Local Time 07:35 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION settings for Waveshare Pico displays sans MISO pins ?
Posted: 06:37am 01 Jun 2022
Beep raises the GPpin for a set time then lowers it again, that's all. It doesn't produce a tone. It's relying on you using an active piezo buzzer, not the passive magnetic one that's on the board. It will never work.
2.
GP14 is allocated to Touch beep in the above listing. You can't allocate it to PWM if you do that.
I think Peter is currently sorting out a bug that prevents you allocating a single pin to PWM. Up until now you had to allocate both pins, even if you only needed one, so you couldn't use GP14 if GP15 was already in use. Check the latest release.
You can operate the buzzer without using any sort of Beep or Play command. One way is to use the PULSE command in a loop. That outputs a single pulse on the pin. If you then use PAUSE and loop back to the PULSE command you'll get a tone whose frequency depends on the PAUSE value. PULSE toggles the pin on each use so you get a square wave. If you run the loop for a set number of times in a FOR-NEXT then you can set the length of the pulse. You can then have something like:
'produces 0.5ms pulses on GP14
'freq falls with higher numbers. freq = 0.5 is 1kHz
SUB BUZZ(freq,length)
local i
for i = 1 to length
 pulse GP14, 0.5
 pause freq
next
End sub
(I've not actually tested this)
Posted: 06:56am 01 Jun 2022
  Quote  I think Peter is currently sorting out a bug that prevents you allocating a single pin to PWM. Up until now you had to allocate both pins, even if you only needed one, so you couldn't use GP14 if GP15 was already in use. Check the latest release.
Not true - there is no bug just one user who misunderstood the documentation
Posted: 09:37am 01 Jun 2022
Ah, right - sorry if I also misunderstood.  :)
goc30
Posted: 02:02pm 01 Jun 2022
option list
OPTION SYSTEM I2C GP6,GP7
OPTION LCDPANEL ILI9488W, LANDSCAPE,GP8,GP15,GP9,GP13
OPTION TOUCH GP16,GP17,GP14
GUI CALIBRATE 0, 3975, 109, -1291, 843
OPTION SDCARD GP22, GP5, GP18, GP19
> option touch disable
> option touch gp16,gp17
> gui calibrate
Done. No errors
Deviation X = 10, Y = -4 (pixels)
> pwm gp14,1000,50
Error : Pin not set for PWM
> setpin gp14, PWM7A
> pwm gp14,1000,50
goc30
Posted: 02:09pm 01 Jun 2022
local i
for i = 1 to length
 pulse GP14, 0.5
 pause freq
next
End sub
it work correctly
don't forget declare gp14 as dout
Posted: 02:24pm 01 Jun 2022
  Quote   pwm gp14,1000,50
RTFM
PWM 7,1000,50
goc30
Posted: 03:00pm 01 Jun 2022
  matherp said
RTFM
PWM 7,1000,50
pwm 7A or pwm 7B ?????
setpin gp14, PWM7A  ????
pulse gp14
Why make it simple when you can make it complicated
Edited 2022-06-02 01:07 by goc30
Posted: 03:31pm 01 Jun 2022
I think I've got this now...
You have to specify both the PWM channel and the pin number a some PWM channels can appear on alternative pins.
SETPIN GP14, PWM7A '7A because that's what GP14 can handle
'as PWM7B isn't set up with a SETPIN nothing will happen on it
PWM 7, 1000, 50  'output, on PWM7, 1000Hz at 50% duty cycle on channel A
I assume tha this would be valid (hardware allowing) and PWM7A not configured:
SETPIN GP15, PWM7B
PWM 7, 1000, , 50  'output 50% duty cycle on channel B only
It's an assumption as I've never driven a B channel alone.
Posted: 04:19pm 01 Jun 2022
Don't know how the manual could be much clearer
  Quote  SETPIN pin, PWMnx Allocate pin to PWMnx
'n' is the PWM number (0 to 7) and 'x' and is the channel (A or B)
The setpin can be changed until the PWM command is issued. At that point
the pin becomes locked to PWM until PWMn,OFF is issued.
  Quote  PWM channel, frequency,
[dutyA] [,dutyB]
PWM channel, OFF
  Quote  There are 8 separate PWM frequencies available (channels 0 to 7) and up to
16 outputs with individually controlled duty cycle. You can output on either
PWMnA or PWMnB or both for each channel - no restriction.
Minimum frequency is 15Hz. Maximum speed is OPTION CPUSPEED/4
At very fast speeds the duty cycles will be increasingly limited
Edited 2022-06-02 02:21 by matherp
goc30
Posted: 04:57pm 01 Jun 2022
  matherp said  Don't know how the manual could be much clearer
this is only clear to those who wrote the program, but not to those trying to understand this "logic". But hey, you can't be good everywhere.
What is unfortunate is for users who have to waste time trying to understand what the programmer meant
And above all, let's not forget that this project (MicroMite) is the fruit of passionate amateurs, and not industrialists accustomed to the rigor and seriousness of the profession. So we have to forgive the weaknesses and shortcomings and deal with it.
Edited 2022-06-02 03:02 by goc30
Posted: 05:05pm 01 Jun 2022
The code follows the H/W. Perhaps a little bit of understanding about how the H/W works may help you. The RP2040/Pico manuals are excellent
goc30
Posted: 05:11pm 01 Jun 2022
  matherp said  The code follows the H/W. Perhaps a little bit of understanding about how the H/W works may help you. The RP2040/Pico manuals are excellent
I'm not sure arrogance is the smartest answer. After 45 years of career in industrial computing and robotics, I think I can teach you much more about the management of PWMs (which I used from 1982 with Intel 8748s and Mosfets) than you would be able to understand. .
so come back to more humility. You'll see.. it doesn't hurt!!
Posted: 05:46pm 01 Jun 2022
Ah - answered on the other thread. I hadn't spotted the double comma. Should have gone to ****Savers. :)
Peter's right on this - it's the way the hardware works on the Pico. I know the RP2040 Datasheet is huge, but there's an immense amount of information in it and it's not as difficult to follow as you may think (most of the time!). Just avoid anything that says CPU or PIO on it. ;)
I think the main confusion comes in that there are A and B channels on each PWM device. On each device the channels always have the same frequency but the duties are independent. SETPIN relates to a single channel A or B. PWM relates to the PWM device, both channels of it. Consequently, if you want to use A and B channels you need two SETPIN statements.
Something that confused me at first. There are actually 8 PWM *devices* available - the frequencies are simply set for each device. It's not a choice of 8 frequencies - which was what I was expecting, coming from a background where the PWM frequencies were derived from a set of dividers.
