Local Time 08:57 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Update to Graphics Programming manual
LeoNicolas
Posted: 06:10am 25 Nov 2020
Hey Doug
The following code is the updated version of the first quaternion example (cube rotation). I replaced the quaternion custom subs with the native math q_* commands. I'm thinking to move the cube initialization values to a data structure, what do you think?
Tomorrow I will update the second example.
quaternion1.bas.zip
option explicit
option default FLOAT
' 3D wire frame graphics demo using quaternions to rotate the coordinates
dim rotq(4),v(4),vout(4),i%,x1,y1,z1,x2,y2,z2,vertex
' define the coordinates of a cube with the z-axis towards the viewer
' coordinates of the cube
dim cube(3,7)=(-100,-100,100,0, -100,100,100,0, 100,-100,100,0, 100,100,100,0, -100,-100,-100,0, -100,100,-100,0, 100,-100,-100,0, 100,100,-100,0)
' define the coordinate pairs that make up the edges of the cube
dim cubelocation(2)=(mm.hres/2,MM.VRES/2,-500) 'actual location of the centre of the cube in space
dim cubelines%(1,11)=(0,1, 0,2, 1,3, 2,3, 4,5, 4,6, 5,7, 6,7, 0,4, 1,5, 2,6, 3,7)
'define the projection plane
dim viewplane = -200
dim lines%(3,11) 'storage for the coordinates for lines drawn
for i%=0 to 7 'convert coordinates to normalised form
 x1=cube(0,i%)
 y1=cube(1,i%)
 z1=cube(2,i%)
 math q_vector x1,y1,z1,v()
 cube(0,i%)=v(1)
 cube(1,i%)=v(2)
 cube(2,i%)=v(3)
 cube(3,i%)=v(4)
next i%
'create a quarternion to rotate 2 degrees about x axis
'play with the x,y,z vector which is the sxis of rotation
math q_create rad(2), 1,0,0, rotq()
'draw lines in memory (page 1)
page write 1
do
 cls
 for i%=0 to 11 'project the coordinates onto the viewplane
   vertex=cubelines%(0,i%)
   z1=cube(2,vertex)*cube(3,vertex)+cubelocation(2)
   x1=(cube(0,vertex)*cube(3,vertex)*viewplane/z1+cubelocation(0))
   y1=(cube(1,vertex)*cube(3,vertex)*viewplane/z1+cubelocation(1))
   vertex=cubelines%(1,i%)
   z2=cube(2,vertex)*cube(3,vertex)+cubelocation(2)
   x2=(cube(0,vertex)*cube(3,vertex)*viewplane/z2+cubelocation(0))
   y2=(cube(1,vertex)*cube(3,vertex)*viewplane/z2+cubelocation(1))
   lines%(0,i%)=x1 : lines%(1,i%)=y1
   lines%(2,i%)=x2 : lines%(3,i%)=y2
 next i%
 for i%=0 to 7 'rotate coordinates
   v(1)=cube(0,i%) 'X
   v(2)=cube(1,i%) 'Y
   v(3)=cube(2,i%) 'X
   v(0)=cube(3,i%) 'magnitude
   v(4)=0
   math q_rotate rotq(),v(),vout()
   cube(0,i%)=vout(1) 'X
   cube(1,i%)=vout(2) 'Y
   cube(2,i%)=vout(3) 'Z
   cube(3,i%)=vout(0) 'magnitude
 next i%
 for i%=0 to 11 'draw the new lines
   line lines%(0,i%),lines%(1,i%),lines%(2,i%),lines%(3,i%),1,rgb(white)
 next i%
 'copy page 1 to the screen (page 0)
 page copy 1 to 0
loop
end
panky
Posted: 11:04pm 25 Nov 2020
  matherp said  Doug
You should change the authorship to yourself!!!!
Trivial changes:
change 10 to 13 in first line
Mode 9 is not widescreen
Mode 10: 12-bit is allowed, monitor sees 848x480@60Hz
Paragraph starting VGA Monitors need correcting to match mode list
page 17 again mode 10 does allow 12-bit mode
Page 17 Comment at bottom on modes 10,11,12 should be that not everyone may have a widescreen monitor. They don't "permanently alter anything
Mode command chapter
Firmware now rounds up to 8Kbytes not 128Kbytes
Default modes can be 1,9, 10, 11, 12
page 31 memory is allocated in chunks of 8Kbyes
Thanks Peter, corrections are included for the next release - can you tell me what the pixel rate is for modes 8, 10, 11,12 and 13 are please.
I appreciate your comment about the authorship - the expression 'on the shoulders of giants' comes to mind!
Doug.
panky
Posted: 11:13pm 25 Nov 2020
For the 3 amigos from Canada (Pete, Pete and Leo)    or anyone else, is there anywhere I can get an intro to 3D graphics (particularly as it would apply to the CMM2) or perhaps one of you might throw together a few paragraphs for me?
Doug.
vegipete
Posted: 01:49am 26 Nov 2020
I am mulling over my treatise on octahedral optimization and while I wasn't planning on much depth to the math behind 3D graphics, maybe I'll expand on it a bit more.
Although I'd wait a bit until the firmware has settled down and the potential new commands become real.
LeoNicolas
Posted: 02:21am 26 Nov 2020
  panky said  For the 3 amigos from Canada (Pete, Pete and Leo)    or anyone else, is there anywhere I can get an intro to 3D graphics (particularly as it would apply to the CMM2) or perhaps one of you might throw together a few paragraphs for me?
Doug.
I can write some lines about generic 3D math and link some good videos about this subject. Peter Mather is implementing new commands specifically to 3D rendering and soon we will have this capability directly implemented in the firmware, but the basic 3D math doesn't depend on this implementation.
panky
Posted: 05:00am 26 Nov 2020
Thanks guys, as we all know, just keeping up with Peter is a mamoth task
LeoNicolas
Posted: 05:24am 26 Nov 2020
Hey Doug
I've updated both quaternion examples. I removed the custom quaternion functions and cleaned up the code. I decided to keep the Painter's Algorithm in the second example. It's being used to render the faces in the correct order. Normally I only use this algorithm to define the render order of different objects, not for faces.
This version has a better performance compared to the original source code. I included new code comments as well.
Leo
quaternion1.bas.zip
quaternion2.bas.zip
LeoNicolas
Posted: 05:39am 26 Nov 2020
This is another nice example. It is the same code I used for the Octahedron challenge with small modifications (I'm not printing the statistics) but instead of rendering the Octahedron, I'm rendering an Icosahedron. The Icosahedron data was created by VegiPete.
This code is not using quaternions. I'm rotating the vertices using a 3D rotation matrix (https://en.wikipedia.org/wiki/Rotation_matrix#In_three_dimensions) and I'm using the face normal to determine if the face will be rendered or not.
icosahedron.bas.zip
Edited 2020-11-26 15:43 by LeoNicolas
markboston36
Posted: 07:28pm 26 Nov 2020
  LeoNicolas said  This is another nice example. It is the same code I used for the Octahedron challenge with small modifications (I'm not printing the statistics) but instead of rendering the Octahedron, I'm rendering an Icosahedron. The Icosahedron data was created by VegiPete.
icosahedron.bas.zip
i read quaternions as quaterino :P is that a four part neutrino? :P
