Local Time 11:03 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.07.00RC1 - Getting closer :-)
     Page 2 of 4
vegipete
Posted: 05:46am 10 Jun 2021
I'm not sure where to put this, since I'm still running an older beta.
Also not sure that it's even a bug, but the output of the following is less than ideal over the console and Tera Term:
> cls : for i = 1 to 100 : ? @(i) i : next
Try the above from the prompt. On the VGA screen, the output is as expected.
With Tera Term, the output doesn't scroll as I would expect, and the first number doesn't even appear. The horizontal positioning in Tera Term is what I would expect - character based.
Change the loop to, say, 10, to see the missing first number - no "1" appears in Tera Term.
This might just be a problem with Tera Term, in which case ignore the above.
edit: Weird, I just quit and re-ran Tera Term and now the numbers scroll as expected, although "1" is still missing.
_
Edited 2021-06-10 15:52 by vegipete
Posted: 07:41am 10 Jun 2021
  Quote  I'm not sure where to put this, since I'm still running an older beta.
If you put a pause after the print you will see the 1 does appear but then gets overwritten. It appears teraterm doesn't like a cursor command where the y coordinate is 0. I'll add 1 and put the change into the final release
Posted: 08:15am 10 Jun 2021
*deleted*
Edited 2021-06-10 18:18 by Volhout
KeepIS
Posted: 01:49am 14 Jun 2021
I've just loaded CMM2V5.07.00RC2 14-06-2021. I have a weird problem:
If I type files, I get the file manager, but "Syntax" appears at the top of the screen followed by CMD prompt.
If I send a file to the CMM2, it runs correctly, if I type EDIT, the editor opens, shows the file in edit mode, and then has the same message as the File command.
So can't edit or select anything from file manager.
Anyone running the latest test release notice anything like this?
BTW re-programmed and verified correctly, same error?
Mike
Posted: 07:19am 14 Jun 2021
Try erase all before programming. Remove battery. Reflash, then after entering start-up params see if fixed
KeepIS
Posted: 08:03am 14 Jun 2021
Thanks, I had already erased everything prior to programming, however I had not removed the backup battery, so all I did was remove all power, remove backup and shorted out battery socket and 5v line just for good measure (caps holding a charge),  reinstalled battery and powered up, greeted with initialisation prompts, all good now Editor and Files work.
Posted: 08:24am 14 Jun 2021
Great, now the interesting question is why pause is working on the CMM2 but not the H7 since I copied the fix from the CMM2
KeepIS
Posted: 08:59am 14 Jun 2021
I have a H7V1 and two H7V2 all give the same results with Pause, IE lockup if called too many times in succession with delays above 1.5ms
Out of interest I just now tried using Bitbash on the CMM2 as a delay command, dam that's sweet, perfect pulse timing on the DSO and so simple to implement.
Posted: 09:02am 14 Jun 2021
I'll put bitbang on the H7 later this week
KeepIS
Posted: 09:06am 14 Jun 2021
  Quote  I'll put bitbang on the H7 later this week
       Thank you, so many uses with the nature of the H7.
Posted: 12:06pm 14 Jun 2021
  KeepIS said  Out of interest I just now tried using Bitbash on the CMM2 as a delay command, dam that's sweet, perfect pulse timing on the DSO and so simple to implement.
Can you post your code? I'm afraid I have no idea what you're doing or how you're doing it.
vegipete
Posted: 07:35pm 14 Jun 2021
Is this an MMBasic bug?
e = 10
k = 1
do while e
  print e
  if k then do : loop until inkey$ <> ""
  e = e - 1
loop
end
> run
Error in line 3: LOOP has an UNTIL test
According to the manual, this should work.
  Quote  If there are more statements on the line (separated by colons (:) they will also be executed if true or skipped if false.
Change line 5 to
  if k then : do : loop until inkey$ <> "" : endif
and it does work.
Posted: 08:06pm 14 Jun 2021
It also works (on the PicoMite) if changed thus:
 if k then
 endif
So basically it seems to be looking for an Endif so that the bounds of the Do-Loop can be found.
If you see what I mean....  :)
Edited 2021-06-15 06:10 by Mixtel90
KeepIS
Posted: 09:58pm 14 Jun 2021
The thread below explains why I tried different ways to substitute the Pause command in the CMM2 and ARMH7, the CMM2 is now fixed and hopefully the ARMH7 will follow.
Pause cmd problem
When I get back home I'll post the results using the Bitbang command as an accurate delay command.
Some may be wondering why I don't use a Timer interrupt or other Timer variation, apart from the fact that I have no vacant timer slots left, these introduce other clash issues within the critical multiple pin clock and decode procedures in a big automation project that I'm running on the ARMH7.
Edited 2021-06-15 07:59 by KeepIS
KeepIS
Posted: 12:32am 15 Jun 2021
I've been away from the CMM2 for a few months, so something may have changed in the current firmware? IE. I'm missing something bleeding obvious!, however after updating to the last test Beta release, I'm loosing options with a power cycle, hopefully not another seniors moment.
Vbat pin is 2.92v which should be fine.
DSO on the vbat pin, no glitch, perfect DC line.
Time and Date are NOT lost.
Nothing connected to the IO port.
Pin 40 is not at ground potential.
After power cycle:
>  Option List
CURRENT VGA mode 800x600 RGB332
OPTION USBKEYBOARD UK
Before power cycle:
> Option List
CURRENT Default mode 12 960x540
CURRENT VGA mode 960x540 RGB332
CURRENT DISPLAY 45,120
OPTION USBKEYBOARD US
OPTION SD TIMING FAST
OPTION RTC CALIBRATE 55
OPTION KEYBOARD REPEAT 600,40
OPTION SEARCH PATH /Test Programs/
Mike
Edited 2021-06-15 14:02 by KeepIS
Posted: 06:59am 15 Jun 2021
@KeppIs:
Are the options lost on every power cycle, or just during firmware update.?
I am running RC1, I can try tonight with exactly your options set (I'll change the path...).
Posted: 07:03am 15 Jun 2021
Try a new battery. Clock will work at a level where memory is lost. If you look at the voltage characteristics of lithium cells 2.92v is basically flat
Edited 2021-06-15 17:09 by matherp
KeepIS
Posted: 07:56am 15 Jun 2021
Now 3.3 volts, and exactly the same result?
KeepIS
Posted: 12:52am 16 Jun 2021
Reprogrammed with an earlier version of FW V5.07.00b24, options are now correctly maintained across any number of power cycles.
Edited 2021-06-16 10:52 by KeepIS
     Page 2 of 4
