Local Time 23:10 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA V5.07.05 betas
     Page 11 of 11
Posted: 02:36pm 03 Sep 2022
Hi Peter,
I connected a 50Hz square wave to gp8 (source impedance is 10k)
> ?mm.ver
5.070517
> option list
OPTION SYSTEM I2C GP14,GP15
OPTION COLOURCODE ON
OPTION DISPLAY 40, 100
OPTION LCDPANEL ILI9341, LANDSCAPE,GP20,GP21,GP22
OPTION SDCARD GP17
OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3
OPTION RTC AUTO ENABLE
> setpin gp8,fin
> ?pin(gp8)
142
> ?pin(gp8)
96
> ?pin(gp8)
98
> ?pin(gp8)
110
> ?pin(gp8)
100
option audio disable
........causes reboot
> option list
OPTION SDCARD GP17
> setpin gp8,fin
> ?pin(gp8)
50
> ?pin(gp8)
50
> ?pin(gp8)
50
> ?pin(gp8)
50
> ?pin(gp8)
50
> ?pin(gp8)
50
EDIT:
Hi Peter,
Bad wire on the breadboard. One side had nice 50Hz, the other side intermittend (pico side).]
Sorry,
Edited 2022-09-04 00:43 by Volhout
Posted: 07:30am 15 Sep 2022
A tiny PicoMite incosistency.
Last pin in OPTION COUNT doesn't accept GP number. Works fine otherwise.
> update firmware
PicoMiteVGA MMBasic Version 5.07.05b18
Copyright 2011-2022 Geoff Graham
Copyright 2016-2022 Peter Mather
> option list
OPTION KEYBOARD US
> OPTION SDCARD GP13, GP10, GP11, GP12
> OPTION CPUSPEED 378000
> OPTION COUNT gp6, gp7, gp14, gp15
Error : Pin 15 is in use
> OPTION COUNT gp6, gp7, gp14, 20
>  option list
OPTION KEYBOARD US
OPTION CPUSPEED (KHz) 378000
OPTION COUNT GP6,GP7,GP14,GP15
Posted: 09:18am 15 Sep 2022
Thanks - cut-and-paste typo
Posted: 09:05pm 16 Sep 2022
A strange tale but true...
I regularly leave picomites running overnight when connected to my powered hub which in turn is connected to my PC.
So far all my picomites have been flashed with the non-VGA versions.
A few days ago, I flashed one with the VGA edition. Next morning, the program that was running had disappeared. Not stopped, but gone.
I repeated the exercise with a new picomite. Same result.
Load a bas program, reboot the PC with the pico plugged in and running and the bas program has gone. Any program saved to a flash slot appears to be safe, but not the one running.
I can see the heartbeat missing a few beats during the PC startup.
This is all with beta18 and a picomiteVGA with no options set and no other devices attached. Windows 11 on the PC.
The non-VGA editions are OK with the same setup.
Posted: 08:50am 17 Sep 2022
It appears that the USB disconnect is disrupting the DMA on the second processor leading to an invalid address which cause a reset. The firmware automatically wipes the current program in this case to stop the PicoMite getting into a reset loop with no way of breaking out. I'm not sure of what I could do to fix this as it seems to be caused by the USB driver interacting with the DMA
Posted: 03:03pm 17 Sep 2022
Peter,
Is there anyway to detect that this has happened/is happening ? If you can detect it, you could reload the current program from SD or flash after the wipe.
Posted: 04:55pm 17 Sep 2022
  Quote  Is there anyway to detect that this has happened/is happening ?
Not that I can see. It just throws a processor exception that my trap routine picks up. No way to distinguish it from a user "POKEing" something silly
Posted: 08:42pm 17 Sep 2022
That darn USB stack has been a pain...
As long as it doesn't happen with the non-VGA version, I am safe.
I will have to test to see how it survives a RPi reboot.
It does survive unplugging the USB, you just have to remember.
Users will soon learn to do backups!
cosmic frog
Posted: 07:16am 18 Sep 2022
Just having my Picomite connected to my PC as it boots up causes this memory wipe thing to happen. I thought it was just a thing with my PC. I'm using Win 8.1.
Dave.
Posted: 06:03pm 19 Sep 2022
  Quote  Just having my Picomite connected to my PC as it boots up causes this memory wipe thing to happen.
This seems to be some sort of bug in TinyUSB. A workaround is to use a serial console and an external USB/UART (e.g. OPTION SERIAL CONSOLE 1,2)
When the PicoMiteVGA is already powered with the VGA output running (remember this runs on core 1) and the USB CDC connects then it causes a processor hardfault exception on core 0. Originally I assumed the hardfault was on the VGA core but this isn't the case. This only occurs in the VGA version. With a standard Picomite externally powered (not via the USB) you can plug and unplug the USB and there is no effect - a running program keeps running. I'll post a question on the Pico forum but don't expect any joy.
Posted: 04:43am 20 Sep 2022
I'm currently working on a PM-VGA design, and I have not seen this issue.
Watching this thread with interest.
In my case, I use the SD card to transfer new codes, and the built-in editor to find and squish bugs as I develop the code, so perhaps cos I never plug in a USB cable to the PM module when it is already powered...
I would try that, but I think we all know what would happen, so it is probably pointless.
Posted: 06:53am 20 Sep 2022
I think I may have found a way to circumvent the issue - will post an update when happy
Posted: 12:17pm 20 Sep 2022
Peter,
You must be growing grey hair by now on this tinyUSB stack...
And .... you keep finding workarounds around it's flaws...
Super....
Thank you for being here
Harm(Volhout)
shellberight
Posted: 04:58pm 20 Sep 2022
I am new to this project, but I was wondering if the new Pico with wifi interface would be supported in some manner?  I was thinking that passing data from a web box to a serial input would be useful.  Thanks
Posted: 05:05pm 20 Sep 2022
  Quote  I am new to this project, but I was wondering if the new Pico with wifi interface would be supported in some manner?
No: supporting it uses too much memory (RAM and flash) and it is much easier to use a ESP8266 connected to a serial port to achieve the same
Note to all. Please use the release candidate thread for any further comments/bugs
Edited 2022-09-21 03:07 by matherp
     Page 11 of 11
