Local Time 08:01 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : UART problems - porting from PICAXE to MM2...
Posted: 04:19am 27 Jul 2021
something like this should do the trick:
SetTick 100, isr
  Do While message$<>"": Loop
  Print
  Input message$
End
isr:
  If message$<>"" Then
    Print Left$(message$,1);
    message$=Mid$(message$,2)
  EndIf
IReturn
just replace the Print Left$(message$,1); with Print #n....
rob   :-)
addendum: geoff - just noticed a small error in the index of the 5.05.04 MX170 PDF manual, the item "MID$" appears twice.
Edited 2021-07-27 14:24 by robert.rozee
Geoffg
Posted: 06:06am 27 Jul 2021
  robert.rozee said  just noticed a small error in the index of the 5.05.04 MX170 PDF manual, the item "MID$" appears twice.
Thanks, I will fix.
Geoff
Posted: 06:32am 27 Jul 2021
I can now report that the test unit I took to the site today, worked perfectly in about 8-10 different physical locations at the extreme edge of the expected range.
Lovely.
Now I can order more boards and begin assembly.
Thank you to all who added to this thread - your help saved my sanity.
