Local Time 18:09 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SPI help needed
lew247
Posted: 09:17am 25 Jan 2022
  robert.rozee said
  Mixtel90 said
(1) is this the board/module Lewis is dealing with:
https://wiki.seeedstudio.com/Wio_RP2040_mini_Dev_Board-Onboard_Wifi/
YES
if so,
(2) we need the schematic for the module - this will document the connections between the RP2040 and ESP8285. this in itself is sufficient information to access and use the module. without knowing how the two chips are connected together, we can do nothing.
Not available anywhere
my GUESS is that an SPI connection is used to allow the RP2040 to load firmware into the ESP8285's flash. thereafter, the same pins are reconfigured as TTL serial (RxD, TxD), allowing normal communications of AT commands and any data to send/receive.
No
It seems the esp8285 is preprogrammed before insertion with the AT command set from the factory
It is only connected to the RP2040 via SPI the uart pins do not seem to be connected at all
Posted on the Seeedstudio forum is source code for the MicroPython firmaware for Wio RP2040 mini available?
It's not however the people on the forum say it seems to be this https://github.com/IsQianGe/rp2040-spi
Edited 2022-01-25 19:18 by lew247
Posted: 04:29am 26 Jan 2022
  Mixtel90 said  It really is a hell of a lot easier to use COM ports and AT commands. You can just have a big RX buffer and hope. :)  Yes, I know parsing is a pain, but compared to SPI without documentation that's easy.
I hear that!
I absolutely LOVE the serial port buffers, cos they can catch ANYTHING that arrives from the likes of an RF module, even if the main loop is busy, then as you go through the main loop, you look and see if anything is waiting in the buffer, and if there is, go and process it.
The buffers constitute a very effective serial message queue system that basically takes care of itself in the background.
