Local Time 09:51 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite V5.04.09 Beta 16
Geoffg
Posted: 05:16am 31 Mar 2018
Damn, I guess that now is the time to setup a test jig. I don't have a MPU6050 so I hope that the problem shows up with some other device.
Watch this space.
Posted: 06:50am 31 Mar 2018
I connected a HMC5883L compass module and it ran for 8 minutes before timing out.
Only one run so far. I will try a few more times.
sagt3k
Posted: 07:40am 31 Mar 2018
Thanks TassyJim for your support
I have not been creating firmware (PIC16/18/32) for many years thanks to Geoff who created this great world for us.
The concept of the I2C protocol is very clear, but assuming that it is not the problem of the module, which is not because I have developed different boards with 28 and 44pin and with many modules, I repeat the concept of I2C is the possibility to interrogate the devices with a certain frequency and speed. Setting time out would penalize this functionality.
If it is an intrinsic problem of the MICROCHIP libraries or of the USB/driver, that can not be overcome.
I did several tests, even to give separate power to the module. As soon as it is connected to the PC USB to change data, this problem occurs.
I have a small board with PIC32MZ-64pin, I'll try these days to see if it happens the same.
MMbasic has great potential, also for future IoTs and mini computers. See the launch of the new C64 or the new VIC20.
Geoff and Matherp and others have made a dream come true and those who have worked there for a long time, know how much can be done.
Antonio
sagt3k
Posted: 07:17pm 03 Apr 2018
Hi to everybody
I'm working with PIC32MX-64pin and I use a microUSB 5pin.
I pull-up pin4/ID with 5Vusb or must be grounded ?
Antonio
cdeagle
Posted: 06:53pm 04 Apr 2018
I've started testing my astronomy and aerospace programs with this version of double precision MMBasic. I'm using the GCMICROBOARD2B from Circuit Gizmos (MX470F512H). So far all the programs I have tested have run to completion without any problems.
Thanks everybody
sagt3k
Posted: 04:13am 05 Apr 2018
Hi cdeagle
have you tried my code, the same sensor and the same conditions?
Antonio
Geoffg
Posted: 05:25am 05 Apr 2018
There was a bug (or more accurately an omission) that prevented the Micromite Plus with double precision floating point from working with the HUMID CSub and other embedded routines that returned floating point values via the argument list.
I have fixed that and the MM+ is now at Beta 17 (the other versions are unchanged at beta 16). Download is via the usual URL.
Now for the USB/I2C issue...
Geoff
sagt3k
Posted: 03:55pm 05 Apr 2018
Hi Geoff
Thanks, then here a new code where I open the I2C and not close. I use other sensor GY91 that has MPU9250+BMP280:
Here the result and code:
DS3231 RTC.CLOCK--------------------------------
00:00:110 01-01-2000 329
MPU6050 (ACC+GYRO+TEMP).SENS--------------------
ACCEL_XOUT 912
ACCEL_YOUT 2540
ACCEL_ZOUT 16180
TEMP(6050) 36.0
GYRO_XOUT 156
GYRO_YOUT 24
GYRO_ZOUT 81
Degrees 8.9
X,Y,Z inc. 3.2 8.9 80.5
BME280 (TEMP+PRESS+HUMID)SENS------------------
TEMP(280) 21.13
PRESS.ATM. 964.2 92
HUMID 0.0
ALTITUDINE 416.20
MCP 9700 TEMP.SENS + VIN------------------------
TEMP(9700) -2.0
V21= 0.00
V22= 0.00
VIN= 0.46
MM.I2C= 0 n.err= 4
CPU 120
' TassyJim
' 16 October 2015
' MPU-6050 gyro/accelerometer
Option AUTORUN ON
Option EXPLICIT
On ERROR IGNORE
Option baudrate 57600
Dim MPU = &h68 ' MPU-6050 address
Dim temp, accelX, accelY, accelZ, gyroX, gyroY, gyroZ, tilt, accelM
Dim gyro(14)
Dim R,RX,RY,RZ As Float
Dim ID,I2Cerr As Integer = 0
Const BME280_ADDRESS = &H76
Const BME280_REGISTER_T1 = &H88
Const BME280_REGISTER_P1 = &H8E
Const BME280_REGISTER_H1 = &HA1
Const BME280_REGISTER_H2 = &HE1
Const BME280_REGISTER_CHIPID = &HD0
Const BME280_REGISTER_CONTROLHUMID = &HF2
Const BME280_REGISTER_CONTROL = &HF4
Const BME280_REGISTER_PRESSUREDATA = &HF7
Const BME280_REGISTER_TEMPDATA = &HFA
Const BME280_REGISTER_HUMIDDATA = &HFD
Dim integer s16=&HFFFFFFFFFFFF0000 , s16b=&H8000
Dim integer s12=&HFFFFFFFFFFFFF000 , s12b=&H800
Dim integer s8= &HFFFFFFFFFFFFFF00 , s8b=&H80
Dim INTEGER T1,T2,T3 'uint16_t, int16_t, int16_t
Dim INTEGER P1,P2,P3,P4,P5,P6,P7,P8,P9 'uint16_t, 8 x int16_t
Dim INTEGER H1,H2,H3,H4,H5,H6 'uint8_t, int16_t , uint8_t, int16_t, int16_t, int8_t
Dim INTEGER t_fine 'used to store accurate temp reading from temp conversion for use in pressure and humidity conversio
Dim press,lasttemp,lasthum,lastalt As Float
SetPin 1,dout
SetPin 2,dout
SetPin 3,dout : Pin(3)=1
SetPin 21,ain
SetPin 22,ain
SetPin 27,Ain
SetPin 18,ain
SetPin 55,dout : Pin(55)=0
Print Chr$(27)+"[2J" ' VT100 CLS
I2Cinit
Print Chr$(27)+"[1;1H"
DS3231
MPU6050
BME280
MCP9700
LEDs
Sub I2Cinit
I2C open 400,250 '400KHz bus speed
Pause 50
bme280_init
mpu6050_init
End Sub
Sub LEDs
Pin(1)=Not Pin(1)
End Sub
Sub DS3231
Print "DS3231 RTC.CLOCK--------------------------------"
RTC GETTIME
Print Time$,Date$,ID
ID=ID+1
End Sub
Sub MCP9700
Print "MCP 9700 TEMP.SENS + VIN------------------------"
Print "TEMP(9700) ",Str$(((Pin(18)-0.5)/0.01),3,1)
Print "V21="Str$(Pin(21)*10,2,2)
Print "V22="Str$(Pin(22)*10,2,2)
Print "VIN="Str$(Pin(27),2,2)
Print "MM.I2C="MM.I2C " n.err="I2Cerr
If MM.I2C>0 Then
Pin(2)=1
Pin(3)=0
I2Cerr=I2Cerr+1
I2C CLOSE
Pause 250
I2Cinit
Else
Pin(2)=0
End If
End Sub
Sub BME280
Print "BME280 (TEMP+PRESS+HUMID)SENS------------------"
If ID Mod 10 = 0 Then
lasttemp=bme280_read_temp()
Press=bme280_read_pressure()
lasthum=bme280_read_humidity()
lastalt=44330.0 * (1.0 - (press / 1013.25) ^ 0.1903))
End If
Print "TEMP(280) ",Str$(lasttemp,2,2)
Print "PRESS.ATM. ",Str$(press,4,1)
Print "HUMID ",Str$(lasthum,4,1)
Print "ALTITUDINE ",Str$(lastalt,4,2)
End Sub
Sub mpu6050_init
I2C WRITE MPU,0,2,&h6B,0 'wake up the MPU-6050
End Sub
Sub MPU6050
I2C WRITE MPU,1,1,&h3B 'Reset memory pointer.
I2C READ MPU,0,14,gyro(1) 'Read 14 bytes
accelX=sint16(gyro(1)*256+gyro(2))
accelY=sint16(gyro(3)*256+gyro(4))
accelZ=sint16(gyro(5)*256+gyro(6))
temp=sint16(gyro(7)*256+gyro(8))/340+36.53
gyroX=sint16(gyro(9)*256+gyro(10))
gyroY=sint16(gyro(11)*256+gyro(12))
gyroZ=sint16(gyro(13)*256+gyro(14))
accelM=Sqr(accelX*accelX+accelZ*accelZ)
If accelM=0 Then ' avoid divde by zero error
If accelY<0 Then
tilt=-90
Else
tilt=90
EndIf
ElseIf accelZ<0 Then
If accelY<0 Then
tilt= -180 - Deg(Atn(accelY/accelM))
Else
tilt= 180 - Deg(Atn(accelY/accelM))
EndIf
Else
tilt = Deg(Atn(accelY/accelM))
EndIf
Print "MPU6050 (ACC+GYRO+TEMP).SENS--------------------"
Print "ACCEL_XOUT ",Str$(accelX,6,0)
Print "ACCEL_YOUT ",Str$(accelY,6,0)
Print "ACCEL_ZOUT ",Str$(accelZ,6,0)
Print "TEMP(6050) ",Str$(temp,3,1)
Print "GYRO_XOUT ",Str$(gyroX,6,0)
Print "GYRO_YOUT ",Str$(gyroY,6,0)
Print "GYRO_ZOUT ",Str$(gyroZ,6,0)
Print "Degrees ",Str$(tilt,4,1)," "
R=Sqr(accelX*accelX+accelY*accelY+accelZ*accelZ)
If R<>0 Then
RX=-(ACos(accelX/R)*180/Pi)+90
RY=-(ACos(accelY/R)*180/Pi)+90
RZ=-(ACos(accelZ/R)*180/Pi)+90
Print "X,Y,Z inc. ",Str$(RX,4,1),Str$(RY,4,1),Str$(RZ,4,1)
End If
End Sub
Function sint16(x) ' convert to signed 16 bit number
If x>32767 Then
sint16 = x - 65536
Else
sint16 = x
EndIf
End Function
Function bme280_read_temp() As float
Local integer var1,var2,adc_T
Local adc%(2)
I2C write BME280_ADDRESS,1,1,BME280_REGISTER_TEMPDATA
I2C read BME280_ADDRESS,0,3,adc%()
adc_T=((adc%(0)<<16) Or (adc%(1)<<8) Or adc%(2))>>4
var1 = ((((adc_T>>3) - (T1 <<1))) * T2) \ q(11)
var2 = (((((adc_T>>4) - (T1)) * ((adc_T\ q(4)) - (T1))) \ q(12)) * (T3)) \ q(14)
t_fine = var1 + var2
bme280_read_temp = ((t_fine * 5 + 128) \ q(8))/100.0
End Function
Function bme280_read_pressure() As float
Local integer var1, var2, adc_P, p
Local adc%(2)
I2C write BME280_ADDRESS,1,1,BME280_REGISTER_PRESSUREDATA
adc_P=((adc%(0)<<16) Or (adc%(1)<<8) Or adc%(2))>>4
var1 = t_fine - 128000
var2 = var1 * var1 * P6
var2 = var2 + ((var1 * P5)<<17)
var2 = var2 + (P4 << 35)
var1 = ((var1 * var1 * P3)\ q(8)) + ((var1 * P2)<<12)
var1 = ((1<<47)+var1)*P1\ q(33)
If var1 = 0 Then
bme280_read_pressure = 0' avoid exception caused by division by zero
Exit Function
EndIf
p = 1048576 - adc_P
p = (((p<<31) - var2)*3125) \ var1
var1 = (P9 * (p\ q(13)) * (p\ q(13))) \ q(25)
var2 = (P8 * p) \ q(19)
p = ((p + var1 + var2) \ q(8)) + (P7<<4)
bme280_read_pressure = p/25600.0
End Function
Function bme280_read_humidity() As float
Local integer v_x1,adc_H
Local adc%(1)
I2C write BME280_ADDRESS,1,1,BME280_REGISTER_HUMIDDATA
I2C read BME280_ADDRESS,0,2,adc%()
adc_H=(adc%(0)<<8) Or adc%(1)
v_x1 = t_fine - 76800
v_x1=(((((adc_H<<14)-((H4)<<20)-(H5*v_x1))+16384)\ q(15))*(((((((v_x1*H6)\ q(10))*(((v_x1*H3)\ q(11))+32768))\ q(10))+2097152)*H2+8192)\ q(14)))
v_x1 = (v_x1 - (((((v_x1 \ q(15)) * (v_x1 \ q(15))) \ q(7)) * (H1)) \ q(4)))
If v_x1< 0 Then v_x1 = 0
If v_x1 > 419430400 Then v_x1= 419430400
bme280_read_humidity = (v_x1\ q(12)) / 1024.0
End Function
Sub bme280_init
Local i%,cal%(17)
I2C write BME280_ADDRESS,1,1,BME280_REGISTER_CHIPID
I2C read BME280_ADDRESS,0,1,i%
'If i%<>&H60 Then Print "Error BME280 not found"
I2C write BME280_ADDRESS,1,1,BME280_REGISTER_T1
I2C read BME280_ADDRESS,0,6,cal%()
T1=cal%(0) Or (cal%(1)<< 8)
T2=cal%(2) Or (cal%(3)<< 8): If T2 And s16b Then T2=T2 Or s16 'sign extend if required
T3=cal%(4) Or (cal%(5)<< 8): If T3 And s16b Then T3=T3 Or s16
I2C write BME280_ADDRESS,1,1,BME280_REGISTER_P1
I2C read BME280_ADDRESS,0,18,cal%()
P1=cal%(0) Or (cal%(1)<<8)
P2=cal%(2) Or (cal%(3)<<8): If P2 And s16b Then P2=P2 Or s16 'sign extend if required
P3=cal%(4) Or (cal%(5)<<8): If P3 And s16b Then P3=P3 Or s16
P4=cal%(6) Or (cal%(7)<<8): If P4 And s16b Then P4=P4 Or s16
P5=cal%(8) Or (cal%(9)<<8): If P5 And s16b Then P5=P5 Or s16
P6=cal%(10) Or (cal%(11)<<8): If P6 And s16b Then P6=P6 Or s16
P7=cal%(12) Or (cal%(13)<<8): If P7 And s16b Then P7=P7 Or s16
P8=cal%(14) Or (cal%(15)<<8): If P8 And s16b Then P8=P8 Or s16
P9=cal%(16) Or (cal%(17)<<8): If P9 And s16b Then P9=P9 Or s16
I2C write BME280_ADDRESS,1,1,BME280_REGISTER_H1
I2C read BME280_ADDRESS,0,1,H1
I2C write BME280_ADDRESS,1,1,BME280_REGISTER_H2
I2C read BME280_ADDRESS,0,7,cal%()
H2=cal%(0) Or (cal%(1)<< 8): If H2 And s16b Then H2=H2 Or s16 'sign extend if required
H3=cal%(2)
H6=cal%(6): If H6 And s8b Then H6=H6 Or s8 'sign extend if required
H4=(cal%(3)<<4) Or (cal%(4) And &H0F): If H4 And s12b Then H4=H4 Or s12 'sign extend if required
H5=(cal%(5)<<4) Or (cal%(4)>>4): If H5 And s12b Then H5=H5 Or s12
I2C write BME280_ADDRESS,0,2,BME280_REGISTER_CONTROLHUMID,&H05 '16x oversampling humidity
I2C write BME280_ADDRESS,0,2,BME280_REGISTER_CONTROL,&HB7 '16x oversampling pressure/temp, normal mode
End Sub
Function q(x As integer) As integer 'returns 2 raised to the power
q=(1<<x)
End CFunction
My circuit has microUSB with pin4/ID in pullup with 5Vusb and D+/D- with resistor in series.
Antonio
sagt3k
Posted: 08:56am 06 Apr 2018
Hi Geoff
Another interesting information...
Same circuit connected with usb on a PC.
Then, if I leave PC with inactive OS, the circuit works for days without errors.
But just starting windows even without terminal emulator sw, errors occur.
Coud it be theUSB driver that communicates with the micro and interferes with IC2 routines?
Antonio
Posted: 11:47am 08 Apr 2018
Geoff, is there any plan for an upgrade for the cgcolormax2 basic? It would be interesting to add the c funtion capability, especially if these funtions where compatble wit the micromite functions.
Geoffg
Posted: 09:52pm 08 Apr 2018
I do have it on my list but it would be a big job (so it keeps getting put off). The upgrade would be to a version compatible to the current version of Micromite MMBasic and that would be slightly incompatible with V4.3 for the Colour Maximite - which might cause a problem for some.
Not sure about porting the CFunction capability - that is closely tied to the hardware.
sagt3k
Posted: 04:37pm 23 Apr 2018
Hi Geoff
I wanted to update you on the subject,I tried the same code with the PIC32MZ-64pin@200Mhz,same condition, directly through USB<-->PC, USBID with pin ID, 10K or resistor for I2C, firmware v.5.0405
It works for days without an error, perfectly
Antonio
Geoffg
Posted: 10:50pm 23 Apr 2018
I have been experimenting with this issue. The good news is that I can reproduce it and it seems to be caused by the USB hardware/driver which disables the PIC32 interrupts for too long. The bad news is that I have not been able to find a way to fix the problem.
I am still experimenting but the fact that it works on the PIC32MZ shows that it is probably performance related. Perhaps (on the MZ) the interrupts are disabled for a shorter time.
Geoff
sagt3k
Posted: 05:23am 24 Apr 2018
Thanks Geoff
It is already comforting to know that the problem has been found.
The problem occurs both in Win7/10 and in Linux, so I think it is to be exluded O.S.
Antonio
Geoffg
Posted: 06:29am 28 Apr 2018
I believe that I have fixed the USB/I2C issue.
Download Micromite V5.04.09 Beta 19 from here: http://geoffg.net/Downloads/Micromite/Micromite_V5.04.09_Beta.zip
