Local Time 00:59 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New game to CMM: Gauntlet port
     Page 2 of 6
MauroXavier
Posted: 11:06am 02 Jul 2019
  Frank N. Furter said   @MauroXavier:
Please keep on!
I'm still waiting for having the time to reflash my CMM to try out your programs!
Unfortunately it doesn't work with my current CMM firmware!
You will need to update to the last firmware version because the previous versions has a bug in the port command.
  Cyber said  May be they are just silent or haven't heard about things happening.
I noticed quiete an increasing interest in vintage gaming lately here and there.
To expand the audience, I'm thinking in host a site dedicated to MBasic games and tools, with a comprehensive list with the hardware and firmware requirements (CMM, MMX, Pi-cromite etc) to each software.
Turbo46
Posted: 10:58pm 02 Jul 2019
Yes Mauro,
Please keep on. As Geoff said "You have taken the Colour Maximite to a new level"
I have the sound chips and intend to build a stereo version of the circuit above. For various reasons I have not been able to spend much time on the CMM but hope to in two or three weeks. I am waiting for the new version of MMBasic 5 for the CMM also.
Where did you get the oscillator from?
Bill
MauroXavier
Posted: 11:06am 03 Jul 2019
In the CdN Studio version that I'm about to release, it will include the support to only one SN76489 (and clones) and a AY-3-8910 (8912/3 too).
I have removed the stereo support to the SN76489 because was too few stereo musics to this sound chip, almost all arcades that uses two of these are using one to music and other to sound effects.
I'm removed the stereo support to optimize the speed and to keep the memory constrains.
I have faith that the MBasic 5.0 with the cFunctions will bring all the speed that I need to develop some types of games with good and old 8 bit musics without any slowdown, and with this I will include again the stereo support.
About the oscillator, I am from Brazil and I bought it from an e-commerce from my country (Mercado Livre) which I think was a miracle to have found one.Edited by MauroXavier 2019-07-04
Turbo46
Posted: 11:39am 03 Jul 2019
Thanks Mauro,
So far my searches for "32.768 khz crystal oscillator" only turn up surface mount oscillators or just the crystal. I have a crystal already so I may have to build one using a CMOS inverter chip.
Bill
Cyber
Posted: 01:18pm 03 Jul 2019
  MauroXavier said  I have removed the stereo support to the SN76489 because was too few stereo musics to this sound chip, almost all arcades that uses two of these are using one to music and other to sound effects.
So you are removing pin D11 from lib code and only D10 will be used for sound output?
And do you have plans on how to settle with music and sound effects using one chip?
MauroXavier
Posted: 02:20pm 03 Jul 2019
You can build a stereo circuit with no problems, it will work anyway playing in the two chips at same time because the lib send the data simultaneously.
I'm using the PWM to play SFX, and I'm developing some functions to emulate noise channel and other interessing things using native sound of CMM. This is a good approach to play the sound effects to the users that doesn't have the sound chip.
When the MBasic 5.0 came ready to the CMM with the cFunctions, I will include the stereo support again.
Cyber
Posted: 02:36pm 03 Jul 2019
MauroXavier, very good solutions!
Cyber
Posted: 05:11pm 03 Jul 2019
  Turbo46 said  So far my searches for "32.768 khz crystal oscillator" only turn up surface mount oscillators or just the crystal.
I was googling for oscillator in my country very long, also was resulting in just a crystal.
But finally I found this: https://prom.ua/p723053349-3579545-jco8-generator.html
Googled by "3,579545" :)
And it worked for me! (costed about $2)
I'm posting a link just for reference, maybe marking will help you: JCO8-3-B 3,579545
Here is another link with similar product: https://www.retrosales.com.au/products/parts-modding-crystal-oscillator-4-433mhz-pal-colour-5v-4pin-xtal-dip14
Try searching based on keywords from these pages. Hope that helps.
Edited by Cyber 2019-07-05
Turbo46
Posted: 07:58pm 03 Jul 2019
Thanks Cyber,
Sorry I gave the wrong frequency above, I had it in my head that it was a clock oscillator not the NTSC one. Your Retrosales link looks good to me. I will order a couple.
Bill
Cyber
Posted: 08:20pm 03 Jul 2019
I think these at Retrosales are just regular quartz generators, it's just that they propose to use it to correct video colour issues.
Its shape looks like mine. And when looking at small datasheet they provided I see specs and pinout are the same as mine.
So I thought it's the same. Hope, I'm not wrong.
Frank N. Furter
Posted: 07:56am 09 Jul 2019
Hi MauroXavier,
I ordered some SN76489 to try your phantastic games. Just for interest: Can you give me the reason for this crooked frequency? Is it a coincidence that it is the same frequency as NTSC?
Frank
Turbo46
Posted: 09:01am 09 Jul 2019
Hi Frank,
I can't find the reference right now but I believe that the NTSC frequency was chosen so that the oscillator could be shared with the video signal generator.
Bill
Frank N. Furter
Posted: 09:10am 09 Jul 2019
Hi Bill,
thanks for the info!
Frank
MauroXavier
Posted: 11:17am 09 Jul 2019
  Frank N. Furter said   Hi MauroXavier,
Frank
In this case it's because the majority music files that I found from SN76489 are using this clock frequency (Master System, Game Gear, SC-1000, SC-3000, Tandy 1000 and some SEGA Arcade machines). Other files using different clock frequencies are from BBC Micro (4 Mhz) and few arcades (Moon Patrol, Kung Fu Master etc).
Recently I found a tool that convert MIDI files and AY-3-8192 YM file format to VGM for SN76489 and the results are very good. There are so many fantastic YM files from Atari ST, and it's very interessing listen the differences from a AY-3-8192 music when played in a SN76489, and in some cases I liked more the converted version.
In the next month, with the release of the last version of the CdN Media Studio and a site dedicated to games for Colour Maximite that I'm creating, I will include at least 300 music files for this chip, after all, who build this little circuit to your Colour Maximite must deserve some hours of pure sound chip musics enterteniment. ;)
Turbo46
Posted: 10:04pm 09 Jul 2019
Hi Mauro,
This all sounds very exciting and I hope it gives Maximite games programmers the incentive to produce new games or perhaps modify existing ones.
I hope you include a 'Donate' button on your web page (are you listening Geoff?). The only two people that I know of that have donate facilities are TassyJim and Nick and I have been happy to donate the mere pittance that they suggest for their excellent work.
I also hope that your system will be supported by the new Maximite when that comes (the Arduino shield connector). It would be a pity if it is not and we have to kludge up an interface.
I wonder if anyone has experimented with voice synthesis on the Maximite? That could add a extra dimension to some games.
Bill
Frank N. Furter
Posted: 08:16am 10 Jul 2019
+1 !!!
@Mauro: Thank you so much for your efforts! I am very curious!
@Bill: We can implement SAM for voice synthesis:
Take a look at our forum here.
Frank
MauroXavier
Posted: 10:53am 10 Jul 2019
Very interesting! I caught myself now thinking of what it would be like a single gaming board made to connect behind the Color Maximite (or even Maximite), or in the Arduino connector on the CMM, with SAM, SN76489 and a double DB9 joystick port, and obviously, with a open source schematics, circuit board, source code and other related things on GitHub...
Hmm...
Turbo46
Posted: 12:33pm 10 Jul 2019
@ Frank, thank you for that I was not aware of that post. I will have to check it out further.
@ Mauro, Yes, I made a similar suggestion for the new Maximite here :
  Quote  6. I/O connections. As a follow up to the Maximite 3, an I/O interface module would make a useful addition. It could be housed in the same size case as the new Maximite (if possible) and sit underneath it. It would be connected to the Maximite via the rear ribbon cable connector. This could be handy for the existing Maximites too.
Connectors on the front would provide for joysticks, nunchucks and paddles (if the paddle is not part of the joystick). Perhaps a USB to USB connection interface to allow the Silicon Chip USB Mouse & Keyboard Adaptor (or similar) to be mounted inside.
Connectors or terminals for communications I/O could be included, the PCB could also include provision for an RS485 interface. Linking or Dupont leads on the PCB could provide for variations.
Perhaps a MicroBus Click board interface could be included with a means of connecting it to the outside world.
I was thinking of a follow up article to the new Maximite in Silicon Chip magazine but if a standard interface module could be somehow adopted I believe it could provide some consistency to game design. I guess it would need more than just the ribbon cable interface if it was to include the sound chip(s) and SAM but if they could remain on the arduino shield that would be easier.
Bill
PS. when I said USB to USB above I meant USB to serial.
Edit: I used to have a Votrax chip working on a Signetics 2650 microprocessor way back when dinosaurs roamed the earth. It was fun.Edited by Turbo46 2019-07-11
MauroXavier
Posted: 08:26pm 10 Jul 2019
I'm changing the PSGLIB to include a initial configuration to possibilite to the user choose in wich port the sound chip are connected, also including what sound can be used:
- SN76489 (one or dual)
- AY-3-8190/2/3
- PWM
I'm created a basic rotine to use PWM channels to play some SN76489 musics, using two channels, but the volume are very low. If I could use two channels of squared wave at same time would be fantastic, meanwhile the PSGLIB it's using fast changing of squared waves to simulate more than one channel, but this consumes a lot of CPU and it's good only to opennings and title screens (like a ZX Spectrum 48k).
With the MMBasic 5 release to CMM, I will gonna rebuild the PSGLIB using cFunctions, with this I believe that we will have a excellent game card using little resources.
SimpleSafeName
Posted: 03:54am 01 Aug 2019
  Cyber said  I think these at Retrosales are just regular quartz generators, it's just that they propose to use it to correct video colour issues.
It's an "active" oscillator (requiring 5 volts, hence the extra pins), you should be good.
For those stateside, this is where I found mine:
https://www.ebay.com/itm/Crystal-Oscillator-Frequency-Range-on-Offer-0-25MHz-to-200MHz/183882413008?ssPageName=STRK%3AMEBIDX%3AIT&var=691556708355&_trksid=p2060353.m2749.l2649
I probably could have got it cheaper, but I didn't want to wait.
     Page 2 of 6
