Forum Index : Microcontroller and PC projects : PicoVaders
I can confirm that the standard Atari joysticks work fine at 3V3 on the PicoGAME. This I know 'cos I have one. :) Not all D9F joysticks will work though as some use non-Atari wiring. Typically, anything intended for the Spectrum+ or Spectrum 128 built-in jowstick ports will definitely not work unless you either make an adapter or rewire them. The connections are completely different. Of course, if I was modifying this for the PicoGAME I'd probably make it recognise the controllers rather than the joysticks. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| cosmic frog Guru Joined: 09/02/2012 Location: United KingdomPosts: 310 |
There was a similar discusion about standardizing joysticks for the original Colour MaxiMite way back in 2013. Link Dave. |
As far as PicoGAME is concerned I simply used pins that would reach on the PCB. :) As usual it was designed for my own fun so I'd no standards to follow. lol (Doing final hardware tweaks today, I think. Then I need to have a serious look at the documentation as quite a bit has changed since V1.4. It's now, officially, going to be V2.0. I made my mind up this morning. The ports are identical to V1.4.) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hence Personally whenever this is brought up I'm going to push what Mick has already comitted to fibreglass, and provided @matherp doesn't decide on something different that will then give us a defacto standard for the PicoMite VGA ... until someone decides what they really want is Nunchucks https://www.youtube.com/watch?v=-ctFBlSStFI I believe the OP is just wiring up 3 buttons and wanted some sort of compatibility, and it's easier to be compatible with the PicoGAME joystick interface than the PicoGAME gamepad interface. Best wishes, Tom Edited 2022-07-05 21:17 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Incidentally, the PicoGAME Mini uses the same GP connections on its controller port, so that's another layer of compatibility. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
![]() MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1548 |
Because I followed the manual, I already use GP0 and GP1 for audio. so I use GP2 for Fire, GP3 for Left and GP4 for Right all 3 Switches are connected to 3.3V and the GPIO Pins the Start of the Program looks like this: 'GPIO USED: GP2 Fire, GP3 Left,GP4 Right Const JF=4 'GP2 Const JL=5 'GP3 Const JR=6 'GP4 SetPin JF, DIN, pulldown:'fire SetPin JL, DIN, pulldown:'left SetPin JR, DIN, pulldown:'right so that everyone can use the Pins of his choise by changing the Const Values Here the Version with (additional) Joystick or Button support PicoVadersGPIO.zip Edited 2022-07-06 02:25 by Martin H. 'no comment |
Hi Martin, Mick, Tom, This is a patch for the GAME pico VGA board revision 1.4. It uses the "PIONES" statemachine handling a single NES controller at port A (K8). It is very playable !!! Use < and > and B key to fire. picovaders_NES.zip Enjoy... Edited 2022-07-06 06:06 by Volhout PicomiteVGA PETSCII ROBOTS |
Neat, I've just given it a go on my PicoGAME VGA with the clone NES controller and it works quite nicely. Only two significant issues, the title-screen is very unresponsive to the fire-button being pressed and occasionally movement of the gun halts and I have to release and repress the direction button. Not sure if this is a problem with the cheapo controller, with @Volhout's PIO code, or with the game logic itself. Despite this I think the PicoGAME VGA really does meet its design goals and PicoVaders shows it off very nicely. Even if it is a little self-serving I think congratulations are due to all involved .EDIT: Actually it appears (correctly) to be the A key to fire, so is that a typo or is one of our controllers labeled wrong ? Best wishes, Tom Edited 2022-07-06 06:33 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Sorry, yes it is the A key. I noticed the reluctance to start from startup screen. Will look into that tomorrow. Volhout PicomiteVGA PETSCII ROBOTS |
to get the start screen more responsive, change the end of the Into Sub to Do While Inkey$<>" " Print @(74,210) " PRESS FIRE TO START " for btn=1 to 60 If Pin(jf) Then Exit sub Pause 10 next btn Print @(82,210) " " for btn=1 to 60 If Pin(jf) Then Exit sub Pause 10 next btn Loop this should make things better. The difference between The Button and a Keypress is. The Pin request gives the current state of the fire button while the last Keypress is buffered. If you press space at any stage in the loop it is noticed and the Loop end. The State of the fire Button is requestet "just in Time" --- AT the Next Game I will ask you first the do the routines for the NES Controller How about a little Library which can be merged to the own source code to make things easier Have Fun, Chears Martin Edited 2022-07-06 13:45 by Martin H. 'no comment |
PicoVaders1.0.zip so here is the fixed Version with a more responsive Intro Screen :-) If you might change the GPIO Ports, it is done by the "Const" Settings at the Start of the Program. '-----------------Init---------------- ' 'GPIO USED: GP2 Fire, GP3 Left,GP4 Right 'Change this for your Input Ports ' Const JF=4 'GP2 Const JL=5 'GP3 Const JR=6 'GP4 ' '------------------------------------- have Fun .. chars, Martin ![]() 'no comment |
Hi Martin, Tom, I have changed the PIONES program by adding some more comments. How this would translate into a library, I am not sure. But this should allow you to adapt the PIONES to other IO pins, and (not tested) would also allow for support of up to 4 NES controllers as PIO1 has 4 state machines. Just add PIO INIT's and PIO start's Regards, Volhout 'PIONES - PIO SPI for NES controller 'PIONES is software that runs on the RP2040 PIO state machines to read from 'NES controllers (SPI). This is indenpendent of the 2 ARM cores. 'For VGA picomite PIO 0 is used to generate VGA. PIO 1 is used for PIONES '-------------------------------- IO pin configuration ------------------------- 'VGApicomiteGAME board revision 1.4 'pin asignment Port A/K8/sm0 Port B/K7/sm1 'data (in) gp1 gp4 'latch (out) gp2 gp5 'clk (out) gp3 gp22 '--------------------------------- PIO configuration -------------------------- 'note: the PIO program for both PIO statemachines is the same, the IO definition 'in the pinctrl register is different. The statemachines actually run same code 'PIO1 execute frequency (identical for all state machines) f=100000 'PIO1 shift register control (identical for all state machines) s=2^19 'set bit 19 = IN shift left, OUT shift right 'PIO1 sm0 config 'When your NES controller is connected to different pins, adapt below 4 lines. SetPin gp1,pio1 'data SetPin gp2,pio1 'latch SetPin gp3,pio1 'clock p0=Pio(pinctrl 1,1,1,gp1,gp3,gp2,gp3) 'GP1=IN base GP2=SET GP3=OUT/SIDESET ' ^ ^ ^ ^ ' | | | +---- clock pin ' | | +-------- latch pin ' | +------------ clock pin (second definition of same pin) ' +---------------- data pin 'PIO1 sm1 config 'When your 2nd NES controller connects to different pins, adapt below 4 lines. SetPin gp4,pio1 'data SetPin gp5,pio1 'latch SetPin gp22,pio1 'clock p1=Pio(pinctrl 1,1,1,gp4,gp22,gp5,gp22) 'GP4=IN base, GP5=SET GP22=OUT/SIDESET ' ^ ^ ^ ^ ' | | | +---- clock pin ' | | +-------- latch pin ' | +------------ clock pin (second definition of same pin) ' +---------------- data pin '------------------------------ PIO program (comment) ------------------------- 'pio1 sm0 program, identical code for sm0 and sm1, clock is side set pin 'adr/instr/comment '0 E081 'set pindir latch, out [side 0] '1 E000 'set latch low [side 0] '2 A0EB 'MOV null inverted to OSR [side 0] OSR = &hffffffff '3 6081 'OUT 1 bit OSR to pindirs [side 0] set clock to output (pindir = 1) '4 E001 'latch high [side 0] latch pulse '5 E000 'latch low [side 0] '6 E027 'load X with value 7 [side 0] counter for bits shifted in '7 A0C3 'mov NULL to ISR [side 0] clear shift register '8 4001 'shift 1 bit data in ISR [side 0] adress 8 and 9 are the shift in loop '9 1048 'JMP X-- to &h8 [side 1] this is the clock pulse 'A 8000 'push ISR [side 0] 8 bits to fifo 'B 0004 'jmp to &h4 [side 0] next cycle '&h0C....&h1F not used '------------------------- END PIO program (comment) -------------------------- '-------------------------------- START PIO 1 --------------------------------- 'PIO1 program (hex data values are from above listing) Dim a%(7)=(&h6081A0EBE000E081,&hA0C3E027E000E001,&h0004800010484001,0,0,0,0,0) 'program and start the PIO1 state machines PIO program 1,a%() 'program PIO1 PIO init machine 1,0,f,p0,,s,0 'init sm0 from address &h00 PIO init machine 1,1,f,p1,,s,0 'init sm1 from address &h00 (run same code) PIO start 1,0 'start PIO1 sm0 PIO start 1,1 'start PIO1 sm1 Print "PIO 1 running" '------------------------------ MAIN level test code ----------------------------- dim h%(4) 'read PIO fifo's to this array 'power the 2 ports K8 and K7 only if needed by hardware platform SetPin gp14,dout:Pin(gp14)=1 SetPin gp15,dout:Pin(gp15)=1 'read the FIFO's that contain the NES controller keys ' the FIFO's are 4 levels deep, are autonomously filled from the statemachines ' when full, new data is refused. To get the latest NES controller status, read 4 ' old fifo values, the 5'th values is just entered in the fifo, and is actual. Do PIO read 1,0,5,h%() 'read 5 values (h%(0...4)) from FIFO sm0 Print Hex$(255-h%(4)), 'print actual (h%(4)) value inverted (switches pull down) PIO read 1,1,5,h%() 'read 5 values (h%(0...4)) from FIFO sm1 Print Hex$(255-h%(4)) 'print actual (h%(4)) value inverted (switches pull down) Pause 100 Loop While Inkey$="" End Edited 2022-07-06 21:35 by Volhout PicomiteVGA PETSCII ROBOTS |
Thanks Volhout. The PicoMite doesn't really have provision for libraries per se (i.e. no #INCLUDE), you are basically limited to copying and pasting code snippets. In theory my MMBasic transpiler 'sptrans' (https://github.com/thwill1000/cmm2-sptools) can be used as a pre-processing step to #INCLUDE code, however I've not ported that to PicoMite yet, and it would itself need transpiling. This isn't a priority for me at the moment as I don't develop on the PicoMite directly but on Linux and then use 'sptrans' running on MMB4L to transpile followed by 'gonzo' to transfer the .bas file to the PicoMite. I've also been using MMB4W and SD card swapping where that is more convenient. I still haven't gotten around to playing with gamepad support in my own PicoMite game, but I wonder if there is a fundamental problem that we are only reading the controller at a single specific instant in each game frame. Possibly it needs reading multiple times during each frame and the results ORing together, you would clear this state at the beginning of each frame - I will need to experiment. Martin note that when reading the pins directly for a digital joystick (or just discrete buttons) you can instead of reading all the pins at a single instant register I/O pin interrupts to capture "button" presses. In the interrupt handler store the presses as bits in a byte (the format the NES PIO code uses to return its results) which you then inspect at the appropriate place in the main loop. And finally (at least for now) Volhout I'm not asking you to look at it in the short-term, but I wonder if rather than the above we could/should use PIO to read the Atari joysticks too and return the results in exactly the same format/order as the NES gamepads - though obviously only 5 bits (directions and button 'A') rather than 8 bits of data. Best wishes, Tom Edited 2022-07-06 21:56 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Hi Tom Well, I know, lib Function is just for Maximite I meant more a collection of sups and functions that one can integrate into the own program to standardize the joystic query and so, support the PicoGAME board per default. Such a Function that I can call during the Program for Example "Joystat(nr)" which returns the Status of one Joystick Maybe returns a String such as "Up" Down" "Left" "Right" "Fire" "Start" "Select" Or a combination Edited 2022-07-06 22:12 by Martin H. 'no comment |
https://github.com/thwill1000/pico-game-vga/wiki/Reading-the-NES-gamepads Very much WIP. Edited 2022-07-06 22:03 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
well from my point of view, PicoVaders is finnished.. Thanks to Volhout for doing the adaptations To PicoGAME board. ![]() (I can't test it right now because i dont own one) I'm just experrimenating with the SetTick function and I'm thrilled. This opens up further possibilities for the next project Edited 2022-07-06 22:26 by Martin H. 'no comment |
Hi Martin, Tom, This is the changed code for the startup screen using the NES controller. 'adaptation for piones handler do 'Do While Inkey$<>" " Print @(74,210) " PRESS FIRE TO START " for i=1 to 60 Pause 10 pio read 1,0,5,NES%() if 255-NES%(4)=&h80 then exit do next i Print @(82,210) " " for i=1 to 60 Pause 10 pio read 1,0,5,NES%() if 255-NES%(4)=&h80 then exit do next i loop 'end of adaptation for piones handler End Sub PicomiteVGA PETSCII ROBOTS |
Fine Thank you all for your support. I think, I'll consider the PicoGAME board. when I start my next "Proof of Concept" ![]() (is there a shop were I can order the PCB within the EU?) 'no comment |
Alas "no", but once Mick finishes work on the v2.0 PCB I don't mind putting one in the post to you at cost - no promises on whether German customs will be so generous. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
