Local Time 16:03 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : tft screen for micromite
Dudulle
Posted: 10:51pm 09 Apr 2021
thanks Turbo46, this time everything is working :)
Dudulle
Posted: 08:09pm 20 Apr 2021
Hello everyone
I have a new probleme ; I can't save any program on SD card with save command (save "test.bas" ). The micromite just respond "error"
But I can make a directory, or delete a file (with kill command).
Drive command is not working on micromite, like on duinomite ?
Edited 2021-04-21 06:13 by Dudulle
Geoffg
Posted: 10:49pm 20 Apr 2021
That is strange.  If you can create a directory you should be able to create a file.  What is the exact and full error message?
The Micromite does not have the Drive command as it only supports one SD Card.
Geoff
Dudulle
Posted: 05:12pm 21 Apr 2021
Hi Geoff
First I would like to thank you for the great job you did, I am a huge fan of MMBASIC.
I made a picture of the screen (screenshot not working) to show the error message.
Posted: 05:24pm 21 Apr 2021
Looks like there is no space before the first "
Also do you have a program loaded? I don't know if MMBasic will save nothing
Dudulle
Posted: 05:44pm 21 Apr 2021
I made a little program for the test, and I have the same error message with or without space.
Geoffg
Posted: 01:01am 22 Apr 2021
This is getting stranger and stranger.  The way the error message function works there should always be a colon after the word Error followed by a message.  It looks as if the CPU is tripping up (that is a technical term!) while displaying the message.
It could be the SD card that is the problem.  A corrupted file allocation table can cause strange errors.  Could you please reformat the SD card on a PC and try again.  Also, trying a different SD card might provide a clue.
Geoff
Dudulle
Posted: 07:16pm 23 Apr 2021
Hello
I tried others cards, with full reformat, but the problem still the same...
Dudulle
Posted: 05:01pm 27 Apr 2021
Can I solve the problem by flashing the card?
If I can't use the built-in reader is it possible to add another on ?
Posted: 09:24pm 27 Apr 2021
You can create and delete directories so the SDcard 'write' seems to be working.
You would get a full error message if there was trouble writing to the card.
Try
SAVE IMAGE "test.bmp"
to see if you can save a screen image to the SD card.
Also please LIST the file you are trying to save.
If you have any non-ascii characters in it, that might be causing problems.
Dudulle
Posted: 09:41pm 27 Apr 2021
Hi TassyJim
I made a very simple test :
sub heure()
 do
 print time$
 pause (1000)
 cls
 loop
end sub ()
When I try to save it with SAVE "test.bas" I have the same message : error
Saving image is not working too.
Dudulle
Posted: 04:32pm 30 Apr 2021
Can I use the card reader who is on the tft screen ?
Dudulle
Posted: 06:03pm 02 May 2021
sorry for my messages, I found the solution by myself. I just had to type OPTION SDCARD 52,53 without 17
It was well explained but I had misunderstood...
Edited 2021-05-03 08:19 by Dudulle
