Local Time 20:45 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for Windows - alphas
     Page 11 of 12
Posted: 10:19am 25 Feb 2022
Good morning Peter,
Two bugs/inconsistencies, one request and one question this morning:
1. Bug 1:
CMM2:
> Print Mm.Info(FileSize "dir-that-exists")
-2
> Print Mm.Info(FileSize "dir-that-exists/")
Invalid file specification
> Print Mm.Info(FileSize "dir-that-exists\")
> Print Mm.Info(FileSize "file-that-exists.txt")
6378
> Print Mm.Info(FileSize "file-that-does-not-exist.txt")
-1
MMB4W:
0
-1
-1
6378
-1
Note that I don't care what the "answer" is, just that it is consistent across the CMM2, PicoMite, MMB4W and MMB4L ... well actually it will never be completely consistent for MMB4L since directories have a "size" (usually 4096) in Linux.
2. Bug 2:
Run this on the CMM2 and MMB4W:
Open "foo.txt" For Output As #1
Print #1, "Hello World"
Print #1, "Goodbye World"
Close #1
Open "foo.txt" For Input As #1
Print Eof(#1)
s$ = Input$(255, #1)
Print Eof(#1)
Close #1
The output on the CMM2:
0
1
The output on MMB4W:
0
-1
I think the returned value for EOF should be 1 as MMBasic generally uses 1 for TRUE.
3. The request:
Could we please have (on all platforms) a MM.INFO(EXISTS "foo") that returns 1 if "foo" exists and is a file OR a directory.
4. The question:
Am I correct in thinking MMB4W allows more than 10 open files unlike the other ports, and if so how many?
Edited 2022-02-25 20:20 by thwill
Posted: 10:41am 25 Feb 2022
Think they are all done including the request
MMBasic.zip
The question - not sure if there is a limit in windows but I've allowed for 64 com ports and 64 files
Currently working on porting the socket support from Pi-Cromite. Have you included this in MMB4L?
Edited 2022-02-25 20:42 by matherp
Posted: 10:45am 25 Feb 2022
  matherp said  Think they are all done including the request
Thanks Peter, will give it a spin on Monday morning ... I want to grab a few hours this weekend to work on MMB4L.
  Quote  Currently working on porting the socket support from Pi-Cromite. Have you included this in MMB4L?
Not yet Peter and it isn't slated for the first non-alpha/beta release. I can't keep up with you and am not even trying I would however be grateful if I can cannibalise whatever you do for MMB4W.
Edited 2022-02-25 20:51 by thwill
Posted: 11:03am 25 Feb 2022
  Quote   I would however be grateful if I can cannibalise whatever you do for MMB4W.
The Pi-Cromite code should work out of the box for you - I need to make changes for windows
Posted: 11:37am 25 Feb 2022
Thanks Peter, I had assumed as much but you never know.
Posted: 01:08pm 25 Feb 2022
  PeterB said  Is there a place in this world for a device to convert USB into multiple I/O pins?
Picomite I/O serial client Posted yesterday. More to come.
Plasmamac
Posted: 01:58pm 25 Feb 2022
Hi matherp , today i have testet MMBasic4W on 16 win 10 Pc , most diffent hardware.
Demox runs fine !  Btw its the only software i know which play modfiles without extra dll such like fmod.
Edited 2022-02-25 23:59 by Plasmamac
Plasma
Posted: 02:20pm 25 Feb 2022
  Quote  Hi matherp , today i have testet MMBasic4W on 16 win 10 Pc , most diffent hardware.
Posted: 04:04pm 25 Feb 2022
V5.07.03pa12
MMBasic.zip
Fixes bug in F2 leaving the editor
NEW FUNCTIONALITY
TCP command as per Pi-Cromite
GETIP$() function as per Pi-Cromite
SYSTEM command as per Pi-Cromite
JSON$ function
Pi-cromite Manual.pdf
This now allows you to do things like download the weather. You will need to substitute your own openweathermap.org APIKEY$ and a local PLACEID$ in the attached to make it work for you.
Option explicit
Option default none
Dim a$,b$,c$
Dim integer i,j,rlen
Dim m%(4000)
Dim PLACEID$="2638878"
Dim APIKEY$="myAPIkey"
' get the IP address of openweathermap and open a client connection to it
a$="api.openweathermap.org"
TCP client a$,80
' construct the request for a weather report and send it
b$= "GET /data/2.5/weather?id="+PLACEID$+"&APPID="+APIKEY$
b$=b$+" HTTP/1.0"+Chr$(13)+Chr$(10)+Chr$(13)+Chr$(10)
TCP send b$
'set up a longstring variable and read the return message into it
LongString clear m%()
TCP receive c$
If c$<>"" Then LongString append m%(),c$
Loop While c$<>""
' trim off the HTTP header
LongString trim m%(),LInStr(m%(),"{")-1
rlen=LLen(m%())
' process the message, in this case just print it out
i=1
Do While rlen>0
If rlen>240 Then
j=240
Else
j=rlen
EndIf
rlen=rlen-j
Print LGetStr$(m%(),i,j);
i=i+j
Print ""
TCP close
Print "Weather for "+json$(m%(),"name")
Print "Temperature is ",val(json$(m%(),"main.temp"))-273
Print "Pressure is ",json$(m%(),"main.pressure")
Print json$(m%(),"weather[0].description")
Edited 2022-02-26 02:12 by matherp
Posted: 04:19pm 25 Feb 2022
  matherp said  V5.07.03pa12
Nice.
FYI and take them or leave them I added a couple of extensions to JSON$ and SYSTEM for MMB4L, you can see more here:
https://github.com/thwill1000/mmb4l-src/blob/main/linux-src/functions/fun_json.c
https://github.com/thwill1000/mmb4l-src/blob/main/linux-src/commands/cmd_system.c
Sorry folks the last two links are only accessible to collaborators on that GitHub project, however I've recently cleared it with Geoff and from alpha 4 MMB4L will be going open-source and that project will become public.
Posted: 04:36pm 25 Feb 2022
Latest version of the doc. I tried to export as PDF again but the converter complained, so it's zipped RTF again.
MMBasic For Windows 220225.zip
Posted: 06:03pm 25 Feb 2022
  Mixtel90 said  Latest version of the doc. I tried to export as PDF again but the converter complained, so it's zipped RTF again.
Thanks for that. I just printed it to "Microsoft Print to PDF".
MMBasic_For_Windows.pdf
Posted: 06:23pm 25 Feb 2022
  Quote  Latest version of the doc.
Forgot to mention in dispatches, mp3, flac and wav playback now support multiple sampling frequencies. FLAC tested up to 192k @ 24-bit
Plasmamac
Posted: 07:48pm 25 Feb 2022
no picromite here so i have to ask :
is it ok what
a$=  GETIP$("www.google.com")
end
will show the ip without print a$ ?
Plasma
Goksteroo
Posted: 12:11am 26 Feb 2022
Issues with PAUSE... can be inaccurate with values <50, and very inaccurate with values <10 and let's not mention <1! This little test programme will show the issues better than I could describe them. Runs on CMM2 with results the same for using PAUSE or DO/LOOPs.
Came about when I was using PAUSE to make a scrolling page smooth (no GETSCANLINE in MMB4W) and couldn't get consistency until I used the DO/LOOP approach.
do
cls
td=0
tp=0
input "Delay wanted:";d
for i=1 to 10
print
timer=0
do
loop while timer<d
t=timer
inc td,t
print "Do/Loop: ";d,t
timer=0
pause d
t=timer
inc tp,t
print "Pause:   ";d,t
next
print "Do/Loop average: ";td/10
print "Pause average:   ";tp/10
print:print "Press [SPACE]"
do
loop while inkey$<>" "
loop
Posted: 05:58am 26 Feb 2022
  Goksteroo said  Issues with PAUSE... can be inaccurate with values <50, and very inaccurate with values <10 and let's not mention <1!
It is a known problem.
Timer is very accurate but PAUSE and SETTICK not so good as you have seen.
For long pauses, if critical, I suggest start with a pause a bit shorter than required then use timer in a loop to sneak up on the target time.
For SETTICK, I found that cancelling the settick timer and re-starting it every time the tick fires gives a more consistent result. If you leave the SETTICK repeating, you can get a very short time interval.
Hopefully, a resolution can be found soon. Multitasking operating systems make life difficult.
Posted: 08:48am 26 Feb 2022
  Quote  Timer is very accurate but PAUSE and SETTICK not so good as you have seen.
I think I can fix pause but settick will take a bit longer - watch this space
Edited 2022-02-26 18:51 by matherp
Posted: 10:16am 26 Feb 2022
V5.07.03a13
MMBasic.zip
Rework of pause and settick
Test program
option milliseconds on
settick 1000,myint
timer=0
do
 pause 5000
 print time$
loop
sub myint
 static int lasttime=timer
 print timer-lasttime
 lasttime=timer
end sub
Edited 2022-02-26 20:20 by matherp
Michal
Posted: 01:28pm 26 Feb 2022
Hi matherp,
Or maybe SQLite should be included?
Then one could get DATA from text fields as with BASIC DATA with arguments separated by comma.
Using simple SQL queries
Michal
Edited 2022-02-26 23:29 by Michal
Posted: 01:45pm 26 Feb 2022
For the last two mmb4w firmware updates, I am denied access to copy to a folder which is in my path. I'm the administrator--when I click to give administrator rights, still denied. I copied to a different folder, opened an "Administrator command line" (DOS with administrator rights) and tried to copy to the folder I wanted, but get this:
C:\WINDOWS\system32>copy \dl\micromite\_mmb4w\mmbasic.exe \bin
Access is denied.
       0 file(s) copied.
What has changed (there has been a Win10 update on my laptop since this last succeeded), and what more can I do? (Who has more rights on my laptop than I as administrator do? ... grrr)
     Page 11 of 12
