Local Time 16:51 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : BNO055: The best position sensor BUT!!
Bizzie
Posted: 09:26pm 22 Feb 2018
Matherp,
Have you tried the uart (S0 = 0, S1 = 1) interface on the BNO055 borads?
I have an application on some agricultural equipment where the sensor would be about 5m from the mite. Do you think it would work?
Rob White
Posted: 10:16pm 22 Feb 2018
  Quote  Have you tried the uart (S0 = 0, S1 = 1) interface on the BNO055 borads?
No - sorry. It seems to transmit in non-ascii so I didn't get round to trying to decode it
  Quote  I have an application on some agricultural equipment where the sensor would be about 5m from the mite. Do you think it would work?
5m on I2C can be OK. I would set the speed down fairly low and use 1K2 pullups
Bizzie
Posted: 12:44am 23 Feb 2018
Thanks,
Will try the I2C first.
Rob White
palcal
Posted: 04:07am 23 Feb 2018
@ Matherp
Using the latest firmware and SSD1963_4 display
Tried the AI code but get an error
  Quote  [347] Option autorefresh off
Error: Not valid for this display
Paul.
Azure
Posted: 04:19am 23 Feb 2018
Paul.
Not sure if this helps or not.
Did you use the OPTION command to set display buffering
[code]'Set up the display using the new buffered driver
OPTION LCDPANEL SSD1963_4_16_buff, L, RDpin[/code]
palcal
Posted: 05:11am 23 Feb 2018
NO I didn't I was looking for the latest Extreme Manual my latest is V5.03.10
I will give that a go.
Paul.
Azure
Posted: 05:18am 23 Feb 2018
It was in the details of Peters Post, but given it was a long post I thought it was easy to overlook.
Hope it helps.
If not the seemingly tireless Matherp will surely come to the rescue.
palcal
Posted: 05:24am 23 Feb 2018
OK that did the trick, got it working OK.
Will have to find the latest MX manual.
Paul.
palcal
Posted: 05:26am 23 Feb 2018
Well I shouldn't have missed that it was sticking out like dogs b****.
Paul.
Azure
Posted: 05:40am 23 Feb 2018
The excitement of that great application to have a play with from Matherp hid the obvious.
palcal
Posted: 05:51am 23 Feb 2018
Yes, he is amazing. Now I have the Attitude Indicator, probably less than $100.
I just need another $250,000 or so for a plane and flying lessons.
Paul.
Azure
Posted: 06:45am 23 Feb 2018
Isn't that what the sprites and scrolling background extensions on the MMX were for... so you could write your own plane simulator
