Local Time 08:33 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA V5.07.07b19 - Major enhancement - 640x480  edit in colour
     Page 2 of 5
homa
Posted: 04:35pm 18 Feb 2023
  matherp said  V5.07.07b20
PicoMiteVGAV5.07.07b20.zip
Fixes a bug if OPTION DEFAULT MODE 2 is set and you execute EDIT 1
small error:
When entering e.g. >files the screen will be dark/black/blank for a short time until the output appears. (But not always!??)
The same with e.g. >edit whereby this does not really disturb, since also another screen structure comes.
Mark
Posted: 02:26am 19 Feb 2023
I’ve noticed the same thing (blanking) on one monitor, but not on another. Also, when playing a .wav file on the monitor that blanks, the screen goes black while the file plays. On the other monitor, the text wiggles slightly. It clears up when the file stops playing.
Posted: 09:03am 19 Feb 2023
V5.07.07b21
PicoMiteVGAV5.07.07b21.zip
Please let me know if this solves the audio and screen blanking issues
Unfortunately this means I have had to put the SDcard routines back into RAM so we have lost 4k of program space - now 92K
I could see the issues on one monitor and this change seems to have solved them - please let me know
This release will delete options and the flash disk
Posted: 11:01am 19 Feb 2023
That program space is shrinking....   :(
Posted: 11:13am 19 Feb 2023
  Mixtel90 said  That program space is shrinking....   :(
as far as i am aware, individual program size is limited by the amount of RAM available to the editor in order to edit it. however, while the editor is running there are a number of routines present in RAM, that while needed by the interpreter, are not used by the editor.
therefore, i wonder if there is some way to 'bump' routines declared as "__not_in_flash_func" out or RAM while the editor is running, then reload them upon exiting the editor so that they are again available to the interpreter. to this end, i've posted a question on the pico forums:
https://forums.raspberrypi.com/viewtopic.php?t=347663
i'm picking it would probably be necessary for the set of 'bumped' routines to reside in RAM contiguous with the block of RAM the editor uses for its buffer, but how to achieve this is another question.
rob   :-)
Posted: 12:17pm 19 Feb 2023
I won't panic until it gets to 32k - that's the "old school" limit. :)
Amnesie
Posted: 12:42pm 19 Feb 2023
I could live with less program space too. But that's just me :)
-Daniel
Posted: 12:53pm 19 Feb 2023
  Mixtel90 said  I won't panic until it gets to 32k - that's the "old school" limit. :)
Classic basic uses 32 bit variables , so 32k is a lot. Mmbasic uses a lot more per variabele.
I feel, Cannot prove it, picomite Needs this ram. Logic analyzer uses 60k already. It is not even a game with multiple levels.
Please dont shrink any further, or remove funtionality.
Edited 2023-02-19 22:57 by Volhout
Posted: 01:02pm 19 Feb 2023
I forget, is this the variable/heap RAM we are taking about ? My recollection is that the program itself runs from flash and the interpreter/firmware is split between RAM and flash ... presumably with the RAM part being loaded from the flash when the Pico starts?
Posted: 01:16pm 19 Feb 2023
of course, i'm forgetting there is FLASH CHAIN n, so one can just spread a large program over multiple flash slots. there are 5(?) slots, each 92k, giving a total program size of 460k when all chained together.
speaking of which, perhaps it is time to drop the concept of flash slots completely.
instead have .BAS and .BIN files in the onboard file system, where .BAS is a BASIC human-readable text file, and .BIN is a tokenized BASIC program (each .BIN files would need to exist as a single contiguous block). the editor could load either type, and save either type, but CHAIN could only call a .BIN file.
the only 'complexity' would be that you would need to load a .BAS file into the editor, then save it as a .BIN file before it could be run or chained. and there would need to be a bit of shuffling around to ensure that .BIN files written by the editor were always contiguous. oh, and RUN and CHAIN would now always require a string parameter.
a positive outcome would that the FLASH... group of commands would become completely redundant. and  OPTION AUTORUN could be depreciated in favour of simply always running any AUTOEXEC.BIN file that exists on the onboard file system.
rob   :-)
Edited 2023-02-19 23:20 by robert.rozee
Posted: 01:26pm 19 Feb 2023
Rob
I'm sure its great you are taking an interest but your freeing up random bits of non-contiguous memory is of no use. There are other ways of increasing program space but as Volhout says it is variable RAM memory that is more precious so not a priority
Posted: 01:54pm 19 Feb 2023
  matherp said  [...] freeing up random bits of non-contiguous memory is of no use. There are other ways of increasing program space but as Volhout says it is variable RAM memory that is more precious so not a priority
quite true, contiguous memory is the requirement. however, using FLASH CHAIN n largely mitigates the program size complaint, as a BASIC program can span 400k or more without issue.
with a fixed number of routines that the INTERPRETER needs to reside in RAM, there is no simple solution to lack of BASIC variable space. well, you could allocate the TILE memory from the interpreter's pool only when required, but that is just another 12k(?), minus the code required to manage it.
switching from flash slots to instead having .bas/.bin files is unrelated to freeing up RAM, but may be a pleasant simplification for picomite users. as i recall, the idea of using fixed flash slots was only necessary because at the time there was no path to having a file system in the onboard flash. that has now changed.
rob   :-)
Edited 2023-02-20 00:02 by robert.rozee
homa
Posted: 03:24pm 19 Feb 2023
  matherp said  V5.07.07b21
YES the problem is solved for me. Works perfectly now, good job.
Mark
Posted: 06:00pm 19 Feb 2023
The blanking is solved when loading a file or entering edit mode, but it still blanks while playing a .WAV file from SD card. The screen does not blank when playing a .wav file from flash. The audio sounds fine while playing regardless of SD or flash.
Mark
dgrissom
Posted: 06:56pm 19 Feb 2023
Note certain if this has been reported?
On my system using "b21" the editor is not properly showing marked blocks for  Cut/Paste, etc.
Posted: 07:58am 20 Feb 2023
Fix one problem and create another
No version change - just a 1 line fix
Posted: 10:29am 20 Feb 2023
I'm finding the colour doesn't work properly in
CLS rgb(...)
e.g.
MODE 1
CLS RGB(red)
Pause 1000
CLS RGB(green)
Pause 1000
CLS RGB(blue)
Pause 1000
I think I'm getting WHITE in each case.
CLS RGB(black) works.
option list is just
OPTION KEYBOARD US
Makes no difference having OPTION CPUSPEED 252000
Tried with b20 & b21.
Using PRINT @ or TEXT with colours (and obeying TILE sizes) seems fine - I do get coloured text.
Edited 2023-02-20 20:29 by JohnS
Posted: 10:54am 20 Feb 2023
@Peter,
Feature request: when "colourcode ON" and in "mode 1", please automatically select "tile small".
Bug report: V50707b21 running picochess3 program (attached). This works fine on V50707b18.
[109] For j=0 To offsets(piece(i))-1
Error : Stack overflow, expression too complex at depth 9
I monitor C-stack, and it was not 0, but that is based on earlier provided thresholds (you posted). Maybe this is (in the end) a stack error with current memory map.
If you run picochess3, put it in the same folder as the sprite file Small_Col.bmp. Picochess will play against itself, so nothing needed. Just press F2 (run).
picochess3.zip
I hope this one is simple to fix...
Edited 2023-02-20 20:57 by Volhout
Posted: 10:59am 20 Feb 2023
This is correct.
To get colour you need to use the TILE command. CLS is the equivalent of BOX 0,0,mm.hres,mm.vres,0,0,rgb(red)  and any colour in mono mode is white. They both use the DRAWRECTANGLE primitive. I played with interpreting the coordinates in DRAWRECTANGLE to see if the matched tile boundaries and then setting the tile colours accordingly but it has far too many unforeseen consequences that would completely bemuse the user to be a realistic option
Posted: 11:24am 20 Feb 2023
@Peter,
I have one more program that refuses to work with the new memory map.
Not enough memory to load sprites.
This change (b21) is really killing existing programs. Many of the larger programs will need a complete rewrite and memory optimize.
I know I asked for color in mode 1 in the editor, regret it now I see the result.
     Page 2 of 5
