Local Time 15:05 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.00.02 betas
     Page 14 of 23
Posted: 02:26pm 09 Feb 2025
This is all caused by you lot requesting layers in mode 1. I'll see if I can optimise the code in some different way.
electricat
Posted: 02:34pm 09 Feb 2025
If that would somehow be usefull, added short pause eliminates prob.
OPTION RESOLUTION 640 also works OK
PAUSE 1
Loop Until KeyDown(0) <>0
My MMBasic 'sand box'
Posted: 02:43pm 09 Feb 2025
Try this
PicoMite.zip
Posted: 03:17pm 09 Feb 2025
@Peter,
Is the HDMI firmware good to run on a 2350B module (specially this one )?
I remember in the past that it was not recommended to use this due to certain issues which have possibly been addressed since?
If you say the firmware will run OK on this module, which sets of pins do I need to use for HDMI (same GPs or different).
The reason for asking is because I need a few more IO pins for my intended application so thought the B could be a possible solution.
Posted: 03:29pm 09 Feb 2025
The DVI pins are the same (the HSTX module). Pinout
I've just been designing a board for one. :)
Posted: 03:33pm 09 Feb 2025
  Mixtel90 said  The DVI pins are the same (the HSTX module). Pinout
Thanks for confirming pins.
Do we know for sure if the firmware runs as expected on a B??
electricat
Posted: 04:01pm 09 Feb 2025
  matherp said  Try this
PicoMite.zip
Looks good!
stanleyella
Posted: 05:53pm 09 Feb 2025
this is complicated... hdmi stuff
if I upgrade reflash is there a way to keep previous option settings other than save as text? I seem to be doing it a lot and it's a drag. can not just copy text options into mmcc got to do each option at a time. stan
electricat
Posted: 06:11pm 09 Feb 2025
  stanleyella said  this is complicated... hdmi stuff
I just save options --> OPTION DISK SAVE fname$ to SD card
Also take screen using phone (to remember SD card pins if I have no spare time say for few weeks, so sure will forget).
Then on new reflash you only need set OPTION SDCARD
and load from sd card using OPTION DISK LOAD fname$
Not too complicated.
I also wrote 70% (but jumped to another project and unfinished   ) options extractor/converter from binary *.opt  file to text .txt ...
But google can convert (OCR) taken photo (that via mobile phone) to text.
So may posibilities to make life easier
Posted: 06:25pm 09 Feb 2025
For Harm
b10 updated 18:54UTC 09/02 - making pio easier
Print "compiling first"
PIO assemble 1
.program first
.side set 1
.line 0
Pull block
.wrap target
Mov x,osr side 1
.label loop
Nop side 0 [4]
Jmp x--,loop side 1 [4]
IRQ 0 side 0
.wrap
.end program list
Print "compiling second"
PIO assemble 1
.program second
.side set 1
.line next
.wrap target
Wait 1 irq 0 side 0
Wait 1 irq 0 side 1
.wrap
.end program list
Also improved colour coding of PIO directives
Fixed optimisation of HDMI drivers
Edited 2025-02-10 04:55 by matherp
Posted: 07:38pm 09 Feb 2025
@ WhiteWizard
IIRC Peter tweaked the PSRAM timing and has got 1280P out of the RP2350B. That's fine with me. :)
Posted: 08:00pm 09 Feb 2025
  Mixtel90 said  @ WhiteWizard
Thanks - I remember something too but just can’t find the post(s) - although I was looking on my small-screen phone as opposed to looking on a big screen!
Will assemble a set-up this week using the B module and will see if stable with SD, RTC, I2S and HDMI.
stanleyella
Posted: 10:35pm 09 Feb 2025
but I had to setup my sd card and traced the pins then someone posted same pins in option order. phew! so until sd card set up won't work.
copy paste option list from mmcc to notepad and save as works
Posted: 11:39pm 09 Feb 2025
After  --> OPTION DISK SAVE fname$ to A: use MMCC file manager to transfer fname$ to your computer.
After the update use MMCC file manager to transfer fname$ to A: then OPTION DISK LOAD fname$
Posted: 01:09am 10 Feb 2025
  Quote  copy paste option list from mmcc to notepad and save as works
If you save your options in a file with .mmc extension you can drag and drop into MMCC
From the MMEdit help:
  Quote  One example of a command file is used for re-configuring a picomite after firmware updates. (This is not normally required)
'target port\com4:115200 s\command
option reset
flash erase all
var clear
OPTION CPUSPEED 250000
OPTION SYSTEM SPI 14,15,16
OPTION SDCARD 17
OPTION LCDPANEL ILI9341,L,10,11,12
OPTION TOUCH 19,20
GUI CALIBRATE 0, 250, 504, 925, 747
'settime
Each line is displayed with three options
Yes send this line
No skip this line
Cancel skip this line and all subsequent lines.
Updating a pico is as simple as
dragging the uf2 file onto the MMCC console, wait for the firmware update to finish,
drag the pico.mmc configuration file onto the MMCC console area.
You now have an updated and clean picomite again.
Posted: 07:12am 10 Feb 2025
Hi Peter,
Is there any way you can extract what "next" is? Somthing like a% = PIO(.line next)
I'll play with b10 soon. Currently re-learning KiCAD for board design. It's been a while since I made a PCB (I think my last one was for the micromite Huntron Tracker, 4-5 years ago), I forgot a lot. But the first board (not pico, but a RIAA phono preamp for my brother) is at JLC now. Funny, vinyl records are "the thing" now in Netherlands. What ever...
I installed KiCAD from Ubuntu repository. And Ubuntu is a not leading edge for applications, so I ended up using KiCAD 5 (KiCAD is at 8 now). Bummer : no 3D view. Anyway, it works, and JLC understands the gerbers. So all is fine.
EDIT: I just checked the changes for b10 for the assembler, and they work nice. It compiled my frequency counter correct. Coloring of the .xxx directives is also working. VGA works (tested on petscii).
Edited 2025-02-10 17:40 by Volhout
Posted: 07:58am 10 Feb 2025
@Peter,
By using OPTION LCDPANEL CONSOLE [font[,fc[,bc]]] the user is able to select their preferred text and background colours for the Command Prompt. This is perfect - I personally like to use white on blue rather than the default white on black.
However, with COLOURCODE ON, the Editor's background colour uses the background colour as set above in OPTION LCDPANEL CONSOLE. This makes the COLOURCODED text horrid to use.
Please can I suggest a simple tweak so that IF the COLOURCODE is ON, then ensure the Editors background is set to black first.
If COLOURCODE is OFF then as current, it can simply use the fc and bc colours in the Editor.
On exiting the Editor, the fc and bc colours should be restored for the Command Prompt (effectively only relevant if ColourCode is On).
Hope this makes sense.....
JanVolk
Posted: 08:26am 10 Feb 2025
Peter, Harm,
V6.00.02b10 now available.
Nop now has support in this version.
The PIO commands are now displayed more clearly in the editor.
Everything is reset.
Greetings,
Jan
Posted: 09:02am 10 Feb 2025
NO: I can't cater for every setting that a user chooses to invoke. If you leave the defaults as-is everything works properly. If, for example, you choose to change the background colour then the firmware respects that. It can't be expected to undo your choices for particular circumstances. Similarly changes to default fonts can cause unexpected issues. The default font is re-applied in various circumstances (like library save) and if you are in a low res mode when this happens you end up with a big font.
The moral of this story is: don't change defaults unless you really know what you are doing and understand the consequences. Far better to change things dynamically in a program and if you want to be tidy then clear them up on program exit.
  Quote  Is there any way you can extract what "next" is? Something like a% = PIO(.line next)
I'll include a new function
PIO(NEXT LINE [channel])
If channel is not specified then it uses the last pio specified by a PIO ASSEMBLE command or gives an error if there hasn't been one.
If channel is specified, it returns the next line for that channel which will be zero if that channel has not been used.
UPDATE
I've upgraded b10 with the PIO(NEXT LINE function if you re-download
Edited 2025-02-10 19:39 by matherp
Posted: 10:14am 10 Feb 2025
Peter,
PIO(NEXT LINE) works. I first was condused since PIO(.WRAP) and PIO(.WRAP TARGET) tried this with next as PIO(.NEXT LINE). But the "." is not needed.
     Page 14 of 23
