Local Time 01:00 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : simplest 32MX150 ICSP
     Page 11 of 28
Posted: 07:38am 30 Jun 2014
Was out today but will try to look at it tomorrow.
I have the code typed in but it's untested!
BTW, I think SetMode with 1f, 6 i.e. 111110 takes the TAP controller to Reset (11111) then to Idle (the final 0) if that helps. The pic here is convenient rather than a PDF (for me).
JohnEdited by JohnS 2014-07-01
MOBI
Posted: 01:13pm 30 Jun 2014
@JohnS
As far as I can make out, SetMode is working as I can check Status ok, read device id code ok and erase chip also works.
All the pseudo code functions appear to work i.e data in and data out seem to be correct until I try to use the xferinstruction pseudo code.
Thanks for the section on the TAP, I'll see if it make any more sense with the PDF files I already have.
It would be nice to know if anyone has got xferinstruction to work and what language/format it is done in.
David M.
Posted: 02:10am 01 Jul 2014
Have done a bit of testing.
When I use XferInstruction I get back (hex):
c004c008 after using EJTAGBOOT
4004c008 otherwise
They seem to make sense as the top bit that is only set after EJTAGBOOT is the ROCC bit which confirms a reset has just occurred.
What value(s) do you see?
So far so good, but I'm sending what I thought was sane (?!) MIPS32 ASM (as hex) and after that I read the FASTDATA register. But I get PrAcc as 0 instead of 1.
I suppose this means either my ASM is bad or my code to get Fastdata is bad. More testing needed...
edit: or my typing is rubbish - I dropped a 0. Now it "works" but I get all 1s
JohnEdited by JohnS 2014-07-02
JTR0701
Posted: 11:38am 01 Jul 2014
  MOBI said   2014-06-30_113917_MMprog32.zip
I know you guys are working on a different approach to me but maybe you can help me with a little problem.
I am trying to get the XferInstruction function to work but for some reason, the 32 bit data read back from the XferData (hextobin$("0004c000")) is displaced one place to the left.
Sub xferInstruction (st$)
SendCommand (etap_control$)
xferdata (hextobin$("0004c000"))
Loop Until Mid$(outdata$,14,1) = "1"
SendCommand (etap_data$)
XferData (hextobin$(st$))
sendcommand (etap_control$)
xferdata (hextobin$("0000c000"))
End Sub
Not sure why you are testing bit 14 for the prACC bit when it is actually bit-18 (unless you are assembling the bits in reverse order where bit-18 would became bit-14. However I see no reason why you would be doing that and I see no code that shows what you are doing. Unfortunately you cut out too much code for me to be able to give a fully helpful answer.)
MOBI
Posted: 12:14pm 01 Jul 2014
  Quote  Not sure why you are testing bit 14 for the prACC bit when it is actually bit-18 (unless you are assembling the bits in reverse
The TDO "dataout$" has its LSB on the right (normal binary) and so need to test bit 18, but this is represented as a string which counts from the left which is bit 14.
Did you open the zip file for the rest of the code? I think there should be enough to go by as what was cut out was the code relating to downloading the PE loader, data block and flash programming etc.
The block of code shown on the screen is just the XferInstruction routine.
David M.
JTR0701
Posted: 01:12pm 01 Jul 2014
Hi David,
I went over the code in the zip file numerous times. It does not include the low level primitives I needed to verify why the bits may be reversed. Now you have explained it, it makes sense.
Seems to me you may have missed that the first data bit is clocked out on the last bit of the TMS header, not the first bit of the data in. You need to "remember" this bit and carry it over. Then the whole 32-bits of data that clocked out as the instruction is clocked in, need to be shifted to the left (ends up shifted right in your string) with the carry over bit from the header put in bit-0 (string - bit-31) and the previous bit-31 (bit-0) discarded. (Just when you thought this was complicated enough...)
Last time I seen your low level primitives there was no provision for this to happen so I think it is a fair bet that is a good place to look at next.
-Jim
Edited by JTR0701 2014-07-02
Posted: 01:22pm 01 Jul 2014
David,
Just realised that I should say the (hex) values I posted are what my code gets. You should see the same values, but what do you get?
MOBI
Posted: 05:16pm 01 Jul 2014
@Jim
That gives me something to chew over. I suspected something like a "carry over" bit (rightly of wrongly) because the data clocked out is displaced 1 bit left. Is this normal? Must have a closer look at the timing charts again. I am just a bit puzzled because the XferData works quite happily with the DeviceID code read and display.
@JohnS
My XferInstruction routine is locking up on the first XferData 0004c000. The 32 bit word clocked out is 0004c000 shifted left one bit.
I think I need to display data in vs data out and look more closely at the number of bits and bit patterns. The MaxiMite text is not the easiest for ageing eyes to see clearly.
I'll be back....
David M.
JTR0701
Posted: 07:14pm 01 Jul 2014
David, sorry! The "missing code" is in the zip file. When I double clicked the .BAS file it opened in the VB6 IDE. Great I thought, syntax highlighting, I was expecting it to open in textpad with no such luxuries.
The thing is, as soon as it opened in the VB6 IDE, all the subs and functions were separated from the main guts of the code and I didn't see them. Forgot about that...
As it turns out your code is far more advanced than what I had seen previously and it appears to me that you are correctly picking up the first TDO on the last TMS clock so scrub that idea.
One thing I did notice is a nasty in this bit of code:
Sub setmode(st$)
Local x
For x = 6 To 1 Step - 1
Pin(pgd) = 0 'TDI
Pulse clk, .01
Pin(pgd) = Val(Mid$(st$,x,1)) 'TMS
Pulse clk, .01
Pulse clk, .01
Pulse clk, .01
Next x
End Sub
Notice that it does not set the pgd pin as an input for the TDO like your "clock" stub does. Doubt this is the problem at hand here but it is still not correct none the less.
I cannot see a prime suspect in why the readback is shifted one bit. May get a chance to look at it in more depth later.
MOBI
Posted: 08:19pm 01 Jul 2014
  Quote  Notice that it does not set the pgd pin as an input for the TDO like your "clock" stub does. Doubt this is the problem at hand here but it is still not correct none the less.
My current version is as you suggest - I tried it last night out of desperation but it made no difference but left it with the pgd as input in the appropriate place. Now I'm starting to dream about the B thing!
Glad you found the rest of the code. If I had left in all the flash programme and verify etc. it would have been considerably more cluttered.
Interesting to note that regardless of what code I feed in in place of 0004c000, the resultant dataout$ is always the 0004c000 left shifted 1 bit. Time to look up the bits of the control register to see what they are really meant to be.
biik !
David M.
Posted: 09:59pm 01 Jul 2014
I'm hunting around the code and will post any randomish thoughts.
I see in clock that you read in tdo later than I do, though I have a comment to remind me that mine may be wrong (I hate that Mchp datasheet).
I have (in pseudo C code):
/* swap next two? */
tdo = pin
clk = 1
clk = 0
return
If wrong, and I don't know it is or isn't, I don't see how that could cause a shift or why it wouldn't cause lots of other trouble.
I try to leave that "pin" as an input as I figured my code will run very slowly across USB so any clashes would last ages.
The reason I got to clock was that I was wondering if there's an unread bit lying around. The above wouldn't account for one as far as I can see.
Not currently relevant but I don't think your read_memory is right - it doesn't look to write into the fastdata register at ff200000 (mine also doesn't work so take my thought with a sack of salt!)
JohnEdited by JohnS 2014-07-03
MOBI
Posted: 10:39pm 01 Jul 2014
@John
I can't see how the clock can be the cause (but that just means I can't see it - it just might though).
I had a look at the ECR and the PrAcc etc are in the right place, so a body is still none the wiser. Another sleepless night?
It's a mystery because deviceID also uses 32 bit xferdata and works ok. So....?
David M.
JTR0701
Posted: 11:01pm 01 Jul 2014
tdo = pin
clk = 1
clk = 0
return
Right, you need to swap the top two around.
Correct and correct. David is not writing the prACC bit so the xferfastdata sub is currently borked. However it is not being used yet so that is not the current issue. However the code will need to be fixed to write the prACC bit as per figure 6-9 in the prog specs. Good catch!
Posted: 11:24pm 01 Jul 2014
Thanks, Jim.
I've swapped the lines (more than once) and the odd thing is it makes no difference, which at packets over USB speeds (slows!) surprises me.
The XferFastData looks wrong for an extra reason as it doesn't check the PrAcc that comes in to make sure it's 1. But I agree it's not even being used yet so cannot be relevant to the XferInstruction problem. It's got me stumped I think.
A small oddity: in function hextobin$ the local h$ is not explicitly set to an empty string. I didn't realise MMBasic auto-initialises string variables (as I suppose it must be doing).
MOBI
Posted: 11:37pm 01 Jul 2014
  Quote  Correct and correct. David is not writing the prACC bit so the xferfastdata sub is currently borked. However it is not being used yet so that is not the current issue. However the code will need to be fixed to write the prACC bit as per figure 6-9 in the prog specs. Good catch!
I didn't think the xferfastdata was correct, but that has been the least of my problems, but it is now on my list as a definite. Just need to solve the current problem and find an elusive round tuit. In three weeks the wife and I will be in Holland/UK for 6 weeks. I'll have the laptop and the hotels have wifi so if it isn't done and dusted by then I can keep in touch.
Meanwhile, back to the scratch pad. (the balding spot on the head)
David M.
JohnL
Posted: 11:54pm 01 Jul 2014
Pickit 3 is down to US$20. Is it genuine or not? IT WORKS PERFECTLY so who cares.
http://www.banggood.com/Pickit3-Pickit-3-Kit3-Emulator-Progr ammers-Programmer-p-88947.html
vasi
Posted: 04:24am 02 Jul 2014
Reading about the effort these people are making, Microchip should get ashamed! They said they will give a helping hand...
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 09:19am 02 Jul 2014
Help from Microchip would be good! Not sure what would be most useful (hardware LOL or even a better PDF about this stuff).
Meanwhile, I got a ReadMemory function working :)
Also have the PE loading and it will read me one word. Then it seems dead :(
It doesn't always even manage one, so something's not right!
Takes about 90 secs to load the PE and start it running.
MOBI
Posted: 12:35pm 02 Jul 2014
  JohnS said  Meanwhile, I got a ReadMemory function working :)
Hi John,
I wonder if I have been jumping the gun by trying to verify memory too soon. I thought that I should be able to do a verify after an erase but perhaps I need to properly enter serial execution mode first? I imagined it was only needed for programming but is it also required for reading?
Something to try later today.
David M.
Posted: 01:16pm 02 Jul 2014
I haven't yet tried an erase as I fancied ReadMemory and its ilk first.
To get that working I do EnterSerialExecutionMode and then set the BMX regs and finally ReadMemory seems OK.
SetBMX is:
/* step 1: init BMXCON (at 0xbf882000) to 0x1f0040 */
XferInstruction(0x3c04bf88); /* lui a0,0xbf88 */
XferInstruction(0x34842000); /* ori a0,0x2000 */
XferInstruction(0x3c05001f); /* lui a1,0x1f */
XferInstruction(0x34a50040); /* ori a1,0x40 */
XferInstruction(0xac850000); /* sw a1,(a0) */
/* step 2: init BMXDKPBA (at 0xbf882010) to 0x800 */
XferInstruction(0x34050800); /* li a1,0x800 */
XferInstruction(0xac850010); /* sw a1,16(a0) */
/* step 3: init BMXDUDBA & BMXDUPBA to value of BMXDRMSZ */
XferInstruction(0x8C850040); /* lw a1,64(a0) */
XferInstruction(0xac850020); /* sw a1,32(a0) */
XferInstruction(0xac850030); /* sw a1,48(a0) */
ReadMemory arranges to call that if not yet done, then:
XferInstruction(0x3c13ff20); // lui s3,0xff20 (==fastdata)
XferInstruction(0x3c080000 | (addr >> 16)); // lui t0,(high addr)
XferInstruction(0x35080000 | (addr & 0xffff)); // ori t0,(low addr)
XferInstruction(0x8d090000); // lw t1,(t0)
XferInstruction(0xae690000); // sw t1,(s3)
XferInstruction(0x0); // nop (needed?)
SendCommand(ETAP_FASTDATA, 5);
return XferFastData(0);
     Page 11 of 28
