Local Time 13:24 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Game: various *mites: Four Equals Ten
Posted: 06:16pm 15 Jan 2023
  vegipete said  The program shown below doesn't output as expected:...
In what way? because the C heap and stack don't change? SUB calls and LOCAL variables aren't implemented internally the way you think. Try making recursive FUNCTION calls instead.
Edited 2023-01-16 04:16 by thwill
vegipete
Posted: 08:36pm 15 Jan 2023
Yupp, functions break it much faster, and drop the console connection too.
(partial retyping from VGA display:)
1      &h20041300 &h18700
2      &h20041088 &h18700
3      &h20040E10 &h18700
4      &h20040B98 &h18700
5      &h20040920 &h18700
6      &h200406A8 &h18700
7      &h20040430 &h18700
8      &h200401B8 &h18700
9      &h2003FF40 &h18700
10     &h2003FCC8 &h18700
11     &h2003FA50 &h18700
12     &h2003F7D8 &h18700
13     &h
[7] Print i, "&h" Hex$(MM.Info(STACK)) " &h" Hex$(MM.Info(HEAP))
Error : Stack overflow, expression too complex at depth 13
>list
CLS
c = 0
c = Recurr(c+1)
End
Function Recurr(i)
 Pause 100
 Recurr = Recurr(i+1)
end function
Not quite the same error as the 4 = 10 game, but similar...
Posted: 09:12pm 15 Jan 2023
  vegipete said  Here is a silly little arithmetic game based on the app 4 = 10
We used to do something similar at school:
Using four 7s, make each number from one up.  You can use any of the usual mathematical operators (and parentheses). You always have to use all four 7s. You can use numbers such as 77 (using up two 7s).
E.g. 77 / 77 = 1, 7/7 + 7/7 = 2.
I can't recall if CEIL / FLOOR were allowed, but I think not as they probably make things too easy.
bar1010
Posted: 05:34pm 20 Jan 2023
Thanks for uploading this nice program, Vegipete.
