Local Time 07:12 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit V5
     Page 19 of 19
Andrew_G
Posted: 09:18pm 28 Feb 2023
Good on you Jim!
I am so glad to hear that your GOOD health is stopping you working on MMEdit 24x7.
I'm happy with my workaround.
(I was worried that my brain-fog had returned).
Cheers,
Andrew
Posted: 04:11am 04 Mar 2023
MMEdit has had an update.
In the editor, you now have a configurable column marker. This helps you keep lines of code within the limits of the 'mite editor.
There is also a command to word-wrap comments. This allows you to write long comments then wrap them before sending to the 'mite (TBS etc)
In the Command Centre,
We now have auto-reconnect. This is handy when you have to do a rest to get an IP etc. No longer any need to do a disconnect-reconnect yourself.
MMCC now does word-wrap. This splits lines at the current display width, not at the nearest space character.
When you copy the text either by mouse selection or edit menu, the long lines are rejoined. I don't know what the maximum line size is. The longest I have tried is about 7500 characters. This is handy/essential when playing with json data.
If you don't use word-wrap, lines are up to 255 characters but only display the console width. The extra characters are captured when doing a copy operation.
Entering the file manager sets the 'mite clock to match the PC time. This prevents all your files have a date timestamp of 1-1-2000. I will probably make that an option or only change the date if it is obviously wrong.
I still haven't given the RPi version any love but I will try and update it soon.
Posted: 08:13pm 04 Mar 2023
  Quote  In the Command Centre,
I forgot to mention that this feature is for Windows only. I will investigate Linux later.
Andrew_G
Posted: 09:10pm 04 Mar 2023
Hi Jim,
Don't waste this good weather but:
- wrap works a treat - thanks!
- my <TAB> key isn't doing anything - is it me or a new 'feature'? (I can tap the space bar a few times until you get a chance to look at it).
Cheers,
Andrew
Posted: 09:53pm 04 Mar 2023
That what comes from using the latest beta of PureBasic to compile with.
I will roll back to an earlier version and post the update later today.
Andrew_G
Posted: 10:04pm 04 Mar 2023
Don't stress Jim. I'm playing with two Picos talking to each other so I've got more than enough fun for a while.
Andrew
Posted: 10:16pm 04 Mar 2023
It's not just tab spaces, it also killed off auto-completion and a few other important things.
I will raise the issue with PureBasic and roll back a beta in the mean time..
Posted: 01:58am 05 Mar 2023
I have just uploaded the Windows files again. This time, TAB should work again.
Linux didn't seem to be inflicted with the disappearing tab key so I haven't updated.
Website updated at 0200UTC 5 Mar
Pluto
Posted: 09:36am 05 Mar 2023
Working with HTML-files in MMEdit+MMCC:
- Is there a way to copy files from flash (A:) to Windows without having an SD-card?
/Pluto
Posted: 11:10am 05 Mar 2023
  Pluto said  Working with HTML-files in MMEdit+MMCC:
/Pluto
Yes, that's what the file manager is for.
Pluto
Posted: 01:24pm 05 Mar 2023
Thanks!
I have opened the filemanager many times in the past, but i never fully understood how it works.
When you said it is possible, I had to test again. And it works very nicely!
Regret that i didn't ask earlier.
/Pluto
disco4now
Posted: 08:53am 06 Mar 2023
I like auto-reconnect, well love it really!
F4 H7FotSF4xGT
Posted: 08:55am 06 Mar 2023
  disco4now said  I like auto-reconnect, well love it really!
Likewise.
Pluto
Posted: 10:23am 06 Mar 2023
     Page 19 of 19
