Local Time 05:23 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Alpha Firmware
     Page 10 of 17
Posted: 03:28pm 06 Jun 2021
I think TIMER is going negative...
I'd ignored it for a while. When I came to try Timer=0 it said that valid values were 0 - 4.somethingE -something else (sorry, I can't remember the numbers). I'll wait and see what happens later.
Posted: 03:36pm 06 Jun 2021
a18
PicomiteV5.07.00a18.zip
fixes issue with timer=
Lots of internal work preparing for I/O. More work on flash and option storage
New OPTION
OPTION CPUSPEED cpuspeedinkhz
This allows you to set the cpu speed - after option reset it will be the "new" default 125,000
I've been running completely reliably at 250,000KHz and that has been the speed for all recent alphas. I'm wondering if some of the issue people have been reporting is because their chips don't like the overclock.
Use option reset, flash erase all and var clear to clean up before and after loading the alpha
Edited 2021-06-07 01:36 by matherp
Posted: 03:45pm 06 Jun 2021
Looks like it's a speed issue on my dodgy Pico. I've just this min been running it with a17 on it at 125000 and it seems to be ok. Raspberry pi point out that their default speed is 133000 and running faster is "unsupported" so it's quite likely that that's the speed (or maybe slightly more) that they are tested at.
I don't know if they do what it says, but I also tried 133000 and 140000. It seems to be working. Pressing reset does what I expected.
Edit:
Using a18 - run the dodgy board up to 200000 and apparently ok.
Edited 2021-06-07 02:03 by Mixtel90
Posted: 04:18pm 06 Jun 2021
With a17, my dodgy pico flashes the LED and presents the MMBasic prompt after power-cycling, unlike before.
FWIW, "As" is still duplicated in "LIST FUNCTIONS".
And with a18--all ok.
Edited 2021-06-07 02:20 by lizby
cdeagle
Posted: 04:24pm 06 Jun 2021
Zipped file of NPOE.BAS attached
npoe.zip
Posted: 04:27pm 06 Jun 2021
I've just been running the "good" one at a range of speeds from 50000 up to 260000. If you go too high it does tell you an interesting acceptable range though. :)
romba6
Posted: 04:32pm 06 Jun 2021
  Quote  . I'm wondering if some of the issue people have been reporting is because their chips don't like the overclock.
Thank you Peter - a17 perfect at default - fails at 200000. so no worries.
Will see what I can get out of the other pico
Posted: 04:39pm 06 Jun 2021
It's worth getting flash_nuke.uf2 from the Raspberry Pi Pico pages in case you set OPTION CPUSPEED too high. :)  It'll wipe the flash and hence the options, getting you out of a sticky situation. :)
Posted: 04:56pm 06 Jun 2021
What about a flash command like
FLASH READ n,"filename.bas" ' Reads a program from SD & loads to the specified flash spot
This might enable something like Thwill's chained tests.
Posted: 05:13pm 06 Jun 2021
WARNING: had problems when setting:
option cpuspeed 265000
the pico's USB console port was gone - rather permanently. reflashing with alpha 18 didn't fix it, reflashing with MicroPython worked, but reflashing with alpha 18 resulted in no USB console port again.
solution was to flash with an earlier alpha, then with alpha 18.
might i suggest placing the saved options into a block of flash that is overwritten by 0xFF whenever the mmbasic .uf2 file is flashed? ie, effectively include in the .uf2 file a set of default (blank) options. the same for the index into the 10 program slots so that they are always erased too.
the pico i'm testing with worked fine from 48MHz to 260MHz. at 48MHz the speed was almost exactly the same as the original MX150-based micromite, while the current consumption was around 13mA.
changing CPU speeds did knock the USB subsystem (under linux) out of action in a fairly unpredictable manner around 50% of the time. i now have the magic incantations to unbind/rebind USB on 'speed dial' so can do a quick repair without rebooting. when using option cpuspeed nnn it may be worthwhile looking at just writing the option, then printing a message that the change will take effect after the next restart of the pico.
rob   :-)
addendum: why the choice of specifying the cpu speed in kHz, instead of MHz like the MX17O version of mmbasic does?
Edited 2021-06-07 03:19 by robert.rozee
Posted: 06:32pm 06 Jun 2021
a19
PicomiteV5.07.00a19.zip
Full PWM support
PWM channel, frequency, [duty1] [,duty2]
PWM channel, OFF
e.g.
SETPIN 1,PWM0A
SETPIN 2,PWM0B
PWM 0,1000,33,67
PWM 0,OFF
The setpin can be changed until the PWM command is issued. At that point the pin becomes locked to PWM until PWM n,OFF is issued
There are 8 separate PWM frequencies available (0 - 7) and up to 16 outputs with individually controlled duty cycle. You can output on either PWMnA or PWMnB or both for each channel - no restriction
Minimum frequency is given by the equation
65535 < (OPTION CPUSPEED * 1000)/256
This gives a minimum frequuency of 7.5Hz with a clock speed of 125MHz
Maximum speed is OPTION CPUSPEED/4
Of course at very fast speeds the duty cycles will be increasingly limited
Re: locking up by overclocking. I've limited the maximum to 250MHz which seems to run (just about) on all processors. I will also provide a stand-alone program that can reflash the options to default. Given how easy the Pico is to flash, this is better than the usual pin-held-low or repeat character approaches
Valid channels for PWM and other special functions are given in the attached table and the codes for SETPIN are as in the table.
const struct s_PinDef PinDef[NBRPINS + 1]={
   { 0, 99, "NULL",  UNUSED  ,99},                                                         // pin 0
   { 1,  0, "GP0 ",  DIGITAL_IN | DIGITAL_OUT | UART0TX | SPI0RX | I2C0SDA | PWM0A,99},   // pin 0
{ 2,  1, "GP1 ",  DIGITAL_IN | DIGITAL_OUT | UART0RX | I2C0SCL | PWM0B ,99},     // pin 1
{ 3, 99, "GND ",  UNUSED  ,99},                                                         // pin 2
{ 4,  2, "GP2 ",  DIGITAL_IN | DIGITAL_OUT | SPI0SCK | I2C1SDA | PWM1A ,99},      // pin 3
{ 5,  3, "GP3 ",  DIGITAL_IN | DIGITAL_OUT | SPI0TX | I2C1SCL | PWM1B ,99},     // pin 4
{ 6,  4, "GP4 ",  DIGITAL_IN | DIGITAL_OUT | UART1TX | SPI0RX | I2C0SDA | PWM2A ,99},   // pin 5
{ 7,  5, "GP5 ",  DIGITAL_IN | DIGITAL_OUT | UART1RX | I2C0SCL | PWM2B ,99},     // pin 6
{ 8, 99, "GND ",  UNUSED  ,99},                                                         // pin 7
{ 9,  6, "GP6 ",  DIGITAL_IN | DIGITAL_OUT | SPI0SCK | I2C1SDA | PWM3A ,99},   // pin 8
{ 10,  7, "GP7 ",  DIGITAL_IN | DIGITAL_OUT | SPI0TX | I2C1SCL | EXT_PWM3B ,99}, // pin 9
   { 11,  8, "GP8 ",  DIGITAL_IN | DIGITAL_OUT | UART1TX | SPI1RX | I2C0SDA | PWM4A ,99}, // pin 10
{ 12,  9, "GP9 ",  DIGITAL_IN | DIGITAL_OUT | UART1RX | I2C0SCL | PWM4B ,99},     // pin 11
{ 13, 99, "GND ",  UNUSED  ,99},                                                        // pin 12
{ 14, 10, "GP10",  DIGITAL_IN | DIGITAL_OUT | SPI1SCK | I2C1SDA | PWM5A ,99},   // pin 13
{ 15, 11, "GP11",  DIGITAL_IN | DIGITAL_OUT | SPI1TX | I2C1SCL | PWM5B ,99},       // pin 14
{ 16, 12, "GP12",  DIGITAL_IN | DIGITAL_OUT | UART0TX | SPI1RX | I2C0SDA | PWM6A ,99},  // pin 15
{ 17, 13, "GP13",  DIGITAL_IN | DIGITAL_OUT | UART0RX | I2C0SCL | PWM6B ,99},     // pin 16
{ 18, 99, "GND ", UNUSED  ,99},                                                         // pin 17
{ 19, 14, "GP14",  DIGITAL_IN | DIGITAL_OUT | SPI1SCK | I2C1SDA | PWM7A ,99},     // pin 18
{ 20, 15, "GP15",  DIGITAL_IN | DIGITAL_OUT | SPI1TX | I2C1SCL | PWM7B ,99},   // pin 19
{ 21, 16, "GP16",  DIGITAL_IN | DIGITAL_OUT | UART0TX | SPI0RX | I2C0SDA | PWM0A ,99},  // pin 21
{ 22, 17, "GP17",  DIGITAL_IN | DIGITAL_OUT | UART0RX | I2C0SCL | PWM0B ,99},     // pin 22
{ 23, 99, "GND ",  UNUSED  ,99},                                                        // pin 23
   { 24, 18, "GP18",  DIGITAL_IN | DIGITAL_OUT | SPI0SCK | I2C1SDA | PWM1A ,99}, // pin 24
   { 25, 19, "GP19",  DIGITAL_IN | DIGITAL_OUT | SPI0TX | I2C1SCL | PWM1B ,99},   // pin 25
   { 26, 20, "GP20",  DIGITAL_IN | DIGITAL_OUT | I2C0SDA | PWM2A ,99},            // pin 26
   { 27, 21, "GP21",  DIGITAL_IN | DIGITAL_OUT | I2C0SCL | PWM2B ,99},     // pin 27
{ 28, 99, "GND ",  UNUSED  ,99},                                                        // pin 28
{ 29, 22, "GP22",  DIGITAL_IN | DIGITAL_OUT | PWM3A ,99},             // pin 29
{ 30, 99, "RUN ",  UNUSED  ,99},                                                        // pin 30
   { 31, 26, "GP26",  DIGITAL_IN | DIGITAL_OUT | ANALOG_IN | I2C1SDA | PWM5A , 0 },        // pin 31
   { 32, 27, "GP27",  DIGITAL_IN | DIGITAL_OUT | ANALOG_IN | I2C1SCL | PWM5B , 1 },        // pin 32
{ 33, 99, "AGND", UNUSED  ,99},                                                         // pin 33
{ 34, 28, "GP28",  DIGITAL_IN | DIGITAL_OUT | ANALOG_IN | PWM6A , 2 },                  // pin 34
   { 35, 99, "VREF", UNUSED  ,99},                                                         // pin 35
{ 36, 99, "3V3 ", UNUSED  ,99},                                                         // pin 36
{ 37, 99, "3V3E", UNUSED  ,99},                                                         // pin 37
{ 38, 99, "GND ", UNUSED  ,99},                                                         // pin 38
{ 39, 99, "VSYS", UNUSED  ,99},                                                         // pin 39
{ 40, 99, "VBUS", UNUSED  ,99},                                                         // pin 40
{ 41, 25, "GP25", DIGITAL_OUT | PWM4B  ,99 },                                           // pin 41
Edited 2021-06-07 04:34 by matherp
Posted: 08:34pm 06 Jun 2021
I thought I'd put together a bit of *very* provisional documentation for my own use 'cos I forget stuff. It may come in useful to someone.  :)
Picomite.zip
palcal
Posted: 08:51pm 06 Jun 2021
@ Mixtel90......thanks for that, very helpful
Posted: 10:31pm 06 Jun 2021
  lizby said  What about a flash command like
Sounds useful, but until my SD card adapter arrives and I have a chance to do a deep dive on this I don't know if it's enough. I'm only familiar with the CMM 1&2 so the limitations of the "micro"-mite will be new territory for me.
I am guessing that if all else fails I can use Python to read and write to the PicoMite over the serial connection and thus make it dance to whatever tune I like, including finding and executing a sequence of test programs - perhaps the threat of Python alone might be sufficient to motivate Peter to include some enabling functionality in the firmware .
Anyway joking aside the progress is as always phenomenal and leaves me in envy of his time, stamina and technical prowess.
On a related matter can I expect MMBasic on the Picomite to have any mechanism for sharing code, e.g. LIBRARY or #INCLUDE or would that be straying back into microcomputer territory again ?
Edited 2021-06-07 08:33 by thwill
led-bloon
Posted: 10:33pm 06 Jun 2021
a19 Fully loaded - Just a silly one ..
mis-typed option cpuspeed 25000 (ilo 250000)
Got:
Error : 25000 is invalid (valid is 48000 to 0)
led
Miss you George
Posted: 06:31am 07 Jun 2021
It's correct at the bottom end. 50% isn't bad for an alpha release. :)
@lizby Re. FLASH READ
That might not be possible. I suspect that it'll probably depend on whether there is buffer RAM available to accept the incoming file in the minimum readable block size before writing it to flash in the minimum block size while still having space in RAM for the routine that's handling the transfer. RAM is handled in fixed block sizes, it isn't contiguous, so I'm guessing that everything would have to fit into one block.
@thwill
I had considered asking about a shared library, accessed from whichever flash area is loaded at the time. I have a feeling that it may not be possible for the same reason as above - because it contains proglets it probably has to be in RAM. One approach might have been to use one of the flash areas as the library and #include it by copying into an area of RAM while retaining the program. Whether that's remotely feasible I've no idea.
@matherp
Sorry, I'm having a "thick" morning. If the choice of PWM speeds is 0-7 why do you allocate 1000 to get a frequency of 1kHz? Do you mean that there are 8 PWM *ports*, PWM0, PWM1, PWM2 etc. with outputs A and B on each?
A minor correction, smaller font size and tidied up the line lengths.
Picomite.zip
Edited 2021-06-07 18:45 by Mixtel90
Posted: 09:16am 07 Jun 2021
  Quote   Do you mean that there are 8 PWM *ports*, PWM0, PWM1, PWM2 etc. with outputs A and B on each?
There are 8 PWM channels (0-7) each of which can have its own frequency and up to 2 pins on each channel ( A  and B) with the same or different duty cycles
Posted: 10:59am 07 Jun 2021
Installed a19 and tried the pwm's. Did not work until I went through the sequence of option reset, flash erase all, and var clear.
I ran into one strange thing. When you start a PWM and the program ends, the PWM does not stop. That in itself is not so strange (althgough stopping the PWM when the program hits and END could also be logical), but I would expect when you alter the program, and run it again that PWM's would accept the changes. They do not.
Peter, would you at start (run) of the program perform a "pwm 0,off, .... pwm 8,off.
Is there a possibility to het the "servo" commands back in ? Technically it is very possible to use PWM, but with integer percents in PWM that is not a lot of resolution.
Posted: 12:29pm 07 Jun 2021
a20
PicomiteV5.07.00a20.zip
I2C and I2C2 now working - see example program for BMP180 below
CPU_Speed error reporting fixed
  Quote  Technically it is very possible to use PWM, but with integer percents in PWM that is not a lot of resolution.
PWM command accepts floats for duty cycles
  Quote  When you start a PWM and the program ends, the PWM does not stop
I think this is the case in all versions
  Quote  but I would expect when you alter the program, and run it again that PWM's would accept the changes. They do not.
That was a bug which should now be fixed
Option EXPLICIT
Option DEFAULT FLOAT
Const i2caddr=&b1110111
Const MS7=7 'set default wait period
Const signed=1
Const unsigned=0
Dim i2cin$ 'max size for integer conversion
Dim UT%,UP%
Dim ac1%,ac2%,ac3,ac4%,ac5%,ac6%,b1%,b2%,mb%,mc%,md% 'bmp180 parameters
Dim x1%,x2%,b5%,b6%,x3,b3%,b4%,b7%,OSS%
Dim temperature%,pressure%
Dim altitude,QNH,pressureinHpa
Dim OSSdata%(4)
Dim OSSscale%(4)
On error skip 1
SetPin 14,i2c1sda
SetPin 15,i2c1scl
I2C2 OPEN 400,1000
init:
 OSS%=1 'set oversampling ratio
' OSS%=0 ' Uncomment this line to check algorithm against datasheet
 OSSdata%(0)=&H34 'commands to sample pressure% with different levels of overs
ampling
 OSSdata%(1)=&H74
 OSSdata%(2)=&Hb4
 OSSdata%(3)=&HF4
 OSSscale%(0)=1 'scale factors for calcs when oversampled
 OSSscale%(1)=2
 OSSscale%(2)=4
 OSSscale%(3)=8
 I2C2 WRITE i2caddr,1,1,&HAA 'send read calibration data command
 I2C2 READ i2caddr,0,22,i2cin$ 'read in calibration data
 ac1%=Str2bin(int16,Mid$(i2cin$,1,2),big)
 ac2%=Str2bin(int16,Mid$(i2cin$,3,2),big)
 ac3=Str2bin(int16,Mid$(i2cin$,5,2),big)
 ac4%=Str2bin(uint16,Mid$(i2cin$,7,2),big)
 ac5%=Str2bin(uint16,Mid$(i2cin$,9,2),big)
 ac6%=Str2bin(uint16,Mid$(i2cin$,11,2),big)
 b1%=Str2bin(int16,Mid$(i2cin$,13,2),big)
 b2%=Str2bin(int16,Mid$(i2cin$,15,2),big)
 mb%=Str2bin(int16,Mid$(i2cin$,17,2),big)
 mc%=Str2bin(int16,Mid$(i2cin$,19,2),big)
 md%=Str2bin(int16,Right$(i2cin$,2),big)
' Uncomment this block to check algorithm against datasheet
'  ac1%=408
'  ac2%=-72
'  AC3=-14383
'  ac4%=32741
'  ac5%=32757
'  ac6%=23153
'  b1%=6190
'  b2%=4
'  mb%=-32768
'  mc%=-8711
'  md%=2868
main:
 I2C2 WRITE i2caddr,0,2,&HF4,&H2E 'send temp conversion
 Pause MS7 'wait for temperature% conversion
 I2C2 WRITE i2caddr,1,1,&HF6 'send read data
 I2C2 READ i2caddr,0,2,i2cin$ 'read 2 bytes
 UT%=Str2bin(uint16,i2cin$,big)
'  UT%=27898 ' Uncomment this line to check algorithm against datasheet
 I2C2 WRITE i2caddr,0,2,&HF4,ossdata%(oss%) 'send pressure% conversion
 Pause (oss%+1)*ms7 'wait for the p  ressure% conversion
 I2C2 READ i2caddr,0,3,i2cin$ 'read 3 bytes
 UP%=Str2bin(uint32,Chr$(0)+i2cin$,big)
 UP%=UP%>>(8-oss%) 'scale the oUT%pUT% by the numb%er of unused bits in the xl
sb byte
'  UP%=23843' Uncomment this line to check algorithm against datasheet
 calc_temp()
 calc_pressure()
 pressureinHpa=pressure%/100
 Print "Temperature = ",Str$(temperature%/10,4,1)," Deg C"
 Print "Local pressure = ",Str$(pressure%/100,4,1)," Hectopascal/mb"
 Input "QNH in Hpa/Mb  ? ",QNH
 altitude=calcaltitude(QNH,pressureinHpa)
 Print "Current altitude in feet = ",altitude
 Print "Reverse calculate Sea level pressure = ",calcQNH(altitude,pressureinHp
a)," Hectopascal/mb"
End
' calc_temperature%: calculate the temperature% from the raw temperature% given
the calibration parameters
Sub calc_temp
 x1%=(UT%-ac6%)*ac5%\powerof2(15)
 x2%=mc%*powerof2(11)/(x1%+md%) 'This needs to be a floating divide to match t
he datasheet
 b5%=x1%+x2%
 temperature%=(b5%+8)\powerof2(4)
End Sub
' calc_pressure: calculate the pressure% from the raw pressure% given the calib
ration parameters and temperature% oUT%pUT%
Sub calc_pressure
  b6%=b5%-4000
  x1%=(b2%*(b6%*b6%/powerof2(12)))\powerof2(11)
  x2%=ac2%*b6%\powerof2(11)
  x3=x1%+x2%
  b3%=(((ac1%*4+x3)*ossscale%(oss%))+2)\4
  x1%=AC3*b6%\POWEROF2(13)
  x2%=(b1%*(b6%*b6%/POWEROF2(12)))\POWEROF2(16)
  x3=((x1%+x2%)+2)\4
  b4%=ac4%*(Abs(x3+32768))\powerof2(15)
  b7%=Abs(UP%-b3%)*(50000\ossscale%(oss%))
  pressure%=(b7%*2)\b4%
  x1%=(pressure%\powerof2(8))*(pressure%\powerof2(8))
  x1%=(x1%*3038)\powerof2(16)
  x2%=(-7357*pressure%)\powerof2(16)
  pressure%=pressure%+(x1%+x2%+3791)\powerof2(4)
  End Sub
Function calcQNH(currentaltitude,localpressure)
 calcQNH=(localpressure*100)/((1-(currentaltitude*0.3048/44330))^5.255)/100
End Function
Function log10(x)
 log10=Log(x)/2.302585093
End Function
Function calcaltitude(sealevelpressure, localpressure)
 Local a As float, b As float
 calcaltitude=((10^(log10(localpressure/sealevelpressure)/5.2558797))-1)/-6.87
55856  *1000000
End Function
Function powerof2(i As integer) As integer
powerof2=(1<<i)
End Function
Posted: 12:48pm 07 Jun 2021
*confused*
SetPin 14,i2c1sda
SetPin 15,i2c1scl
I2C2 OPEN 400,1000
The I2Cs are I2C (channel 1) and I2C2 (channel 2), so shouldn't the SETPINs refer to i2c2sda and i2c2scl in this example?
     Page 10 of 17
