Local Time 15:31 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.01.00 betas
     Page 12 of 15
dddns
Posted: 11:18am 17 Sep 2025
  dddns said  Hello,
the latest RP2350 HDMI and VGA firmware gives me an error when executing files command. This happens only for Resolution 800 and 848 for A: and B: drive, all others work:
> files
A:/
Error : Not enough Heap memory
> option list
PicoMiteVGA MMBasic RP2350B Edition V6.01.00b11
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION PICO OFF
OPTION RESOLUTION 800x600 @ 360000KHz
OPTION DISPLAY 50, 100
OPTION SDCARD GP24, GP25, GP26, GP27
OPTION VGA PINS GP32,GP34
The problem with "files" command still exists for me in b12.
I can confirm that files get corrupt, when
copy "file.txt" to "file1.txt"
file1.txt will be corrupted and a large part gets cut off at the top. If the file is small it will result in a 0 byte file.
Posted: 11:30am 17 Sep 2025
  Quote  The problem with "files" command still exists for me in b12.
Will have to reduce the maximum number of files in those modes from 1000 to say 750
  Quote  I can confirm that files get corrupt, when
Was as a result of the "fix" for zero length files b13 should solve this
Posted: 11:40am 17 Sep 2025
@Peter,
The 2040 test version also solves the problems (file copy problem, and framebuffer merge problem) for the 2040 Game*Mite.
Posted: 09:28am 18 Sep 2025
@Peter,
Will you also update the other (VGA/HDMI) b12 versions with this fix ?
Posted: 08:41am 20 Sep 2025
V6.01.00b13
PicoMiteV6.01.00b13.zip
Fixes the zero length file bug WITHOUT bu....ing anything else (I hope)
New experimental drivers for the SSD1963 (WIP)
Posted: 11:17am 20 Sep 2025
@Peter,
Can you share more info regarding the SSD1963 drivers as very curious…..
twofingers
Posted: 11:53am 20 Sep 2025
Hi Peter,
is it the desired behavior that an entry in the command line - after running a program with `Option Explicit` - produces an error message about an undeclared variable? I would have expected the lifetime of `Option Explicit` to be limited to the program itself. (V6.01.00b5e)
Kind regards
Michael
Posted: 01:19pm 20 Sep 2025
Has always been this way AFAIK
twofingers
Posted: 01:55pm 20 Sep 2025
Thanks!
Okay, so that means that to disable "Option Explicit" on the command line, I have to start a program that doesn't contain "Option Explicit"?
From manual p91:
This option is disabled by default when a program is run.
Posted: 05:24pm 20 Sep 2025
If i recall correctly, I encountered this behavior, and "new" at the command line undid OPTION EXPLICIT. Of course, you lose your variable values, but you also would if you started a new program.
Edited 2025-09-21 03:26 by lizby
EDNEDN
Posted: 09:44pm 20 Sep 2025
@matherp
In the MMInKey() function in the PicoMite.c file, there is this non-sensical code.
It doesn't hurt anything, but it can't ever be true.   Perhaps it should be || instead of &&  ?
       if (c < '1' && c > '6')
           c1 = '[';
           c2 = c;
           return 0x1b;
       } // the 3rd char must be in this range
Edited 2025-09-21 07:45 by EDNEDN
Posted: 04:22pm 21 Sep 2025
Peter,
B13 seems pretty good. I have hoever one thingI havenot been able to quantify.
For picofrog, I toy around with sprites, that occasionally are shown outside the lcd screen when I make a mistake.
I remember this was very robust, but in b13, the pico crashes. White screen, no console.
Is anything changed in the protection of screen coordinates? Or is my memory false. This is on 2040 game mite.
I have not found a simple way to reproduce yet.
Posted: 04:46pm 21 Sep 2025
It shouldn't crash but it should error. Can you create a simple test program so I can investigate?
  Quote   there is this non-sensical code.
Hmmm...
Edited 2025-09-22 02:47 by matherp
Posted: 08:03pm 21 Sep 2025
@Peter - I am using one of your RP2350B DIL modules (with b13 firmware) connected to one of the latest batch of 5” IPS panels arrived form BuyDisplay (exactly the same module you link to on your PicoPalm thread).
Using 8-bit data connection. The issue I am seeing is a reversal of the Red and the Blue colours (green is ok). OPTION LCDPANEL SSD1963_5,L,,,,GP1 is set.
Using GP13-GP16 for D/C, WR, RD, RST.
Note option 5A does not work (splits the screen), and other sizes tried too without success.
Everything else works as expected.
Is there some kind of ‘undocumented invert’ parameter to resolve this issue in a similar manner as on the SPI screens?
Also FYI, lots of time was lost attempting to use GP40-GP47 for the 8-bit data link (and using GP40 as the last parameter in the OPTION).
It did not work - several DILs used, and three sets of wiring for each and all failed; only worked when I moved to GP1-GP8. Could there be a bug when using high PIN numbers?
Also - tried on 6.0..3 and same issue with blue and red colours reversed.
Posted: 09:54pm 21 Sep 2025
Manual page 60
  Quote  16-bit Parallel LCD Panels
SSD1963 panels can also be enabled for 16-bit parallel operation. In this case, by default, pins GP0-GP15 are
used for the data connections and, by default, pins GP16 to GP19 are used for the control signals DC, WR, RD
and RESET.
For systems using the RP2350B only the data pins used can be selected by using the optional DB0pin parameter
in the configuration command.
  Quote  SSD1963_5ER_16 For the 5 inch EastRising panel
Edited 2025-09-22 07:55 by matherp
Posted: 05:02am 22 Sep 2025
@Peter - I did see this in the manual regarding 16-bit mode, but I was ideally needing to use 8-bit mode.
Are you saying the red and blue will switch round with the 5ER_16 (and that I can’t therefore use 8-bit comms)?
I would try it but I’m away from PicoMite until this evening so curiosity has got to me….
Could there be a 12 bit mode too as you’ve eluded to in b13 (for the ER I mean)? Be useful to know so I can save some pins!!
Edited 2025-09-22 15:04 by WhiteWizzard
disco4now
Posted: 06:43am 22 Sep 2025
You can use POKE DISPLAY to change the colour order after the display is initialised when there is not a specific config for it. see this this thread
F4 H7FotSF4xGT
Posted: 03:19pm 22 Sep 2025
V6.01.00b14
PicoMiteV6.01.00b14.zip
Fixes a couple of types in PIO
Fixes a typo in reading escape sequences#
Only the 16-bit drivers support changing the SSD data pins. There is quite a lot of overhead in processing this and with 3 transfers per pixel for 8-bit mode that would slow things down too much.
The release does include 3 buffered drivers for the 5" BuyDisplay IPS display on the RP2350 BUT they are all 400x240 resolution. They do allow the data pins to be assigned as the updates take place on the 2nd processor. Feel free to try them.
SSD1963_5_BUFF, SSD1963_5_12BUFF and SSD1963_5_16BUFF. Parameters are as per the manual
Posted: 06:18pm 22 Sep 2025
@Peter - Thanks for explaining, although FYI, I do have remapped 8-bit data working when DB0-DB7 are assigned to GP1-GP8 (since GP0 is used for the PSRAM CS on your DIL module).
VERY HAPPY with the massive improvement over 8-bit speed when using 16-bit comms set with OPTION ....5ER_16,L,,GP17,,GP1
Can confirm too the Red/Blue are sorted too making the colours in the EDITOR look normal once again!
Thanks for the heads up on the 12-bit buffer; will try that on another unit later.........
dddns
Posted: 07:10pm 22 Sep 2025
If you are talking about serial, an observation on 2350VGA:
Since long ago, scrolling in the editor in a long program leaves sometimes rests of escape sequences like "[" or "~" from the cursor keys. This only happens beyond the first let's say 40Kb. The scrolling slows down and immediately these errors occur.
Sometimes it crashed the Pico and hard reset is necessary.
And if a program executes an inkey$ command and looks for e.g. chr$(129) like the FM then it crashed for me fore sure.
With b13 this is gone for all directions of the cursor keys! For the first time since half a year. Only Page Up/down leaves a "~"
With b14 it came back. I reverted to b13 and it's fine again.
I'm using as well inkey$ and even stressing serial by accidentally uploading a program while the basic program is running doesn't crash it.
I've used b13 now two days intensively and found, that it runs best since long
> option list
PicoMiteVGA MMBasic RP2350B Edition V6.01.00b13
OPTION KEYBOARD US
OPTION PICO OFF
Saying it "crashes" it is maybe too much but it doesn't respond anymore
Edited 2025-09-23 05:17 by dddns
     Page 12 of 15
