Forum Index : Microcontroller and PC projects : MMBasic for Windows - betas
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4405 |
I've used this in the past, but development seems to have stopped: https://www.dependencywalker.com/ On the briefest of examinations this appears to be a replacement: https://github.com/lucasg/Dependencies Best wishes, Tom Edited 2023-03-13 20:56 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| yock1960 Senior Member Joined: 18/08/2020 Location: United StatesPosts: 167 |
Neat! I never knew something like this existed, easy peasy! Thanks Tom! Steve |
| Michal Senior Member Joined: 02/02/2022 Location: PolandPosts: 125 |
https://github.com/lucasg/Dependencies Michal |
Did this ever happen? I haven't managed to find it. I keep getting syntax errors, trying to convert some of my old programs. PIXEL, PLAY TTS, CONTROLLER and I'm sure many more are different or not supported, not surprisingly, but it would be nice to know how things are supposed to work. Steve |
| toml_12953 Guru Joined: 13/02/2015 Location: United StatesPosts: 736 |
Here's my standard Green Hat program in MMBASIC for Windows. It will give you an example of MODE, PIXEL and LINE: 5 TIMER=0 10 MODE 3 ' 320x200 pixels 20 P=160: Q=100 30 XP=144: XR=1.5*3.1415927 40 YP=56: YR=1: ZP=64 50 XF=XR/XP: YF=YP/YR: ZF=XR/ZP 60 FOR ZI=-Q TO Q-1 70 IF ZI<-ZP OR ZI>ZP GOTO 150 80 ZT=ZI*XP/ZP: ZZ=ZI 90 XL=INT(.5+SQR(XP*XP-ZT*ZT)) 100 FOR XI=-XL TO XL 110 XT=SQR(XI*XI+ZT*ZT)*XF: XX=XI 120 YY=(SIN(XT)+.4*SIN(3*XT))*YF 130 GOSUB 170 140 NEXT XI 150 NEXT ZI 155 T=TIMER 157 DO:LOOP UNTIL INKEY$<>"" 160 MODE 9: CLS: PRINT T/1000;" seconds": END 170 X1=XX+ZZ+P 180 Y1=199-(YY-ZZ+Q) 190 PIXEL X1,Y1,RGB(GREEN) 200 IF Y1 = 199 GOTO 220 210 LINE X1,Y1+1,X1,199,,RGB(BLACK) 220 RETURN 999 END |
| pwillard Guru Joined: 07/06/2022 Location: United StatesPosts: 347 |
Jim, Can we have an option to *not* auto-indent "comment" lines on "Program --> Format Indentation"? Edited 2023-03-19 01:48 by pwillard |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6629 |
Can we have an option to *not* auto-indent "comment" lines on "Program --> Format Indentation"? LIke this? STATIC p oldpinz = pinz pinz = PORT(gp6,5) logd$(n MOD 500)= BIN$(pinz,5)+","+STR$(INT(TIMER)) INC n IF PIN(gp6) THEN INC p :PRINT CHR$(8)+MID$("|/-\|/-\",(p MOD 8)+1,1); 'if pin(gp9) then print "clock stopped @ ";time$ 'if pin(gp10) then print "Restarted @ ";time$ IF (pinz AND &b10000) THEN ' restarted - have a sleep PRINT "restart" errmsg$ = "re-start" 'logit = 1' restarted wifitick = TIMER + 30000 picotick = TIMER + 30000 ELSEIF (pinz AND &b01000) THEN PRINT " RTC stopped - resetting" errmsg$ = " RTC stopped - resetting" doreset ELSE Look in MMedit.inf Under [options] ; 2 = indent one tab size, 3 = leave line As Is Indent Comments = 0 Remember to have MMEdit closed down when modifying the inf files. Jim VK7JH MMedit |
| electricat Senior Member Joined: 30/11/2020 Location: LithuaniaPosts: 299 |
What I am doing wrong? (latest beta, MODE 1) I need create some simple sprite from data on fly, and tried small test, but failed to display as I understand small 3x3 white square. dim spr%(26)=(255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255) SPRITE LOADARRAY #2,3,3,spr%(26) SPRITE SHOW #2, 10,10,0,0 My MMBasic 'sand box' |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12061 |
SPRITE LOADARRAY #2,3,3,spr%() |
No, now SPRITE LOADARRAY #2,3,3,spr%() but black screen, no sprite. dim spr%(26)=(255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255) SPRITE LOADARRAY #2,3,3,spr%() SPRITE SHOW #2, 10,10,0,0 My MMBasic 'sand box' |
I think you need the alpha channel as well. try &hFF0000FF for blue, fully opaque. Jim VK7JH MMedit |
Yes. It was! Problem solved, sprite is on. Thx! My MMBasic 'sand box' |
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1135 |
A User Manual for MMBasic 4 Windows is close to draft release. If you would like a program to play with, the one below will run on the latest release of MMBasic for Windows (5.07.03b15) Happy to answer any questions on the program. Regards, Doug. ' Educ-8 Microcomputer - simulation in MMB4W 5.07.03b15 ' Original hardware and concept: Copyright Jim Rowe, ' Electronics Australia ' Adaption for MMBasic: Copyright Doug Pankhurst ' MMBasic: Copyright Geoff Graham, Peter Mather '------------------------------------------------------ ' Do some initial housekeeping/setup Option explicit Dim version$ = "Version: 7a Created: 22:00 21/4/22" ' now supports CMM2 - automatically set CMM2% = 1 for CMM2 Dim CMM2% = 0 ' flag to handle CMM2 specific code If instr(1,MM.DEVICE$,"Colour") Then CMM2% = 1 endif CLS font 4,2 TEXT 20,20,"EDUC-8 - Educational Microcomputer" ' ' setup menu dim E8_Opts$ Dim E8_Enhance% = 0 Dim PLDIMDone% = 0 dim TLDIMDone% = 0 ' simple program to add 2 numbers '*****Note: Weird ********************************************** ' E8 opcodes are defined and referred to in E8 octal (737) ' Indirect addressing and any memory reference ' is in real octal (377) '*************************************************************** ' ADDR DATA Label Inst E8 OpCode '(octal) (octal) (E8 octal) '(377) (377) (737) ' 000 350 START: CLA 710 ' clear AC ' 001 050 TAD A: 110 ' 2's add A: to AC ' 002 051 TAD B: 111 ' 2's add B: to AC ' 003 152 DCA C: 312 ' deposit AC to C:, clear AC ' 004 240 JMP START: 500 ' jump START: ' 005 360 HLT 720 ' halt ' 006 ' 007 ' 010 A: ' 011 B: ' 012 C: ' data for program above in real octal (377) ' data &O350,&O050,&O051,&O152,&O240,&O360 '------------- ' Test Reader program ' ADDR DATA Label Inst E8 OpCode '(octal) (octal) (E8 octal) '(377) (377) (737) ' 000 301 START: SKF 601 ' skip on input flag data ready ' 001 240 JMP START: 500 ' jump to start ' 002 302 KRS 602 ' read input buffer (punch) to AC ' 003 304 RKF 604 ' reset input flag ' 004 240 JMP START: 500 ' jump START: ' 005 360 ' data for read punch program data &O301,&O240,&O302,&O304,&O240,&O360 '-------------------------------------------------------------------- FONT 2 Do TEXT 10,140, "EDUC-8 CONFIGURATION/SETUP MENU" TEXT 10,160, "1. Pre-load a program into Educ-8's memory" TEXT 10,180, "2. Pre-load a program into the paper tape" TEXT 10,200, "3. Select original or custom instruction set" Text 10,220, "9. Exit setup and start Educ-8" TEXT 10,240, "Note: Options 2 and 3 not implimented yet" TEXT 10,260, "- see notes in program for operation of Educ-8" TEXT 10,280, "" INPUT "Select option 1 above and press Enter ",E8_Opts$ Select Case Val(E8_Opts$) Case 1 Do_ProgLoad Case 2 ' Do_TapeLoad ' not yet implemented Case 3 ' E8_Enhance% = 1 ' not yet implemented End Select TEXT 380,280, " " Loop Until Val(E8_Opts$) = 9 ' these next subs are just for the menu ' - skip over to start of E8 program proper '------------------------------------------------------ ' If pre-load selected above, define main memory and/or ' paper tape memory here, else define in main program below ' Sub Do_ProgLoad ' only dim here if we are going to pre-load Local i%,a% Dim RAM_Mem%(128) ' longstring array of 1024 bytes used as RAM For i% = 0 to 5 READ a% longstring setbyte Ram_Mem%(),i%,a% Next i% PLDIMDone% = 1 ' so we don't dim below End sub Sub Do_TapeLoad ' only dim here if we are going to pre-load Dim RP_Mem%(32) ' longstring of 256 bytes TLDIMDone% = 1 ' so we don't dim below End sub '*************************************************************** ' Enter Educ-8 program proper '------------------------------------------------------- ' To understand the full operation of Educ-8, you should ' arrange to get a copy of the original Educ-8 project ' from Electronics Australia. ' Briefly, Educ-8 is a simulation of a subset of the ' (the serial version) DEC PDP-8S instruction set. ' The full hardware component of Educ-8 was designed ' using off the shelf 74xx IC's by Jim Rowe. ' To use: ' Click the RUN switch - this will step you through the ' program that reads in data from the Paper Tape Reader. ' '------------------------------------------------------- ' Educ-8 registers ' - all utilize the low order 8 bits only Dim PCReg% ' Program Counter Dim MAReg% ' Memory address register 8 bits Dim MBReg% ' Memory buffer register 8 bits Dim INReg% ' Instruction register Dim ACReg% ' Accumulator 8 bits Dim OCReg% ' Operation code register - bits 5,6,7 Dim OAReg% ' Operand address register bits 0 - 3 DIM PGReg% ' page address reg high order 4 bits of MA '---------------------------------------------------------------- ' Memory RAM If PLDIMDone% = 0 then ' if not done above, do now Dim RAM_Mem%(128) ' longstring array of 1024 bytes used as RAM endif ' - use LONGSTRING SETBYTE nbr%,data to store value from 0 to 255 ' - use LGETBYTE nbr% to return value from longstring '------------------- ' State flags Dim LoadFlag% = 0 ' Dim DepositFlag% = 0 ' Dim ExamineFlag% = 0 ' Dim FetchFlag% = 0 ' Dim DeferFlag% = 0 ' Dim ExecuteFlag% = 0 ' Dim RunFlag% = 0 ' Run/halt flag - 1 = run, 0 = halt DIM SingContFlag% = 0 ' single or cont - 0=single=halt after each inst DIM SloFstFlag% = 0 ' DIM IAFlag% = 0 ' direct/indirect address flag '-------------------------------------------------------------------- ' IOT device flags and buffers ' Note: The Educ-8 is the DTE, whatever device is connected is the DCE DIm D0CTS% ' clear to send from input device 0 DIM D1CTS% ' device 1 DIM D0IPBuf% ' input buffer device 0 DIM D1IPBuf% ' device 1 DIM D0RTS% ' ready to send to output device 0 DIM D1RTS% ' device 1 DIM D0OPBuf ' output buffer for device 0 DIM D1OPBuf% ' device 1 ' actual pin assignments for CMM2/Picomite - define as needed ' - need 20 digital pins ' device 0 CONST D0DSR_Pin = 1 ' input - flag from device - ready to receive or send CONST D0DTR_Pin = 2 ' output - flag to device - EDUC-8 done and ready CONST D0Data_Pin = 3 ' input - receive port + 7 more consecutive pins ' device 1 CONST D1DSR_Pin = 11 ' input - flag from device - ready to receive or send CONST D1DTR_Pin = 12 ' output - flag to device - EDUC-8 done and ready CONST D1Data_Pin = 13 ' input - receive port + 7 more consecutive pins '------------------------------------------------------------------------ ' Arithmetic flags Dim CarryFlag% = 0 ' accumulator carry flag - 1 = carry Dim ZeroFlag% = 0 ' accumulator zero flag - 1 = zero ' misc Dim B4Mask% = &B1111 ' mask direct address bits 0-3 Dim B8Mask% = &B11111111 ' mask low order 8 bits Dim B15Mask% = &B111111111111111 ' mask low order 15 bits Dim OCMask% = &B11100000 ' mask in opcode bits 5,6,7 DIM OAMask% = &B1111 ' mask in operand address bits DIM PGMask% = &B11110000 ' mask in Page address in MBReg DIM opcode% ' note these bits are also used for different purposes ' in operate and IOT microinstructions Dim DataSw% ' low order 8 bits equate to data switch 0 thru 7 Dim Sw_Reg% ' low order 15 bits equate to switches left to right Dim i,j 'general purpose counters '-------------------------------------- ' front panel 15 switches, 0 thru 14 ' data switches d0 thru d7 - 0 = off, any other value = on Dim s7%,s6%,s5%,s4%,s3%,s2%,s1%,s0% ' control switches Dim s8% ' load address - mom - 0 = off, 1 = load address Dim s9% ' deposit - mom - 0 = off, 1 = deposit data Dim s10% ' examine - mom - 0 = off, 1 = examine memory Dim s11% ' run - mom - 0 = off, 1 = run Dim s12% ' halt - mom - 0 = off, 1 = halt Dim s13% ' single/continuous - 1 = single, 0 = continuous Dim s14% ' slow/fast - 0 = slow, 1 = fast Dim sw_num% ' switch number 0 thru 14, right to left '--------------------------------------- ' Static switch display shape parameters ' - x offset from top left of screen for 15 switches 'Dim sw_xtl%(14) = (20,60,100,140,180,220,260,300,420,460,500,620,660,700,740) Dim sw_xtl%(14) = (300,260,220,180,140,100,60,20,420,460,500,620,660,700,740) ' y offset from top left of screen Dim sw_ytl% = 220 '............ ' switches - actual switch x and y co-ordinates ' on/off switches - off position Dim xbar_onf% = 7 ' on and off bar x offset Dim ybar_of% = 223 ' off bar y pos (absolute) Dim w_onf_bar% = 24 ' on and off bar width Dim h_onf_bar% = 3 ' on and off bar height ' polygon x co-ordinates - starts top left, add per switch Dim dsx_of%(3) = (6,32,37,1) ' polygon y co-ordinates (absolute) - starts top left Dim dsy_of%(3) = (222,222,245,245) ' on/off switches - on position for on/off and momentary switches Dim xbar_on% = 7 ' on bar x pos Dim ybar_on% = 264 ' on bar y pos (abs) ' polygon x co-ordinates - starts top left, add per switch Dim mdsx_on%(3) = (1,37,32,6) ' polygon x positions - starts top left ' polygon y co-ordinates (absolute) - starts top left Dim mdsy_on%(3) = (245,245,268,268) ' polygon x positions - starts top left ' momentary switches - off position Dim mxbar_of% = 5 Dim mybar_of% = 245 Dim w_mbar_of% = 28 Dim h_mbar_of% = 4 ' polygon x co-ordinates - starts top left, add per switch Dim msx_of%(5) = (1,37,34,34,4,4) ' polygon y co-ordinates - starts top left, add per switch Dim msy_of%(5) = (240,240,246,249,249,246) ' momentary switches on position ' - same as for on/off switches '------------------------------ ' arrays to hold static switch parameters Dim stype%(14) = (0,0,0,0,0,0,0,0,1,1,1,1,1,0,0) ' 0=on/off, 1=mom Dim scol(14) ' pre-define switch colours For i = 0 to 7 ' data switches D7 thru D0 scol(i) = rgb(130,130,150) Next i scol(8) = rgb(0,0,250) ' Load scol(9) = rgb(250,0,250) ' Deposit scol(10) = rgb(130,160,130) ' Examine scol(11) = rgb(0,250,0) ' Run scol(12) = rgb(250,0,0) ' Halt scol(13) = rgb(250,150,150) ' Single/Continuous scol(14) = rgb(150,250,250) ' Slow/Fast ' per switch variables Dim sw_col ' switch colour Dim sw_type% ' switch type - 0 = on/off, 1 = momentary Dim sw_stat% ' switch status - 0 = off, 1 = on (operated) '-------------------------------------- ' Paper tape reader/punch parameters ' Tape memory = max 256 bytes If TLDIMDone% = 0 then ' may have been preset above Dim RP_Mem%(32) ' longstring of 256 bytes endif dim Tape_Mem%(4) ' longstring 32 bytes of tape visible dim RPInBuf% = 0 ' buffer for punch input Dim RPOutBuf% = 0 ' buffer for reader output Dim RPPos% = 0 ' pointer into RP_Mem%() Dim RPOnInit% = 1 ' so we do readytaperead just once dim RPOffInit% = 1 DIM RPSw% = 0 Dim RPHeadByte% = 0 ' byte under read/punch head Dim RPTrailer% dim DTR0Flag% 'Dim ReadPunch% = 0 ' 0 = read, 1 = punch Dim RPOnOff% = 0 ' Reader/Punch 1 = power on 'DIM RPDSR% = 0 ' reader/punch 1 = ready to read/punch 'Dim RPFault% = 0 ' 0 = good, 1 = read/punch error 'DIM RPLED% = 0 ' indicate read or punch operation 'Dim RPSpeed% = 0 ' reads/punches per sec, 0 = 2/sec, 1 = 100/sec ' '-------------------------------------- ' GUI setup ' constants for area ctrls - equate to bits(-1) in SwReg% CONST SD7 = 8 'SwReg% bit 7 CONST SD6 = 7 CONST SD5 = 6 CONST SD4 = 5 CONST SD3 = 4 CONST SD2 = 3 CONST SD1 = 2 CONST SD0 = 1 ' SwReg% bit 0 CONST SLoad = 9 'SwReg% bit 8 CONST SDep = 10 CONST SExam = 11 CONST SRun = 12 CONST SHalt = 13 CONST SSinCon = 14 CONST SFstSlo = 15 ' SwReg% bit 14 '-------------------------------------- ' pre set some registers for initialise PCReg% = 0 ' program counter MAReg% = 0 ' memory addr register MBReg% = 0 ' memory buffer register ACReg% = 0 ' accumulator PGReg% = 0 ' page register INReg% = 0 ' instruction register ' preset some switch parameters Sw_Reg% = &b000000000000000 '......... ' Start of initialise subs INITIALISE: Init_Display ' draw all static user interface ' set up all IO pins etc. If CMM2% = 1 Then Init_IO ' set up CMM2 I/O pins Else Init_RdrPunch ' set up glass Reader Punch Endif ' GUI area defines for mouse click on switches ' - must be after initialise GUI Area SD7,20,220,38,50 GUI Area SD6,60,220,38,50 GUI Area SD5,100,220,38,50 GUI Area SD4,140,220,38,50 GUI Area SD3,180,220,38,50 GUI Area SD2,220,220,38,50 GUI Area SD1,260,220,38,50 GUI Area SD0,300,220,38,50 GUI Area SLoad,420,220,38,50 GUI Area SDep,460,220,38,50 GUI Area SExam,500,220,38,50 GUI Area SRun,620,220,38,50 GUI Area SHalt,660,220,38,50 GUI Area SSinCon,700,220,38,50 GUI Area SFstSlo,740,220,38,50 If CMM2% then GUI CURSOR COLOUR RGB(RED) ' only works on CMM2 Endif GUI LED #20,"",220,382,6,RGB(red) GUI Switch #21,"ON|OFF",50,340,50,40,RGB(Green),rgb(0,120,0) GUI Interrupt M_ClkDn,M_ClkUp '----------------------------------------------------------- MAIN: ' start of state machine Do while inkey$ = "" ' just so we can breakout cleanly Do While RunFlag% = 1 ' main program loop, ' - broken out by Halt instruction, Halt key, or Sing/Cont = Sing ' debug - text 0,340,"Enter run loop" Fetch ' get instruction pointed to by PCReg If SloFstFlag% = 0 Then Pause 400 Endif ExecuteInst ' execute it If SloFstFlag% = 0 Then Pause 400 Endif If (SingContFlag% = 0) Then RunFlag% = 0 Endif ' debug - Text 0,340,"Thru main loop" LOOP If LoadFlag% then ACReg% = 0 ' for clean start LoadAddr Draw_Sw (sw_num%) Draw_RegLEDs (PCReg%,MAReg%,MBReg%,ACReg%,INReg%) ClearBit (Sw_Reg%,8) LoadFlag% = 0 Endif If DepositFlag% then Deposit Draw_Sw (sw_num%) Draw_RegLEDs (PCReg%,MAReg%,MBReg%,ACReg%,INReg%) PCReg% = PCReg% + 1 ' now pointing to next mem location ClearBit (Sw_Reg%,9) DepositFlag% = 0 Endif If ExamineFlag% then Examine Draw_Sw (sw_num%) Draw_RegLEDs (PCReg%,MAReg%,MBReg%,ACReg%,INReg%) Draw_OCLEDs (OCReg%) PCReg% = PCReg% + 1 ' now pointing to next mem location ClearBit (Sw_Reg%,10) ExamineFlag% = 0 Endif Loop ' End of main program loop 'debug Text 0,360,version$ + "End program" End '********************************************************** 'Subs for handling switch non-running operations Sub LoadAddr Local i% PCReg% = Sw_Reg% AND B8Mask% MAReg% = PCReg% MBReg% = 0 End Sub Sub Deposit Local t_byte$ MAReg% = PCReg% AND B8Mask% MBReg% = Sw_Reg% AND B8Mask% OCReg% = MBReg% AND OCMask% Longstring Setbyte RAM_Mem%(),MAReg%,MBReg% End Sub Sub Examine Local i% MAReg% = PCReg% AND B8Mask% MBReg% = LGETBYTE (RAM_Mem%(),MAReg%) INReg% = MBReg% OCReg% = MBReg% AND OCMask% End Sub '------------------------------------------------- ' Operational subs and functions Sub Fetch ' get instruction from address pointed to by PC FetchFlag% = 1 ExecuteFlag% = 0 MAReg% = PCReg% AND B8Mask% PGReg% = PCReg% AND PGMask% INReg% = LGETBYTE (RAM_Mem%(),PCReg%) MBReg% = LGETBYTE (RAM_Mem%(),MAReg%) OCReg% = MBReg% AND OCMask% ' opcode bits 5,6,7 opcode% = OCReg% >> 5 ' move OC to lo 3 bits OAReg% = MBReg% AND OAMask% ' lo order 4 bits - mem addr of operand PCReg% = (PCReg% + 1) AND B8Mask% Draw_SFlags ' state LEDs End Sub SUB ExecuteInst ' decode instruction and execute ' Local opcode% FetchFlag% = 0 ExecuteFlag% = 1 If opcode% < 6 then IAFlag% = GetBit%(MBReg%,4) ' indirect address flag endif Select Case opcode% ' codes 0 thru 5 and memory reference instructions Case 0 Do_AND Case 1 Do_TAD Case 2 Do_ISZ Case 3 Do_DCA Case 4 Do_JMS Case 5 Do_JMP ' operate microinstructions Case 6 ' now further decode IOT microinstructions Do_IOT ' I/O microinstructions Case 7 ' now further decode operate microinstructions print ,,,,,,,,,,,,,,,"start Do_IOT",opcode% Do_OPM ' IOT microinstructionsOCReg% = end select ' update all LEDs Draw_RegLEDs (PCReg%,MAReg%,MBReg%,ACReg%,INReg%) Draw_OCLEDs (OCReg%) Draw_SFlags If SingContFlag% = 0 then ' just do 1 instruction RunFlag% = 0 Endif end sub '------------------------------ ' memory reference instructions Sub Do_AND ' AC AND contents of direct or indirect mem location MAReg% = PGReg% OR OAReg% ' MAReg now 8 bit pointer to direct address MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' get data from direct address location If IAFlag% = 1 then ' indirect address, get address pointed to lo order 4 bits MAReg% = MBReg% ' load indirect address into MAReg MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' then get indirect data endif ' direct address - just use low order 4 bits ACReg% = B8Mask% AND (ACReg% AND MBReg%) If ACReg% = 0 Then ZeroFlag% = 0 Else ZeroFlag% = 1 Endif CarryFlag% = 0 End Sub ' exit with result in AC Sub Do_TAD ' 2's addition AC + contents of direct or indirect mem location MAReg% = PGReg% OR OAReg% ' MAReg now 8 bit pointer to direct address MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' get data from direct address location If IAFlag% = 1 then ' indirect address, get address pointed to lo order 4 bits MAReg% = MBReg% ' load indirect address into MAReg MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' then get indirect data endif ' direct address - just use low order 4 bits ACReg% = ACReg% + MBReg% If (ACReg% AND &Hffffffffffffff00) <> 0 then CarryFlag% = 1 Else CarryFlag% = 0 Endif END SUB ' exit with result in AC SUB Do_ISZ ' increment contents of direct or indirect mem location and skip if zero MAReg% = PGReg% OR OAReg% ' MAReg now 8 bit pointer to direct address MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' get data from direct address location If IAFlag% = 1 then ' indirect address, get address pointed to by lo order 4 bits MAReg% = MBReg% ' load indirect address into MAReg MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' then get indirect data endif ' direct address - just use low order 4 bits ACReg% = MBReg% ' get data from mem, inc and store back ACReg% = ACReg% + 1 MBReg% = ACReg% ' Longstring SETBYTE RAM_Mem%(),MAReg%,MBReg% If (B8Mask% AND ACReg%) = 0 Then ZeroFlag% = 0 CarryFlag% = 1 Else ZeroFlag% = 1 PCReg% = PCReg% + 1 ' skip next instruction CarryFlag% = 0 Endif END SUB Sub Do_DCA ' deposit AC in direct or indirect mem location and clear AC MAReg% = PGReg% OR OAReg% ' MAReg now 8 bit pointer to direct address MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' get data from direct address location If IAFlag% = 1 then ' indirect address, get address pointed to by lo order 4 bits MAReg% = MBReg% ' load indirect address into MAReg MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' then get indirect data endif ' direct address - just use low order 4 bits Longstring SETBYTE RAM_Mem%(),MAReg%,ACReg% ACReg% = 0 CarryFlag% = 0 ZeroFlag% = 0 END SUB ' exit with AC = 0 SUB Do_JMS ' jump to subroutine at direct or indirect mem location MAReg% = PGReg% OR OAReg% ' MAReg now 8 bit pointer to direct address MBReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' get indirect address If IAFlag% = 1 then ' indirect address, get address pointed to by lo order 4 bits MAReg% = MBReg% ' load indirect address into MAReg endif ' direct address - just use low order 4 bits Longstring SETBYTE RAM_Mem%(),MAReg%,PCReg% ' store return addr in 1st sub location PCReg% = MAReg% + 1 END SUB SUB Do_JMP ' jump to location at direct or indirect mem location MAReg% = PGReg% OR OAReg% ' MAReg now 8 bit pointer to direct address If IAFlag% = 1 then ' indirect address, get address pointed to lo order 4 bits MAReg% = LGETBYTE(RAM_Mem%(),MAReg%) ' get data from indirect address endif ' direct address - just use low order 4 bits PCReg% = MAReg% ' target address END SUB ' end of memory instructions '-------------------------------- ' operate microinstructions - opcodes 7xx SUB Do_OPM ' - decodes OPM instructions Local i%,tmpb7%,tmpb0% ' Local opcode% opcode% = MBReg% AND &B11111' get OC lo 5 bits ( the xx part) Select Case opcode% Case 0 ' NOP ' - do nothing - fall into next instruction Case 1 'IAC - inc AC by 1, result in AC ACReg% = ACReg% + 1 If (ACReg% AND &Hffffffffffffff00) <> 0 then CarryFlag% = 1 ACReg% = ACReg% AND B8Mask% ' back to lo order 8 bits Else CarryFlag% = 0 Endif Case 2 ' RAL - rotate AC 1 bit left, b7 -> b0,b1-b6 <- 1 place tmp_b7% = GetBit%(ACReg%,7) ACReg% = ACReg% << 1 If tmp_b7% = 0 then ClearBit(ACReg%,0) else SetBit(ACReg%,0) Endif If (ACReg% AND &Hffffffffffffff00) <> 0 then CarryFlag% = 1 ACReg% = ACReg% AND B8Mask% ' back to lo order 8 bits Else CarryFlag% = 0 Endif Case 4 ' CMA - invert all bits in AC ACReg% = B8Mask% AND (INV(ACReg%)) If ACReg% = 0 then ZeroFlag% = 1 Else ZeroFlag% = 0 Endif Case 5 ' CMA then IAC - comliment then increment AC - form 2s comp ' do CMA first ACReg% = B8Mask% AND (INV(ACReg%)) If ACReg% = 0 then ZeroFlag% = 1 Else ZeroFlag% = 0 Endif ' then IAC ACReg% = ACReg% + 1 If (ACReg% AND &Hffffffffffffff00) <> 0 then CarryFlag% = 1 ACReg% = ACReg% AND B8Mask% ' back to lo order 8 bits Else CarryFlag% = 0 Endif Case 8 ' CLA - clear AC to 0 ACReg% = 0 ZeroFlag% = 1 Case 9 ' CLA then IAC - clear AC then add 1 - ie. set AC = 1 ' first CLA ACReg% = 0 ' then IAC ACReg% = ACReg% + 1 CarryFlag% = 0 ZeroFlag% = 0 Case 12 ' CLA then CMA - clear AC then invert AC - ie. set AC = -1 ' first CLA - AC = 0 ACReg% = 0 ' then CMA - AC now all 1s - = -1 ACReg% = B8Mask% AND (INV(ACReg%)) CarryFlag% = 0 ZeroFlag% = 0 Case 17 ' HLT RunFlag% = 0 ClearBit (Sw_Reg%,12) ClearBit (Sw_Reg%,11) Case 18 ' RAR - rotate AC 1 bit right tmp_b0% = GetBit%(ACReg%,0) ACReg% = B8Mask% AND (ACReg% >> 1) If tmp_b0% = 1 then SetBit (ACReg%,7) Else ClearBit (ACReg%,7) Endif Case 20 ' SMA - skip on minus AC ' - ie. if AC a neg num (bit 7 = 1), skip next inst If GetBit%(ACReg%,7) = 1 Then PCReg% = PCReg% + 1 Endif Case 24 ' SZA - skip on zero AC - ie. if AC = 0, skip next instruction If ACReg% = 0 then ZeroFlag% = 0 PCReg% = PCReg% + 1 endif Case 28 ' SZA then SMA - skip next instruction if AC is minus or zero If (GetBit%(ACReg%,7) = 1) OR (ACReg% = 0) Then PCReg% = PCReg% + 1 Endif End Select END SUB '******* in development ******* SUB Do_IOT ' input/output instructions - 6xx Local DSRFlag%,DTRFlag%,RWFlag%,Device%,DevIO% ' Local opcode% ' opcode% = MBReg% AND &B11111' get OC lo 5 bits ( the xx part) If CMM2% = 0 Then ' is MMB4W so simulate I/O ' DSR0Flag% set by device 0 to signify ready for E8 to send if device input ' or data sent from device and ready for E8 to read if device output ' DSR1Flag% - as above for device 1 ' RW0Flag% - set to 1 to read data from i/p buffer ' or write data to o/p buffer ' RW1Flag% - as above for device 1 ' RW0InBuf% - input buffer for device 0 ' RW1InBuf% - input buffer for device 1 ' RW0OutBuf% - output buffer for device 0 ' RW1OutBuf% - output buffer for device 1 ' DTR0Flag% set by E8 to device 0 to signify data sent by E8 if device input ' or data read by E8 if device output ' DTR1Flag% - as above for device 1 ' Device% - 0 for device 1, 1 for device 1 ' DevIO% - 0 if input, 1 if output Select Case opcode% Case 1 ' &O01 SKF - get DSR, skip if device 0 ready to receive ' - simulated paper tape reader ' - acts like, from device - OK, ready for you to send to me DSR set DSR0Flag% = P_SKF0%() ' function returns 1 if read ready If DSR0Flag% = 1 Then PCReg% = PCReg% +1 Endif CASE 9 ' &O11 SKF - get DSR, skip if device 1 ready to receive ' - acts like, from device - OK, ready for you to send DSR set If DSR1Flag% = 1 Then PCReg% = PCReg% +1 Endif CASE 17 ' &O21 SDF - get DSR, skip if device 0 ready, data sent '- acts like, from device - OK, got that and ready for next, DSR set If DSR0Flag% = 1 Then PCReg% = PCReg% +1 Endif CASE 25 ' &O31 SDF - get DSR, skip if device 1 ready, data sent '- acts like, from device - OK, got that and ready for next, DSR set If DSR1Flag% = 1 Then PCReg% = PCReg% +1 Endif CASE 2 ' &O02 KRS - read input buffer of device 0 into AC RPInBuf% = P_KRS0%() ' function returns byte under read head ACReg% = RPInBuf% CASE 10 ' &O12 KRS - read input buffer of device 1 into AC ACReg% = RW1InBuf% CASE 18 ' &O22 LDS - write AC to output buffer of device 0 RW0OutBuf% = ACReg% CASE 26 ' &O32 LDS - write AC to output buffer of device 1 RW1OutBuf% = ACReg% CASE 4 ' &O04 RKF - send DTR - E8 has received i/p from device 0 OK ' - acts like, to device - I got that, DTR set, when you've send next, set DSR P_RKF0 ' simulate reader reset, advance then ready DTR0Flag% = 1 CASE 12 ' &O14 RKF - send DTR - E8 has received i/p from device 1 OK ' - acts like, to device - I got that, DTR set, when you've send next, set DSR DTR1Flag% = 1 CASE 20 ' &O24 RDF - send DTR - E8 has sent o/p to device 0 ' acts like, to device - I've sent data, DTR set, when you're done set DSR DTR0Flag% = 1 CASE 28 ' &O34 RDF - send DTR - E8 has sent o/p to device 1 ' acts like, to device - I've sent data, DTR set, when you're done set DSR DTR1Flag% = 1 CASE 6 ' &O06 KRB (KRS + RKF) device 0 - read input and acknowledge RPInBuf% = P_KRS0%() ' simulate reader reading byte under head ACReg% = RPInBuf% P_RKF0 ' sub to send reset/advance to tape DTR0Flag% = 1 ' RKF CASE 14 ' &O16 KRB (KRS + RKF) device 1 - read input and acknowledge ACReg% = RW1InBuf% ' KRS DTR1Flag% = 1 ' RKF CASE 22 ' &O26 LDB (LDS + RDF) device 0 - write data and acknowledge RPOutBuf% = ACReg% ' LDS DTR0Flag% = 1 ' RDF CASE 30 ' &O36 LDB (LDS + RDF) device 1 - write data and acknowledge RW1OutBuf% = ACReg% ' LDS DTR1Flag% = 1 ' RDF End select Else ' real I/O for CMM2 - ensure pin selection done before running Select Case opcode% Case 1 ' &O01 SKF - skip if device 0 ready to send CASE 9 ' &O11 SKF - skip if device 1 ready to send CASE 17 ' &O21 SDF - skip if device 0 ready to rx CASE 25 ' &O31 SDF - skip if device 1 ready to rx CASE 2 ' &O02 KRS - read input buffer of device 0 into AC CASE 10 ' &O12 KRS - read input buffer of device 0 into AC CASE 18 ' &O22 LDS - write AC to output buffer of device 0 CASE 26 ' &O32 LDS - write AC to output buffer of device 1 CASE 4 ' &O04 RKF - send DTR - E8 has received i/p from device 0 OK CASE 12 ' &O14 RKF - send DTR - E8 has received i/p from device 1 OK CASE 20 ' &O24 RDF - send DTR - E8 has sent o/p to device 0 CASE 28 ' &O34 RDF - send DTR - E8 has sent o/p to device 1 CASE 6 ' &O06 KRB (KRS + RKF) device 0 - read input and acknowledge CASE 14 ' &O16 KRB (KRS + RKF) device 1 - read input and acknowledge CASE 22 ' &O26 LDB (LDS + RDF) device 0 - write data and acknowledge CASE 30 ' &O36 LDB (LDS + RDF) device 1 - write data and acknowledge End select Endif END SUB '------------------------------------------------- ' Interrupts Sub M_ClkDn ' left button down click local a If CMM2% Then sw_num% = CLICK(ref)-1 ' turn ctrl number to bit number Else sw_num% = MOUSE(ref)-1 ' turn ctrl number to bit number Endif If (sw_num% < 0) or (sw_num% > 14) then sw_num% = 12 endif ToggleBit (Sw_Reg%,sw_num%) Select Case sw_num% CASE 14 ' Slow/FGetBit%1 SloFstFlag% = GetBit%(Sw_Reg%,sw_num%) CASE 13 ' single/continuous switch SingContFlag% = GetBit%(Sw_Reg%,sw_num%) Case 12 ' Halt switch RunFlag% = 0 ClearBit (Sw_Reg%,sw_num%) ' halt bit ClearBit (Sw_Reg%,11) ' also run bit Case 11 ' Run switch RunFlag% = GetBit%(Sw_Reg%,sw_num%) Case 10 ' Examine switch ExamineFlag% = GetBit%(Sw_Reg%,sw_num%) Case 9 ' Deposit switch DepositFlag% = GetBit%(Sw_Reg%,sw_num%) Case 8 ' Load switch LoadFlag% = GetBit%(Sw_Reg%,sw_num%) ' CASE else ' sw_num% = 12 End Select Draw_Sw (sw_num%) RPSw% = MOUSE(REF) ' Reader/Punch on/off switch If RPSw% = 21 then 'CTRLVAL(#21) = 1 then If CTRLVAL(#21) then ' If RPOnInit% = 1 then ' 1 means first time so do it ReadyTapeRead ' load tape ready for E8 programatic read RPOnInit% = 0 endif else Clear_RdrPunch RPOnInit% = 1 Endif endif End Sub Sub M_ClkUp ' left button up If CMM2% = 1 Then sw_num% = CLICK(LASTref)-1 ' turn ctrl number to bit number Else sw_num% = MOUSE(LASTref)-1 ' turn ctrl number to bit number Endif If (sw_num% > 7 ) and (sw_num% < 13) then pause 300 ClearBit (Sw_Reg%,sw_num%) Draw_Sw (sw_num%) Endif End Sub '----------------------------------------------------- ' General Subroutines 'Subroutine to draw single switch defined by sw_num% Sub Draw_Sw sw_num% Local sxtl% 'top left x pos of switch sw_num% Local w_sb% = 38 ' width of switch box Local h_sb% = 50 ' height of switch box Local sx%(3) ' array holding 4 polygon points for switch when off Local mx%(5) ' array holding 6 polygon points for mom sw when off Local mdx%(3)' array holding 4 polygon points for all switches when on Local x% Local SwBit% = &B000000000000001 Local SwBitMsk% = &B100000000000000 If CMM2% = 1 Then ' to get around cursor shadow problem GUI CURSOR OFF ' hide cursor while operating switch Endif ' set per switch parameters sw_type% = stype%(sw_num%) sw_col = scol(sw_num%) sw_stat% = Sw_Reg% AND (SwBit% << sw_num%) ' calculate switch x top left position based on switch number sxtl% = sw_xtl%(sw_num%) ' blank out switch box sxtl%,sw_ytl%,w_sb%,h_sb%,,rgb(black),rgb(black) ' now paint actual switch if sw_stat% = 0 then ' is in the off position if sw_type% = 0 then 'is an on/off style switch for x% = 0 to 3 ' build actual polygon points - on/off sw = off sx%(x%) = sw_xtl%(sw_num%) + dsx_of%(x%) next x% polygon 4,sx%(),dsy_of%(),sw_col,sw_col box sxtl%+xbar_onf%,ybar_of%,w_onf_bar%,h_onf_bar%,,rgb(white),rgb(white) else ' is a momentary style switch, then special off position for x% = 0 to 5 ' build actual polygon points - mom sw = off mx%(x%) = sw_xtl%(sw_num%) + msx_of%(x%) next x% polygon 6,mx%(),msy_of%(),sw_col,sw_col box sxtl%+mxbar_of%,mybar_of%,w_mbar_of%,h_mbar_of%,,rgb(white),rgb(white) endif else ' is in the on position - same for on/off and momentary for x% = 0 to 3' build actual polygon points - both types = on mdx%(x%) = sw_xtl%(sw_num%) + mdsx_on%(x%) next x% polygon 4,mdx%(),mdsy_on%(),sw_col,sw_col box sxtl%+xbar_onf%,ybar_on%,w_onf_bar%,h_onf_bar%,,rgb(white),rgb(white) endif If CMM2% = 1 Then GUI CURSOR ON 0 GUI CURSOR COLOUR rgb(red) Endif End Sub '--------------------------- ' Draw register LEDs Sub Draw_RegLEDs (PCReg%,MAReg%,MBReg%,ACReg%,INReg%) Local pc_temp%,ma_temp%,mb_temp%,ac_temp%,in_temp% Local x%,y%,i% x% = 40 y% = 43 pc_temp% = PCReg% AND B8Mask% ma_temp% = MAReg% AND B8Mask% mb_temp% = MBReg% AND B8Mask% ac_temp% = ACReg% AND B8Mask% in_temp% = INReg% AND B8Mask% For i% = 7 To 0 Step -1 If GetBit%(pc_temp%,i%) then Circle x%,y%,6,1,,RGB(black),RGB(red) Else Circle x%,y%,6,1,,RGB(black),RGB(80,80,80) EndIf If GetBit%(ma_temp%,i%) then Circle x%,y%+30,6,1,,RGB(black),RGB(red) Else Circle x%,y%+30,6,1,,RGB(black),RGB(80,80,80) EndIf If GetBit%(mb_temp%,i%) Then Circle x%,y%+60,6,1,,RGB(black),RGB(red) Else Circle x%,y%+60,6,1,,RGB(black),RGB(80,80,80) EndIf If GetBit%(ac_temp%,i%) Then Circle x%,y%+90,6,1,,RGB(black),RGB(red) Else Circle x%,y%+90,6,1,,RGB(black),RGB(80,80,80) EndIf If GetBit%(in_temp%,i%) Then Circle x%,y%+120,6,1,,RGB(black),RGB(red) Else Circle x%,y%+120,6,1,,RGB(black),RGB(80,80,80) EndIf x% = x% + 40 Next i% End Sub '--------------------- ' Draw the opcode LEDs Sub Draw_OCLEDs (OCReg%) Local oc_temp%,x%,y% ' high order 3 bits shifted to 3 low order bits oc_temp% = (OCReg% AND OCMask%) \ 32 x% = 438 y% = 43 ' Memory reference instructions If oc_temp% = 0 then 'AND Circle x%,y%,6,1,,RGB(black),RGB(red) Else Circle x%,y%,6,1,,RGB(black),RGB(80,80,80) Endif If oc_temp% = 1 then 'TAD Circle x%,y%+30,6,1,,RGB(black),RGB(red) Else Circle x%,y%+30,6,1,,RGB(black),RGB(80,80,80) Endif If oc_temp% = 2 then 'ISZ Circle x%,y%+60,6,1,,RGB(black),RGB(red) Else Circle x%,y%+60,6,1,,RGB(black),RGB(80,80,80) Endif If oc_temp% = 3 then ' DCA Circle x%,y%+90,6,1,,RGB(black),RGB(red) Else Circle x%,y%+90,6,1,,RGB(black),RGB(80,80,80) Endif If CarryFlag% = 1 Then ' Carry Circle x%,y%+120,6,1,,RGB(black),RGB(RED) Else Circle x%,y%+120,6,1,,RGB(black),RGB(80,80,80) Endif If oc_temp% = 5 then ' JMP Circle x%+40,y%+60,6,1,,RGB(black),RGB(red) Else Circle x%+40,y%+60,6,1,,RGB(black),RGB(80,80,80) Endif If oc_temp% = 4 then ' JMS Circle x%+40,y%+90,6,1,,RGB(black),RGB(red) Else Circle x%+40,y%+90,6,1,,RGB(black),RGB(80,80,80) Endif ' Operate Microinstructions - OPR If oc_temp% = 7 then ' OPR Circle x%+40,y%,6,1,,RGB(black),RGB(red) Else Circle x%+40,y%,6,1,,RGB(black),RGB(80,80,80) Endif ' Input/Output transfer instructions - IOT If oc_temp% = 6 then ' IOT Circle x%+40,y%+30,6,1,,RGB(black),RGB(red) Else Circle x%+40,y%+30,6,1,,RGB(black),RGB(80,80,80) Endif If ZeroFlag% = 1 Then ' Zero Circle x%+40,y%+120,6,1,,RGB(black),RGB(RED) Else Circle x%+40,y%+120,6,1,,RGB(black),RGB(80,80,80) Endif End Sub '----------------- ' Draw state flags Sub Draw_SFlags Local x%,y% x% = 718 y% = 43 ' Operational state flags If RunFlag% = 1 then Circle x%,y%,6,1,,RGB(black),RGB(red) Else Circle x%,y%,6,1,,RGB(black),RGB(80,80,80) Endif If FetchFlag% = 1 then Circle x%,y%+30,6,1,,RGB(black),RGB(red) Else Circle x%,y%+30,6,1,,RGB(black),RGB(80,80,80) Endif If DeferFlag% = 1 then Circle x%,y%+60,6,1,,RGB(black),RGB(red) Else Circle x%,y%+60,6,1,,RGB(black),RGB(80,80,80) Endif If ExecuteFlag% = 1 then Circle x%,y%+90,6,1,,RGB(black),RGB(red) Else Circle x%,y%+90,6,1,,RGB(black),RGB(80,80,80) Endif End Sub '----------------------------------------------- ' Misc subs and functions ' Bit manipulation routines Function GetBit% (arg1%,arg2%) Local reg%,bitnum%,resultbit% reg% = arg1% bitnum% = arg2% resultbit% = reg% AND (&B1 << bitnum%) If resultbit% <> 0 then GetBit% = 1 Else GetBit% = 0 Endif End Function Sub SetBit (arg1%,arg2%) Local reg%,bitnum%,bitmask% reg% = arg1% bitnum% = arg2% arg1% = reg% OR (&B1 << bitnum%) End Sub Sub ClearBit (arg1%,arg2%) Local reg%,bitnum% reg% = arg1% bitnum% = arg2% reg% = reg% AND (B15Mask% AND (INV(&b1 << bitnum%))) arg1% = reg% End Sub Sub ToggleBit (arg1%,arg2%) Local reg%,bitnum%,tbit% reg% = arg1% bitnum% = arg2% tbit% = GetBit% (reg%,bitnum%) If tbit% = 0 then reg% = reg% OR (&B1 << bitnum%) Else reg% = reg% AND (B15Mask% AND (INV(&B1 << bitnum%))) Endif arg1% = reg% End Sub '------------------------------------------------- ' Initialise Subroutines - just called once at startup ' but safer here like this. Sub Init_IO ' configure pins etc for IO ' Local i% ' If CMM2 = 1 Then ' device 0 ' CONST Dev0DSR = 0 ' pin to receive device ready ' CONST Dev0DTR = 1 ' to to signal E8 done and ready ' CONST Dev0Data = 2 ' number of starting pin for port command ' ' - need 7 more consecutive pins ' Dim D0DSRFlag% ' input from dev signalling previous done/ready ' DIM D0DTRFlag% ' output to device signalling E8 done, get ready for next ' Setpin Dev0DSR,DIN ' to E8, (dev) I'm ready ' Setpin Dev0DTR,DOUT ' from E8, I'm done, get ready ' ' device 1 ' CONST Dev1DSR = 10 ' pin to receive device ready ' CONST Dev1DTR = 11 ' to to signal E8 done and ready ' CONST Dev1Data = 12 ' number of starting pin for port command ' ' - need 7 more consecutive pins ' Dim D1DSRFlag% ' input from dev signalling previous done/ready ' DIM D1DTRFlag% ' output to device signalling E8 done, get ready for next ' Setpin Dev1DSR,DIN ' to E8, (dev) I'm ready ' Setpin Dev1DTR,DOUT ' from E8, I'm done, get ready ' Endif End Sub ' Initialise display - only called once at startup ' but safer here and uses local variables Sub Init_Display Local i,j,x,d 'counting variables Local SwBitMsk% CLS Colour RGB(black),RGB(220,210,210) RBox 0,0,799,300,,RGB(white),RGB(220,210,210) ' face Text 20,0,"EA EDUC-8+ MICROCOMPUTER",,4,2 Box 20,30,318,150,,RGB(80,80,80),RGB(80,80,80) Font 1 Text 342,38,"PC" Text 342,68,"MA" Text 342,98,"MB" Text 342,128,"AC" text 342,158,"IN" Box 420,30,80,150,,RGB(80,80,80),RGB(80,80,80) Text 390,38,"AND" Text 390,68,"TAD" Text 390,98,"ISZ" Text 390,128,"DCA" TEXT 376,158,"CARRY" Text 503,38,"OPR" Text 503,68,"IOT" Text 503,98,"JMP" Text 503,128,"JMS" TEXT 503,158,"ZERO" Box 700,30,80,150,,RGB(80,80,80),RGB(80,80,80) Text 670,38,"RUN" Text 656,68,"FETCH" Text 656,98,"DEFER" Text 663,128,"EXEC" ' now switch labels Text 422,193,"LOAD" ' Text 422,206,"ADDR" Text 468,193,"DEP" Text 502,193,"EXAM" Text 626,193,"RUN" Text 666,193,"HALT" Text 706,193,"SING" Text 746,193,"SLOW" Text 706,206,"CONT" Text 746,206,"FAST" ' draw bit numbers x = 35 For d = 7 To 0 Step -1 Text x,192,Str$(d) x = x + 40 Next d ' draw opcode lines Line 20,212,137,212,4,RGB(black) Line 140,212,217,212,4,RGB(black) Line 220,212,338,212,4,RGB(black) 'draw momentary action indicators Triangle 421,206,457,206,439,216,RGB(black),RGB(black) Triangle 461,206,497,206,479,216,RGB(black),RGB(black) Triangle 501,206,536,206,518,216,RGB(black),RGB(black) Triangle 620,206,656,206,638,216,RGB(black),RGB(black) Triangle 661,206,694,206,677,216,RGB(black),RGB(black) ' draw switches Sw_Reg% = Sw_Reg% AND B15Mask% For sw_num% = 0 to 14 Draw_Sw sw_num% Next sw_num% ' draw LEDs Draw_RegLEDs (PCReg%,MAReg%,MBReg%,ACReg%) Draw_OCLEDs (OCReg%) Draw_SFlags End Sub '------------------------------------------------- 'Reader Punch routines Sub Init_RdrPunch Local i%,x% Local ptx%(5) = (0,390,440,390,0,50) Local pty%(5) = (400,400,450,500,500,450) RBox 20,305,400,220,,RGB(WHITE),RGB(220,210,210) TEXT 32,306,"Paper Tape Reader/Punch",,1,2 Polygon 6,ptx%(),pty%(),rgb(White),rgb(200,200,210) ' draw sprocket holes For x% = 67 to 377 step 10 Box x%,458,6,4,,RGB(black),rgb(WHITE) next x% ' draw read/punch head Box 214,396,12,110,2,rgb(blue),-1 'rgb(210,210,220) ' switch and read/punch head 'debug - load some data into tape for testing for x% = 0 to 255 longstring setbyte RP_Mem%(),x%,x% next x% RPOnInit% = 1 ' RPOffInit% = 0 end sub FUNCTION P_SKF0%() ' pseudo SKF dev 0 - test if reader ready If CTRLVAL (#21) = 1 Then ' will P_SKF0% = 1 Else P_SKF0% = 0 endif end FUNCTION FUNCTION P_KRS0%() ReadTape P_KRS0% = RPHeadByte% end FUNCTION SUB P_RKF0 AdvanceTape End sub FUNCTION P_KRB0%() ' P_KRS0% plus P_RKF0 ReadTape P_KRB0% = RPHeadByte% AdvanceTape End FUNCTION sub Clear_RdrPunch ' on power off Local x% ' clear tape ready for advance to start bit BOX 51,401,339,98,,rgb(200,200,210),rgb(200,200,210) ' draw sprocket holes For x% = 67 to 377 step 10 Box x%,458,6,4,,RGB(black),rgb(WHITE) next x% ' draw read/punch head Box 214,396,12,110,2,rgb(blue),-1 For x% = 0 to 31 Longstring Setbyte Tape_Mem%(),x%,0 Next x% ' RPOffInit% = 0 ' done the clear, so skip until new OFF end sub sub ReadyTapeRead ' called once on power on/of Reader/Punch ' load and read(advance) tape until 1st location of tape mem ' is under the read head ' - this will be the first byte of the RP_Mem% array (first byte of tape) Local i%,x%,y%,z% RPPos% = 0 '*** possibly offer loading tape from file here ' clear tape ready for advance to start bit Clear_RdrPunch ' start by loading visible tape from tape memory ' read first 18 bytes of tape to position first byte under tape read head For y% = 0 to 15 Longstring Setbyte Tape_Mem%(),0,LGetByte (RP_Mem%(),RPPos%) ShowTape ' read byte at read head and shuffle forward For x% = 31 to 1 step -1 Longstring Setbyte Tape_Mem%(),x%,LGetByte (Tape_Mem%(),x%-1) Next x% Inc RPPos% next y% ' tape now sitting with first actual tape position ' under tape reader head ' exit with RPPos% pointing to 17th location on tape but ' with 1st location under tape read head end sub Sub ReadTape ' KRS - read byte under head RPHeadByte% = LGetByte (Tape_Mem%(),15) end sub Sub AdvanceTape ' RKF - advance tape 1 position, set ready ' enter with RPPos% pointing to location on rp mem ' and byte to read on tape under the read head ' start by loading next location on tape from tape display memory Local x% if RPPos% < 256 Then ' copy from rp mem into tape display mem Longstring Setbyte Tape_Mem%(),0,LGetByte (RP_Mem%(),RPPos%) RPTrailer% = 32 else ' in trailer to move last tape position under read head Longstring Setbyte Tape_Mem%(),0,0 RPTrailer% = RPTrailer% - 1 endif ' shuffle tape display forward For x% = 31 to 1 step -1 Longstring Setbyte Tape_Mem%(),x%,LGetByte (Tape_Mem%(),x%-1) Next x% ShowTape If RPTrailer% = 0 then ' we got to end of tape RPOnOff% = 0 ' turn tape off Ctrlval(#21) = 0 endif INC RPPos% ' point to next position on tape ctrlval(#20) = 1 pause 500 ctrlval(#20) = 0 End Sub sub ShowTape local x%,y%,BitNum% Local TapeByte%,TapePos% TapePos% = 0 Do While TapePos% < 32 TapeByte% = LGetByte (Tape_Mem%(),TapePos%) TapePos% = TapePos% + 1 x% = 60 + (TapePos% * 10) BitNum% = 0 for y% = 410 to 450 step 10 if Getbit%(TapeByte%,BitNum%) = 1 then If TapePos% = 16 then circle x%,y%,3,,,rgb(red),rgb(red) else circle x%,y%,3,,,rgb(white),rgb(white) endif else Circle x%,y%,3,,,rgb(190,190,200),rgb(190,190,200) endif BitNum% = BitNum% + 1 next y% BitNum% = 5 for y% = 470 to 490 step 10 if Getbit%(TapeByte%,BitNum%) = 1 then If TapePos% = 16 then circle x%,y%,3,,,rgb(red),rgb(red) else circle x%,y%,3,,,rgb(white),rgb(white) endif else Circle x%,y%,3,,,rgb(190,190,200),rgb(190,190,200) endif BitNum% = BitNum% + 1 next y% LOOP pause 100 end sub ' End of initialise subroutines '------------------------------------------------------- 'End ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Wow. Thanks, Panky. Did not know mouse also could be used! Usefull and interesting piece of code for learning. We learned ZX spectrum basic years ago without any manuals, only by looking at somebodys` code :) My MMBasic 'sand box' |
As far as I am aware MMB4W runs without issue on any up-to-date install of W10 or W11 64-bit. It runs on W7 (32 or 64-bit?) but you may have to use the optional parameter on launch to disable audio. Has anyone got it running on W7 with audio? I've been down the rabbit hole on this trying to find the correct set of dlls to make it work on W7 with audio but failed. If anyone with more knowledge of windows than me wants to try and solve this then it would make the code more generally useful for those still stuck on W7 |
Hi all, draft version of MMBasic for Windows User Manual. You should be able to download from Please advise any errors/omissions, Regards Doug. Edit: This may make it easier! https://www.dropbox.com/s/sqwkv63ylhclhhp/MMB4W_User_Manual_v0.7odt.pdf?dl=0 Edited 2023-04-22 20:50 by panky ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Thanks for this. Joining my collection of always-open MMBasic manual PDFs. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1156 |
Hi Panky, thank you very much for the manual! Frank |
You should be able to download from Please advise any errors/omissions, Regards Doug. Edit: This may make it easier! https://www.dropbox.com/s/sqwkv63ylhclhhp/MMB4W_User_Manual_v0.7odt.pdf?dl=0 On page 28 you mention passing by reference. Maybe you could also show passing by value. All you have to do is include the argument in parentheses like so: a=4: b=4 testsub((a),b) print a,b sub testsub(x,y) x=x+1: y=y+1 end sub 4 5 |
On page 28 you mention passing by reference. Maybe you could also show passing by value. All you have to do is include the argument in parentheses like so: a=4: b=4 testsub((a),b) print a,b sub testsub(x,y) x=x+1: y=y+1 end sub 4 5 Thanks Tom, I understand what is happening but am unsure as to where you might use this and why? Can you expand a little? Regards, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
