Forum Index : Microcontroller and PC projects : Power Failure Chips
A Pi Zero W, and it's been running all day so far It's got a 3.5A battery so will be perfect to keep it running if there was a short power cut |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3881 |
I got this LIPO charger with battery: https://www.amazon.com/gp/product/B07H3KSBSX/ref=ppx_yo_dt_b_asin_title_o01__o00_s00?ie=UTF8&psc=1 It ran a raspberry pi zero w for 20 hours and 17 minutes, and the pi started back up when I plugged the charger back in. Price is up $3 since I bought it. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
On a second test, the pi rebooted upon removal of power from the lipo charger. I'll see how long it runs again disconnected from the charger, and then try again with a biggish cap on the pi supply. 21 hours on the second pass; no glitch upon plugging in the module with a flat lipo. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
This 18650 power bank will run a raspberry pi zero w for over 5 hours, and was glitchless in my testing upon power disconnect, but does not recharge (overnight, for instance), when power is applied again with the pi connected, so the pi never starts up again. Has anyone found one of these large power banks (~20000mAh) which powers a device (pi) while charging, and is glitchless when removing or applying power? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
