3 46206F4E 0D656C69 0000000A 'err4 20746F4E 6E65704F 0A0D6465 00000000 20746F4E 62616E45 0D64656C 0000000A 46206F4E 20656C69 74737953 0A0D6D65 00000000 End Csub |
Yes, I had the same but Peter's update has fixed it. I now stop at line 170 with: > RUN [170] SDcard fileopen,PIC$ Error: Not Ready > I probably haven't loaded something up here though so I'll keep playing - tomorrow. Time for bed now. Greg |
I get this with the new code. > RUN [170] SDcard fileopen,PIC$ Error: Not Readyy |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11893 |
I get this problem if I disconnect the CS pin from the SD card. Make sure "const SD_CS_PIN = 10" is specified correctly for your wiring and that the pin specified is not in use for anything else. If that is all correct try running at "CPU 20" or "CPU 10" to see if your SD card is too slow. Finally, make sure you are using a SDHC card with 4GB or more. SD cards of 2GB give a problem (including with Geoff's inbuilt MM+ firmware) This is my test setup using one of Mick's serial backpacks |
I think I'm OK with the connections, my problem is not being familiar with using the LIBRARY and MM.STARTUP. I tried to do two LIBRARY SAVE's which didn't work (RTFM) and now I also need to deal with the two MM.STARTUP subs, i.e. for the SD card driver and for the enhanced ILI9341 driver. How much of this code at the start of the new SD card driver is needed, i.e. do we need the LOAD and SAVE subs or were these specific to the SD card test program? Greg sub mm.startup
sdcard 0,23 'set up the chip select pin for the SDcard end sub sub load(f$) sdcard 6,f$ end end sub sub save(f$) sdcard 7,f$ end sub Csub SDcard 'SPI1 version |
None of it: that was the change I made to the SDcard driver to allow the mount command "SDcard 0,pinno" to be used from within a program. The "load" and "save" subroutines are just used to mimic the MM+ commands on the MM2 |
sub mm.startup
sdcard 0,23 'set up the chip select pin for the SDcard end sub sub load(f$) sdcard 6,f$ end <<<<<<<< ??? end sub sub save(f$) sdcard 7,f$ end sub Csub SDcard 'SPI1 version I'm tired, but isn't that end a bad thing? Micromites and Maximites! - Beginning Maximite |
No: it is very specifically required otherwise you get an error as the subroutine has nothing to return to when called from the command line because the "load" bit of the Cfunction includes a "NEW" which destroys the return address. This took some time to sort out. |
| Page 1 of 2 |
