Forum Index : Microcontroller and PC projects : Hexedit binary file editor
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11873 |
The framebuffer takes memory from the same area as arrays so using it has no advantage over accessing an integer array using peek and poke at the byte level |
"MATH SET nbr, array()" beats "PAGEWRITE FRAMEBUFFER : CLS" for more flexible filling of byte values. However, "FRAMEBUFFER BACKUP" and "FRAMEBUFFER RESTORE" need loops with arrays. Creative use of blit can quickly copy large (and small) chunks of data. There's no telling what creative and confusing actions could be accomplished with sprites. And I still think viewing the file on screen could on occasion be useful. ===== Aside: What is the difference between "FRAMEBUFFER WRITE" and "PAGEWRITE FRAMEBUFFER"? Visit Vegipete's *Mite Library for cool programs. |
| jirsoft Guru Joined: 18/09/2020 Location: Czech RepublicPosts: 533 |
It's also possible to use just small buffer in RAM (what you can see on screen) and the rest have in "secret" file on SD. So you are not limited by RAM.. 1. Undo stack on SD (limitless) or 2. Mirror file, where you can do all the changes and on end just rename original to .OLD and mirror to original JirSoft Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
| epsilon Senior Member Joined: 30/07/2020 Location: BelgiumPosts: 255 |
I think a useful feature would be to save parts of a file to repair corrupt files (CMM2 bug) without using a PC. The file size is not that important (<100KB usually). Regards Michael Only the modified parts of the file that's being edited are saved back. I don't understand the nature of that corrupt file bug well enough to see how hexedit can help. In my case I just lose the bottom 10 lines of the file. I assumed the file just got truncated, in which case hexedit won't be very helpful. However, if all/most of the contents of the file are still there and are just not being displayed properly because a 0 byte or something like that snuck in, then you can use hexedit to fix that. Next time I run into that corruption issue, I'll take a look with hexedit. Epsilon CMM2 projects |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1769 |
Hi Ruben, in my case the bug changes the file size eg from 25000 to 45000 bytes and fills it up with garbage (s. screenshot). The editor can no longer load the file because the line length is too long. I usually delete the garbage with Notepad ++ on Windows. However, some program lines at the end are lost. Having a Hexedit that can copy bytes 1 to &Hxxxxxxxxx to a new file could have helped. But this is no problem. I can just write a little CMM2 tool that will copy a file while the line length is less than 240 bytes. EDIT: I did it. I think something like this can do the job. '*************************************************** ' This tool may help for corrupted ".BAS"-files ' with a LINE IS TOO LONG issue (no warranty) '**************************************************** OPTION BASE 0 OPTION EXPLICIT MODE 1,8 do CLS input "Corrupted file:";FN$ if FN$="" then PRINT "Bye!" END endif FileExist=MM.INFO(FILESIZE FN$)<>-1 if Not FileExist then PRINT "Error: File '"+FN$+"' not found!" PAUSE 1000 endif loop until FileExist open FN$ for input as #1 open "repfile.bas" for output as #2 do a$=input$(1,#1) b$=b$+a$ i=i+1 if a$=chr$(13) then a$=input$(1,#1) b$=b$+a$ i=i+1 if a$=chr$(10) then PRINT b$; PRINT #2,b$; b$="" i=0 end if end if loop until EOF(#1) or i >= 240 close #1,#2 PRINT "done!" Thank you for your attention. Michael EDIT: Notepad++ screenshot corrupted file: Edited 2020-10-03 05:47 by twofingers ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Happy Sunday all, I uploaded hexedit v0.3 to GitHub: https://github.com/epsilon537/hexedit_cmm ChangeLog --------- 0.3: - Fixed cosmetic bug where first character sometimes remains inverted right after loading a file. - Fixed bug with goto when in ASCI column. - Fixed ctrlF fill bug. - New feature: Ctrl-T toggles between different word sizes: 8-bit, 16-bit, 32-bit and 64-bit. - New feature: Ctrl-E exports part of file as text or as binary. - Reduced redraw artifacts when editing. - Added file size to footer. 0.2: - Documentation updates. - Fixed error 'Function name + variable name must be less than 33 characters'. - Using "." instead of " " in ASCII block locations past file size. - Using "?" instead of non-printable characters in ASCII block. - Fixed program crash when insert is pressed. - Added Loading..., Inserting..., Deleting..., Filling... indications. - Fixed heap memory issues. - Increase File Size Limit to 1.6MB Michael, the export binary feature should do what you want. Cheers, Epsilon. Epsilon CMM2 projects |
Hi Ruben, the export function works for my corrupt file as expected. Thanks! One idea: I would suggest setting the default values for the export function: startaddr = 0, endaddr = current cursorpos. I changed the SUB printHeader in my copy of your Hexedit: SUB printHeader LOCAL header$ = "Hexedit V"+VERSION$+" by Epsilon."; LOCAL byteNr$ = " 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 0123456789ABCDEF" 'Print inverted PRINT @(0,0,2) header$ + SPACE$(MM.HRES/MM.INFO(FONTWIDTH) - LEN(header$)) 'Print CYAN) color rgb(CYAN) PRINT @(0,MM.INFO(FONTHEIGHT),0) byteNr$ color rgb(WHITE) END SUB Two observations: 1. The modified indicator works not correct if I delete/insert a Byte. 2. Using a basic function as a variable is not a good idea (loc% - loc()). Your code is just inspiring! Thanks! Kind regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
One idea: I would suggest setting the default values for the export function: startaddr = 0, endaddr = current cursorpos. I'll add that one to the feature request heap. At some point I'm going to have to write a smart INPUT function that supports default arguments, Esc key to abort etc. Right now I'm still just using MMBasic's INPUT. I changed the SUB printHeader in my copy of your Hexedit: SUB printHeader LOCAL header$ = "Hexedit V"+VERSION$+" by Epsilon."; LOCAL byteNr$ = " 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 0123456789ABCDEF" 'Print inverted PRINT @(0,0,2) header$ + SPACE$(MM.HRES/MM.INFO(FONTWIDTH) - LEN(header$)) 'Print CYAN) color rgb(CYAN) PRINT @(0,MM.INFO(FONTHEIGHT),0) byteNr$ color rgb(WHITE) END SUB Great idea! I plugged that right in. Thanks! Two observations: 1. The modified indicator works not correct if I delete/insert a Byte. In the sense that everything after the deleted/inserted byte shows up as modified? Maybe I broke the principle of least surprise there. When a byte is deleted, all bytes behind it move up one position, so are 'modified' compared to the original. It sounds reasonable to me, but I can imagine opinions on that may vary. One annoying consequence is that insert followed by delete, or vice versa, does not 'unmodify' the bytes after it again. Same things as overwriting a byte sequence, then going back and overwriting it again with the original byte values. Once a location is marked as modified it stays modified until the file is saved. 2. Using a basic function as a variable is not a good idea (loc% - loc()). Oops! I'll switch to pos then. In the meantime I uploaded v0.4. https://github.com/epsilon537/hexedit_cmm ChangeLog --------- 0.4: - New feature: Ctrl-S find byte sequence. - Added column header, contributed by Michael "twofingers". - Modified some key bindings (Sorry!). Load and Save moved to F3 and F2. Ctrl-S is now bound to the search function. - Increased file size limit to 3MB. Apologies for changing the keybindings. I figured out could still get away with it less than a week after the initial release. I just had to bind the search function to either Ctrl-S or Ctrl-F, so Load and Save moved to F3 and F2. Cheers, Ruben. Edited 2020-10-06 17:06 by epsilon Epsilon CMM2 projects |
Hi Ruben, At some point I'm going to have to write a smart INPUT function that supports default arguments, Esc key to abort etc. Right now I'm still just using MMBasic's INPUT. A smart INPUT function is a very good idea! I made one years ago for my "File Selector" for Maximite. A updated version is here (INPUT function). Two observations: 1. The modified indicator works not correct if I delete/insert a Byte. In the sense that everything after the deleted/inserted byte shows up as modified? No, just the indicator in the footer. Kind regards Michael Edited 2020-10-07 19:19 by twofingers ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Hi Michael, I'll take a look at that smart input function and file selector. Thank you! Got it (finally!). I uploaded a fix. https://github.com/epsilon537/hexedit_cmm Epsilon CMM2 projects |
Hi Ruben, Thanks for the updated Hexedit! Kind regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
