Local Time 03:48 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ThatDiceGame
mclout999
Posted: 12:11am 12 Jan 2021
  Quote   Mclout99, let me know if your Keytronics mouse works with this version!
Still an issue but slightly better.  One suggestion/request, if you could make the selections from one roll to the next stick it would be better for gameplay but worse for anyone having that issue I have with my Keytronics mouse. If you are rolling for a goal of say full house you tend to roll the same few dice to try to get it. Not a deal-breaker though. Thanks.  I wonder what it is with that damn Keytroinics mouse it is REALLY OLD but still works.
yock1960
Posted: 01:37am 12 Jan 2021
Dang! How about with a different mouse? Is yours a Waveshare board? I finally got around to hooking up and updating the Retromax, which is also a 480mhz CPU....no issues.
I will look into adding an on/off selector for sticky dice picks.
Steve
yock1960
Posted: 02:39am 12 Jan 2021
@mclout999
Are you only having issues with dice selecting now? If so, I might see how to fix that....apart from making them sticky.
Steve
mclout999
Posted: 04:35am 12 Jan 2021
  yock1960 said  @mclout999
Steve
With that mouse only (so not that important) any selection of any buttons or die can give two clicks. Like I said it is a little less likely to bounce but not by much. I do only mean for them to be sticky after the roll is hit so you don't have to reselect them over again. Thanks.
PilotPirx
Posted: 11:26am 12 Jan 2021
After winning, game asks for pressing right button. But i have no right button (nunchuk), "R"egame doesn't work. I can only quit the game.
The lower part of the side flickers sometimes.
yock1960
Posted: 01:54am 13 Jan 2021
  PilotPirx said  After winning, game asks for pressing right button. But i have no right button (nunchuk), "R"egame doesn't work. I can only quit the game.
Oops! Broke that trying to fix something else...fixed now. Use the 'C' button to select quit or rematch.
@mclout999 - try this and tell me if it's any better!
Steve
ThatDiceGame_8.zip
mclout999
Posted: 05:44am 13 Jan 2021
  Quote  @mclout999 - try this and tell me if it's any better!
Working quite well now.  Thanks!  (No sticky dice yet? )
yock1960
Posted: 11:37pm 13 Jan 2021
Great! No, not yet...eventually.
Steve
mclout999
Posted: 04:52pm 14 Jan 2021
  Quote  Great! No, not yet...eventually.
Some news that may infuriate you as it did me. I found another Keytronics mouse and tested it and initially it was having some of the same key bounce issues and I had a hunch seeing as they are ancient and unused for YEARS I disassembled it and cleaned the microswitches with some IPA and LOW AND BEHOLD it works just fine now,(my bad) It seems likely there was a bit of oxidation inside the microswitches. On the first mouse, It was misbehaving for a few moments on the last update, and then I kind of grided on the button for a while and it started working but I could not be sure.  When I got the second one out and it behaved the same way I was sure of it.  Sorry for misdirecting you down MY RABBIT HOLE.  Lesson learned, old as hell equipment = do some maintenance first or suspect the device before the software.
As always Thanks.
