Forum Index : Microcontroller and PC projects : speed tests
| Page 1 of 2 |
could someone please run the following code on various micromites and report the times returned: Print "Sieve of Eratosthenes Speed Test" Start = Timer 10 W=500:Dim F(W):P=1:A=3 20 F(P)=A:P=P+1:If P>W Then GoTo DONE 30 A=A+2:X=1 40 S=A/F(X):If S=Int(S) Then 30 50 X=X+1:If X<P And F(X)*F(X)<=A Then 40 60 GoTo 20 DONE: Print (Timer-Start)/1000 so far: MX170 @ 40MHz reports 5.31 seconds. i'm intetested in getting the results for MX470, MZ, RPi zero, and RPi 3. cheers, rob :-) |
E100 MM+ 470 @ 100MHz = 2.958 E100 MM+ 470 @ 120MHz = 2.462 ![]() Smoke makes things work. When the smoke gets out, it stops! |
| Lou Senior Member Joined: 01/02/2014 Location: United StatesPosts: 229 |
Rob, I ran your program on a Grogster SkinnyMite board with an MX470F512H chip, version 4.6b++b16 software, CPU 40, all old stuff. The result was 7.282 (CPU 80, result 4.097) I also ran it on an MX150F128B version 4.5 Beta 10 software, CPU 40, result 6.857 Even older stuff (I know, a 150 who cares) but I had it handy and ran it. Lou Microcontrollers - the other white meat |
palcal![]() Guru Joined: 12/10/2011 Location: AustraliaPosts: 2052 |
E100 MM+ 470 @ 100MHz = 2.972 MMX @ 200 MHz = 1.121 Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
jman![]() Guru Joined: 12/06/2011 Location: New ZealandPosts: 711 |
Hi Rob PiZero (not w) Regards Jman |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 210 |
Hi Rob Raspberry Pi B+ v1.2: 0.666 Raspberry Pi 2B v1.2: 0.221 (running off 8GB USB Flash drive) Raspberry Pi 3: 0.217 (running off 8GB USB Flash drive) Of course, it varies on whether the Pi's are being over-clocked [My Pi 2 & 3 are throttled to 1 GHz: not the fastest kids on the block!] Rgds don Miss you George |
do you know what clock speed the B+ is running at? i believe the default should be 700MHz from what i can see online. cheers, rob :-) |
Raspberry Pi B+: 1GHz arm core freq=500MHz: sdram freq=600MHz: over volts=6: gpu mem=128 Rasbian wheezy Miss you George |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11889 |
Pi zero W 0.63 Pi 3 Model B V1.2 0.185 MMX 252MHz 0.934 |
| Phil23 Guru Joined: 27/03/2016 Location: AustraliaPosts: 1667 |
I think I have the record! Is this cheating? |
Sorta makes the Pi 3 look pretty impressive Vs the 2.4Gig Core i7 with 16Gigs. And a bit more than the $60.00 price tag. Phil. |
there does seem to be quite a variation in what different people are seeing on the same RPi hardware. i'm guessing this is caused by clock tweak differences, and perhaps even power quality (if a RPi detects sagging power it seems to throttle back the clock to reduce current draw). peter: are all your RPi's running at the standard out-of-the-box clock rate? that is 1GHz for the zero, 1.2GHz for the 3. jman: your RPi zero seems much slower than peter's RPi zero W, is it doing anything else at the same time that might be slowing it down? btw, i'm wanting the numbers for a speed comparison chart in a magazine article. the article will be mostly about the MX170, but i'm keen to include a couple of the RPi results for speed comparisons. results for several 1980's machines will also be included. here are the results so far plus the 'historic' figures from the net: How Fast Were Those Late 1970s Home Computers? 8-Bit Home Computer Benchmarks computer model clock CPU time lines/sec ============== ===== === ==== ========= TRS 80 model I with Level II Basic 1.77 MHz Z80 421 s 378 Sinclair ZX Spectrum +3 3.55 MHz Z80A 388 s 411 Tandy 102 2.40 MHz 80C85 367 s 434 Atari 130XE (Atari BASIC Rev. C) 1.79 MHz 6502C 338 s 471 Atari 800XL 1.80 MHz 6502 316 s 504 Tandy 64K CoCo 2 0.90 MHz 6809E 271 s 588 Commodore Plus/4 1.80 MHz 8501 267 s 597 Sony F1XV MSX2+ (MSX Microsoft BASIC 3.0) 3.58 MHz Z80A 260 s 613 Commodore C64 1.00 MHz 6510 254 s 627 Commodore VIC-20 (Microsoft BASIC 2a) 1.00 MHz 6502 234 s 681 TRS-80 Micro Colour Computer (MC-10) 0.90 MHz 6803 220 s 724 Apple IIe Enhanced (Applesoft II) 1.00 MHz 6502 211 s 755 Sharp MZ-731 4.00 MHz Z80A 182 s 875 Commodore 128 2.00 MHz 8502 152 s 1048 Tandy 64K CoCo 3 1.79 MHz 809E 147 s 1084 Amstrad CPC464 4.00 MHz Z80A 140 s 1138 Acorn Electron 2.00 MHz 6502 138 s 1154 BBC Model B (BBC BASIC 2) 2.00 MHz 6502 101 s 1577 BBC Master (BBC BASIC 4) 2.00 MHz 65SC12 76 s 2096 Micromite MX150 40 MHz mips M4K 6.86 s 23232 Micromite MX170 (Mk II) 40 MHz mips M4K 5.31 s 30000 Micromite MX470 (plus) 100 MHz mips M4K 2.96 s 53854 Micromite MZ2048 (extreme) 200 MHz mips M 1.12 s 142105 MMbasic on RPi Zero (JG) ARMv6 0.89 s 178387 MMbasic on RPi B+ (DH) ARMv6 0.67 s 239189 MMbasic on RPi Zero W (PM) ARMv6 0.63 s 252857 MMbasic on RPi 3 (DH) ARMv8 0.22 s 734101 MMbasic on RPi 3 (PM) ARMv8 0.19 s 861081 MMbasic for WIN32 2400 MHz i7 0.06 s 2569355 cheers, rob :-) |
Yes Note that my Pi zero is a "W" jman's isn't - don't know if this makes a difference. I'm running Raspbian Jessie Lite on the W (no GUI). - full Raspbian Jessie on the Pi 3 |
| isochronic Guru Joined: 21/01/2012 Location: AustraliaPosts: 689 |
I am a bit surprised at the '170 time, it should be faster I think. I copied a sieve-of-eratosthenes [from a page of Peter M. Maurer], bodged it a bit to match my f77 interpreter, on a '170 at 50MHz it takes about half a second, including printing the list of 95 numbers. |
Hi Rob, Just couldn't resist trying it.... Had to power up my old AMD Athlon 1200 that's been parked under the front bench. Think it's been retired for around 11 years. 0.251 is the best I see. Put's it in amongst the rPi's. DOS MMbasic 4.5 of course. Cheers Phil. |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1772 |
Just outta curiosity: which "list of 95 numbers"? Printing a list of 500 numbers takes on my MM2 (48 Mhz, MMBasic 5.1, 38400 Baud ) 0.6s. Start = Timer For i = 1 To w:Print f(i);:Next Print (Timer-Start)/1000 At 115200 Baud takes it 0.2s. This code takes 3.8s. Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
the below provides a more complete set of results, including counting the number of statements and lines. the core bit of code is exactly the same as posted on the net here: http://www.retroprogramming.com/2010/01/8-bit-home-computer-benchmarks.html cheers, rob :-) Print "Sieve of Eratosthenes Speed Test" Start = Timer 10 W=500:Dim F(W):P=1:A=3 20 F(P)=A:P=P+1:If P>W Then GoTo DONE 30 A=A+2:X=1 40 S=A/F(X):If S=Int(S) Then 30 50 X=X+1:If X<P And F(X)*F(X)<=A Then 40 60 GoTo 20 DONE: Elapsed = (Timer-Start)/1000 Print Elapsed " seconds" I = 0 ' statement counter J = 0 ' line counter Erase F 110 I=I+4: J=J+1: W=500:Dim F(W):P=1:A=3 120 I=I+3: J=J+1: F(P)=A:P=P+1:If P>W Then GoTo FINI 130 I=I+2: J=J+1: A=A+2:X=1 Print ,P Chr$(13); 140 I=I+2: J=J+1: S=A/F(X):If S=Int(S) Then I=I+1: GoTo 130 150 I=I+2: J=J+1: X=X+1:If X<P And F(X)*F(X)<=A Then I=I+1: GoTo 140 160 I=I+1: J=J+1: GoTo 120 FINI: Print I " statements" Print J " lines" Print I / Elapsed " statements per second" Print J / Elapsed " lines per second" > > > run Sieve of Eratosthenes Speed Test 5.403 seconds 48122 statements 19747 lines 8906.53 statements per second 3654.82 lines per second |
I guessed it produces the prime numbers under 500 ? (or is it the first 500 prime numbers ?- I probably made a mistake ) |
Anything that contains a PRINT statement is not measuring the speed of the processor but the speed of the output device. Microblocks. Build with logic. |
You did! Best regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
| Page 1 of 2 |
