Local Time 22:17 20 Nov 2026 Privacy Policy
Forum Index : Solar : Build a 60 Amp PWM Boost Charger
Posted: 04:27am 13 Nov 2021
  Solar Mike said  Certainly the Alloy bars can carry huge amounts of current compared to the PCB tracks and are very cost effective and easier to purchase compared to copper bars; how does it go on using them over time, as the surface oxidation that forms is an insulator.
Guess if the bars are polished up and a thin film of jointing compound used prior to clamping up, then all air is excluded and oxidation under the joint doesn't occur.
I have seen alloy bars used in switchboards, but they were all nickel plated.
Mike
Aluminium is used a great deal these days for power distribution. You are quite right about the oxide layer, but there is a commercial grease called "Alminox" to be used when using aluminium crimp fittings and bolting to aluminium busbars.
Its the proper stuff, designed specifically for this application.
https://www.blackwoods.com.au/electrical/cable-accessories/jointing-resins-compounds/compound-joint-elec-alminox-grey-alm325g/p/00670412
