Local Time 03:45 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 graphics examples and explanation
GregZone
Posted: 05:54am 01 Jul 2020
  panky said  Sorry folks, flakey PDF creation with PDF Creator.
I tested this version,
Graphics Programming on the CMM2-v1.0b.pdf on Firefox and Acrobat 9.
Please let me know if there is still an issue. Also corrected a few of (my) typos.
Thanks for the quick fix Doug.
I've tested on my system and looks to be all good now.
One other thought occurred to me: It might be useful to add a "Revision History" page to the end of the document, where you can briefly note changes & additions made to later versions.
I suggest this, as this is a tuturial / reference that's likely to grow as more content is added.  For those who have already worked through an earlier version, it will be very useful to be able to easily identify what sections have been changed or added since the version they have previously read (instead of having to re-read the whole document, to try and figure out what's new).
Just me 2c
KeepIS
Posted: 09:41am 01 Jul 2020
s.
Very nice manual, thanks for putting it together.
Mike.
Posted: 10:57am 01 Jul 2020
When replacing the crystal oscillator with a canned one improves the performance, there is a possibility that the oscillator area on the board is noisy because digital traces run through the area (in different layers). If one of these digital traces is toggling (i.e. to create VGA video..??) this can phase modulate the crystal oscillator.
Phase modulation of the crystal oscillator may cause instability in the PLL's inside the H7.
This can only be solved by improving the board layout. If the Waveshare board is the culprit (we have no control over it's layout), there is no alternative then placing a canned oscillator.
Edited 2020-07-01 20:58 by Volhout
Shadamus
Posted: 08:44pm 05 Aug 2020
Panky / matherp, is this "Graphics Programming on the CMM2" document going to be part of the official documents hosted off of Geoff's site?
I saw the other documentation errata thread, but that one seemed to be focused on documents that Geoff maintains.
If this document is going to be maintained/released, I have one update to new syntax.
The POLYGON command, used in the example on page 19, now has a first parameter telling it how many points to use from the array.  Peter indicated this change was made prior to the 5.05.03 release, which is what Geoff's site has available for download (in addition to the newer beta builds).  https://www.thebackshed.com/forum/ViewTopic.php?TID=12423&P=2
That's the only one I've run into, but thought I'd mention, to the maintainers.
NEVERMIND -- I just saw Panky's post of the updated doc, and it's fixed there.
Edited 2020-08-06 07:03 by Shadamus
PhenixRising
Posted: 04:05pm 21 Feb 2026
Now that I'm working with the CMM2 that has sat around for years, I can hardly contain my excitement.
A couple of questions:
I'm using Mode 11,16 if that's even relevant.
Am I able to take a bitmap image (a button for example) and embed it (as text?) in the code? If so, is there a tool/utility for this?
There are links in all CMM2 documents to TassyJim's defunct site. Where can I find Font-tweak, etc.?
Posted: 07:51pm 21 Feb 2026
https://www.thebackshed.com/forum/ViewTopic.php?TID=18132&PID=242245#242245#242245
Also included in the latest picomite firmware bundle.
PhenixRising
Posted: 12:07am 22 Feb 2026
Thanks Jim....ttf fonts??? Awesome
I never expected this and so I had done a lot of research before asking here and I was convinced that I was going to have to go through a lot of struggling. But here we have it
Talk about the gift that keeps on giving.
