| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12058 |
homa and mozzie Please could you post details of the various screens you have tested and the status of what works and what doesn't (including dual touch). Then I can construct a list of know good screens for future users. Thanks |
| WhiteWizzard Guru Joined: 05/04/2013 Location: United KingdomPosts: 2994 |
@Peter For testing purposes, I am using your latest published firmware (PicoMiteHDMIUSBV6.03.00RC15.uf2) on your PICO I2S reference board set with OPTION RESET HDMIUSBI2S I have various HDMI usb-capacitive Touchscreens here and will report back on how they behave. To clarify, should the 'coming soon' program that you posted on the 'Now were cooking...' thread be the one we need to use? I ask, because it appears to be, but I am only seeing Expand and Contract reports (and not sure if the original syntax in there is still in use). I will also test the 'Pump demo' too, but I believe that is really just reacting touch-down and touch-up. Will also check two-finger GUI TEST TOUCH. Currently using genuine Waveshare 7HP-CAPQLED (7" Quantum Dot). Pump demo and two-finger touch work good. Only Contract and Expand work in the other test program. Do you need anything else tested for each screen? |
The latest code is RC15. The only thing missing is a bluetooth hdmi version which I need some new H/W to test properly. You can check touch functionality with GUI TEST TOUCH which supports dual touch traces or you can run the attached to test all the gestures. This works on my 7" display with all gestures passing. You can also play with the on-screen keyboard which you set up with OPTION SCREEN KEYBOARD n where n is the screen percentage to use for the keyboard (30-40 recommended) |
Acknowledged. I just had a superb OLED monitor just arrive (Showscren OLED 10.5", 2560x1600). Image is absolutely amazing with blacks being truly black, no matter what angle (i.e. no backlight wash). However, when plugged in I get the following appear: PicoMiteHDMI MMBasic USB RP2350B Edition V6.03.00RC15 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather > Multi-touch Connected on channel 4 (10 contacts, 16383x9599) > Unknown Device Connected on channel 3 (pid=&H859, vid=&H27C0) > 0x6 0xA 0xFF 0x9 0xFF 0xA1 0x1 0x85 0x50 0x9 0xFF 0x15 0x0 0x26 0x0 0xFF 0x75 0x8 0x95 0x3F 0x81 0x6 0x85 0x51 0x9 0xFF 0x15 0x0 0x26 0x0 0xFF 0x75 0x8 0x95 0x3F 0x91 0x6 0xC0 Unknown Device Connected on channel 2 (pid=&H859, vid=&H27C0) > 0x5 0x1 0x9 0x2 0xA1 0x1 0x85 0x7 0x9 0x1 0xA1 0x0 0x5 0x9 0x19 0x1 0x29 0x3 0x15 0x0 0x25 0x1 0x75 0x1 0x95 0x3 0x81 0x2 0x75 0x1 0x95 0x5 0x81 0x3 0x5 0x1 0x9 0x30 0x75 0x10 0x95 0x1 0x55 0xE 0x65 0x11 0x35 0x0 0x46 0x79 0x8 0x26 0xFF 0x3F 0x81 0x2 0x9 0x31 0x46 0x8A 0x3 0x26 0x7F 0x25 0x81 0x2 0x9 0x38 0x15 0x81 0x25 0x7F 0x75 0x8 0x95 0x1 0x81 0x6 0xC0 0xC0 It is capable of receiving video via USB so not sure if that is related to the two 'Unknown Device' listed above. Using OPTION RESOLUTION 1280 Is this a non-starter, or does the above mean something to you?? |
| JanVolk Guru Joined: 28/01/2023 Location: NetherlandsPosts: 420 |
Peter, Edit might affect the mouse and I2C, as Edit freezes on my system with the message "Error I2C display not configured." After that, the editor becomes unusable (> cursor) and only responds with the scroll wheel displaying strange characters. The LCDI2C also no longer works correctly with this version. Disabling OPTION SYSTEM I2C does not help either. Tested with RP2350 and RP2040. PicoMite MMBasic RP2350B V6.03.00RC15 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather Total of 6 Mbytes PSRAM available > option list PicoMite MMBasic RP2350B V6.03.00RC15 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION PICO OFF OPTION CPUSPEED (KHz) 200000 OPTION DISPLAY 50, 100 OPTION F1 help OPTION F5 list commands OPTION F6 list functions OPTION F7 list pins OPTION F8 option list OPTION F9 fm OPTION PLATFORM WeAct-RP2350B-FLASH:16-PSRAM:8 OPTION PSRAM PIN GP0 PicoMite MMBasic RP2040 V6.03.00RC15 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather > option list PicoMite MMBasic RP2040 V6.03.00RC15 OPTION COLOURCODE ON OPTION HEARTBEAT OFF OPTION PICO OFF OPTION CPUSPEED (KHz) 200000 OPTION DISPLAY 50, 115 OPTION SDCARD GP19, GP10, GP11, GP12 OPTION F1 help OPTION F5 list commands OPTION F6 list functions OPTION F7 list pins OPTION F8 list system i2c OPTION F9 fm Jan. |
Strange Observation (don’t ask how I found it!): In the editor (with colourcode on), place the cursor after any code, and then type any 8 hexadecimal characters (0-9, a-f). On pressing the eighth character, the 8 characters turn green (as if it is a value). The simplest form of this is with nothing in the editor, just type for example 00000000 Anything beforehand, either on the same line, or any line beforehand, will still show this ‘feature’. Anything typed after (either on same line or another line) switches it back to white. NOT an issue, was just an observation I spotted |
With an 8" Waveshare (8DP-V2): When the USB touch is connected, I see the following message: USB Mouse Connected on channel 2 This is no matter which of the four USB ports the touch is connected to. |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 724 |
> option list PicoMiteHDMI MMBasic USB RP2350A Edition V6.03.00RC15 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION SYSTEM I2C GP20,GP21 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION RESOLUTION 1280x720 @ 372000KHz OPTION DISPLAY 30, 80 OPTION GUI CONTROLS 50 OPTION SDCARD GP22, GP26, GP27, GP28 OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5 OPTION RTC AUTO ENABLE OPTION MODBUFF ENABLE 192 OPTION PLATFORM HDMIUSB OPTION DEFAULT FONT 3, 1 What a party :-) I've installed the latest RC15. Sometimes I can get two fingers to work with GUI TEST TOUCH, but in 9 out of 10 cases only one is registered. The code above never displays the multi-touch gestures either. What a shame. The recognition rate seems to be too poor for that. And yet it’s supposed to support 10-point multi-touch. I’m still having the same issue with the Microsoft USB mouse/keyboard dongle, as WhiteWizzard also points out. OPTION SCREEN KEYBOARD 30 OPTION SCREEN KEYBOARD off Great! The on-screen keyboard is brilliant, isn't it? [2] Option keyboard 30 Error : Invalid in a program > Can I show or hide it using a code? It would be brilliant if you could tap two fingers from the bottom of the screen or double tap three fingers to bring it up, and have a button to hide it again, just like on a tablet :-) But for that to work, multitouch would have to be working in the first place; as I said, my screen is an MageDok T090A HDMI 9-inch IPS 1280x720 Touch 10 point. The pump demo works perfectly! Thanks Peter. Matthias |
I’ve tried GUI TEST TOUCH several times now. I don’t think I actually have true multi-touch. It just looks like it, but the points are always alternating between the two fingers. That’s why I mistakenly thought it only worked sometimes! |
The on=screen-keyboard (OSK) will show when at the command prompt and disappear when you run a program. To use it in a program you can use the command KEYBOARD ON/OFF |
Great! Edited 2026-06-03 07:46 by homa |
Peter, Also tested with the WebMite RP2350 V6.03.00RC15 version, where the same editing problem occurs as in my previous message. Error: Display not configured, and one can no longer exit the editor properly; response on the screen is only possible via the mouse buttons and scroll wheel with Tera Term. By I2C, I meant that the I2CLCD command no longer works correctly with an LCD2004 display. Strange characters appear on the display. Going back to V6.03.00RC14, it works correctly again for the two PicoMite versions. Jan. |
Peter, Could the maximum character limit of the A drive file also apply to the FM file, causing copying to fail if it is too long for FM? Jan. |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3416 |
Peter, thank you for the enhanced OneWire commands. OneWire WRITE Pin, Flag, length, array() OneWire READ Pin, Flag, length, array() OneWire WRITE Pin, Flag, length, String$ OneWire READ Pin, Flag, length, String$ Are all perfect. > PinNo=mm.info(pinno GP6) > OneWire WRITE PinNo, 1, 1, &h33 : OneWire READ PinNo, 2, 8, RC$ > ROM = str2bin(Uint64,RC$,big) : ? ROM, "or &h";hex$(ROM) 2891667279928370184 or &h2821441204C02408 > > z$ = chr$(&hCC)+chr$(&h44) > OneWire WRITE PinNo, 1, 2, z$ > |
| mozzie Guru Joined: 15/06/2020 Location: AustraliaPosts: 470 |
G'day Peter, For Future Reference: WaveShare 7" 1024 x 600 HDMI QLED CAP Touch Display - 5 point touch (Purchased 2026) Works with: ALL tests GUI TEST TOUCH - Dual Trace - Passed On Screen Keyboard - Passed Pump GUI Demo - Passed Swipe U/D/L/R - Passed TAP/DTAP/HOLD - Passed EXPAND/CONTRACT - Passed ROTATE CW/CCW - Passed Two Finger Tap - Passed WaveShare 7" QLED CAP Touch 70H-1024600-QLED-B Elecrow 10.1" 1280 x 800 HDMI IPS RES Touch Display - 1 point touch (Purchased 2020) Works with: GUI Test Touch - Single Trace - Passed On Screen Keyboard - Passed Pump GUI Demo - Passed Swipe U/D/L/R - Passed TAP/DTAP/HOLD - Passed EXPAND/CONTRACT - N/A ROTATE CW/CCW - N/A Two Finger Tap - N/A Elecrow HEV1001(RR101) 10.1" Metal Shell Touch Monitor Still happy as a pig in the proverbial Regards, Lyle. |
JanVolk Sorry about the editor - found and fixed - will post update later. What version are you seeing the i2clcd issues with? Nothing has changed in that area for some time. Please provide a test program because I can't replicate My test program which works perfectly I2CLCD init &H27 Do I2CLCD 1,1,Space$(20) I2CLCD 2,1,Space$(20) I2CLCD 3,1,Space$(20) I2CLCD 4,1,Space$(20) I2CLCD 1,Rnd*10+1,Str$(i)+Chr$(0) I2CLCD 2,Rnd*10+1,Str$(i+10)+Chr$(0) I2CLCD 3,Rnd*10+1,Str$(i+20)+Chr$(0) I2CLCD 4,Rnd*10+1,Str$(i+30)+Chr$(0) Inc i Pause 200 Loop Please explain more the FM request. Edited 2026-06-03 18:21 by matherp |
fix for editor issue in non-display versions PicoMiteRP2040V6.03.00RC15.zip PicoMiteRP2350V6.03.00RC15.zip |
Peter, Thanks for fixing the error in edit. I happened to use a very long name and was able to save it to A just fine. But when I try to copy this file with a long name to B using FM, I get "Path too long". Example: save "abcdefghijklmnopqrstuvwxyzABCDEFGHIJ12345.bas" works fine to drive A, but not to drive B with FM. If I copy "a:/abcdefghijklmnopqrstuvwxyzABCDEFGHIJ12345.bas" to "b:/backup/abcdefghijklmnopqrstuvwxyzABCDEFGHIJ12345.bas", it works fine. But if the "backup" folder is longer, for example: "backupRP2040-sd", then copying "a:/.........." to "b:/backupRP2040-sd/" also works fine. With FM, I get Path too long. To get everything on the screen correctly with FM, I set: OPTION DISPLAY 50,118 In Tera Term, I make extensive use of copy and paste with the drag function, so I have no problems entering long names. Regarding the interference with the I2C LCD2004 display with I2CLCD, I tested it again with the latest firmware and am now using a saved file, and it works well now because I did not use edit. > option list PicoMite MMBasic RP2040 V6.03.00RC15 OPTION SYSTEM I2C GP20,GP21 OPTION COLOR CODE ON OPTION HEARTBEAT OFF OPTION PICO OFF OPTION CPU SPEED (KHz) 200000 OPTION DISPLAY 50, 118 OPTION SDCARD GP19, GP10, GP11, GP12 OPTION F1 help OPTION F5 list commands OPTION F6 list functions OPTION F7 list pins OPTION F8 list system i2c OPTION F9 fm Jan. |
Peter, Updated the PicoMite MMBasic RP2040 V6.03.00RC15 firmware and edit is working normally again. Thanks. Jan. |
Jan Try this with your long filenames (RP2040 PicoMite) PicoMite.zip |
