Local Time 04:52 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Beta Testers Wanted
     Page 19 of 26
Alan68
Posted: 08:34pm 30 Jan 2014
Hi MOBI,
Analogue PIN 3 does not work on my PIC's, I have a program to view the first 6 analogue inputs 2 to 7 and if you put a voltage on PIN 2, PIN 3 shows the same value.
Alan
Geoffg
Posted: 09:00pm 30 Jan 2014
  MOBI said   A bug??
None of my chips (6 off) will read analogue on pin3. Analogue works quite happily on all other pins designated.
The data sheet for the series says pin 3 is AN1??? Should work??
It is a bug!!
Thank you very much MOBI. Brilliant discovery and thanks Alan for confirming it.
I just could not believe that everything worked perfectly first time... my faith in the (imperfect) universe is restored.
I will fix this in the next beta version which should be out in 4 or 5 days (this will include a 44 pin version).
Thanks again,
Geoff
Posted: 09:45pm 30 Jan 2014
Hi All,
Maybe if an adapter was made up to connect to a Test-A-Mite it would be easy to check several basic functions of the uMite..
The TAM could test Digital IO, Analog in, H-L and L-H transition, count, frequency and period measurements.
I havent yet got my blank chips from Element14 (bit peeved, although I have been in hospital, that they said there were some instock but 2 weeks nearly later and they still havent arrived
Anyway wont be long
Posted: 10:39pm 30 Jan 2014
  Geoffg said  It is a bug!!
ALRIGHT!!!!!
Houston, we have a bug!!!!!
It took THIRTY ONE pages of thread, but we found one!
Good work, MOBI and Alan.
Posted: 11:43pm 30 Jan 2014
  atmega8 said
The only equal is, that we bought the same Pic's from the same charge/ distributor.
Type is 32MX150F128B-ISP.
This is the chip that I am using.
I haven't tried them at 48MHz.
I have had a couple running more ore less nonstop for a week without any problems.
How are you powering them?
I use the USB 5V with my own 3.3V regulator and 10uF on the input and output of the regulator and a couple of 0.01uF caps close to the IC.
I put the PC in sleep mode overnight which keeps the 5V on and when I restart the PC the uMite is still there outputting data every 5 minutes...
donmck
Posted: 10:55am 31 Jan 2014
Looks like this is about the cheapest FTDI converter board that includes postage, and it looks like the user can select the voltage also.
http://dx.com/p/ftdi-basic-fio-pro-mini-lilypad-downloader-w hite-black-278463#.UuwMVbTtqqI
Cheers Don...
https://www.dontronics.com
donmck
Posted: 11:41am 31 Jan 2014
Cheers Don...
Just found this one which is $1 cheaper and definitely voltage selectable.
http://www.ebay.com.au/itm/FT232RL-USB-To-TTL-Serial-Adapter -Module-For-The-Arduino-Mini-Port-3-3V-5-5V/251388888343?rt= nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSI C.FIT%26ao%3D1%26asc%3D261%26meid%3D4513667444108221320%26pi d%3D100005%26prg%3D1088%26rk%3D2%26rkt%3D5%26sd%3D2311218911 71%26
Cheers Don...
Posted: 12:20pm 31 Jan 2014
Cheers Don...
You can select the voltage level but there is no external regulator so there are only a few milliamps available for driving external devices.
plasma
Posted: 01:42pm 31 Jan 2014
found two errors in the manual
page 28 : open comspec$ command - the pins for com1 and 2 are wrong
com 2 use pin 9 & 10
com 1 use pin 21 & 22
page 39 : chart has no com1 but double com2 header
Edited by plasma 2014-02-01
donmck
Posted: 03:25pm 31 Jan 2014
  TassyJim said
Cheers Don...
Yes, looks like about 50ma as far as I can tell.
What we need is an Ebay Chinese gentleman that produces the above board, but with a 3.3V power supply on board. Been searching but can't find anything even close.
Don...
MOBI
Posted: 03:49pm 31 Jan 2014
Pin functionality check.
I have checked all pins for basic I/O functionality and with the exception of pin3 AIN, all appear to work as intended. I haven't yet checked SPI, I2C, COM or Open Collector. Unless someone else has?
So far it is looking good.
David M.
Posted: 06:27pm 31 Jan 2014
  MOBI said
Yes, it has a 9 pin connector but the signal levels are 5V and the polarity is inverted like RS232. As the inverter runs happily at 3.3v, I don't have to worry about putting limiting resistors in.
Gday David,
I have just caught up with this conversation.. Please forgive me bringing it up again.
Unless you have a very unusual USB to TTL inverter I would put my money on it being a VERY CHEAP chinese USB to RS232 converter..
RS232 is plus and minus 3v-30V levels (+-12v being a more pseudo standard) but with many early (maybe more recent as well) laptops this got bastardised to GND (for the minus levels) and 5v for the plus levels that worked most of the time (short distance transfers).. I suspect that what you actually have there, conforms to that non-standard standard, and explains the need for inverters.
MOBI
Posted: 07:25pm 31 Jan 2014
  mick said  RS232 is plus and minus 3v-30V levels (+-12v being a more pseudo standard) but with many early (maybe more recent as well) laptops this got bastardised to GND (for the minus levels) and 5v for the plus levels that worked most of the time (short distance transfers).. I suspect that what you actually have there, conforms to that non-standard standard, and explains the need for inverters
Yes, that sounds pretty well what I have here. They certainly were very cheap. I never had any issues with them though. They all worked even at high data rates. The D9 connector has always been an annoyance - I would have preferred header pins.
The only problem I had with one was assigning the wrong driver and now, no matter what I tried, I couldn't get the correct driver back to that lead. Doesn't matter, I have plenty.
Are you up and about yet? We're all thinking about you.
David M.
Posted: 07:36pm 31 Jan 2014
At fear of monopolising threads with my ailments...
Thanks for your thoughts..
Yes I have had the major blockage fixed (where they thought it might be difficult), which have improved my lot many 100's %, but after fixing that one they found another less critical blockage further along so I go back into Melbourne Private tomorrow for it to be fixed and I should be home Tuesday Morning..
Now hopefully my PIC32 chips arrive from Element14 Been ordered 13 days now... Very slack of them.. Prob just as well I havent been in a position to play with one else I would be pretty peeved.
MOBI
Posted: 08:35pm 31 Jan 2014
Further to pin functionality, I think we can give I2C master mode a clean bill of health. Haven't tried multi master or slave mode yet.
To test the pin I/O functions, I set up a PWM and used it as an input to each of the pins in turn and printed the result to the display. Used the cro to verify frequency, period etc.
David M.
jman
Posted: 10:16pm 31 Jan 2014
I have tested the SPI with a Nokia monochrome LCD and
am happy to report it works a treat (The format is great)
Jman
Posted: 10:25pm 31 Jan 2014
I have tested a blinking LED on pin-14, and am pleased to report that it blinks.
Seriously though, I plan to do some serial port tests in the next few days, and also either I2C or serial to an ALFAT SD card filesystem module which I was unable to get to work with the PICAXE chips.
atmega8
Posted: 10:02am 01 Feb 2014
Geoff,
will you please provide the internal memory mapping of the system?
Peek and Poke is possible, so why not use it;-)
If it is an open system, then we should know whats going on there internally.
That's what made the Apples and sinclairs.....etc.. so interesting and successfull.
BobD
Posted: 11:02am 01 Feb 2014
  atmega8 said   Geoff,
what happens when the next compile shifts things along a few bytes?
who said it was open? See this.
atmega8
Posted: 12:13pm 01 Feb 2014
Open in means of technology.
Edited by atmega8 2014-02-02
     Page 19 of 26
