Local Time 10:42 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite L4: 5.05.09 with DOCUMENTATION!
sagt3k
Posted: 06:01pm 27 Mar 2019
Hi matherp
I noticed something strange about file management (I have stm32l431+flash W25Q32) after I break with ctrl+c a file in append mode.
In practice after having done the breack of an append it does not allow me to do "save" except after having done an "edit"
Here the steps:
>format
>save "code.bas"
>run
after a loops I break the code with CTRL+C
> print mm.free
3837952
> files
A:
267 code.bas
160000 OUT.TXT
Ok then I kill the file:
> kill "code.bas"
> files
A:
160000 OUT.TXT
> save "code.bas"
Error: No more memory available
> files
A:
160000 OUT.TXT
0 code.bas
Now I do "edit" and (save or exit without change code)
> save "code.bas"
> files
A:
160000 OUT.TXT
268 code.bas
I can save more several times without errors
> save "code.bas"
> save "code.bas"
This is the code:
Option autorun on
SetPin 2,dout
Dim X As Integer = 0
Open "OUT.TXT" For APPEND As #1
X=X+1
Print #1,Timer
If X Mod 1000=0 Then
Close #1
Print Timer,X, " - A:diskfree:"MM.FREE
End If
Pin(2)=Not Pin(2)
Posted: 06:05pm 27 Mar 2019
This is because the Armmite only supports a single file handle and there is a file left open by your program. If you just type "close 1" before the save you will find it works. I'll put an automatic close into the next version if you try and save.
I fell over this today testing lizby's issueEdited by matherp 2019-03-29
sagt3k
Posted: 06:20pm 27 Mar 2019
Ok thank
Is there the possibility to close file and save data after ctrl+c if there is an opened file?
So this would avoid losing data. Do you think it makes sense?
Posted: 08:09am 28 Mar 2019
Please find attached a trivial update that closes an open file before executing a save or autosave command
2019-03-28_180338_ArmmiteL4.zip
  Quote  Is there the possibility to close file and save data after ctrl+c if there is an opened file?
Not really, because then you couldn't CONTINUE in any program that had an open file. With the update above the situation is pretty safe as NEW, RUN, LOAD, SAVE, AUTOSAVE, permanent OPTION all close any open files before executing.
  Quote  How is the timed sleep implemented ? are you using the RTC wakeup timer ?
Which clock domain : RTCclock with post divider
Yes
  Quote  Are there commmands to manipulate the registers directly ( like peek and poke )
PEEK and POKE should both work on registers but let me know if there appear to be issues
  Quote  when invoking SLEEP 10 :
PC13 goes low and the cpu goes to sleep for 10 seconds.
after the time has elapsed PC13 goes high and the cpu wakes up.
PC13 is controlled by the vbat power domain so it can toggle even if the main
power of the cpu is off.
Let me know if you can get it to work and I'll look at incorporating it. RTC wakeup was a pig to get working as there was a bug in the CubeMX code. Also be aware that the processor "wakes" every 32 seconds regardless of the length of SLEEP. This is a hardware limitation and is handled inside the CPU SLEEP commandEdited by matherp 2019-03-29
sagt3k
Posted: 11:59am 28 Mar 2019
Hi matherp
If possible other requests
- "load" with R as optional to load&run code
- "filesize" function that return the size in byte of a file in the flash
Posted: 02:40pm 28 Mar 2019
  Quote  If possible other requests
Your wish....
2019-03-29_003730_ArmmiteL4.zip
2019-03-29_012130_Armmite_L4_Manual.pdf
LOAD "filename",r as per Micromite+
Note the new command SYNCH. This flushes the buffer from the flash driver. Until this is done the filesize is not updated and the disk may or may not be written.
Note also, if an existing file is opened for output then filesize will give the size of the previous version of the file until the file is closed or SYNCH is called.
Timer = 0
Open "T" For output As #1
Print "Size after opening is : ",Filesize("T")
For i=0 To 1000
Print #1,i, "Hello World"
Next i
Print "Size after writing 1000 lines is : ",Filesize("T")
Synch #1
Print "Size after synch is : ",Filesize("T")
For i=0 To 1000
Print #1,i, "Bye World"
Next i
Print "Size after writing another 1000 lines is : ",Filesize("T")
Close #1
Print "SIze after closing is : ",Filesize("T")
Print "Time taken is : ",Timer/1000," seconds"
Edited by matherp 2019-03-30
sagt3k
Posted: 05:14pm 28 Mar 2019
Thanks matherp
CaptainBoing
Posted: 05:18pm 28 Mar 2019
and with that the memory size limit on any program is gone (as if it mattered with the MMX etc...)
Posted: 05:32pm 28 Mar 2019
  Quote  and with that the memory size limit on any program is gone (as if it mattered with the MMX etc...)
Yes . Didn't know if this would work but it seems to behave perfectly
Program 1
Dim a%
VAR restore
Print "program 1, run : ",a%
a%=a%+1
VAR save a%
Pause 1000
Load "p2",r
Program 2
Dim a%
VAR restore
Print "program 2, run : ",a%
a%=a%+1
VAR save a%
Pause 1000
Load "p1",r
Posted: 06:25pm 28 Mar 2019
Interesting... I did not expect variables to keep their values.
CaptainBoing
Posted: 06:33pm 28 Mar 2019
this is excellent - it is possible to have programs that run as overlays and you simply "page in" the section of code o run.
Question... there is no library with MMX, is there any way to maintain a "kernel" of key functions between overlays int he same way variables survive?
Posted: 06:48pm 28 Mar 2019
  Quote  it is possible to have programs that run as overlays and you simply "page in" the section of code o run.
No - sorry, all or nothing
  Quote  Question... there is no library with MMX, is there any way to maintain a "kernel" of key functions between overlays in the same way variables survive?
No: they will need replicating in each program. I didn't include the library in the Armmite L4 as it uses quite a lot of program memory and there is little advantage given that the Armmite doesn't support CFunctions which is where the big space saving gains are found.
  Quote  Interesting... I did not expect variables to keep their values.
They don't. I'm using VAR SAVE to store the value in the uP flash memory and VAR RESTORE to read it back. This is just standard Micromite functionality. Equally I could have written variable values out to the a file and read them back.
Posted: 07:44pm 28 Mar 2019
Oh - sorry - yes you are indeed doing that!!
Thanks for saying so (and the code already does but I failed to see it).
