lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709
Posted: 09:56am 05 Jan 2019
Peter How can you run the Vreg from both battery and USB at the same time when they are both different voltages? Unless the blob marked 11 and 22 is something special?
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11881
Posted: 10:09am 05 Jan 2019
This is a normally open shorting link (add a solder blob to close)
Shorting it allows you to run the PCB without the U2 module and without the battery if required (testing etc.)
Yes but then I waste lots of battery life. Only say 85% efficient on the boost and then waste (1.7/5*100)% of the battery in heat rather than (0.4/3.7*100)% - bad idea Edited by matherp 2019-01-06
Posted: 10:41am 06 Jan 2019
Have you by any chance measured the current draw? I'm wondering what it is with just the BMP180 and HC-12 in standby or receive mode is
HankR Senior Member Joined: 02/01/2015 Location: United StatesPosts: 209
Posted: 08:25pm 08 Jan 2019
I'd like to request a small line of .1 inch spaced pads for a daughter board plug-in L4 wakeup device.
At least 3 pads for a male or female header would allow for a board-powered device (and of course also allow for self power) that could be in the area of microamp drain. Not just for an RTC but other custom circuits.
An additional pin would allow for a choice of two wakeup pins, or new added jumpers could enable that option. I prefer jumpers to solder blob bridges, but will take anything.
Hank
Posted: 10:30am 09 Jan 2019
Peter Have you thought about using an ABS07W-32.768kHz-D-1-T for the crystal? 63p and 10ppm stability
