Forum Index : Microcontroller and PC projects : Sound on the Color Maximite 2
| MauroXavier Guru Joined: 06/03/2016 Location: BrazilPosts: 307 |
You can use any VGM file that is for the SN76489, but some machines use other clocks like the BBC Micro or some arcade machines, then it must adjust in the PSGLib what clock is used for play in the correct frequency. If you want good VGM files that are very compatible, get them from games for SEGA Master System: https://www.smspower.org/Music/VGMs Some games use this sound processor to complement sound, like the YM2612 from SEGA Mega Drive / Genesis. If you download VGM from this console you will listen to only to the PSG sounds but not the FM. In the case of NES 2A03, the compatibility is very low, about 20% of VGM files play correctly, this is because the simulation is focused only to play the basic implementation with some registers and wave types, like the triangle, pure square and squared with variable cycles using sawtooth waves to simulate them, and finally, white noise with sound approximation. The most noticeable absence is that doesn't have any DPCM sound implementation, unfortunately. For the future, I want to implement the sound chip AY-3-8192 too. A good approach to consuming less CPU could be to convert the VGM files to another file that is the frequencies already converted without any sound chip simulation. Maybe I develop a converter someday. You can create good SN76489 music using the DefleMask Tracker (which is very good!) or the SnevenTracker (which I not used yet). |
Typo in the above URL for VGMs, should be https://www.smspower.org/Music/VGMs John |
| capsikin Guru Joined: 30/06/2020 Location: AustraliaPosts: 342 |
Thanks for the VGM info. TassyJim has a converter from QBasic sound strings to DATA statements for arguments to PLAY TONE. That's a simpler system though. |
