Forum Index : Microcontroller and PC projects : BASIC10Liners - challenge for CMM2
I'm putting together something in 10 (or fewer) lines ... in Base 48. Why that size? The built-in CMM2 editor with all defaults is 48 lines of 100 characters. So the ENTIRE program is visible at once as a single page. No scrolling up/down/left/right. Visit Vegipete's *Mite Library for cool programs. |
| hitsware2 Guru Joined: 03/08/2019 Location: United StatesPosts: 738 |
> So the ENTIRE program is visible at once as a single page. I always try to attain that ... Count me in .... Preparing a work ( play ) space . ![]() my site |
Hi All, @Tom, I nominated you as you seemed to have a desire to "cross the t's and dot the i's" with your Welcome tape rules.. I figured you might enjoy creating the rules for a competition.. I don't think programs should be submitted BEFORE the rules are set in concrete.. I am amiable to any rule constraints proving the consensus agrees that they are FAIR and reasonable.. I would personally prefer to not see C-Subs etc as many cant speak in C (such as myself) and I would prefer as level a playing field as possible.. However it depends on the groups opinions... As to generous offer... I am flattered but it is not entirely so. I have heaps of PCBs that I have designed over the years for various flavours of mites and honestly, the market has dropped away dramatically in recent times. So they can sit here on my desk or be put to some use.. I prefer that someone can use them. On that subject I am always willing to offer freebies to those in need or students if they only ask (just pay postage) I am happy to even offer a 2nd and 3rd prize if we can attract enough entries.. or increase the value of the offering(s). Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| Rado Regular Member Joined: 27/11/2020 Location: CroatiaPosts: 59 |
48x100 would capture the spirit of such competitions. and I guess no CSUBs should be allowed because they provide unfair advantage to more advanced coders. |
Re rules: - I would say that no CSUBs should be a given. - 48x100 sounds like the maximum we should be considering, I'd be inclined smaller personally, but see next comment - We should probably consider not allowing any asset files (sorry @lizby) - it's presumably a programming competition not a graphics/sound competition - I'm pretty confident 4.8K is more than enough to write a simple runtime in, then you just load a practically unlimited size actual (non BASIC) program from an asset file. (You might use a simple "RISC" runtime to bootstrap a larger runtime to run the actual program, it would be slow, but you could bootstrap some impressive text games that way.) Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6112 |
When the dust settles on the rules, I think I will join the challenge. I will however use a CMM1 (don't have a CMM2 yet). By putting the rules to editor size (48x100 characters) the CMM1 can also compete (well 48 x 80 I guess..). There is one disadvantage using 48x100 max: this will lead to unreadable code. If you decide for 2k or 5k size on the STM32 people can still write readable code in the editor, since the code will be stripped of it when downloaded. And a "memory" will reveal the size in the STM. Volhout PicomiteVGA PETSCII ROBOTS |
I'm missing something What happened to 10 lines ? as : 10 statements 20 statements 30 statements 40 statements 50 statements 60 statements 70 statements 80 statements 90 statements 100 statements Plenty readable ..... Edited 2021-02-09 00:33 by hitsware2 my site |
@hitsware 10 lines in the editor means the whole program will be just the 10 lowest lines in this. No one will have a clue what is going on. Edited 2021-02-09 00:46 by Volhout PicomiteVGA PETSCII ROBOTS |
| MauroXavier Guru Joined: 06/03/2016 Location: BrazilPosts: 307 |
I suggest create two categories, both with no CSUB and no external assets: - 100 characters x 10 lines - 5K full size Sincerely, I prefer only a 10x100 contest. I love the idea of "make the most with the least". Edited 2021-02-09 03:13 by MauroXavier |
Fair enough. This 8 lines longer, but with no .bmp file. mode 7,8:w=rgb(white):bk=rgb(1,1,1):dim cr(5):cr(0)=rgb(green): cr(1)=rgb(red):cr(2)=rgb(cyan):cr(3)=rgb(yellow):cr(4)=rgb(blue) cls w:x=13:y=13:for i=0 to 4:circle x,y,12,,,cr(i),cr(i):y=y+26:next i line 13,134,13,154,2,bk:line 13,134,4,143,,bk:line 14,134,22,142,,bk line 13,160,13,180,2,bk:line 13,180,4,171,,bk:line 14,180,22,170,,bk line 30,2,72,2,2,bk:line 34,4,34,112,2,bk:line 67,4,67,112,2,bk: circle 51,112,17,,,bk:circle 51,112,16,,,bk:box 36,90,31,22,,w,w for i=1 to 9: on error skip: blit close i: next i r=w:x=0:y=0:w=26:For i=1 To 8:Blit read i,x,y,w,w:y=y+w:Next i Blit read 9,w,0,46,120: x=37:y=16:for i=1 to 4:blit write i,x,y,w,w:y=y+w:next i:v=5:b=4:CLS r: d$="ChemiChaos/5 Vials vegipete/lizby":text 160,0,d$,c,1,,rgb(red),r: d$="1=L,2=R;' '=pick/put,r=reload,x=next":text 160,10,d$,c,1,,rgb(red),r: For j=0 To 4:Blit write 9,j*50,100:next j:dim t(5,4):restore g: Do:d$="":For i=0 To 3:read l:h$=Str$(l):d$=d$+h$:if l=0 then:cls r:font 5: s$="S A F E !":text 60,100,s$,,,,rgb(green),r:do:loop:endif:next i: e: k=1:x=10:For i=0 To 3:h$=mid$(d$,i*4+1,4):for j=1 to b: c$=mid$(h$,j,1):l=val(c$):t(k,j)=l:t(5,j)=0:blit write l,i*50+10,82+j*w next j:k=k+1:Next i:blit write 6,9,70:p=1:u=0:do:do:c$=inkey$: loop until c$<>"":if c$="1" then:if x>50 then: blit x,44,x-50,44,26,52: box x,44,26,52,0,r,r:x=x-50:p=p-1:endif:elseif c$="2" then: if x<200 then: blit x,44,x+50,44,26,52:box x,44,26,52,0,r,r:x=x+50:p=p+1:endif elseif c$="r" then:box 0,44,320,52,,r,r:box 210,108,w,w*4,0,r,r:goto e: elseif c$="x" then:box 0,44,320,w*2,0,r,r:box 210,108,w,w*4,0,r,r: exit : elseif c$=" " then:if u then:for i=1 to b:n=t(p,i):if n>0 then:exit for:endif: next i:if n=z or i=5 then:i=i-1: if i>0 then:t(p,i)=z:blit write z,x,82+i*w blit write 8,x,44: blit write 6,x,70:u=0:endif:endif:else:for i=1 to b: z=t(p,i):if z<>0 then:t(p,i)=0:x=(p-1)*50+10:blit write z,x,44: blit write 7,x,70:blit write 8,x,82+i*w:u=1:exit for:endif:next i:endif: endif:loop:loop: g: Data 2321,1412,4412,4333,4232,5235,2443,3554,3124,2121,2444,3331,1224,4232 Data 4311,4133,2141,4333,3242,4121,1314,3424,3231,2142,3233,4141,1241,2243 Data 3324,4421,1123,2431,4552,2444,3255,3332,2422,1434,3313,1241,0 Unfortunately, I haven't been able to test it (new drawn sprites tested on F4)--my CMM2 is in the barn, and we had 10+ inches of snow last night--not navigable for me. (I'm ignoring what you said about "not a graphics/sound competition".) (And I hope I haven't stepped on vegipete's toes by bastardizing his fine game.) PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Are you kidding? I think it's awesome! Your latest version doesn't quite work: line 11: BLIT WRITE doesn't want width and height parameters (Actually, I'm not sure why line 11 is there at all, only last 2 statements seem to matter?) line 10: BLIT READ region is slightly off: "Blit read 9,w+3,0,45,130" Any reference to BLIT WRITE 6,7 and 9 needs an extra parameter ",0" I never get the "S A F E !" message. Is that expected? I suppose your version needs a name. "MiniChaos" seems inappropriate, as the program itself is complete chaos! Fixes: mode 7,8:w=rgb(white):bk=rgb(1,1,1):dim cr(5):cr(0)=rgb(green): cr(1)=rgb(red):cr(2)=rgb(cyan):cr(3)=rgb(yellow):cr(4)=rgb(blue) cls w:x=13:y=13:for i=0 to 4:circle x,y,12,,,cr(i),cr(i):y=y+26:next i line 13,134,13,154,2,bk:line 13,134,4,143,,bk:line 14,134,22,142,,bk line 13,160,13,180,2,bk:line 13,180,4,171,,bk:line 14,180,22,170,,bk line 30,2,72,2,2,bk:line 34,4,34,112,2,bk:line 67,4,67,112,2,bk: circle 51,112,17,,,bk:circle 51,112,16,,,bk:box 36,90,31,22,,w,w for i=1 to 9: on error skip: blit close i: next i r=w:x=0:y=0:w=26:For i=1 To 8:Blit read i,x,y,w,w:y=y+w:Next i Blit read 9,w+3,0,45,130: x=37:y=16:for i=1 to 4:blit write i,x,y:y=y+w:next i:v=5:b=4:CLS r: d$="ChemiChaos/5 Vials vegipete/lizby":text 160,0,d$,c,1,,rgb(red),r: d$="1=L,2=R;' '=pick/put,r=reload,x=next":text 160,10,d$,c,1,,rgb(red),r: For j=0 To 4:Blit write 9,j*50,100,0:next j:dim t(5,4):restore g: Do:d$="":For i=0 To 3:read l:h$=Str$(l):d$=d$+h$:if l=0 then:cls r:font 5: s$="S A F E !":text 60,100,s$,,,,rgb(green),r:do:loop:endif:next i: e: k=1:x=10:For i=0 To 3:h$=mid$(d$,i*4+1,4):for j=1 to b: c$=mid$(h$,j,1):l=val(c$):t(k,j)=l:t(5,j)=0:blit write l,i*50+10,82+j*w next j:k=k+1:Next i:blit write 6,9,70:p=1:u=0:do:do:c$=inkey$: loop until c$<>"":if c$="1" then:if x>50 then: blit x,44,x-50,44,26,52: box x,44,26,52,0,r,r:x=x-50:p=p-1:endif:elseif c$="2" then: if x<200 then: blit x,44,x+50,44,26,52:box x,44,26,52,0,r,r:x=x+50:p=p+1:endif elseif c$="r" then:box 0,44,320,52,,r,r:box 210,108,w,w*4,0,r,r:goto e: elseif c$="x" then:box 0,44,320,w*2,0,r,r:box 210,108,w,w*4,0,r,r: exit : elseif c$=" " then:if u then:for i=1 to b:n=t(p,i):if n>0 then:exit for:endif: next i:if n=z or i=5 then:i=i-1: if i>0 then:t(p,i)=z:blit write z,x,82+i*w blit write 8,x,44: blit write 6,x,70:u=0:endif:endif:else:for i=1 to b: z=t(p,i):if z<>0 then:t(p,i)=0:x=(p-1)*50+10:blit write z,x,44: blit write 7,x,70:blit write 8,x,82+i*w:u=1:exit for:endif:next i:endif: endif:loop:loop: g: Data 2321,1412,4412,4333,4232,5235,2443,3554,3124,2121,2444,3331,1224,4232 Data 4311,4133,2141,4333,3242,4121,1314,3424,3231,2142,3233,4141,1241,2243 Data 3324,4421,1123,2431,4552,2444,3255,3332,2422,1434,3313,1241,0 Visit Vegipete's *Mite Library for cool programs. |
Thank you, vegipete. I forgot that while BLIT WRITE on the F4 (and Plus and eXtreme and H7) requires the width and height, on the CMM2 it has remembered how they were READ, and so doesn't require those. I would expect the "S A F E !" message to appear (e.g., if you keep pressing "x"), but maybe I missed something, working blind without my CMM2. You're right about line 11--that was left over from my testing on the F4. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
If comments are not to be counted against any limits then extracting and executing code written inside comments ist verboten .Tom Edited 2021-02-09 05:29 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| elk1984 Senior Member Joined: 11/07/2020 Location: United KingdomPosts: 232 |
Reminds me of this |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6604 |
@lizby In "next i" the "i" is usually not required. That's 2 bytes per loop saved. It's also something I would normally never suggest doing. Jim VK7JH MMedit |
| Paul_L Guru Joined: 03/03/2016 Location: United StatesPosts: 769 |
Next WHAT! for i-1 to 10:for j=1 to 100:'do something:next j:next i 'controls step variable for i-1 to 10:for j=1 to 100:'do something:next j, i 'also controls step variable for i-1 to 10:for j=1 to 100:'do something:next:next 'doesn't controls step variable for i-1 to 10:for j=1 to 100:'do something:next 'j:next 'i 'what the heck is that! A limitation of the basic REM or "'" is that it causes the interpreter to stop reading the line and ignore everything after. But when the line concatenation character ":" is inserted the "'" doesn't respect it. If the inline "'" caused later characters to be ignored until the [(end of line) OR (a line concatenation character ":")] it would be more flexible. You could save the extra bytes in code and speed it up at the same time. It's sort of like Wayne Ratliff's idea to allow delimiting pairs to be (), {}, [], or even <> interchangeably. You can visually identify the pairs more reliably, and an interpreter, pre-processor or full compiler can identify the pairs more reliably, but it would not necessarily add to the size of any compiled or assembled code. Paul in NY |
@Nimue, in an effort to move things forward and actually move this competition forward I've sent you a PM, you may not have noticed that TBS has that facility ;-) Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Nimue Guru Joined: 06/08/2020 Location: United KingdomPosts: 449 |
Missed that -- got it now. You have a DM!! N Entropy is not what it used to be |
@thwill >> sent link to GoogleDoc with starter rules for 10.... N Entropy is not what it used to be |
Or the bracketed pairs in Algol68 LOL John |
