Local Time 00:05 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Turntable speed control
Posted: 09:01am 09 Jan 2023
Yep, that's the sort of stuff. Almost impossible to fit to most ready-built turntables There are exceptions at the top end). I have considered a feedback system for this project. A black stripe under the platter would give me one pulse per rev. I could get the speed and shift the motor frequency slightly. There's not much point in sampling more often than that as this is a flywheel system - it takes time to respond. Even correcting after every rev might be too frequent.
Tinine
Posted: 09:21am 09 Jan 2023
Yeah it's a big ol' flywheel. Those guys still sample @500Hz though. I was thinking a SETTICK 1 on the Pico and an encoder resolution to suit.
Craig
lew247
Posted: 06:49am 05 Sep 2024
  TassyJim said
  Quote  Aren't the frequencies in PLAY TONE and PLAY SOUND integers?
I needed 91.5 Hz for  a CTCSS encoder. The pico came to the rescue.
Floats do work for TONE.
Jim do you have any details on this?
I'm going to need a ctcss encoder/decoder for a project I have in mind (radio interface)
If you had anything to give me a head start it would be great
Posted: 07:14am 05 Sep 2024
  lew247 said  Jim do you have any details on this?
Nothing to detail
I needed 91.5 Hz continuous so
PLAY TONE 91.5
A standard audio filter and the level reduced to what I needed.
I was no doing a decoder. I would use a dedicated IC for that.
zeitfest
Posted: 11:47am 05 Sep 2024
Just an observation
A certain product of "Danish shortbread biscuits" is packaged in a circular tin, at a premium cost, with two layers of admittedly delicious biscuits. I would guess they are a global merch in supermarkets etc.
The lid has a circular pattern of alternating small strips near the outside. Counting them gives 384 ... which is 256 + 128  ie 1 and a half 256.
My thought is, that should be useable as an optical counter and so give direct digital velocity/positioning.  Maybe even photo-reduced to a smaller size.
[There is also another such pattern on the side of the tin but that will have a join in it so maybe not as accurate for a circle, but maybe unrolled for a linear application? ]
I haven't tried it though.
Posted: 11:57am 05 Sep 2024
  TassyJim said  I would use a dedicated IC for that.
Pico can do it. It can decode morse (not as good as a human, but it works), so it can also decode this tone..
Posted: 12:52pm 05 Sep 2024
https://www.qsl.net/g4usp/Simple%20CTCSS%20CODEC/CTCSS%20CODEC.htm Using a NE567N
