Local Time 18:12 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for Windows - pre-alphas
     Page 11 of 17
Posted: 04:43pm 08 Feb 2022
Try now
MMBasic.zip
Plasmamac
Posted: 07:18pm 08 Feb 2022
works
Plasma
Plasmamac
Posted: 08:23pm 08 Feb 2022
sry Matherp found a new one
after playing with mode the editor wont start with standard mode and will not show the statusline .
Plasma
Goksteroo
Posted: 01:44pm 09 Feb 2022
I've converted No_Clue (the crossword solver) from CMM2 to MM-Basic for Windows and it is fully working without issues (famous last words). Simple conversions as it's just a text juggling program. Just had to change the way the cursor flashed and a couple of other minor things. Set to run in Mode 14 as I like this in a little window on my desktop. Change the 2nd line to your own mode preference.
no_clue_MM-Win.zip
Enjoy
Posted: 02:10pm 09 Feb 2022
Peter is #INCLUDE on the roadmap ?
What about the other niceties (and eccentricities) of the CMM2 pre-processor ?
Edited 2022-02-10 01:18 by thwill
Turbo46
Posted: 10:20pm 09 Feb 2022
  Quote  Peter is #INCLUDE on the roadmap ?
Yes please Peter.
I still hold faint hopes for #INCLUDE on the Pico.
Bill
Posted: 11:32pm 09 Feb 2022
  Turbo46 said  I still hold faint hopes for #INCLUDE on the Pico.
He may surprise me, but I think that when Peter says that isn't possible he won't be exaggerating ... it would certainly require significant changes to the edit/load/run program life-cycle and would also only be possible for PicoMites with SD cards.
Edited 2022-02-10 09:32 by thwill
Turbo46
Posted: 07:56am 10 Feb 2022
Hi Tom,
I guess my idea of it is too simplistic. I thought it would just be a matter of noting the included filename(s) as the main file is loaded and then loading and appending them to the end of the original file.
I feel it would be a handy addition to any MMBasic version that uses an SD, HDD or SSD as a storage medium. A pity that .INC files are only available to the CMM2 and of course your MMb4L.
Bill
Posted: 08:30am 10 Feb 2022
Definitely no on the PicoMite otherwise as Tom says it breaks the lifecycle. Load a program with includes and then edit and the includes are in the edit so why have them separate in the first place.
Includes will be there on the windows version eventually. Need to crack sound and serial first. Then implement the CMM2 editor + a lot of other support stuff.
My current intention is to implement ALL CMM2 functionality (except the pin I/O of course) + other stuff like socket support as in the defunct Pi-Cromite
Edited 2022-02-10 18:32 by matherp
Turbo46
Posted: 09:10am 10 Feb 2022
  Quote  Includes will be there on the windows version eventually.
Thanks Peter, I'm hoping that someday programs like ZMIM and SAAINT will run on MMBasic for Windows with little modification.
  Quote  My current intention is to implement ALL CMM2 functionality (except the pin I/O of course)
I look forward to it. Thank you again.
Bill
Posted: 09:15am 10 Feb 2022
  Quote  Thanks Peter, I'm hoping that someday programs like ZMIM
ZMIM already runs - see earlier in the thread
Turbo46
Posted: 09:26am 10 Feb 2022
Yes thanks Peter. I did see that. I was meaning the 'non transpiled' version meant for the CMM2. I suspect that will happen when you implement the #INCLUDE directive.
Bill
Michal
Posted: 10:33am 10 Feb 2022
Hi matherp,
Could you upload ZMiM versions for your MMBasic for Windows?
Michal
Posted: 11:38am 10 Feb 2022
  Michal said  Hi matherp,
Michal
As an interim measure I've uploaded "zmim_win.bas" to my official Z-MIM GitHub repository, use this link to download it:
https://github.com/thwill1000/cmm2-zmim/archive/refs/heads/master.zip
Note that this version expects to be extracted into a directory named "zmim" in your default path (as set with OPTION DEFAULT PATH).
Michal
Posted: 11:47am 10 Feb 2022
  thwill said  As an interim measure I've uploaded "zmim_win.bas" to my official Z-MIM GitHub repository, use this link to download it:
Thanks,
Michal
Posted: 11:56am 10 Feb 2022
  Michal said  Thanks
No worries.
Note if you are interested in how the code works then look at the original files in the "src/" directory, not the transpiled form. Even then it isn't "state of the art" MMBasic code as it is written in an MMBasic 4.5 compatible subset of the current language.
Edited 2022-02-10 21:58 by thwill
Plasmamac
Posted: 01:07am 11 Feb 2022
hi ;,
mode 1 -  18 work
option default mode above 12 up to 18  not
page - work
list pages not
gtx
Plasma
Posted: 08:48am 11 Feb 2022
pa15
MMBasic.zip
Starting on serial. First step to identify com ports available
Use:
LIST COM PORTS
to get a list of all ports available
use function
COMPORT(portno)
to check if a particular port exists
e.g
? COMPORT(22)
Plasmamac
Posted: 11:16am 11 Feb 2022
works
identify com1 and com29
why "list com Ports"  but the command use Comport() ?
Plasma
Michal
Posted: 11:39am 11 Feb 2022
Hi,
How to start the editing console to work in a specific graphics mode and with a specific font?
Michal
     Page 11 of 17
