Local Time 17:04 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help please - Picomite with SPI LCD
Posted: 07:57am 02 Feb 2022
AFAIK there are no 3.2" ili9341 - try ILI9488.
cosmic frog
Posted: 08:52am 02 Feb 2022
Could this just be a case of a weak power supply/USB cable?
Dave.
Posted: 11:38am 02 Feb 2022
I've seen the 3.2" ILI9341 advertised for a long time. It's still 320x240 though, you don't get any extra pixels. I must admit that I've never actually seen one in real life though - it may be just markings and measurements!
If the display is fed from the 5V line it should be ok. I've often run PicoMite / LCD combinations from all sorts of USB ports & cables. They are pretty forgiving.
Posted: 11:52am 02 Feb 2022
3.2" ILI9341 320x240 do exist, there is one in front of me now. I have a 33 ohm resistor to +5V for the backlight LED, haven't tried PWM on it yet. If using PWM start with 50% and something should be visible.
In the photo the LED is a grey wire but does not go to the breadboard. What is it connected to?
Edited 2022-02-02 22:00 by phil99
Glen0
Posted: 08:28pm 02 Feb 2022
WORKING AT LAST
Big thanks for all your contributions.
In the end it was as Peter said, ILI9488
I will be writing this in bold permanent ink on the back of each display. I suppose it's easy for the seller to make the mistake of typing the wrong controller number in the description. I am once again reminded to keep an open mind when faced with such issues.
Luckily the display and Pico can tolerate/survive having 5V shoved down their throats.
It appears to work with or without the MISO pin connected. (Grey wire in the photo)
I have the LED pin connected directly to "VSYS". (3.3V or 100% duty cycle)
Now to get Touch and SD working..
Edited 2022-02-03 06:30 by Glen0
Posted: 08:35pm 02 Feb 2022
Excellent news! :)
Posted: 08:40pm 02 Feb 2022
To get touch and SD working you must disconnect MISO or connect it via a 680 ohm resistor
Glen0
Posted: 08:53pm 02 Feb 2022
Will do thanks
