Local Time 16:58 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : use of spi sd card on mm-28 with 5.2?
Posted: 04:06pm 29 Jan 2017
I've read a number of matherp's posts on CFunction & sd card use under 5.2, but it remains unclear to me (as a newbie) what to do.
Does new 5.2 firmware need to be built including that function?
All I want to do is log 16-byte records, of which the last character is a line feed, to a single file on the sd card. I have an ebay spi sd module.
Can I do this with the standard 5.2 MMBasic?
My MM-28 is running on a MuPv3 with the SPI pins brought out to a header.
In a related question, will I need to provide a high on CS (e.g., using the MuPv3 pin 15 on the header) or does anyone know if the module has a weak pullup?
Edited by lizby 2017-01-31
MikeO
Posted: 07:03pm 29 Jan 2017
HI lizby, I have used Peter's SDcard driver for the MX170 quite a lot and its works extremely well. I have pulled out the basics that you will need from a Library I wrote which you could use in your own program. I hope I have cleaned it up sufficiently but there may be some extra/missing variables but hopefully it will get you started. You can load the Cfunction code as part of your main program or put it in the Library if you are running out of space.
'** MX170 only
dim integer sdFileopen=1
dim Integer sdReadfile=2
dim integer sdWritefile=3
dim integer sdOpendir=4
dim integer sdReaddir=5
'** MX170 only
dim Q$=chr$(34)
dim integer CTRL_Z = 26 'Used in example as EOF marker
dim integer CS_PIN=4 'Chip select pin conected to the SD card
Dim res As Integer
Dim cr$=chr$(13) + chr$(10)
dim integer sdfilepos,err,minWait
dim Integer userprocessflag ,ReadyFlag,stopflag,sdOpenFlag,starttime,debug
sdcard 0,4,0 'set up the chip select pin for the SDcard
'Usage xWritefile Path-Filename$,dataline$
sub xwritefile(fname$,d$)
'print "xwrite:";d$
if sdopenflag=0 then 'see if there is an open file
'attempt to open filename
Watchdog 8000
On error skip
SDcard sdfileopen,fname$
if ChkErr()>0 then Exit Sub
sdopenflag=1 'set the openflag
d$=d$+cr$
On error skip
SDcard sdwritefile,d$,0,len(d$)
sdfilepos=len(d$)
Exit sub
end if
'file is open so write the data
'check for EOF marker
if instr(d$,CHR$(CTRL_Z)) THEN
print asc(d$);" ";sdfilepos
SDcard sdwritefile,d$,sdfilepos,len(d$)
sdopenflag=0 'reset the openflag
Exit sub
else
d$=d$+cr$
end if
On error skip
sdfilepos=sdfilepos+len(d$)
End Sub
Function ChkErr() As Integer
ChkErr=0
if mm.errno<>0 then
print "Error# ";mm.errno; " "; mm.errmsg$
ChkErr=1
end if
end Function
Csub SDcard 'SPI1 version
00000676
'rcv_spi
240300FF 3C02BF80 AC435820 3C03BF80 8C625810 30420080 1040FFFD 3C02BF80
8C425820 03E00008 304200FF
'xmit_spi
308400FF 3C02BF80 AC445820 3C03BF80 8C625810 30420080 1040FFFD 3C02BF80
'mem_set
10C00006 00801021 00862021 A0450000 24420001 5444FFFE A0450000 03E00008
00000000
'mem_cmp
2407FFFF 24C6FFFF 10C70008 00001021 80830000 80A20000 00621023 14400003
24840001 1000FFF7 24A50001 03E00008 00000000
'mystrlen
80830000 10600006 00001021 24420001 00821821 80630000 5460FFFD 24420001
03E00008 00000000
'send_cmd
27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 309100FF 7C111420 04410009
00A09021 24040077 00002821 0411FFF4 00000000 2C430002 10600034 8FBF001C
3231007F 3C109D00 8E030090 8E02001C 80640030 0040F809 24050006 0411FFB2
00000000 8E030090 8E02001C 80640030 0040F809 24050005 0411FFAB 00000000
02202021 0411FFB3 00000000 00122602 0411FFB0 00000000 7E443C00 0411FFAD
00000000 7E443A00 0411FFAA 00000000 324400FF 0411FFA7 00000000 24020040
12220006 24040095 3A310048 24020001 24030087 00402021 0071200A 0411FF9D
00000000 2410000A 0411FF8F 00000000 7C021C20 04610004 2610FFFF 321000FF
1600FFF9 00000000 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020
'disk_readp
27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809021
00C09821 00E0A021 3C029D00 8C42008C 8C4300FC 30630008 00051240 24040051
0043280A 0411FFA6 00000000 14400024 24100001 34109C40 241100FF 0411FF6A
00000000 14510005 2610FFFF 1600FFFB 00000000 1000001A 24100001 240300FE
14430017 24100001 00138823 26310202 12600006 02348823 0411FF5B 00000000
2673FFFF 1660FFFC 00000000 02548021 0411FF55 00000000 A2420000 26520001
1650FFFB 00000000 0411FF4F 00000000 2631FFFF 1620FFFC 00000000 00008021
3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FF43 00000000
02001021 8FBF0024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008
27BD0028
'clust2sect
24A5FFFE 8C830008 2463FFFE 00A3182B 10600005 00001021 90830002 8C820014
70A32002 00821021 03E00008 00000000
'dir_rewind
27BDFFE8 AFBF0014 AFB00010 00A08021 A4A00000 8CA50008 24030001 10A30015
24020001 8C830008 00A3182B 50600012 8FBF0014 54A00008 AE05000C 90830000
24020003 54620008 AE00000C 8C850010 10A00005 AE05000C 0411FFDD 00000000
10000003 AE020010 8C820010 AE020010 00001021 8FBF0014 8FB00010 03E00008
27BD0018
'create_name
27BDFFE0 AFBF001C AFB10018 AFB00014 00A08021 8C910004 02202021 24050020
2406000B 0411FF18 00000000 8E080000 00002021 00001821 24070008 2409002F
2406002E 240A0008 01031021 90420000 24630001 2C450021 14A00018 306300FF
50490017 01031821 10460003 0087282B 14A00008 2445FF9F 54EA0011 01031821
5446000F 01031821 01402021 1000FFEE 2407000B 30A500FF 2CA5001A 10A00003
02242821 2442FFE0 304200FF A0A20000 24840001 1000FFE4 308400FF 01031821
AE030000 2C420021 A222000B 00001021 8FBF001C 8FB10018 8FB00014 03E00008
27BD0020
'get_clust
90840000 24020003 14820006 00001821 90A30015 00031A00 90A20014 00621825
00031C00 90A2001B 00021200 90A4001A 00441025 03E00008 00621025
'get_fat
27BDFFE0 AFBF001C 2CA20002 1440001B 24030001 8C820008 00A2102B 10400018
00601021 000519C2 8C82000C 30A6007F 27A40010 00622821 00063080 24070004
0411FF31 00000000 1440000C 24030001 93A30013 00031E00 93A20012 00021400
00621825 93A20010 00621825 93A20011 00021200 00621825 7C63D800 00601021
8FBF001C 03E00008 27BD0020
'dir_next
27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00808821 00A08021 94B20000
26520001 3252FFFF 12400028 24020003 8CA30010 50600026 8FBF001C 3242000F
54400021 A6120000 24630001 ACA30010 8CA5000C 14A00007 00121902 94830004
0243182B 14600017 24020003 10000018 8FBF001C 90820002 2442FFFF 00621024
54400011 A6120000 0411FFBA 00000000 00402821 2C430002 1460000C 24020001
8E230008 00A3182B 10600008 24020003 AE05000C 02202021 0411FF39 00000000
AE020010 A6120000 00001021 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008
27BD0020
'dir_find
27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00809821 00A08821
00C09021 0411FF31 00000000 14400021 00408021 96260000 30C6000F 02402021
8E250010 00063140 24070020 0411FED2 00000000 0002802B 16000017 02001021
92420000 50400013 24100003 9242000B 30420008 14400008 02602021 02402021
8E250004 2406000B 0411FE64 00000000 10400008 02602021 02202821 0411FF9F
00000000 1040FFE3 00408021 10000002 02001021 02001021 8FBF0024 8FB30020
8FB2001C 8FB10018 8FB00014 03E00008 27BD0028
'follow_path
27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00809021 00A08021 AFA7002C
80E20000 24030020 14430006 00C08821 24E70001 AFA7002C 80E20000 5043FFFD
24E70001 2403002F 54430004 AE000008 24E70001 AFA7002C AE000008 8FA2002C
90420000 2C420020 10400008 02002021 02402021 02002821 0411FEE7 00000000
1000001B A2200000 02002021 27A5002C 0411FF02 00000000 14400015 02402021
02002821 02203021 0411FFA0 00000000 14400010 8FBF001C 8E030004 9063000B
5460000D 8FB20018 9222000B 30420010 10400006 02402021 02202821 0411FF28
00000000 1000FFE8 AE020008 24020003 8FBF001C 8FB20018 8FB10014 8FB00010
03E00008 27BD0020
'pf_lseek
27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00808021 1080004F
24020005 90830001 30630001 1060004B 24020004 8C82001C 0045902B 00B2100A
00409021 8C830018 AC800018 12400043 00001021 90910002 10600012 00118A40
2463FFFF 2642FFFF 0051001B 022001F4 00001012 0071001B 022001F4 00002012
0044102B 54400008 8E050020 00111023 00431824 AE030018 02439023 10000003
8E050024 8E050020 AE050024 0232102B 10400018 00119823 02519023 02002021
0411FEFC 00000000 00402821 2C420002 54400006 A2000001 8E020008 00A2102B
54400004 AE050024 A2000001 1000001B 24020001 8E020018 00511021 AE020018
02531021 00511821 0223182B 5460FFEB 00409021 8E020018 00529021 AE120018
02002021 0411FE6E 00000000 54400004 92040002 A2000001 10000008 24020001
2484FFFF 8E030018 00031A42 00831824 00431021 AE020028 00001021 8FBF0024
8FB30020 8FB2001C 8FB10018 8FB00014 03E00008 27BD0028
'pf_read
27BDFFD0 AFBF002C AFB60028 AFB50024 AFB40020 AFB3001C AFB20018 AFB10014
AFB00010 00808021 00A0A821 00E09821 ACE00000 1080004A 24020005 90830001
30630001 10600046 24020004 8C92001C 8C820018 02429023 0246102B 00C2900A
1240003F 00001021 00A0A021 24160200 8E020018 304301FF 5460001F 8E060018
00021A42 92110002 2631FFFF 00718824 323100FF 1620000E 02002021 54400003
8E050024 10000003 8E020020 0411FEA3 00000000 2C430002 50600004 AE020024
A2000001 10000026 24020001 02002021 8E050024 0411FE24 00000000 14400004
00518821 A2000001 1000001D 24020001 AE110028 8E060018 30C601FF 02C61023
0052882B 0251100A 00408821 00002021 0295200B 8E050028 00403821 0411FDC9
00000000 50400004 8E020018 A2000001 1000000B 24020001 00511021 AE020018
02519023 8E620000 00511021 12400003 AE620000 1000FFC6 0291A021 00001021
8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010
03E00008 27BD0030
'disk_initialize
27BDFFD0 AFBF002C AFB30028 AFB20024 AFB10020 AFB0001C 2403003B 3C02BF80
AC435830 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 2410000A
0411FD20 00000000 2610FFFF 321000FF 1600FFFB 24040040 00002821 0411FD4F
00000000 24030001 14430061 3C029D00 24040048 240501AA 0411FD48 00000000
24030001 14430037 240400E9 27B00010 27B10014 0411FD0B 00000000 A2020000
26100001 1611FFFB 93A30012 24020001 1462004E 00008021 93A30013 240200AA
1462004B 3C029D00 10000008 24112710 0040F809 24040064 2631FFFF 16200005
240400E9 1000003F 00008021 3C109D00 240400E9 3C054000 0411FD28 00000000
5440FFF3 8E020004 12200038 00008021 2404007A 00002821 0411FD20 00000000
14400033 3C029D00 24110004 0411FCE5 00000000 27A40010 00901821 26100001
1611FFFA A0620000 93B00010 32100040 2402000C 24030004 0070100A 10000023
00408021 00002821 0411FD0C 00000000 2C420002 24030002 24100001 0062800B
240300E9 24130041 0062980B 24112710 10000006 3C129D00 0040F809 24040064
2631FFFF 52200011 00008021 02602021 00002821 0411FCF9 00000000 5440FFF6
8E420004 52200009 00008021 24040050 24050200 0411FCF1 00000000 10000003
0002800B 10000002 3C029D00 3C029D00 8C43008C AC7000FC 8C430090 8C42001C
80640030 0040F809 24050006 0411FCAD 00000000 12000005 3C029D00 8C420090
8043003C 3C02BF80 AC435830 2E020001 8FBF002C 8FB30028 8FB20024 8FB10020
8FB0001C 03E00008 27BD0030
'disk_writep
27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 10800014 00808021 30A5FFFF
10A00052 00009021 97828010 1040004F 00858821 92040000 26100001 0411FC99
00000000 97828010 2442FFFF 3042FFFF 12110045 A7828010 5440FFF7 92040000
10000042 00009021 10A00016 97908010 3C029D00 8C42008C 8C4300FC 30630008
00051240 24040058 0043280A 0411FCB0 00000000 14400035 24120001 240400FF
0411FC80 00000000 240400FE 0411FC7D 00000000 24020200 A7828010 1000002B
00009021 26100002 12000008 2610FFFF 2411FFFF 00002021 0411FC72 00000000
2610FFFF 1611FFFC 00002021 0411FC62 00000000 3042001F 24030005 14430010
24120001 10000005 241207D0 0040F809 240403E8 10000003 2652FFFF 241100FF
3C109D00 0411FC54 00000000 50510004 2E520001 5640FFF5 8E020004 24120001
3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FC47 00000000
10000003 02401021 00009021 02401021 8FBF001C 8FB20018 8FB10014 8FB00010
03E00008 27BD0020
'pf_write
AFB00010 00808021 00C09021 00E09821 ACE00000 1080007B 24020005 90830001
30640001 10800077 24020004 14C00010 30630040 5060000A 92020001 00002021
00002821 0411FF84 00000000 50400004 92020001 A2000001 1000006A 24020001
304200BF A2020001 10000066 00001021 54600006 8E03001C 8E030018 2402FE00
00621024 AE020018 8E03001C 8E020018 00621023 0052182B 14600005 00000000
00A0A021 24150200 10000005 2416FFBF 1440FFFB 00409021 10000053 8FBF002C
8E020018 304301FF 54600029 8E110018 00021A42 92110002 2631FFFF 00718824
323100FF 1620000E 02002021 54400003 8E050024 10000003 8E020020 0411FD30
00000000 2C430002 50600004 AE020024 A2000001 1000003B 24020001 02002021
8E050024 0411FCB1 00000000 14400004 00512821 A2000001 10000032 24020001
AE050028 00002021 0411FF43 00000000 50400004 92020001 A2000001 10000029
24020001 34420040 A2020001 8E110018 323101FF 02B18823 0232102B 0242880A
02802021 02202821 0411FF33 00000000 50400004 8E020018 A2000001 10000019
24020001 00511021 AE020018 8E620000 00511021 AE620000 8E020018 304201FF
5440000D 02519023 00002021 00002821 0411FF21 00000000 50400004 92020001
A2000001 10000007 24020001 00561024 A2020001 02519023 1640FFB1 0291A021
00001021 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014
8FB00010 03E00008 27BD0030
'check_fs
27BDFFE0 AFBF001C AFB10018 AFB00014 00808021 00A08821 240601FE 24070002
0411FC1E 00000000 14400028 24030003 92040001 00042200 92020000 00822025
7C042620 2402AA55 14820020 24030002 02002021 02202821 24060036 24070002
0411FC0E 00000000 1440000A 02002021 92040001 00042200 92020000 00822025
7C042620 24024146 10820010 00001821 02002021 02202821 24060052 24070002
0411FBFE 00000000 14400008 24030001 92030001 00031A00 92020000 00621825
7C031E20 38634146 0003182B 00601021 8FBF001C 8FB10018 8FB00014 03E00008
27BD0020
'pf_mount
27BDFFB8 AFBF0044 AFB10040 AFB0003C 00808021 0411FE39 00000000 30420001
14400087 24030002 27A40010 00002821 0411FFBA 00000000 24030001 1443001A
00008821 27A40010 00002821 240601BE 24070010 0411FBD8 00000000 14400078
24030001 93A20014 10400075 24030006 93B1001B 00118E00 93A2001A 00021400
02228825 93A20018 02228825 93A20019 00021200 02228825 27A40010 02202821
0411FF9E 00000000 24040003 10440064 24030001 14400062 24030006 27A40010
02202821 2406000D 24070024 0411FBBA 00000000 1440005A 24030001 93A2001A
00021200 93A30019 00431025 1440000C 93A30013 93A3002A 00031E00 93A20029
00021400 00621025 93A30027 00431025 93A30028 00031A00 00431025 93A30013
70431002 93A60012 00063200 93A30011 00C33025 02268821 AE11000C 93A50010
A2050002 93A40015 00042200 93A30014 00832025 A6040004 93A30017 00031A00
93A70016 00671825 1460000B 00042102 93A70026 00073E00 93A30025 00031C00
00E31825 93A70023 00671825 93A70024 00073A00 00671825 00661823 00621823
00641823 0065001B 00A001F4 00003012 24C50002 AE050008 24C6F00A 3407EFFF
00C7302B 2CA70FF7 24030002 0066380B 3403FFF7 00A3282B 10A0001F 24030003
10E00017 24030006 24030003 14E3000D A2070000 93A50032 00052E00 93A30031
00031C00 00A32825 93A3002F 00A32825 93A30030 00031A00 00A31825 10000003
AE030010 00511821 AE030010 02248821 02221021 AE020014 A2000001 00001821
00601021 8FBF0044 8FB10040 8FB0003C 03E00008 27BD0048 1000FFE6 A2030000
'pf_open
27BDFFA0 AFBF005C AFB10058 AFB00054 00808821 00A03821 10800025 24100005
A0800001 27A20024 AFA20014 27A50010 27A60030 0411FC97 00000000 1440001C
00408021 93A20030 10400018 93A2003B 30420010 54400016 24100003 02202021
27A50030 0411FBEB 00000000 AE220020 93A3004F 00031E00 93A2004E 00021400
00621025 93A3004C 00431025 93A3004D 00031A00 00431025 AE22001C AE200018
24020001 10000002 A2220001 24100003 02001021 8FBF005C 8FB10058 8FB00054
03E00008 27BD0060
'pf_opendir
27BDFFB0 AFBF004C AFB10048 AFB00044 00808021 00A08821 00C03821 10800018
24020005 27A20010 ACA20004 27A6001C 0411FC66 00000000 14400012 8FBF004C
93A2001C 1040000B 02002021 93A30027 30630010 1060000A 24020003 02002021
27A5001C 0411FBB9 00000000 AE220008 02002021 02202821 0411FB5A 00000000
8FBF004C 8FB10048 8FB00044 03E00008 27BD0050
'get_fileinfo
8C830010 10600036 24C20009 90A30000 24040020 1064000E 00A02021 244A0008
24090005 240800E5 10000003 240B0020 106B0007 24840001 00693826 0107180A
A0430000 24420001 544AFFF9 90830001 90A40008 24030020 1083000A 2403002E
A0430000 90A30008 24040020 1464001E 24420001 10000004 90A3000B A0430000
24420001 90A3000B A0C30008 90A4001F 00042600 90A3001E 00031C00 00831825
90A4001C 00641825 90A4001D 00042200 00641825 ACC30000 90A30019 00031A00
90A40018 00641825 A4C30004 90A30017 00031A00 90A40016 00641825 A4C30006
03E00008 A0400000 A0430000 90A30009 24040020 1064FFE3 24420001 A0430000
90A3000A 1464FFDD 24420001 1000FFDE 90A3000B
'dir_read
27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809821
00A08021 00C08821 24020003 241200E5 10000019 2414002E 30C6000F 02202021
00063140 24070020 0411FAA7 00000000 0002102B 54400016 AE000010 92230000
50600012 24020003 10720005 9224000B 10740003 30840008 1080000E 8FBF0024
02602021 02002821 0411FB78 00000000 54400007 AE000010 8E050010 54A0FFE6
96060000 10400003 8FBF0024 AE000010 8FBF0024 8FB40020 8FB3001C 8FB20018
8FB10014 8FB00010 03E00008 27BD0028
'pf_readdir
27BDFFB0 AFBF004C AFB20048 AFB10044 AFB00040 00808821 00A08021 00C09021
1080001B 24020005 27A20010 14C00005 ACA20004 0411FACD 00000000 10000015
8FBF004C 27A6001C 0411FFB9 00000000 24030003 10430004 02002021 1440000D
8FBF004C 02002021 27A5001C 02403021 0411FF6A 00000000 02202021 02002821
0411FB46 00000000 38430003 0003100A 8FBF004C 8FB20048 8FB10044 8FB00040
03E00008 27BD0050
'getFPC
27BDFFF8 AFBF0004 00852023 03E42021 ACC40000 8FBF0004 03E00008 27BD0008
'errstring
27BDFFE0 AFBF001C AFB00018 00808021 00002021 3C059D00 24A518D0 27A60010
0411FFEF 00000000 8FA20010 1200003C 24030001 16030006 24030002 8FA30010
3C049D00 24842544 10000012 00832021 56030006 3C049D00 8FA30010 3C049D00
24842554 10000013 00832021 24842534 00822021 24020003 16020007 24020004
8FA30010 3C049D00 24842560 10000011 00832021 24020004 16020007 24020005
8FA30010 3C049D00 2484256C 10000011 00832021 24020005 16020007 24020006
8FA30010 3C049D00 2484257C 10000010 00832021 24020006 16020007 24020007
8FA30010 3C049D00 2484258C 10000008 00832021 24020007 16020006 3C029D00
8FA30010 3C049D00 248425A0 00832021 3C029D00 8C4200BC 0040F809 00000000
8FBF001C 8FB00018 03E00008 27BD0020
'main
27BDFFA8 AFBF0054 AFBE0050 AFB7004C AFB60048 AFB50044 AFB40040 AFB3003C
AFB20038 AFB10034 AFB00030 00808021 00A08821 00C0A821 00E09821 3C02BF80
8C455830 3C039D00 8C64008C AC850044 8C455800 8C64008C AC850048 8C455840
8C64008C AC85004C 34048260 AC445800 24040C00 AC445840 8C640090 8084003C
AC445830 8C72008C 26540050 8E060000 24020001 10C20006 26570078 24020006
10C20003 24020007 14C20006 24020004 82250000 04A10007 00001021 1000000F
03A52821 14C2001A 24020007 1000FFF9 82250000 27A40010 00821821 02222021
90840000 A0640000 24420001 00A2182A 1060FFF9 27A40010 03A52821 24020006
14C20005 A0A00011 3C029D00 8C4200C4 0040F809 00000000 8E060000 24020001
10C20007 24020006 10C20005 24020007 10C20003 24020004 54C200CB 8E030000
3C029D00 8C430090 80640030 8C430088 00041080 00431021 8C430000 24020065
10620003 24040007 0411FF59 00000000 3C02BF81 8C44F220 7C84D800 3C030661
3463A053 1083000B 24020050 3C02BF81 8C43F220 7C63D800 3C020660 3442A053
00621026 24030050 2404000C 0082180B 00601021 3C039D00 8C630088 00431021
8C430000 24020065 10620084 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800
3C030661 3463A053 10A3000B 24040014 3C03BF81 8C64F220 7C84D800 3C030660
3463A053 00832026 24030014 24050003 00A4180B 00602021 24050008 0040F809
00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053
10A3000B 24040014 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026
24030014 24050003 00A4180B 00602021 24050064 0040F809 00003021 3C029D00
8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040029
3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030029 2405000E
00A4180B 00602021 24050002 0040F809 00003021 3C029D00 8C420010 3C03BF81
8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040029 3C03BF81 8C64F220
7C84D800 3C030660 3463A053 00832026 24030029 2405000E 00A4180B 00602021
24050064 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800
3C030661 3463A053 10A3000B 2404000E 3C03BF81 8C64F220 7C84D800 3C030660
3463A053 00832026 2403000E 24050019 00A4180B 00602021 24050008 0040F809
10A3000B 2404000E 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026
2403000E 24050019 00A4180B 00602021 24050064 0040F809 00003021 3C02BF81
8C43FA84 24160001 7EC31804 AC43FA84 3C02BF81 8C43FB04 24040003 7C831804
AC43FB04 3C02BF80 34038260 AC435800 24030C00 AC435840 3C029D00 8C42008C
AC4000F8 02802021 0411FD0F 00000000 00402021 0411FEA6 00000000 8E020000
54560009 8E030000 02802021 27A50011 0411FD9D 00000000 00402021 0411FE9C
00000000 8E030000 24020002 54620022 8E030000 8EA50000 04A00006 02802021
0411FA78 00000000 00402021 0411FE90 00000000 8E660000 28C20100 1040000B
02802021 26250001 27A70020 0411FACB 00000000 00402021 0411FE85 00000000
8FA20020 10000008 A2220000 02202821 27A70020 0411FAC1 00000000 00402021
0411FE7B 00000000 8FA30020 8FA20068 AC430000 8E030000 24020003 5462007B
8E030000 8EA20000 04410005 3C029D00 8C42008C 8C4200F8 AEA20000 3C029D00
8C42008C 8C4400F8 8E630000 00831821 AC4300F8 8EB60000 241EFE00 02DEF024
02802021 03C02821 0411FA46 00000000 00402021 0411FE5E 00000000 8E660000
28C20100 02221021 AFA2002C 8EA20000 105E004C 32D601FF AFB60028 3C029D00
8C420040 0040F809 24040200 0040B021 02802021 00402821 24060200 27A70020
0411FA8E 00000000 00402021 0411FE48 00000000 02802021 03C02821 0411FA29
00000000 00402021 0411FE41 00000000 8E650000 8FA20028 00452821 2CA20201
14400003 0000F021 24BEFE00 24050200 8FA30028 0065102A 10400009 8FA3002C
8FA40028 02C41021 02C52821 90640000 A0440000 24420001 1445FFFC 24630001
02802021 02C02821 8FA60020 27A70020 0411FBC1 00000000 00402021 0411FE24
00000000 13C0000D 02802021 8E650000 00BE2823 8FA2002C 00452821 03C03021
27A70020 0411FBB4 00000000 00402021 0411FE17 00000000 02802021 00002821
00003021 27A70020 0411FBAB 00000000 00402021 0411FE0E 00000000 10000013
8E030000 02802021 8FA5002C 27A70020 0411FBA1 00000000 00402021 0411FE04
00000000 02802021 00002821 00003021 27A70020 0411FB98 00000000 00402021
0411FDFB 00000000 8E030000 24020004 5462000A 8E030000 02802021 02E02821
27A60011 0411FD22 00000000 00402021 0411FDEF 00000000 8E030000 24020005
5462003C 8E030000 265200A0 02802021 02E02821 02403021 0411FDB3 00000000
00402021 0411FDE2 00000000 92430008 24020016 5462000A 82420009 02802021
02E02821 02403021 0411FDA7 00000000 00402021 0411FDD6 00000000 82420009
50400023 A2200000 92420008 30420010 54400006 2402003C 24130001 02331821
00001021 1000000C 2405000C A2220001 24020044 A2220002 24020069 A2220003
24020072 A2220004 2402003E A2220005 1000FFF2 24130006 02422021 90840009
A0640000 24420001 1445FFFB 24630001 2402000C AFA20020 26440009 0411F7B6
00000000 2673FFFF 02629821 A2330000 8E030000 24020006 5462003E 8E030000
3C029D00 8C420040 0040F809 3404C800 0040B821 02802021 27A50011 0411FCA2
00000000 00402021 0411FDA1 00000000 02802021 00002821 0411F982 00000000
00402021 0411FD9A 00000000 02E09021 0000B021 24130001 02802021 02402821
24060080 27A70020 0411F9D4 00000000 00402021 0411FD8E 00000000 8FA30020
1860000E 00001021 02421821 80630000 54600006 24420001 52600004 24420001
AFA20020 00009821 24420001 8FA30020 0043202A 5480FFF5 02421821 24020080
14620003 02C3B021 1000FFE3 26520080 02F6B021 A2C00000 A2C00001 3C029D00
8C4200B8 02E02021 0040F809 00002821 8E030000 24020007 5462004D 8E020000
02802021 27A50011 0411FC67 00000000 00402021 0411FD66 00000000 02802021
00002821 0411F947 00000000 00402021 0411FD5F 00000000 3C129D00 8E420040
0040F809 24040100 00409821 8E5600C0 24120001 3C179D00 1000001D 241E000D
1452FFFF 02602021 8EE200C8 0040F809 02C02821 0040B021 02602021 0411F74E
00000000 02621821 A07E0000 2404000A A0640001 02802021 02602821 24460002
27A70020 0411FADC 00000000 00402021 0411FD3F 00000000 82C20000 14400005
00000000 82C20001 50400005 A2600000 82C20000 1440FFE2 00000000 A2600000
A2600001 02802021 02602821 24060002 27A70020 0411FAC8 00000000 00402021
0411FD2B 00000000 02802021 00002821 00003021 27A70020 0411FABF 00000000
00402021 0411FD22 00000000 8E020000 1440002D 3C029D00 8C420090 92230000
12A00006 A0430030 3C029D00 8C420090 8EA30000 10000005 A043003C 3C029D00
8C420090 24030002 A043003C 3C029D00 8C430090 80640030 8C420088 00041880
00621021 8C430000 24020065 1062000B 3C109D00 8E020010 24050008 0040F809
00003021 8E030090 8E020010 80640030 24050065 0040F809 00003021 3C109D00
8E030090 8E02001C 80640030 0040F809 2405FFFD 8E030090 8E02001C 80640030
0040F809 24050006 3C029D00 8C43008C 8C640044 3C02BF80 AC445830 8C640048
AC445800 8C63004C AC435840 8FBF0054 8FBE0050 8FB7004C 8FB60048 8FB50044
8FB40040 8FB3003C 8FB20038 8FB10034 8FB00030 03E00008 27BD0058
'.rodata
'err0
6E6B6E55 206E776F 6F727265 000A0D72
'err1
6B736944 72724520 0A0D726F 00000000
'err2
20746F4E 64616552 000A0D79
'err3
46206F4E 0D656C69 0000000A 20746F4E 6E65704F 0A0D6465 00000000 20746F4E
62616E45 0D64656C 0000000A 46206F4E 20656C69 74737953 0A0D6D65 00000000
20746F4E 6E756F6D 0D646574 0000000A
end csub
Codenquilts
Posted: 09:41am 30 Jan 2017
Thanks very much for the post. I learned a lot, including that there is such a thing as the "Library", and that you can use in either the library or your program C code and hex, in addition to basic.
I loaded your code into the library, along with "CFunction CPUSpeed" from the manual. That worked, so the library is OK. I've phaffed around a bit and have been able to read the directory on the SD (two files, LOGFILE.TXT and EMPTY.TXT), but fail when trying to open EMPTY.TXT when using matherp's sdtest.bas code.
In the library I defined CS_PIN as 4 in the library, and have that connected to CS on the SD module.
I wasn't able to create EMPTY.TXT by opening it--I created on the PC. Since I can successfully read the directory, I'm close. What am I doing wrong?
[code]
'option explicit
option default none
' Constants defining SD card calls
const fileopen=1
const readfile=2
const writefile=3
const opendir=4
const readdir=5
'CONST CTRL_Z = 26 'Used in example as EOF marker
'const CS_PIN=4 'Chip select pin conected to the SD card
dim integer i,filepos,num
dim s$
prepnumbers()
' Mount the disk
' open directory
SDcard opendir,""
'read the directory
do
SDcard readdir,s$
if s$<>"" then print s$
loop while s$<>""
' Open a file to use for write
SDCard fileopen,"EMPTY.TXT"
' Write out a title line
s$="Title: 73 times table "+chr$(13)
SDcard writefile,s$,0,len(s$)
' maintain the file pointer - this must be done in the Basic program
filepos=len(s$)
num=0
' write out 500 lines of output updating the file pointer as we go
for i=1 to 500
s$=int2text$(num)+chr$(13)
num=num+73
SDcard writefile,s$,filepos,len(s$)
filepos=filepos+len(s$)
next i
' write something we can recognise as the end of file
s$=chr$(CTRL_Z) 'end of file marker CTRL-Z
' Now lets read back the file to check it
' Read in the first 240 characters positioning the filemarker to the beginning of the file
SDcard readfile,s$,0,240,filepos
print s$;
' loop through the file
do 'NB we call readfile with
SDcard readfile,s$,-1,240,filepos
if instr(s$,CHR$(CTRL_Z)) THEN
s$=left$(s$,instr(s$,CHR$(CTRL_Z))-1)
filepos=0
endif
print s$;
loop while filepos<>0 'loop until the end of the physical file or our end-of-file marker
print ""
end
FUNCTION int2Text$(number AS integer)
local num AS integer, outP AS STRING length 60, unit AS INTEGER
local tmpLng1 AS integer
IF 0 = number THEN
int2Text$ = "zero"
EXIT FUNCTION
END IF
num = ABS(number)
DO
tmpLng1 = num MOD 100
SELECT CASE tmpLng1
CASE 1 TO 19
outP = small(tmpLng1) + " " + outP
CASE 20 TO 99
SELECT CASE tmpLng1 MOD 10
CASE 0
outP = tens((tmpLng1 \ 10) - 2) + " " + outP
CASE ELSE
outP = tens((tmpLng1 \ 10) - 2) + "-" + small(tmpLng1 MOD 10) + " " + outP
END SELECT
END SELECT
tmpLng1 = (num MOD 1000) \ 100
IF tmpLng1 THEN
outP = small(tmpLng1) + " hundred " + outP
END IF
num = num \ 1000
IF num < 1 THEN EXIT DO
tmpLng1 = num MOD 1000
IF tmpLng1 THEN outP = big(unit) + " " + outP
unit = unit + 1
LOOP
IF number < 0 THEN outP = "negative " + outP
Do WHILE ASC(RIGHT$(outp,1))<=32
outp = LEFT$(outp,len(outp)-1)
loop
int2Text$ = outP
END FUNCTION
sub prepnumbers
'small
DATA "one", "two", "three", "four", "five", "six", "seven", "eight", "nine", "ten"
DATA "eleven", "twelve", "thirteen", "fourteen", "fifteen", "sixteen", "seventeen", "eighteen", "nineteen"
'tens
DATA "twenty", "thirty", "forty", "fifty", "sixty", "seventy", "eighty", "ninety"
'big
DATA "thousand", "million", "billion"
dim small(19) AS STRING length 10, tens(7) AS STRING length 10, big(2) AS STRING length 10
FOR i = 1 TO 19
READ small(i)
NEXT
FOR i = 0 TO 7
READ tens(i)
NEXT
FOR i = 0 TO 2
READ big(i)
NEXT
end sub
'[/code]
Here is my output when I run the above code:
LOGFILE.TXT
EMPTY.TXT
[29] SDCard fileopen,"EMPTY.TXT"
Error: Disk Error
MikeO
Posted: 12:20pm 30 Jan 2017
Lizby, did you create the Empty.txt file using the blank file Matherp provided in his write up Zip file,
here .
Also you probably did but you can't use Constant declares in the Library.
Mike
Codenquilts
Posted: 03:11pm 30 Jan 2017
I created the EMPTY.TXT file on the PC with "copy NUL e:\empty.txt".
DIR E:\EMPTY.TXT shows 0 bytes.
In the zip file I have, 2016-05-14_110302_sdcard.zip, there is no EMPTY.TXT. I don't have any matherp code in the library other than what you postes.
There are no CONST statements in my library (which is what you posted plus CFunction CPUSpeed, with OPTION EXPLICIT at the top).
MikeO
Posted: 05:08pm 30 Jan 2017
Hi Lizby, You can't create the files the way you did as they will be Zero bytes long. The files have to exist but they must also be full of Zero bytes and large enough to contain your data. In the Zip file Matherp provides you will find a file Blank.bas you can copy and rename this file to what you want.
I set up a 170 with a SDcard and created 2 files on it from Blank.bas called Logfile.txt and empty.txt. I modified the program code a little to add the usage of my xwritefile sub (takes care of file position etc)and i also used the declares for the SDCARD from the library
I loaded the library file I saved to the Library and the code below to the program area, Initialized and ran the code.
> run
EMPTY.TXT
LOGFILE.TXT
thirty-six thousand four hundred twenty-sevenetn
Write 10 lines to Logfile.txt
End of write 10 lines to Logfile.txt
Read Logfile.txt on PC
Write line #1 to file
Write line #2 to file
Write line #3 to file
Write line #4 to file
Write line #5 to file
Write line #6 to file
Write line #7 to file
Write line #8 to file
Write line #9 to file
Write line #10 to file
Hope this helps, Mike
'option explicit
option default none
dim s$
prepnumbers()
' Mount the disk
' open directory
SDcard SDopendir,""
'read the directory
do
SDcard SDreaddir,s$
loop while s$<>""
SDCard SDfileopen,"EMPTY.TXT"
SDcard SDwritefile,s$,0,len(s$)
filepos=len(s$)
num=0
for i=1 to 500
num=num+73
SDcard SDwritefile,s$,filepos,len(s$)
next i
SDcard SDreadfile,s$,0,240,filepos
print s$;
SDcard SDreadfile,s$,-1,240,filepos
filepos=0
endif
print s$;
print ""
print "Write 10 lines to Logfile.txt"
for i=1 to 10
xwritefile "logfile.txt","Write line #" + str$(i)+ " to file"
next i
Print "End of write 10 lines to Logfile.txt"
end
'subs
IF 0 = number THEN
int2Text$ = "zero"
EXIT FUNCTION
END IF
num = ABS(number)
DO
SELECT CASE tmpLng1
CASE 1 TO 19
CASE 20 TO 99
CASE 0
CASE ELSE
END SELECT
END SELECT
IF tmpLng1 THEN
END IF
num = num \ 1000
unit = unit + 1
LOOP
loop
int2Text$ = outP
END FUNCTION
sub prepnumbers
'small
'tens
'big
FOR i = 1 TO 19
READ small(i)
NEXT
FOR i = 0 TO 7
READ tens(i)
NEXT
FOR i = 0 TO 2
READ big(i)
NEXT
end sub
Codenquilts
Posted: 05:09am 31 Jan 2017
Thanks for your reply and example. Still no joy.
I made the empty.txt and logfile.txt files by copying matherp's blank.bas. Each says 98K on my PC.
Your test code (essentially matherp's sdtest.bas) printed the two file names but failed on SDCard SDfileopen,"EMPTY.TXT" with:
LOGFILE.TXT
EMPTY.TXT
[43] SDCard SDfileopen,"EMPTY.TXT"
Error: Disk Error
I find that once I get the "Disk Error", I have to remove and re-insert the sd card or it fails on SDcard SDopendir,"". I don't know if this is indicative of anything.
Perhaps I have a bum sd card module.
Thanks for your time. I'm not sure there's anything else for me to try except another module (which I don't have, but will order).
(Lordy, 5 for $8.29 USD, delivered Thursday. What a world we live in.)
Edited by lizby 2017-02-01
Posted: 05:28am 31 Jan 2017
  Quote  Perhaps I have a bum sd card module.
Your code doesn't show the initialisation statement, something like:
[code] sdcard 0,4,0 'set up the chip select pin for the SDcard [/code]
The last parameter specifies the clock divider for the SPI bus
0==20MHz
1==10MHz
2==5MHz
If you omit the last parameter speed will default to 5Mhz
Try slowing down the bus to see if this is the problem.
In general use a SDHC card of at least 4Gb. Format FAT32.Edited by matherp 2017-02-01
Posted: 09:15am 31 Jan 2017
is in the library code provided by MikeO. I think the format is FAT32, but I'll check again. It's a 4gb card.
I'll also check out the slower speeds.
MikeO
Posted: 09:30am 31 Jan 2017
@ Matherp, the SD initialise is in the library file but yes he could try an even slower seting but I have not usually had any problems at that bus speed.
Codenquilts
Posted: 12:43pm 31 Jan 2017
I checked and the card is formatted FAT32. I tried the 5mHz speed but there was no difference.
MikeO
Posted: 12:58pm 31 Jan 2017
@Lizby, Just had a thought, is what you have something like this? If so are you running it from 5v or 3.3v as this one has a regulator and also signal voltage conversion between 3.3 to 5v , I am wondering if you are having issues due to this possibly?
Edit: I think this drawing will be near to what you may have. I could be that the level shifter on the data out MISO may be marginal for the uMite which maybe why you can't read the files. You could try some mods to the adapter as in this drawing. Really you don't need the level shifter or reg at all.
Mike Edited by MikeO 2017-02-02
Codenquilts
MikeO
Posted: 03:18pm 31 Jan 2017
@Lizby
  Quote   I think this drawing will be near to what you may have. I could be that the level shifter on the data out MISO may be marginal for the uMite which maybe why you can't read the files. You could try some mods to the adapter as in this drawing. Really you don't need the level shifter or reg at all.
Seems I couldn't add the image when in edit on the previous post so here it is.
Still couldn't do it ?? sent by PM
Mike
Codenquilts
Posted: 07:22am 01 Feb 2017
I got the PM. Was able to snip the legs of the regulator and solder a link between IN and OUT. Could even re-install it if needed. Lifting R4 was trickier. That speck of dust will never go back in. Soldering the link between D0 (SD pin 7) and MISO was really beyond my skill level, but I think I got it with very fine wire.
Still no joy, though. It now says
>RUN
matherp's sd test
[21] SDcard opendir,""
Error: Not Ready
Doesn't print the directory as before.
So I'm ready to give up on this module. What do you use for your SD device?
Posted: 07:57am 01 Feb 2017
I use one of these
Posted: 09:18am 01 Feb 2017
Thank you for that link. Couldn't find anything similar on Amazon Prime, so 3 of them are coming by slow boat.
Posted: 05:50am 03 Feb 2017
New modules of the ebay Arduino type fail as the first one did--print the file names from the home directory, but can't open EMPTY.TXT (which exists).
So I'm awaiting the modules from Waveshare.
Posted: 06:06am 03 Feb 2017
Please post your full program and any needed files as a zip and confirm which version of the MM firmware you are running and I'll test it here.
Posted: 03:44am 04 Feb 2017
Thank you for your interest.
Not much of the code can be said to be mine. The sdtest.zip file contains your sdtest.bas with a print line added, and library.bas, which is the code provided by MikeO, including your hex program (plus CFunction CPUSpeed from the MMBasic manual so I could test that the library was loaded properly).
This is the ebay sd module (with 3.3V regulator):
2017-02-04_134257_sdtest.zip
Running V5.2 on an MM-28 on bigmics MuPv3 board.
Posted: 04:57am 04 Feb 2017
I've just run your code on both 5.2 and 5.3 using a MuPV3 and it works fine using the Waveshare SDcard adapter. I've attached a copy of the test empty file just for completeness
2017-02-04_145659_empty.zip Edited by matherp 2017-02-06
