Local Time 00:45 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoStick VGA
Posted: 11:43am 25 Aug 2022
That looks like an SD card socket but it's actually a micro USB?
Posted: 12:00pm 25 Aug 2022
My bad..... :(  I messed up the BOM.
There's no separate micro USB socket, only the one on the PicoMite.
There *is* the above micro SD socket though.
Edited 2022-08-25 22:01 by Mixtel90
Posted: 12:21pm 25 Aug 2022
@Lizby
This version of your colour bar program should better highlight the nature of the colour problem. Also the monitor may have a "Night Mode" that reduces the blue content.
'Colour bars. RGB(1,2,1) 4 bit with R G & B components
mode 2
dim integer R,G,B,x,y=1
dim integer xx=mm.hres-1,yi=mm.vres/16
for R=0 to 255 step 255
  for G=0 to 3*64 step 64
    for B=0 to 255 step 255
      box x,y,xx,yi,,rgb(R,G,B),rgb(R,G,B)
      box xx-60,y,xx,yi,,rgb(R,0,0),rgb(R,0,0)
      box xx-40,y,xx,yi,,rgb(0,G,0),rgb(0,G,0)
      box xx-20,y,xx,yi,,rgb(0,0,B),rgb(0,0,B)
      y=y+yi
    next
  next
next
Posted: 12:51pm 25 Aug 2022
  Mixtel90 said  My bad..... :(  I messed up the BOM.
OK - no worries. Thanks for explaining.
Martin H.
Posted: 01:46pm 25 Aug 2022
  phil99 said  @Martin H.
A trap when calculating Pico output currents or voltages is the Pin resistance (40 to 50 ohms) is in series. So the VGA resistors need to be lower than you expect.
The Resistorvalues are those, which Mixtel90 posted in his Construction pack.
I am fine with this values, my post was to fix the "tan-ish white" Problem by lizby.
'no comment
