Local Time 01:10 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWeb alphas - It had to be done
     Page 2 of 5
TrevorC
Posted: 04:21pm 31 Jan 2023
Anyone else getting a
Error : Not enough memory
message when trying to edit a program after running it.
Trying to load another program after the above error also gives the same message.
I am also getting multiple ssids as above with wifi scan.
PicoMite MMBasic Version 5.07.07a1
OPTION SYSTEM I2C GP0,GP1
OPTION COLOURCODE ON
OPTION LCDPANEL ILI9341, RLANDSCAPE,GP15,GP14,GP13
OPTION TOUCH GP12,GP11
GUI CALIBRATE 0, 376, 297, 888, 663
OPTION WIFI (details removed)
OPTION SDCARD GP22
> memory
Program:
  4K ( 4%) Program (144 lines)
 78K (96%) Free
RAM:
  0K ( 0%) 0 Variables
  2K ( 1%) General
112K (99%) Free
The program is a analogue clock.
Setting the date and time from the internet is useful.
                    Trevor
Posted: 07:04pm 31 Jan 2023
  Quote  Anyone else getting a
That's an easy one to fix but I'm making no progress at all on TCP and UDP socket support so it may be some time before I post the next alpha
TrevorC
Posted: 09:49pm 31 Jan 2023
Thanks for the reply.
                     Trevor
Posted: 03:49pm 01 Feb 2023
I have to say that the prospect of  TCP and UDP socket support for the Pico W is very exciting.
For me, it would change the Pico from something which has been loads of fun to play with to a device that I will actually use in my household monitoring and control designs.
For 15 years or more I have cobbled things together using PICAXE plus various tiny routers running OpenWrt, Raspberry Pi ZWs with Lua, and ESP8266 and ESP32 running Annex. I'd much rather use MMBasic on a Pico W.
Looking forward to coming announcements.
homa
Posted: 08:46pm 01 Feb 2023
matherp i hate and love you, what great news!
Because of your earlier statements I got myself an ESP-12E module. Now this runs since today and I think great, check thebackshed forum, maybe someone is interested.
And now this!
Thank you! And keep going ... ;-)
I will test this on the weekend **joy**
Edited 2023-02-02 06:52 by homa
homa
Posted: 09:29pm 01 Feb 2023
okay I could not wait until the weekend :)
> Connecting to WiFi...
Connected.
PicoMiteWeb MMBasic Version 5.07.07a1
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
> web http server open
Starting server at 192.168.1.109 on port 80
when I start the webserver
and then access with ncat comes weird stuff?
C:\Users\homa>ncat -n 192.168.1.109 80
¢/í¸┘h¶┘<¿5ÕÅ*═┬@┴¤Rqjr)#░[*éêD↓0‗kú«ä═IÍâB↨þú9ôsãµ±è■!↓õuÄãçàX¦$µØ]D@ïZ#^®´ý?æ£zA↨↑rÙ♠‗毩l¥┘4¸4#♠z3pùÎR↕§~Êöòf♠#Y‗o·þý®µ½¬9┐║_Ñ▒«$üaèxEõ<Gx9GÃØ┘J»a↨;¢j§ðD[æ═_u_A©ı8■ÏZ▒/F╝Ä5*8╠*»»båuUt∟pú   Ò_¥│¶z'X'k►Ï▒►Ü«8äÍ
çUzúu5┐>qlä'w┴Ð┬Óûe dmt
]ç`ÌÀ]ïä6Ó╗┐ùàó
┴ZH∟╔┼ëiʬ2¤q╚ζQó♠ì↔═Ý╔·╔↑W♣g²ëöÛS¢ D▄Ñ ıúLÄöôí$t═→♦úA ↕OBÿ╦s÷¨T│ÈýÁ▲éVc{`º¬¼ß­õ8Mf:▲ÀP¬g8Ó¯ÂfîGâ├d├
)╚o▀x♠©ä◄îü→È-4¬h¼vrüçï+Z/&¥Ìý┐8¡░▀ú
ró*L«wÃè┐}┼▼Ã↑D↑ý_f±£j└Ï0MO:►└Í{ax,Ô♣Î,ä╔¬Ï--▒áÔTú═♠☺c‼o►ëDûM´┬d‗┤G×Ç]wâB→↓×↓¨¡NÒ→►U┐êSÅê³►:ŹéSå↕^
2╝♠Ȱ └­¤►È↔5·╬N-↨☺xÃ÷♣î(®ì;¾[¬¾W♦ä¿~s~ÁÐ!]5­Ù)P┴X♠´.DÆz↑╗BÂUtÁ
è╦ZHè┘c»¶
Iç╗├çëEIÇþ▒ÃY╔Q
ëÐ¥Íû‼ÿ_³■Ú!╬¢YoB@┼FHI$qÝs"×↨Û@säû►»á┤àH«Ñj♠↕L§@│ÚWQïsÀã½│╠╗■Î9Qhm╬]áZ÷ð«▓?o╬ o>kï+!▀*a╚;×gçÆ¯→Ê        é¶1ø÷'A5¡Úà▬ÙE´cÐÑáÔ2& Qåêï¾→B«£Àu┼§H┐ÆìY‗sBÁÿ▲îëoYò$├└rq█Q@dXN¥¶▀ÀóåØK┤☻ìÂÊÐ♥ÌW¶┴☻õÃ6rıuºïKM ù╠ä0½▄×ä»;◄a╔èÝ´ôñ╠↔*¢Ò
Y→{ÀéÃ♣¹→ÉOéé╩Ö2m┤i#q▬ñ8´1jbï┌¶Ô²♣ú▓║ñ"+ÿf6│Ò¶ñ¬♥^JtË┤░jï♣↨→Ƶ┘ÖªrM£R³YA∟▲äS=BíÛ¸♣↨ƒ╚ß²B½+íÅ­ã×╦(Ý-╠▲°‼┌þ3■qü¹├nòKæj∟æ‼Ñâ?¹│1ý╝ެú®┴ÒH↕C→{P/LuÅ3.²±J)
Ë┌I╗Þ´F¢Ú7V&=↓ÀoëNÉ┐¶U[│Û▬NåSn(Õ↓=jö↑┘╣(│i{█
"!õÏ∟A│_³Ó6fBÝ╗÷â>Yè→P¨Ia‼░¬OJ│]╣§k6¥d6èÂâ╝x☺VÁB²ƒÔB¡ðØD^Äd7Àç]*Ê┬╔^┌Þû^┬▒b*°úÚè;─RI?`< ñ▒]×)ñKð
┬²e)z¦N¥n¬ÂÂbÚ»♦7£¬├▬`Z┬'¯┬¤4♥{P±©│▼´¶çX▄ ÐN╬üaWuï¶´È~ò─ѧkaBc¡Ýª▼▒╔▓pt[
BP*<\þ┼♥6bw├6╝UB↨MQ¨uÜ´¨|Õ→BntX£hE↔»ú}ò¬
ù¯59N╔`xÇ┼±.E│g↕$£^♦©çÖbÐ═↑Ï└ !}m▲K©!U;ZW³×i‼iòWÂ█f‗Ûdw┌┤kKA2↕o│ª¨ò¯☺4╗Ì►ì►▓Áæ■┤gæþ°♦êpè─♦LÙÖ‼I¶b░¨ÈÆÄéÄ3g▒;Aúÿ↕÷↓fIàI■¤o¶╩ô↕╗£ôÑÆöKÀùxpá┘i.→ ¾Ó│☺ÕÔ§s╚ÍïC¦qõ3=║X>qá↔┘┴[ÝÿAîλzÛQ±      ☺.΃¤▒┴G¦·¼é╚U«µ─7|╔K­¸)ò▄}¿ı♠3¿SéyòºÆ©HOu☺­{BamD░,Èk±ýg"►GÙÔZ↓ú╠■õ]©mò% X┼¨╠ÀaÚ█m↔N┴í┐↑Ëd@5↔J ÞíúJ─î▲=fj☻ryb♠╦%¯²½§'ö¢Ôp&Û↓U│Ú╔·¾8á|µQı╠B3W
if I call the ip in the browser opens the save as dialog?!
in this file is also only grit.
  JohnS said
Figuring out what to support/allow & the syntax may be a challenge.
How to best allow TCP/IP & UDP, if at all?  Would sending email be useful?  Or ping?  Etc.
do you have any ideas, matherp, about which commands to implement and how?
it would be helpful to query the ip assigned via dhcp with a command
and or on startup after Connected: <ipadr>.
Edited 2023-02-02 07:32 by homa
led-bloon
Posted: 11:03pm 01 Feb 2023
@matherp - Peter
Does this code/site help at all?
benevpi
or
picow-http
led
Edited 2023-02-02 09:33 by led-bloon
Miss you George
TrevorC
Posted: 09:59am 02 Feb 2023
Just noticed that Web ntp response prints date and time correctly but the month
is not being being updated in date$.
                             Trevor
Posted: 03:57pm 02 Feb 2023
Finally some progress - note the Pi icon at the top left responding to the favicon request
Dim buff%(512)
Dim ls%(64)
Dim s$=Space$(255)
LongString append ls%(),"<!doctype html>"
LongString append ls%(),"<HTML>"
LongString append ls%(),"<BODY>"
LongString append ls%(),"<H1>Hello World!</H1>"
LongString append ls%(),"</BODY>"
LongString append ls%(),"</HTML>"
LongString append ls%(),Chr$(10)+Chr$(13)
WEB open tcp server 80
WEB tcp interrupt myint
WEB ntp
'background processing
Sub myint
 WEB tcp read buff%()
 If LLen(buff%())=0 Then Exit Sub
 Local p%=LInStr(buff%(),"GET")
 Local t%=LInStr(buff%(),"HTTP")
 If (p%<>0) And  (t%<>0) And (t%>p%) Then
   s$=LGetStr$(buff%(),p%,t%-p%+4)
   Print "String is ",s$
 EndIf
 If Instr(s$,"favicon") Then
   Print "sending icon"
   WEB Transmit FILE "pi.ico","image/vnd.microsoft.icon"
 Else
   Print "sending page"
   WEB tcp send ls%()
   WEB TCP close
 EndIf
End Sub
I'll post a new release when I've got the code that reads an html file in and automatically populates screen fields with the values of MMbasic variables. This is code from the original PiCromite which can finally make a re-appearance
Edited 2023-02-03 01:59 by matherp
Plasmamac
Posted: 07:34pm 02 Feb 2023
Great
Plasma
Posted: 08:39pm 02 Feb 2023
  matherp said  I'll post a new release when I've got the code that reads an html file in and automatically populates screen fields with the values of MMbasic variables. This is code from the original PiCromite which can finally make a re-appearance
Fabulous.
Pluto
Posted: 08:41pm 02 Feb 2023
Dont know what I am going to use it for, but after understanding that Matherp is developing something for Pico W, I immediately ordered a few.
No hurry with the development Peter, I have still to wait a couple of weeks for arrival of the W
homa
Posted: 09:37pm 02 Feb 2023
hello Peter,
i tried running your code with version 5.07.07a1 on my original pi pico w.
Unfortunately the setup as in your screenshot does not work for me!
Do you have another version?
I also have a pi.ico file on the flash drive.
Will there also be a way to manage tcp connections yourself? As with the ESP-12E module? There you can manage up to 5 connections.
How does that actually look with the pico w? According to Internet data, it can manage up to 4 clients as a SoftAP.  Does that mean that up to 4 client accesses to the pico w are feasible?
Would it make sense to use the AT commands of the ESP-12E module as a basis for the WEB command?
In any case the testing is fun. And I can help you here with pleasure.
The attempts 1-6 are actually self-explanatory ...
Greetings from rainy Germany
Matthias
Posted: 09:51pm 02 Feb 2023
  homa said  i tried running your code with version 5.07.07a1 on my original pi pico w.
To quote Peter:
  Quote  I'll post a new release when I've got the code that reads an html file in and automatically populates screen fields with the values of MMbasic variables
You have to wait for the new alpha release for the new example code to run.
homa
Posted: 09:55pm 02 Feb 2023
The EDGE web browser also has this behavior of wanting to download a file ... but the program behaves differently!
homa
Posted: 09:58pm 02 Feb 2023
Thanks Jim, I had understood this sentence differently.
Matthias
homa
Posted: 04:45pm 04 Feb 2023
Hello Peter,
now you've made my mouth water. The wait is getting me down.
Is there any news? Or can you say something about my questions?
Greetings Matthias
Posted: 01:19pm 05 Feb 2023
Here is a version to play with - what a bu..er this was getting working. Even now it is less than robust - it may never be completely robust.
PicoMiteWeb.zip
New command:
OPTION TCP SERVER PORT n
This is a permanent option and launches a TCP server on the defined port (Use 80 for the example) during every restart of the PicoMiteWeb
USE "OPTION TCP SERVER PORT 0" to disable
When the server is running it can respond to up to MM.INFO(MAX CONNECTIONS) connections at the same time - currently set to 4.
This was the difficult bit to get working as browsers all seem to be different in the way they use connections and do or do-not expect them to be open.
Here is a simple example HTTP host
Dim buff%(512)
Dim myfloat!=16.123
Dim myint%=999
Dim mystring$="The PicoMite Web is GO!!!"
WEB ntp
 poll
Sub poll
 Local p%, t%
 For a%=1 To mm.info(max connections)
 LongString clear buff%()
 WEB tcp read a%,buff%()
 If LLen(buff%()) Then Print "_________________________________________________"
 s$=""
 EndIf
 If Instr(s$,"small") Then
   Print "sending picture"
   WEB Transmit FILE a%,"small.jpg","image/jpeg"
 ElseIf Instr(s$,"favicon") Then
   WEB Transmit FILE a%,"favicon.ico","image/vnd.microsoft.icon"
 ElseIf Instr(s$,"HTTP") Then
   WEB transmit page a%,"test4.html"
 EndIf
 Next a%
End Sub
and here is the HTML file. NB: the base64 string must be converted to a single line and then xmodemed to the PicoMiteWeb. This string is the PicoMiteWeb icon.
<html>
<head>
<title>PicoMiteWeb Test</title>
<link rel="icon" type="image/x-icon" sizes="16x16" href="data:image/png;base64,AAA
BAAEAEBAQAAEABAAoAQAAFgAAACgAAAAQAAAAIAAAAAEABAAAAAAAgAAAAAAAAAAAAAAAEAAAAAAAAAAAA
AAAAP//ADMA/wD/AAQAFf8AAAIACABZAP8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAFAAUAVQBVAAUABQUABQBQBVAFBQAFAFAFBQAAVQBVAAUFBQAAAAAABVAAAAAAAAAAAAAAA
AAAACREMzERAAAAJkRDMxEQAAAmZEQzMREAAAZmREMzERAAAGZkRDMxEQAABmZEQzMREAAAZmREMzERAAA
GZkRDMxH//wAAuzMAALrtAACa7QAArzMAAKv/AACf/wAA//8AAAA/AAAAHwAAAA8AAIAHAADAAwAA4AEAA
PAAAAD4AAAA" />
</head>
<body>
<h1>{mystring$}</h1>
This is a paragraph.
Test of a float: myfloat is {myfloat!}
Test of an integer: myint is {myint%}
Test of a string: mystring is {DateTime$(now)}
Test of a missing variable: missing is {missing}
</body>
</html>
Here are the supporting images
small.zip
I'll now try and explain the new functionality
WEB TRANSMIT CODE cb%,nnn%
Constructs and sends a numerical response to the open connection cb% and on completion closes the connection.
Typical use would be “TRANSMIT CODE cb%, 404” to indicate page not found.
WEB TRANSMIT FILE cb%, filename$, content-type$
This constructs an HTTP 1.1 header with the ’content-type$’
specified, sends it and then sends the
contents of the file to the open connection cb% and on completion closes the connection
WEB TRANSMIT PAGE cb%, filename$
This constructs an HTTP 1.1 header sends it and then sends the
MMBasic will substitute current values for any MMBasic variables or expressions
defined in the file inside curly brackets e.g. {myvar%}
Variables can be simple, array elements or expressions as in the example.
An opening curly bracket can be included in the output by using {{.
When you run a program with the TCP server enabled the firmware will automatically create a receive buffer of 2048 bytes for each of the 4 possible connections.
Your Basic program should poll these receive buffers using the command
WEB TCP READ cb%, buff%()
cb% is the open connection and buff%() is an array to receive any data from that connection as a longstring
If there is nothing received on that connection this will return an empty string
LLEN(buff%())=0
If there is, then the Basic program  must respond with one of the TRANSMIT commands in order to close the connection
There is more functionality that I need to test further that enables the TCP server to be used as one end of an open link. I will then look at the commands for a TCP client - should be easier. Getting this working to the extent that it is has cost me three full days of my life so don't expect a further update too soon
ISSUES:
I believe it is possible for a browser to send connection requests and the associated data faster than the TCP stack on the Pico can respond. In this case you are left with a dangling connection as the Basic program doesn't know about it. This needs further work.
Various error conditions are not handled so be prepared for lockups and have the reset button handy
Sequencing is important - don't connect a client before you have a handler running.
Below is a Basic subroutine for parsing GET requests - came from a Pi-Cromite example but not retested - use or abuse as you wish
Const maxargs = 32
Dim arg$(1,maxargs-1)
'Function to parse an HTML GET request'
' Assumes that the request starts with "GET /"
' and ends with "HTTP"
Function parserequest$(req$, paramcount As integer)
 Local a$,b$
 Local integer inpos,startparam,processargs
 For inpos=0 To maxargs-1
   arg$(0,inpos)=""
   arg$(1,inpos)=""
 Next inpos
 paramcount=0
 a$=Mid$(req$,6,Len(req$)-10)
 inpos=Instr(a$,"?")
 If inpos<>0 Then 'parameters found
   processargs=1
   parserequest$=Left$(a$,inpos-1)
   a$=Mid$(a$,inpos+1)
       arg$(0,paramcount)=""
       arg$(1,paramcount)=""
       inpos=Instr(a$,"=")
       startparam=1
       arg$(0,paramcount)=Mid$(a$,startparam,inpos-startparam)
       startparam=inpos+1
       inpos=Instr(a$,"&")
       If inpos<>0 Then
                    arg$(1,paramcount)=Mid$(a$,startparam,inpos-startparam)
                    a$=Mid$(a$,inpos+1)
                    paramcount=paramcount+1
       Else
           arg$(1,paramcount)=Mid$(a$,startparam)
           processargs=0
       EndIf
   Loop While processargs
 Else
   parserequest$=a$
 EndIf
 If a$="" Then
   parserequest$="index"
 EndIf
 If Instr(parserequest$,".html")=0 And Instr(parserequest$,".HTML")=0 Then
 parserequest$=parserequest$+".html"
End Function
Edited 2023-02-05 23:22 by matherp
homa
Posted: 02:31pm 05 Feb 2023
Thanks a lot Peter!
@all: Attention- the new version also deletes the flash disk! I just lost the test file from me because of my impatience. Not too bad, but if someone has more on it ... just as a hint!
Posted: 02:38pm 05 Feb 2023
Just noticed the BB has corrupted the html even though it is in a code block
test4.zip
     Page 2 of 5
